[Mapbender-commits] r8783 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Feb 19 11:57:44 PST 2014
Author: armin11
Date: 2014-02-19 11:57:44 -0800 (Wed, 19 Feb 2014)
New Revision: 8783
   trunk/mapbender/http/javascripts/map_obj.js
Bugfix for featureInfo preselect
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2014-02-17 14:33:17 UTC (rev 8782)
+++ trunk/mapbender/http/javascripts/map_obj.js	2014-02-19 19:57:44 UTC (rev 8783)
@@ -973,7 +973,6 @@
             var ignoreThisWms = false;
             if (typeof ignoreWms !== "undefined" &&
             ignoreWms.constructor === Array) {
                 for (var j = 0; j < ignoreWms.length; j++) {
                     if (ignoreWms[j] == this.wms[i].wms_id) {
                         ignoreThisWms = true;
@@ -993,11 +992,11 @@
 				//exchange layer parameter with current layer name
 				if (typeof(featureInfoRequest) !== 'undefined' && featureInfoRequest !== "" && featureInfoRequest !== false) {
 					featureInfoRequest = changeURLParameterValue(featureInfoRequest,"LAYERS", this.wms[i].objLayer[j].layer_name);
+					featureInfoRequest = changeURLParameterValue(featureInfoRequest,"QUERY_LAYERS", this.wms[i].objLayer[j].layer_name);
 					featureInfoObj.request = featureInfoRequest;
-					//featureInfoObj.bbox =  this.wms[i].objLayer[j].layer_epsg;//array of bbox objects - find the one which have the needed epsg!
 					var bbox = this.objectFindByKey(this.wms[i].objLayer[j].layer_epsg, "epsg", epsg);
 					if (bbox) {
-						//check if
+						//check if clicked point is in bbox of layer
 						featureInfoObj.inBbox = this.isPointInBbox(realWorldPoint, bbox);
 					} else {
 						featureInfoObj.inBbox = true;
@@ -1042,8 +1041,6 @@
     	return false;
 	function changeURLParameterValue(url, param, newValue){
     		var newAdditionalURL = "";
     		var tempArray = url.split("?");
More information about the Mapbender_commits mailing list
