[Mapbender-commits] r8988 - trunk/mapbender/http/widgets
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 4 05:50:30 PDT 2014
Author: hwbllmnn
Date: 2014-07-04 05:50:29 -0700 (Fri, 04 Jul 2014)
New Revision: 8988
   trunk/mapbender/http/widgets/w_digitize.js
removed obsolete commented code
Modified: trunk/mapbender/http/widgets/w_digitize.js
--- trunk/mapbender/http/widgets/w_digitize.js	2014-07-04 12:48:17 UTC (rev 8987)
+++ trunk/mapbender/http/widgets/w_digitize.js	2014-07-04 12:50:29 UTC (rev 8988)
@@ -200,83 +200,6 @@
-        // if (pos && drawOptions && !drawOptions.highlightFirst) {
-        //     this._digitizePoints.push(pos);
-        // var len = this._digitizePoints.length;
-        // if (len > 0) {
-        //     for (var k=0; k < len; k++) {
-        //         var pk = this._digitizePoints[k].pos;
-        //         var q = this._digitizePoints[k].mousePos;
-        //         str_path += (k === 0) ? 'M' : 'L';
-        //         str_path += q.x + ' ' + q.y;
-                // if (drawOptions.highlightFirst && k === len - 1) {
-                //     var p0 = this._digitizePoints[0].mousePos;
-                //     str_path += 'L' + p0.x + ' ' + p0.y;
-                // if (drawOptions && drawOptions.highlightLast && k === len - 1) {
-                //     continue;
-        //         if (drawOptions && drawOptions.drawPoints &&
-        //             (k === 0 && !this._polygonIsInvalid || k >= len - 2 && !drawOptions.highlightFirst)) {
-        //             var circle = this._canvas.circle(q.x, q.y, this.options.digitizePointDiameter);
-        //             if (k === 0) {
-        //                 circle.attr({
-        //                     fill: drawOptions && drawOptions.highlightFirst ?
-        //                         this.options.pointFillSnapped : this.options.pointFillDefault,
-        //                     "fill-opacity": this.options.opacity,
-        //                     stroke: drawOptions.highlightFirst || drawOptions.highlightLast ?
-        //                         this.options.pointStrokeSnapped: this.options.pointStrokeDefault,
-        //                     "stroke-width": this.options.pointStrokeWidthDefault
-        //             else {
-        //                 circle.attr({
-        //                     fill: drawOptions && drawOptions.highlightLast && k === len - 2 ?
-        //     this._digitizePoints.pop();
-        // if (this._isPolygon(this._digitizePoints, pos) && drawOptions && !drawOptions.highlightLast && !this.polygonIsInvalid) {
-        //     var poly = this._canvas.path(str_path + 'Z');
-        //     poly.attr({
-        //         fill: drawOptions.highlightFirst ?
-        //             this.options.polygonFillSnapped : this.options.polygonFillDefault,
-        //             this.options.lineStrokeSnapped: this.options.lineStrokeDefault,
-        //         "stroke-width": drawOptions.highlightFirst ?
-        //             this.options.polygonStrokeWidthSnapped : this.options.polygonStrokeWidthDefault,
-        //         opacity: this.options.opacity
-        // var line = this._canvas.path(str_path);
-        // line.attr({
-        //     stroke: drawOptions && (drawOptions.highlightFirst || drawOptions.highlightLast) ?
-        //         this.options.lineStrokeSnapped : this.options.lineStrokeDefault,
-        //     "stroke-width": drawOptions && drawOptions.highlightLast ?
-        //         this.options.lineStrokeWidthSnapped : this.options.lineStrokeWidthDefault
-        // line.toFront();
     _digitize: function (e) {
More information about the Mapbender_commits mailing list
