[Mapbender-commits] r8815 - in trunk/mapbender: http/classes http/javascripts http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 7 01:42:53 PDT 2014
Author: hwbllmnn
Date: 2014-05-07 01:42:53 -0700 (Wed, 07 May 2014)
New Revision: 8815
   trunk/mapbender/http/classes/class_map.php
   trunk/mapbender/http/classes/class_wmcToXml.php
   trunk/mapbender/http/javascripts/mod_savewmc.js
   trunk/mapbender/http/plugins/kmlTree.js
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
added drag & drop, display order for kml files
Modified: trunk/mapbender/http/classes/class_map.php
--- trunk/mapbender/http/classes/class_map.php	2014-05-07 07:39:59 UTC (rev 8814)
+++ trunk/mapbender/http/classes/class_map.php	2014-05-07 08:42:53 UTC (rev 8815)
@@ -17,6 +17,7 @@
 	private $wmsArray = array();
     private $kmls;
     private $originalKmls;
+    private $kmlOrder;
 	 * @destructor
@@ -231,6 +232,14 @@
         $this->originalKmls = $originalKmls;
+    public function getKmlOrder() {
+        return $this->kmlOrder;
+    public function setKmlOrder($kmlOrder) {
+        $this->kmlOrder = $kmlOrder;
 	 * @return
@@ -512,6 +521,9 @@
         if(property_exists($jsMapObject, 'originalKmls')) {
             $this->originalKmls = $jsMapObject->originalKmls;
+        if(property_exists($jsMapObject, 'kmlOrder')) {
+            $this->kmlOrder = $jsMapObject->kmlOrder;
 		if (isset($jsMapObject->isOverview) && $jsMapObject->isOverview == "1") {
 			$this->isOverview = true;
Modified: trunk/mapbender/http/classes/class_wmcToXml.php
--- trunk/mapbender/http/classes/class_wmcToXml.php	2014-05-07 07:39:59 UTC (rev 8814)
+++ trunk/mapbender/http/classes/class_wmcToXml.php	2014-05-07 08:42:53 UTC (rev 8815)
@@ -149,6 +149,9 @@
         if($this->wmc->mainMap->getOriginalKmls()) {
             $extensionData['originalKmls'] = base64_encode(serialize($this->wmc->mainMap->getOriginalKmls()));
+        if($this->wmc->mainMap->getKmlOrder()) {
+            $extensionData['kmlOrder'] = json_encode($this->wmc->mainMap->getKmlOrder());
 		// store epsg and bbox of root layer of 0th WMS
 		$firstWms = $this->wmc->mainMap->getWms(0);
Modified: trunk/mapbender/http/javascripts/mod_savewmc.js
--- trunk/mapbender/http/javascripts/mod_savewmc.js	2014-05-07 07:39:59 UTC (rev 8814)
+++ trunk/mapbender/http/javascripts/mod_savewmc.js	2014-05-07 08:42:53 UTC (rev 8815)
@@ -170,6 +170,7 @@
             if(kml) {
                 mb_mapObj[0].kmls = kml._kmls;
                 mb_mapObj[0].originalKmls = kml.originalKmls;
+                mb_mapObj[0].kmlOrder = kml.kmlOrder;
 	    	var mapObjectToSend = $.toJSON(mb_mapObj);
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js	2014-05-07 07:39:59 UTC (rev 8814)
+++ trunk/mapbender/http/plugins/kmlTree.js	2014-05-07 08:42:53 UTC (rev 8815)
@@ -157,7 +157,18 @@
 			})(obj.data.features[i]));
+        $('#kmlTree > li > ul').sortable({
+            update: function() {
+                var kml = $('#mapframe1').data('kml');
+                var urls = [];
+                $(this).children('li[title]').each(function(k, v) {
+                    urls.push($(this).attr('title'));
+                kml.setOrder(urls);
 		$("*:checkbox",$kmlEntry).bind('click', function(){
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-07 07:39:59 UTC (rev 8814)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-07 08:42:53 UTC (rev 8815)
@@ -35,6 +35,7 @@
 		autoDisplay: true
 	_kmls: {},
+    kmlOrder: [],
 	_popup : null,
 	_create: function(){
 		var self = this, o = this.options;
@@ -52,7 +53,7 @@
 			var g,h,nodes = null;
 			$("*",self._popup).remove();
 			var $tabs = $("<ul></ul>");
-			for (var i in self._kmls){
+			for (var i in self.kmlOrder){
 				feed = self._kmls[i] ;
 				if(!feed.display){ continue; }
 				requestGeometries = [];
@@ -201,6 +202,7 @@
                             self.originalKmls = {};
                         self.originalKmls[o.url] = data;
+                        self.kmlOrder.push(o.url);
@@ -236,6 +238,10 @@
             if(kmls) {
                 this.originalKmls = kmls;
+            kmls = mb_getWmcExtensionData('KMLORDER');
+            if(kmls) {
+                this.kmlOrder = JSON.parse(kmls);
                     reload: function() {
@@ -243,7 +249,9 @@
 		        var epsg = $(self.element).mapbender().epsg;
 		        epsg = epsg.split(":")[1];
-                        $.each(self._kmls, function(url, o) {
+                        $.each(self.kmlOrder, function(k, url) {
+                            var o = self._kmls[url];
+                            if(!o) return;
                             $('li[title="' + url + '"] > button[name="remove"]').click();
 		            $.ajax({ url: self._endpointURL,
 			             data: {url: o.url, targetEPSG: epsg},
@@ -267,6 +275,11 @@
+    setOrder: function(order) {
+        this.kmlOrder = order;
+        this.reload();
 	show : function(url){
 		this._kmls[url].display = true;
 		var $map = $(this.element).mapbender();
@@ -299,7 +312,7 @@
 	_display : function(mapitem){
 		// getting the mapitem from the events bre
-		var mapitem = self._kmls[mapitem.url];
+		mapitem = self._kmls[mapitem.url];
 		var geojson = mapitem.data;
 		if(typeof(Mapbender) != "undefined"){
 			var $map = $(self.element).mapbender();
More information about the Mapbender_commits mailing list
