[Mapbender-commits] r8851 - in trunk/mapbender: http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 13 02:01:49 PDT 2014
Author: hwbllmnn
Date: 2014-05-13 02:01:49 -0700 (Tue, 13 May 2014)
New Revision: 8851
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
removed info on click for kml objects, added editing of attributes
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-12 14:31:00 UTC (rev 8850)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-13 09:01:49 UTC (rev 8851)
@@ -82,13 +82,13 @@
     var editHtml = '<div title="Edit feature">' +
         '<div class="digitize-image digitize-polygon"></div>' +
-        '<span>my polygon</span>' +
+        '<span>my polygon</span><br></br>' +
         '<div class="digitize-image digitize-style"></div>' +
         '<div class="digitize-image digitize-attributes"></div>' +
         '<div class="digitize-image digitize-add"></div>' +
         '<div class="digitize-image digitize-export"></div><br></br>' +
         '<div class="digitize-image digitize-pencil"></div>' +
-        '<fieldset class="fieldset-auto-width">' +
+        '<fieldset class="fieldset-auto-width digitize-hidden">' +
         '<div class="digitize-image digitize-move"></div>' +
         '<div class="digitize-image digitize-add-vertex"></div>' +
         '<div class="digitize-image digitize-move-vertex"></div>' +
@@ -220,10 +220,34 @@
         menu.children('li:has(.digitize-pencil)').bind('click', function() {
             $link.addClass('kmltree-selected').siblings().removeClass('kmltree-selected');
+            var idx = $link.attr('idx');
+            var kml = $('#mapframe1').data('kml');
+            var url = $link.parent().parent().attr('title');
+            var feature = kml._kmls[url].data.features[idx];
+            editDialog.find('span').text(feature.properties.title);
             editDialog.dialog('open');
             editDialog.find('.digitize-attributes').bind('click', function() {
                 attributesDialog.dialog('open');
+                var rows = '';
+                $.each(feature.properties, function(k, v) {
+                    if(k.match(/Mapbender:/)) return;
+                    rows += '<tr><td>' + k + '</td><td><input type="text" name="' + k + '" value="' + v + '"></input></td></tr>';
+                attributesDialog.find('table').html(rows);
+                attributesDialog.find('.digitize-save').bind('click', function() {
+                    attributesDialog.find('table input').each(function() {
+                        var k = $(this).attr('name');
+                        var v = $(this).val();
+                        feature.properties[k] = v;
+                    attributesDialog.dialog('close');
+                    editDialog.dialog('close');
+                    kml.refresh(url);
+            editDialog.find('.digitize-pencil').bind('click', function() {
+                $(this).next().toggleClass('digitize-hidden');
             menu.menu('destroy').remove();
         menu.children('li:has(.digitize-remove)').bind('click', function() {
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-12 14:31:00 UTC (rev 8850)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-13 09:01:49 UTC (rev 8851)
@@ -39,7 +39,7 @@
     _popup : null,
     _create: function(){
         var self = this, o = this.options;
-        this.element.bind('click', function(e){
+/*        this.element.bind('click', function(e){
             var map = self.element.mapbender();
             var pos = map.getMousePosition(e);
             var clickPoint =  map.convertPixelToReal(new Point(pos.x,pos.y));
@@ -166,7 +166,7 @@
                 requestGeometries = [];
                 pointGeometries = {};
         self.element.bind('kml:loaded',function(event,obj){
             if(o.autoOpen){
                 self._display(obj);
@@ -279,6 +279,14 @@
         $map.setMapRequest();
+    refresh: function(url) {
+        var $map = $(this.element).mapbender();
+        var itm = this._kmls[url];
+        this._convertFromJson(itm);
+        this.element.trigger('kml:loaded',{type:"geojson",data:itm.data,url:itm.url,display: itm.display, refreshing: true});
+        $map.setMapRequest();
     _load : function(url){
         var epsg = $(self.element).mapbender().epsg;
@@ -426,12 +434,17 @@
         bbox[0] = bbox[0].minus(buffer);
         bbox[1] = bbox[1].plus(buffer);
-        for(var i =0; i < mapitem.geomArray.count(); i++){
-            var h = new Highlight([self.element.attr('id')], "mapframe1_" + parseInt(Math.random()*100000,10),{
+        for(i =0; i < mapitem.geomArray.count(); i++){
+            var elemid = "mapframe1_" + parseInt(Math.random()*100000, 10);
+            var h = new Highlight([self.element.attr('id')], elemid,{
                 "position":"absolute",
                 "top": "0px",
                 "left": "0px",
                 "z-index": "80" },1);
+            $('#mapframe1').children('*[id*="' + elemid + '"]').attr('data-idx', i)
+                .attr('data-url', mapitem.url);
             g = mapitem.geomArray.get(i);
             icon = g.e.getElementValueByName("Mapbender:icon");
             //title = g.e.getElementValueByName("title");
@@ -462,6 +475,7 @@
                 mapitem.highlightArray[j].hide();
         self.element.mapbender().events.afterMapRequest.register(function () {
             if(mapitem.display){
                 for(var i in mapitem.highlightArray){
More information about the Mapbender_commits mailing list
