[Mapbender-commits] r8854 - in trunk/mapbender: http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 13 05:10:33 PDT 2014
Author: hwbllmnn
Date: 2014-05-13 05:10:33 -0700 (Tue, 13 May 2014)
New Revision: 8854
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
added selecting of features via map click, added removal of selected features via add/edit menu
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-13 09:38:04 UTC (rev 8853)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-13 12:10:33 UTC (rev 8854)
@@ -314,6 +314,24 @@
                 digitizingFor = $link.parent().attr('title');
                 that.activate();
+            digitizeDialog.find('.digitize-cursor').bind('click', function() {
+                var kml = $('#mapframe1').data('kml');
+                kml.setQueriedLayer($link.parent().attr('title'));
+            digitizeDialog.find('.digitize-remove').bind('click', function() {
+                var url = $link.parent().attr('title');
+                var feat = $('li[title="' + url + '"] li.kmltree-selected');
+                var idx = feat.attr('idx');
+                var ids = [];
+                var i = 0;
+                $.each(feat.siblings(), function(k, v) {
+                    ids.push($(v).attr('idx'));
+                    $(v).attr('idx', i++);
+                feat.remove();
+                kml.reorderFeatures(url, ids);
             menu.menu('destroy').remove();
         return false;
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-13 09:38:04 UTC (rev 8853)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-13 12:10:33 UTC (rev 8854)
@@ -39,6 +39,40 @@
     _popup : null,
     _create: function(){
         var self = this, o = this.options;
+        this.element.bind('click', function(e) {
+            var map = self.element.mapbender();
+            var pos = map.getMousePosition(e);
+            var clickPoint =  map.convertPixelToReal(new Point(pos.x,pos.y));
+            var res = map.getScale() / mb_resolution / 100;
+            var itm = self._kmls[self.queriedLayer];
+            if(!itm) return;
+            var matched = [];
+            var matchedIds = [];
+            $.each(itm.data.features, function(k, v) {
+                if(v.geometry.type.match(/point/i)) {
+                    var minx = v.geometry.coordinates[0] - 20 * res;
+                    var miny = v.geometry.coordinates[1] - 20 * res;
+                    var maxx = minx + 40 * res;
+                    var maxy = miny + 40 * res;
+                    if(minx < clickPoint.x && maxx > clickPoint.x && miny < clickPoint.y && maxy > clickPoint.y) {
+                        matched.push(v);
+                        matchedIds.push(k);
+                } else {
+                    var box = itm.geomArray.list[k].getBBox();
+                    if(box[0].x < clickPoint.x && box[1].x > clickPoint.x && box[0].y < clickPoint.y && box[1].y > clickPoint.y) {
+                        matched.push(v);
+            if(matchedIds.length > 0) {
+                $('li[title="' + self.queriedLayer + '"] li[idx="' + matchedIds[0] + '"]').click();
 /*        this.element.bind('click', function(e){
@@ -234,6 +268,10 @@
         this._kmls[url].data.features[idx].display = false;
+    setQueriedLayer: function(url) {
+        this.queriedLayer = url;
     addGeometry: function(pts, url, attributesDialog) {
         var $map = $(this.element).mapbender();
         var self = this;
More information about the Mapbender_commits mailing list
