[Mapbender-commits] r8859 - in trunk/mapbender/http: plugins widgets
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 14 00:46:39 PDT 2014
Author: hwbllmnn
Date: 2014-05-14 00:46:39 -0700 (Wed, 14 May 2014)
New Revision: 8859
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/http/widgets/w_digitize.js
added moving of vertices
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-14 06:45:12 UTC (rev 8858)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-14 07:46:39 UTC (rev 8859)
@@ -402,7 +402,7 @@
         that.activate();
-    var featureMoved = function() {
+    var featureModified = function() {
         var kml = $('#mapframe1').data('kml');
         var digit = o.$target.data('mb_digitize');
         var pts = digit._digitizePoints;
@@ -434,7 +434,7 @@
                 o.editedFeature = editedFeature;
                 o.$target
                 .mb_digitize(o)
-                .bind('mb_digitizefeaturemoved', featureMoved);
+                .bind('mb_digitizefeaturemodified', featureModified);
         if (!inProgress) {
Modified: trunk/mapbender/http/widgets/w_digitize.js
--- trunk/mapbender/http/widgets/w_digitize.js	2014-05-14 06:45:12 UTC (rev 8858)
+++ trunk/mapbender/http/widgets/w_digitize.js	2014-05-14 07:46:39 UTC (rev 8859)
@@ -453,11 +453,47 @@
     stopMoving: function(e) {
         this.moving = false;
-        this._trigger("featuremoved", e);
+        this._trigger('featuremodified', e);
+    startVertexMoving: function(e) {
+        var pt = this.pointFromEvent(e);
+        var self = this;
+        this.vertexMoving = false;
+        $.each(this._digitizePoints, function(k, v) {
+            if(self._isPointSnapped(v.mousePos, pt.mousePos)) {
+                self.vertexMoving = true;
+                self.vertexMovingIndex = k;
+                return;
+    vertexMove: function(e) {
+        if(this.vertexMoving) {
+            this._digitizePoints[this.vertexMovingIndex] = pt;
+        this._redraw();
+    stopVertexMoving: function(e) {
+    moveVertexMode: function() {
+        this.element
+            .unbind('mousedown').unbind('mousemove').unbind('mouseup')
+            .bind('mousedown', $.proxy(this, 'startVertexMoving'))
+            .bind('mousemove', $.proxy(this, 'vertexMove'))
+            .bind('mouseup', $.proxy(this, 'stopVertexMoving'))
+            .css('cursor', 'crosshair');
     moveMode: function() {
         this.element
             .bind("mousedown", $.proxy(this, 'startMoving'))
             .bind("mousemove", $.proxy(this, 'move'))
             .bind('mouseup', $.proxy(this, 'stopMoving'))
More information about the Mapbender_commits mailing list
