[Mapbender-commits] r8876 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 16 05:25:43 PDT 2014
Author: hwbllmnn
Date: 2014-05-16 05:25:43 -0700 (Fri, 16 May 2014)
New Revision: 8876
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
fixed selection by map click
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-16 11:55:53 UTC (rev 8875)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-16 12:25:43 UTC (rev 8876)
@@ -54,6 +54,7 @@
             var map = self.element.mapbender();
             var pos = map.getMousePosition(e);
             var clickPoint =  map.convertPixelToReal(new Point(pos.x,pos.y));
+            var wgspt = Proj4js.transform(self.targetProj, self.wgs84, {x: clickPoint.x, y: clickPoint.y});
             var res = map.getScale() / mb_resolution / 100;
             var itm = self._kmls[self.queriedLayer];
             if(!itm) return;
@@ -63,8 +64,9 @@
             $.each(itm.data.features, function(k, v) {
                 if(v.geometry.type.match(/point/i)) {
-                    var minx = v.geometry.coordinates[0] - 20 * res;
-                    var miny = v.geometry.coordinates[1] - 20 * res;
+                    var pt = Proj4js.transform(self.wgs84, self.targetProj, {x: v.geometry.coordinates[0], y: v.geometry.coordinates[1]});
+                    var minx = pt.x - 20 * res;
+                    var miny = pt.y - 20 * res;
                     var maxx = minx + 40 * res;
                     var maxy = miny + 40 * res;
                     if(minx < clickPoint.x && maxx > clickPoint.x && miny < clickPoint.y && maxy > clickPoint.y) {
@@ -72,8 +74,8 @@
                         matchedIds.push(k);
                 } else {
-                    var box = this.getBbox(itm.data.features[k]);
-                    if(box[0] < clickPoint.x && box[2] > clickPoint.x && box[1] < clickPoint.y && box[3] > clickPoint.y) {
+                    var box = self.getBbox(itm.data.features[k]);
+                    if(box[0] < wgspt.x && box[2] > wgspt.x && box[1] < wgspt.y && box[3] > wgspt.y) {
                         matched.push(v);
                         matchedIds.push(k);
@@ -253,7 +255,7 @@
-    reload: function() {
+    // reload: function() {
         // probably nothing needs to be done when transforming on the fly on the client
         // var self = this, o = this.options;
         // var epsg = $(self.element).mapbender().epsg;
@@ -284,11 +286,11 @@
     setOrder: function(order) {
         this.kmlOrder = order;
-        this.reload();
+        this.render();
     reorderFeatures: function(url, ids) {
More information about the Mapbender_commits mailing list
