[Mapbender-commits] r8879 - in trunk/mapbender/http: classes javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 16 06:11:17 PDT 2014
Author: hwbllmnn
Date: 2014-05-16 06:11:17 -0700 (Fri, 16 May 2014)
New Revision: 8879
   trunk/mapbender/http/classes/class_map.php
   trunk/mapbender/http/classes/class_wmc.php
   trunk/mapbender/http/classes/class_wmcToXml.php
   trunk/mapbender/http/javascripts/mod_loadwmc.js
   trunk/mapbender/http/javascripts/mod_savewmc.js
added loading of kmls out of DB WMCs
Modified: trunk/mapbender/http/classes/class_map.php
--- trunk/mapbender/http/classes/class_map.php	2014-05-16 12:45:23 UTC (rev 8878)
+++ trunk/mapbender/http/classes/class_map.php	2014-05-16 13:11:17 UTC (rev 8879)
@@ -16,7 +16,6 @@
 	private $isOverview = false;
 	private $wmsArray = array();
     private $kmls;
-    private $originalKmls;
     private $kmlOrder;
@@ -224,14 +223,6 @@
         $this->kmls = $kmls;
-    public function getOriginalKmls() {
-        return $this->originalKmls;
-    public function setOriginalKmls($originalKmls) {
-        $this->originalKmls = $originalKmls;
     public function getKmlOrder() {
         return $this->kmlOrder;
@@ -518,9 +509,6 @@
         if(property_exists($jsMapObject, 'kmls')) {
             $this->kmls = $jsMapObject->kmls;
-        if(property_exists($jsMapObject, 'originalKmls')) {
-            $this->originalKmls = $jsMapObject->originalKmls;
         if(property_exists($jsMapObject, 'kmlOrder')) {
             $this->kmlOrder = $jsMapObject->kmlOrder;
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2014-05-16 12:45:23 UTC (rev 8878)
+++ trunk/mapbender/http/classes/class_wmc.php	2014-05-16 13:11:17 UTC (rev 8879)
@@ -1156,9 +1156,6 @@
 		// set general extension data
 		if (count($this->generalExtensionArray) > 0) {
-            if(array_key_exists('ORIGINALKMLS', $this->generalExtensionArray)) {
-                $this->generalExtensionArray['ORIGINALKMLS'] = unserialize(base64_decode($this->generalExtensionArray['ORIGINALKMLS']));
 			$json = new Mapbender_JSON();
 			array_push($wmcJsArray, "restoredWmcExtensionData = " . $json->encode($this->generalExtensionArray) . ";");
Modified: trunk/mapbender/http/classes/class_wmcToXml.php
--- trunk/mapbender/http/classes/class_wmcToXml.php	2014-05-16 12:45:23 UTC (rev 8878)
+++ trunk/mapbender/http/classes/class_wmcToXml.php	2014-05-16 13:11:17 UTC (rev 8879)
@@ -146,9 +146,6 @@
         if($this->wmc->mainMap->getKmls()) {
             $extensionData['kmls'] = json_encode($this->wmc->mainMap->getKmls());
-        if($this->wmc->mainMap->getOriginalKmls()) {
-            $extensionData['originalKmls'] = base64_encode(serialize($this->wmc->mainMap->getOriginalKmls()));
         if($this->wmc->mainMap->getKmlOrder()) {
             $extensionData['kmlOrder'] = json_encode($this->wmc->mainMap->getKmlOrder());
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js	2014-05-16 12:45:23 UTC (rev 8878)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js	2014-05-16 13:11:17 UTC (rev 8879)
@@ -487,6 +487,17 @@
 							eval(obj.javascript[j]);
 						if (args.method === "loadWmc") {
+                                                    var kml = $('#mapframe1').data('kml');
+                                                    if(kml) {
+                                                        try {
+                                                            kml._kmls = JSON.parse(restoredWmcExtensionData.KMLS);
+                                                            kml.kmlOrder = JSON.parse(restoredWmcExtensionData.KMLORDER);
+                                                            kml.render();
+                                                        } catch(e) {
+                                                            // just ignore the exception for now
+                                                    console.log(restoredWmcExtensionData)
 							that.events.loaded.trigger({
 								extensionData: restoredWmcExtensionData
Modified: trunk/mapbender/http/javascripts/mod_savewmc.js
--- trunk/mapbender/http/javascripts/mod_savewmc.js	2014-05-16 12:45:23 UTC (rev 8878)
+++ trunk/mapbender/http/javascripts/mod_savewmc.js	2014-05-16 13:11:17 UTC (rev 8879)
@@ -169,7 +169,6 @@
             if(kml) {
                 mb_mapObj[0].kmls = kml._kmls;
-                mb_mapObj[0].originalKmls = kml.originalKmls;
                 mb_mapObj[0].kmlOrder = kml.kmlOrder;
@@ -201,7 +200,7 @@
 		// reversal of above WORKAROUND
-		for (var i = 0; i < mb_mapObj.length; i++) {
+		for (i = 0; i < mb_mapObj.length; i++) {
 			mb_mapObj[i].$target = $target[i];
More information about the Mapbender_commits mailing list
