[Mapbender-commits] r8881 - in trunk/mapbender: http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 20 07:12:42 PDT 2014
Author: hwbllmnn
Date: 2014-05-20 07:12:42 -0700 (Tue, 20 May 2014)
New Revision: 8881
   trunk/mapbender/http/plugins/kmlTree.js
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
experimental style dialog with colorpicker, added a couple of IE8 workarounds
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js	2014-05-16 13:38:37 UTC (rev 8880)
+++ trunk/mapbender/http/plugins/kmlTree.js	2014-05-20 14:12:42 UTC (rev 8881)
@@ -165,7 +165,7 @@
-        $("*:checkbox",$kmlEntry).bind('click', function(){
+        $('input[type="checkbox"]', $kmlEntry).bind('click', function(){
             var idx = $(this).parent().attr('idx');
             if(idx === undefined) {
@@ -191,10 +191,19 @@
             }else{
                 $(this).parent().removeClass("closed");
                 $(this).parent().addClass("open");
+            // IE8 workaround to make style previews visible...
+            $(this).parent().find('ul.ui-sortable li .rvml').removeClass('rvml').addClass('rvml');
+        $('#tabs_kmlTree').bind('click', function() {
+            window.setTimeout(function() {
+                $('#kmlTree').find('ul.ui-sortable li .rvml').removeClass('rvml').addClass('rvml');
+            }, 1000);
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-16 13:38:37 UTC (rev 8880)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-20 14:12:42 UTC (rev 8881)
@@ -105,6 +105,19 @@
         '<div class="digitize-image digitize-save"></div>' +
         '</div>';
+    var editStyleHtml = '<div title="Edit style">' +
+        '<div class="digitize-preview"></div>' +
+        '<table><tr><td>Symbol:</td><td><input type="text" name="marker-symbol" value=""></input></td></tr>' +
+        '<tr><td>Symbolgröße:</td><td><input type="text" name="marker-size" value=""></input></td></tr>' +
+        '<tr><td>Linienfarbe</td><td><input type="color" name="stroke" value="#000000"></input></td></tr>' +
+        '<tr><td>Liniendeckkraft:</td><td><input type="text" name="stroke-opacity" value="1"></input></td></tr>' +
+        '<tr><td>Liniendicke:</td><td><input type="text" name="stroke-width" value="1"></input></td></tr>' +
+        '<tr><td>Flächenfarbe:</td><td><input type="color" name="fill" value="#ff0000"></input></td></tr>' +
+        '<tr><td>Flächendeckkraft:</td><td><input type="text" name="fill-opacity" value="1"></input></td></tr>' +
+        '</table><br></br>' +
+        '<div class="digitize-image digitize-save"></div>' +
+        '</div>';
     var folderMenu = '<ul class="digitize-contextmenu">' +
         '<li><div class="digitize-image digitize-pencil"></div>Edit</li>' +
         '<li><div class="digitize-image digitize-zoomto"></div>Zoom to</li>' +
@@ -135,6 +148,7 @@
     var digitizeDialog,
         editDialog,
         attributesDialog,
+        editStyleDialog,
         button,
         that = this,
         inProgress = false,
@@ -175,6 +189,14 @@
             that.destroy();
+        editStyleDialog = $(editStyleHtml);
+        editStyleDialog.dialog({
+            autoOpen: false,
+            position: [o.$target.offset().left, o.$target.offset().top]
+        }).bind('dialogclose', function() {
+            button.stop();
+            $(this).find('input').unbind('change');
         // Initialise button
@@ -188,8 +210,10 @@
             stop: that.deactivate
-        $('li:has(.digitize-close)').live('click', function() {
-            $(this).parent().menu('destroy').remove();
+        $('li').live('click', function() {
+            if($(this).children('.digitize-close').length === 1) {
+                $(this).parent().menu('destroy').remove();
         $('#mapframe1').bind('kml:loaded', function(evt, item) {
@@ -204,6 +228,38 @@
+    var editStyle = function($link, menu) {
+        return function() {
+            editStyleDialog.dialog('open');
+            var idx = $link.attr('idx');
+            var kml = $('#mapframe1').data('kml');
+            var url = $link.parent().parent().attr('title');
+            var feature = kml._kmls[url].data.features[idx];
+            var preview = editStyleDialog.find('.digitize-preview');
+            preview.html('');
+            preview = preview.get(0);
+            kml.renderPreview(feature, preview);
+            $.each(feature.properties, function(k, v) {
+                editStyleDialog.find('input[name="' + k + '"]').val(v);
+            editStyleDialog.find('input').bind('change', function() {
+                editStyleDialog.find('input').each(function() {
+                    feature.properties[$(this).attr('name')] = $(this).val();
+                    kml.render();
+                    var preview = editStyleDialog.find('.digitize-preview').html('').get(0);
+            editStyleDialog.find('.digitize-save').bind('click', function() {
+                editStyleDialog.dialog('close');
+                kml.refresh(url);
+            editStyleDialog.find('input[name="fill"]').spectrum();
+            editStyleDialog.find('input[name="stroke"]').spectrum();
+            menu.menu('destroy').remove();
     var contextmenuObject = function() {
         var $link = $(this);
         if($link.attr('idx') === undefined) {
@@ -237,6 +293,7 @@
+        menu.children('li:has(.digitize-style)').bind('click', editStyle($link, menu));
         return false;
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-16 13:38:37 UTC (rev 8880)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-20 14:12:42 UTC (rev 8881)
@@ -96,7 +96,6 @@
         var kmls = mb_getWmcExtensionData('KMLS');
-        // try{
         if(kmls) {
             kmls = JSON.parse(kmls);
             this._kmls = kmls;
@@ -105,19 +104,13 @@
                 self.element.trigger('kml:loaded',kmls[k]);
-        // kmls = mb_getWmcExtensionData('ORIGINALKMLS');
-        // if(kmls) {
-        //     this.originalKmls = kmls;
         kmls = mb_getWmcExtensionData('KMLORDER');
         if(kmls) {
             this.kmlOrder = JSON.parse(kmls);
         this.render();
-        // }catch(e){
-        //     console.log(e)
     _init: function(){
         var self = this, o = this.options;
         this._popup = $('<div></div>').dialog({autoOpen : false, height: 500, width: 500});
@@ -149,17 +142,15 @@
         var max = Proj4js.transform(this.wgs84, this.targetProj, {x: bbox[2], y: bbox[3]});
         map.calculateExtent(new Mapbender.Extent(min.x, min.y, max.x, max.y));
-        map.setMapRequest();
+        map.zoom(true, 0.99999999);
     showFeature: function(url, idx) {
-        // this._kmls[url].highlightArray[idx].paint();
         this._kmls[url].data.features[idx].display = true;
         this.render();
     hideFeature: function(url, idx) {
-        // this._kmls[url].highlightArray[idx].hide();
         this._kmls[url].data.features[idx].display = false;
         this.render();
@@ -220,18 +211,6 @@
             //not adding feed twice
             return;
-        // $.ajax({url: '../php/getOriginalKml.php',
-        //         data: {url: o.url},
-        //         type: 'POST',
-        //         dataType: 'text/plain',
-        //         success: function(data) {
-        //             if(!self.originalKmls) {
-        //                 self.originalKmls = {};
-        //             self.originalKmls[o.url] = data;
-        //             self.kmlOrder.push(o.url);
         this.kmlOrder.push(o.url);
@@ -257,39 +236,6 @@
-    // reload: function() {
-        // probably nothing needs to be done when transforming on the fly on the client
-        // var self = this, o = this.options;
-        // var epsg = $(self.element).mapbender().epsg;
-        // epsg = epsg.split(":")[1];
-        // $.each(self.kmlOrder, function(k, url) {
-        //     var o = self._kmls[url];
-        //     if(!o) return;
-        //     // TODO prevent map reload at this point
-        //     $('li[title="' + url + '"] > button[name="remove"]').click();
-        //     $.ajax({ url: self._endpointURL + '?targetEPSG= ' + epsg,
-        //              data: self.originalKmls[url],
-        //              type: 'POST',
-        //              dataType: "json",
-        //              success : function(data,textStatus,xhr){
-        //                  if(!data){
-        //                      self.element.trigger('kml:error',"request returned no data");
-        //                  else if(data.errorMessage){
-        //                      self.element.trigger('kml:error',data.errorMessage);
-        //                  }else{
-        //                      self._kmls[o.url] = {type:"geojson",data:data,url:o.url,display: o.display, loadedOnStartup: true};
-        //                      self.element.trigger('kml:loaded',{type:"geojson",data:data,url:o.url,display: o.display});
-        //              error: function(XMLHttpRequest, textStatus, errorThrown){
-        //                  self.element.trigger('kml:error',"Problem talking to server: " + errorThrown);
     setOrder: function(order) {
         this.kmlOrder = order;
         this.render();
@@ -324,10 +270,6 @@
     remove: function(url){
-        // nrgh there are still references to the highlightobjects somewhere!
-        for(var i in this._kmls[url].highlightArray){
-            this._kmls[url].highlightArray[i].clean();
         delete(this._kmls[url]);
         var $map = $(this.element).mapbender();
         var extent = $map.getExtentInfos();
@@ -397,12 +339,23 @@
             pt = $('#mapframe1').mapbender().convertRealToPixel(pt);
         if(isNaN(pt.x) || isNaN(pt.y)) return;
+        // is this the right place and way to fix it?
         if(feature.properties['Mapbender:icon']) {
+            feature.properties['marker-symbol'] = feature.properties['Mapbender:icon'];
+            feature.properties['Mapbender:icon'] = null;
+        if(feature.properties['marker-symbol']) {
             var size = 32;
+            if(feature.properties['marker-size'] === 'small') {
+                size = 20;
+            if(feature.properties['marker-size'] === 'large') {
+                size = 64;
             if(feature.preview) {
                 size = 20;
-            var img = canvas.image(feature.properties['Mapbender:icon'], pt.x, pt.y, size, size).node;
+            var img = canvas.image(feature.properties['marker-symbol'], pt.x, pt.y, size, size).node;
             if(img.setAttributeNS) {
                 img.setAttributeNS(null, "preserveAspectRatio" , "xMidYMid meet" );
More information about the Mapbender_commits mailing list
