[Mapbender-commits] r8915 - in trunk/mapbender: http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 28 01:23:51 PDT 2014
Author: hwbllmnn
Date: 2014-05-28 01:23:51 -0700 (Wed, 28 May 2014)
New Revision: 8915
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
added icon picking for marker styles, extended marker style dialog
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-28 08:23:16 UTC (rev 8914)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-28 08:23:51 UTC (rev 8915)
@@ -118,7 +118,7 @@
         '<tr><td>Flächendeckkraft:</td><td><div class="opacity-slider" data-name="fill-opacity"></div></td></tr></table>' +
         '<table class="digitize-style-predefined"><tr><td>Symbol:</td><td><input type="text" name="marker-symbol" value=""></input></td></tr>' +
         '<tr><td>Symbolgröße:</td><td><input type="text" name="marker-size" value=""></input></td></tr>' +
-        '<tr><td>Symbolfarbe:</td><td><input type="color" name="marker-color" value=""></input></td></tr>' +
+        '<tr><td>Symbolfarbe:</td><td><input type="color" name="marker-color" value="#ff0000"></input></td></tr>' +
         '<tr><td>Linienfarbe</td><td><input type="color" name="stroke" value="#000000"></input></td></tr>' +
         '<tr><td>Liniendeckkraft:</td><td><div class="opacity-slider" data-name="stroke-opacity"></div></td></tr>' +
         '<tr><td>Liniendicke:</td><td><input type="text" name="stroke-width" value="1"></input></td></tr>' +
@@ -159,6 +159,7 @@
         editDialog,
         attributesDialog,
         editStyleDialog,
+        icons = null,
         button,
         that = this,
         inProgress = false,
@@ -168,6 +169,17 @@
         status = 'none';
     var create = function() {
+        $.ajax({
+            url: '../extensions/makiicons/selection.json',
+            type: 'GET',
+            dataType: 'json',
+            success: function(data) {
+                icons = data;
+                var kml = $('#mapframe1').data('kml');
+                kml.icons = icons;
         // Initialise digitize dialog
@@ -247,6 +259,23 @@
     var editStyle = function($link, menu) {
+        var classPrefix = icons.preferences.fontPref.prefix,
+            iconList = [],
+            search = [];
+        // For each icon
+        $.each(icons.icons, function(i, v) {
+            iconList.push( classPrefix + v.properties.name );
+            if ( v.icon && v.icon.tags && v.icon.tags.length ) {
+                search.push( v.properties.name + ' ' + v.icon.tags.join(' ') );
+            } else {
+                search.push( v.properties.name );
+        editStyleDialog.find('.digitize-style-predefined input[name="marker-symbol"]').fontIconPicker({source: iconList, searchSource: search, emptyIcon: false});
         return function() {
             editStyleDialog.dialog('open');
             var idx = $link.attr('idx');
@@ -325,7 +354,7 @@
                 preview = editDialog.find('.digitize-preview').html('').get(0);
                 kml.renderPreview(feature, preview);
                 preview = attributesDialog.find('.digitize-preview').html('').get(0);
-            kml.renderPreview(feature, preview);
+                kml.renderPreview(feature, preview);
             $('.opacity-slider').slider('option', 'change', function() {
                 if(isline && $(this).attr('data-name') === 'fill-opacity') {
@@ -342,6 +371,7 @@
             editStyleDialog.find('input[name="fill"]').spectrum();
             editStyleDialog.find('input[name="stroke"]').spectrum();
+            editStyleDialog.find('input[name="marker-color"]').spectrum();
             if(menu)
                 menu.menu('destroy').remove();
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-28 08:23:16 UTC (rev 8914)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-28 08:23:51 UTC (rev 8915)
@@ -353,14 +353,11 @@
             feature.properties['marker-type'] = 'custom';
             feature.properties['Mapbender:icon'] = null;
-        if(feature.properties['marker-symbol']) {
+        if(feature.properties['marker-type'] === 'custom') {
             var size = 32;
-            if(feature.properties['marker-size'] === 'small') {
-                size = 20;
+            if(feature.properties['marker-size']) {
+                size = feature.properties['marker-size'];
-            if(feature.properties['marker-size'] === 'large') {
-                size = 64;
             if(feature.preview) {
                 size = 20;
@@ -369,7 +366,66 @@
                 img.setAttributeNS(null, "preserveAspectRatio" , "xMidYMid meet" );
         } else {
-            canvas.circle(pt.x, pt.y, 32).attr(feature.attributes);
+            var size = 32;
+                if(feature.properties['marker-size'] === 'large') {
+                    size = 64;
+                if(feature.properties['marker-size'] === 'small') {
+                    size = 16;
+            if(feature.preview) {
+                size = 20;
+            if(!this.icons) {
+                window.setTimeout($.proxy(function(){
+                    this.renderPoint(canvas, feature);
+                }, this), 100);
+                return;
+            $.each(this.icons.icons, function(_, v) {
+                if('icon-' + v.properties.name === feature.properties['marker-symbol']) {
+                    $.each(v.icon.paths, function(_, p) {
+                        var raph = Raphael();
+                        var tmp = raph.path(p);
+                        var box = tmp.getBBox();
+                        tmp.remove();
+                        $(raph.canvas).remove();
+                        var path = canvas.path(p);
+                        var fac;
+                        if(box.width > box.height) {
+                            fac = size / box.width;
+                        } else {
+                            fac = size / box.height;
+                            fac = fac * 0.7;
+                        // center icon on 0/0, then scale to size, then translate to actual point
+                        // for preview, just start at 0/0
+                            path.translate(-box.x, -box.y);
+                        } else {
+                            path.translate(-box.x - box.width / 2, -box.y - box.height / 2);
+                        // if you get a chrome error 'Invalid value for <path> attribute transform="  "' see:
+                        // http://forum.wakanda.org/showthread.php?6753-error-raphael-min.js-7&p=31624&viewfull=1
+                        path.scale(fac, fac, 0, 0);
+                        if(!feature.preview) {
+                            path.translate(pt.x, pt.y);
+                        path.attr('fill', feature.properties['marker-color']);
+                        path.attr('stroke', 'black');
@@ -415,20 +471,24 @@
     renderFeature: function(canvas) {
         var self = this;
         return function(_, feature) {
-            if(feature.display === false) {
-                return;
+            try{
+                if(feature.display === false) {
+                    return;
+                switch(feature.geometry.type.toLowerCase()) {
+                    case 'point':
+                    self.renderPoint(canvas, feature);
+                    break;
+                    case 'linestring':
+                    self.renderLine(canvas, feature);
+                    break;
+                    case 'polygon':
+                    self.renderPolygon(canvas, feature);
+                    break;
+            }catch(e) {
+                console && console.log('Problem rendering feature', feature, e)
-            switch(feature.geometry.type.toLowerCase()) {
-                case 'point':
-                self.renderPoint(canvas, feature);
-                break;
-                case 'linestring':
-                self.renderLine(canvas, feature);
-                break;
-                case 'polygon':
-                self.renderPolygon(canvas, feature);
-                break;
More information about the Mapbender_commits mailing list
