[Mapbender-commits] r9057 - trunk/mapbender/conf
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Sep 4 02:14:51 PDT 2014
Author: armin11
Date: 2014-09-04 02:14:51 -0700 (Thu, 04 Sep 2014)
New Revision: 9057
   trunk/mapbender/conf/mapbender.conf-dist
add hint to adopt bbox in a reasonable way ;-)
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist	2014-09-03 10:55:50 UTC (rev 9056)
+++ trunk/mapbender/conf/mapbender.conf-dist	2014-09-04 09:14:51 UTC (rev 9057)
@@ -291,6 +291,7 @@
 # if the values are in the range of the max extent and the values will be reduced to this before they are transformed!
 # The boxes came from http://spatialreference.org/ WGS84 Bounds. Maybe they can be pulled directly from the epsg registry itself:
 # http://www.epsg-registry.org/export.htm?gml=urn:ogc:def:area:EPSG::1624&resolvePolygon ...
+# Note: IF SRS_ARRAY_MAX_EXTENTS is set, please adopt the extents so, that they are cover your area of intrest completly - don't use only the information from spatialreference.org, cause this infos are only hints!!!!!!!!
 #define("SRS_ARRAY", "4326,31466,31467,31468,25832");
 #define("SRS_ARRAY_MAX_EXTENTS", "-180,-90,180,90|5.8700,49.1000,7.5000,53.7500|7.5000,47.2700,10.5000,55.0600|10.5000,47.2700,13.5000,55.0600|5.0500,57.9000,12.0000,65.6700");
More information about the Mapbender_commits mailing list
