[Mapbender-commits] r9063 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 10 04:01:22 PDT 2014
Author: armin11
Date: 2014-09-10 04:01:22 -0700 (Wed, 10 Sep 2014)
New Revision: 9063
   trunk/mapbender/http/classes/class_administration.php
   trunk/mapbender/http/classes/class_map.php
   trunk/mapbender/http/classes/class_wmc.php
   trunk/mapbender/http/classes/class_wmcToXml.php
   trunk/mapbender/http/classes/class_wms.php
new possibility to handle metadataurl and dataurl elements in wms and wmc
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php	2014-09-08 15:34:59 UTC (rev 9062)
+++ trunk/mapbender/http/classes/class_administration.php	2014-09-10 11:01:22 UTC (rev 9063)
@@ -1483,6 +1483,32 @@
+	function getInspireDownloadOptionsForLayers($layerIdArray) {
+		$v = array();
+		$t = array();
+		$sql = "SELECT layer_id, f_get_download_options_for_layer(layer_id) as options from layer where layer_id in(";
+		$c = 1;
+		for($i=0; $i<count($layerIdArray); $i++){
+			if($i>0){ $sql .= ",";}
+			$sql .= "$".$c;
+			$c++;
+			array_push($v, $layerIdArray[$i]);
+			array_push($t, 'i');
+		$sql .= ");";
+		$res = db_prep_query($sql,$v,$t);
+		if($res){
+			while($row = db_fetch_array($res)){
+				$downloadOptions[$row['layer_id']] = $row['options'];
+			return $downloadOptions;
+		else{
+			return false;
 	// deprecated! use User->isWmsAccessible
 	function getWmsPermission($wms_id, $user_id) {
 		$array_guis = $this->getGuisByPermission($user_id,true);
Modified: trunk/mapbender/http/classes/class_map.php
--- trunk/mapbender/http/classes/class_map.php	2014-09-08 15:34:59 UTC (rev 9062)
+++ trunk/mapbender/http/classes/class_map.php	2014-09-10 11:01:22 UTC (rev 9063)
@@ -520,6 +520,7 @@
 		for ($i=0; $i < count($jsMapObject->wms); $i++){
 			$currentWms = $jsMapObject->wms[$i];
+			$e = new mb_notice("class_map.php: json map object: ".json_encode($jsMapObject));
 			$wms = new wms();
@@ -571,12 +572,12 @@
 				$newLayer->layer_uid = $currentLayer->layer_uid;
 				$newLayer->layer_name = $currentLayer->layer_name;
 				$newLayer->layer_title = $currentLayer->layer_title;
-				$newLayer->layer_dataurl_href = $currentLayer->layer_dataurl_href;
+				$newLayer->layer_dataurl[0]->href = $currentLayer->layer_dataurl;
 				$newLayer->layer_pos = $currentLayer->layer_pos;
 				$newLayer->layer_queryable = $currentLayer->layer_queryable;
 				$newLayer->layer_minscale = $currentLayer->layer_minscale;
 				$newLayer->layer_maxscale = $currentLayer->layer_maxscale;
-				$newLayer->layer_metadataurl = $currentLayer->metadataurl;
+				$newLayer->layer_metadataurl[0]->href = $currentLayer->layer_metadataurl;
 				$newLayer->gui_layer_wms_id = $currentLayer->gui_layer_wms_id;
 //				$newLayer->gui_layer_wms_id = $wms->objLayer[0]->layer_uid;
 				$newLayer->gui_layer_status = $currentLayer->gui_layer_status;
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2014-09-08 15:34:59 UTC (rev 9062)
+++ trunk/mapbender/http/classes/class_wmc.php	2014-09-10 11:01:22 UTC (rev 9063)
@@ -1432,8 +1432,8 @@
 		// is currently parsed.
 		$extension = false;		$general = false;		$layerlist = false;
-		$layer = false;  		$formatlist = false;	$dataurl = false;
-		$metadataurl = false; 	$stylelist = false;
+		$layer = false;  		$formatlist = false;	$layer_dataurl = false;
+		$layer_metadataurl = false; 	$stylelist = false;
 		// reset WMC data
@@ -1659,6 +1659,8 @@
 					$currentLayer["format"] = array();
 					$currentLayer["style"] = array();
+					//$currentLayer["layer_metadataurl"] = array();
+					//$currentLayer["layer_dataurl"] = array();
 					$layer = true;
 				if ($layer) {
@@ -1688,20 +1690,20 @@
-					elseif ($metadataurl) {
+					elseif ($layer_metadataurl) {
 						if ($tag == "ONLINERESOURCE") {
-							$currentLayer["metadataurl"] = $attributes["xlink:href"];
+							$currentLayer["layer_metadataurl"] = $attributes["xlink:href"];
 						if ($tag == "METADATAURL" && $type == "close") {
-					elseif ($dataurl) {
+					elseif ($layer_dataurl) {
-							$currentLayer["dataurl"] = $attributes["xlink:href"];
+							$currentLayer["layer_dataurl"] = $attributes["xlink:href"];
 						if ($tag == "DATAURL" && $type == "close") {
-							$dataurl = false;
+							$layer_dataurl = false;
 					elseif ($stylelist) {
@@ -1811,10 +1813,10 @@
 							$extension = true;
 						if ($tag == "METADATAURL" && $type == "open") {
-							$metadataurl = true;
+							$layer_metadataurl = true;
 						if ($tag == "DATAURL" && $type == "open") {
-							$dataurl = true;
+							$layer_dataurl = true;
 						if ($tag == "FORMATLIST" && $type == "open") {
 							$formatlist = true;
Modified: trunk/mapbender/http/classes/class_wmcToXml.php
--- trunk/mapbender/http/classes/class_wmcToXml.php	2014-09-08 15:34:59 UTC (rev 9062)
+++ trunk/mapbender/http/classes/class_wmcToXml.php	2014-09-10 11:01:22 UTC (rev 9063)
@@ -313,14 +313,11 @@
 		// Data URL
 		if ($currentLayer->layer_dataurl[0]->href){
-			$e = new mb_exception("class_wmcToXml: dataurl given: ".$currentLayer->layer_dataurl[0]->href);
 			$e_layer_data_url = $this->doc->createElement("DataURL");
 			$e_layer_data_url_or = $this->doc->createElement("OnlineResource");
 			$e_layer_data_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
 			$e_layer_data_url_or->setAttribute("xlink:type", "simple");
 			$e_layer_data_url_or->setAttribute("xlink:href", $currentLayer->layer_dataurl[0]->href);
 			$e_layer_data_url->appendChild($e_layer_data_url_or);
 			$e_layer->appendChild($e_layer_data_url);
@@ -328,7 +325,6 @@
 		// Metadata URL
 		if ($currentLayer->layer_metadataurl[0]->href){
 			$e_layer_metadata_url = $this->doc->createElement("MetadataURL");
 			// Metadata URL online resource
 			$e_layer_metadata_url_or = $this->doc->createElement("OnlineResource");
 			$e_layer_metadata_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php	2014-09-08 15:34:59 UTC (rev 9062)
+++ trunk/mapbender/http/classes/class_wms.php	2014-09-10 11:01:22 UTC (rev 9063)
@@ -1375,13 +1375,23 @@
 		$newLayer->layer_name = $currentLayer["name"];
 		$newLayer->layer_title = $currentLayer["title"];
 		$newLayer->gui_layer_title = $currentLayer["title"];
-		$newLayer->layer_dataurl[0]->href = $currentLayer["dataurl"];
-		$newLayer->gui_layer_dataurl_href = $currentLayer["dataurl"];
+		//if layer is built from wmc, there will only be a string given for each dataurl/metadataurl
+		if (is_string($currentLayer["layer_dataurl"])) {
+			$newLayer->layer_dataurl[0]->href = $currentLayer["layer_dataurl"];
+		} else {
+			$newLayer->layer_dataurl = $currentLayer["layer_dataurl"];
+		if (is_string($currentLayer["layer_metadataurl"])) {
+			$newLayer->layer_metadataurl[0]->href = $currentLayer["layer_metadataurl"];
+		} else {
+			$newLayer->layer_metadataurl = $currentLayer["layer_metadataurl"];
+		//$newLayer->gui_layer_dataurl_href = $currentLayer["dataurl"];
 		$newLayer->layer_pos = $currentLayer["extension"]["LAYER_POS"];
 		$newLayer->layer_queryable = $currentLayer["queryable"];
 		$newLayer->layer_minscale = $currentLayer["extension"]["MINSCALE"];
 		$newLayer->layer_maxscale = $currentLayer["extension"]["MAXSCALE"];
-		$newLayer->layer_metadataurl[0]->href = $currentLayer["metadataurl"];
+//		$newLayer->layer_metadataurl[0]->href = $currentLayer["layer_metadataurl"];
 //		$newLayer->layer_searchable = $currentLayer["searchable"];
 		$newLayer->gui_layer_wms_id = $currentLayer["extension"]["WMS_ID"];
 		$newLayer->gui_layer_status = $currentLayer["extension"]["GUI_STATUS"];
@@ -1536,8 +1546,8 @@
 				$this->objLayer[$i]->layer_minscale . "','".
 				$this->objLayer[$i]->layer_maxscale ."','".
 				$this->objLayer[$i]->layer_metadataurl[0]->href ."','".
-// will be added later, not needed now TODO check if more than one metadataUrl is usefull here
-//				$this->objLayer[$i]->layer_searchable ."','".
+				// will be added later, not needed now TODO check if more than one metadataUrl is usefull here
+				// $this->objLayer[$i]->layer_searchable ."','".
 				$this->objLayer[$i]->gui_layer_wms_id ."','".
 				$this->objLayer[$i]->gui_layer_status ."','".
 				$this->objLayer[$i]->gui_layer_style ."','".
@@ -3314,7 +3324,7 @@
 			$layer_id = $row["fkey_layer_id"];
-			$sql = "Select * from layer where layer_id = $1";
+			$sql = "SELECT *, f_get_download_options_for_layer(layer_id) as downloadoptions FROM layer WHERE layer_id = $1";
 			$v = array($layer_id);
 			$t = array('i');
 			$res_layer = db_prep_query($sql,$v,$t);
@@ -3325,10 +3335,8 @@
 				$this->objLayer[$layer_cnt]->layer_uid = $layer_id;
 				$this->objLayer[$layer_cnt]->layer_name = administration::convertIncomingString($row2["layer_name"]);
 				$this->objLayer[$layer_cnt]->layer_title = administration::convertIncomingString($row2["layer_title"]);
-				//$this->objLayer[$layer_cnt]->layer_dataurl[0]->href =$row2["layer_dataurl"];
 				//load all dataUrl elements from datalink!
 				$sql = "SELECT datalink_id, datalink_url, datalink_format FROM datalink INNER JOIN (SELECT * from ows_relation_data WHERE fkey_layer_id = $1) as relation ON  datalink.datalink_id = relation.fkey_datalink_id AND datalink.datalink_origin = 'capabilities'";
-				$e = new mb_exception(" layer_id=".$layer_id);
 				$t = array('i');
 				$res_dataUrl = db_prep_query($sql,$v,$t);
@@ -3339,9 +3347,16 @@
 					$this->objLayer[$layer_cnt]->layer_dataurl[$count_dataUrl]->format = $row3["datalink_format"];
 					$count_dataUrl++;
-				//asign first dataurl to gui_layer_dataurl_href
-				$this->objLayer[$layer_cnt]->gui_layer_dataurl_href = $this->objLayer[$layer_cnt]->layer_dataurl[0]->href;
+				//exchange layer_dataurl[0]->href with downloadoptions for inspire if defined in mapbender.conf
+				if (defined("SHOW_INSPIRE_DOWNLOAD_IN_TREE") && SHOW_INSPIRE_DOWNLOAD_IN_TREE == true && $row2["downloadoptions"] != "") {
+					//delete {} from downloadoptions and add url
+					if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != "") {
+						$downloadOptionsUrl = MAPBENDER_PATH."/php/mod_getDownloadOptions.php?outputFormat=html&id=".str_replace('{','',str_replace('}','',$row2["downloadoptions"]));
+					} else {
+						$downloadOptionsUrl = "../php/mod_getDownloadOptions.php?outputFormat=html&id=".str_replace('{','',str_replace('}','',$row2["downloadoptions"]));
+					$this->objLayer[$layer_cnt]->layer_dataurl[0]->href = $downloadOptionsUrl;
 				//load all metadataUrl elements from mb_metadata
 				$sql = "SELECT metadata_id, link, linktype, md_format FROM mb_metadata INNER JOIN (SELECT * from ows_relation_metadata WHERE fkey_layer_id = $1) as relation ON  mb_metadata.metadata_id = relation.fkey_metadata_id AND mb_metadata.origin = 'capabilities'";
@@ -3523,7 +3538,7 @@
-		$sql = "Select * from layer where fkey_wms_id = $1 ORDER BY layer_pos";
+		$sql = "SELECT *, f_get_download_options_for_layer(layer_id) as downloadoptions from layer where fkey_wms_id = $1 ORDER BY layer_pos";
 		$v = array($wms_id);
 		$t = array('i');
@@ -3536,8 +3551,6 @@
 			$this->objLayer[$layer_cnt]->layer_abstract = administration::convertIncomingString($row2["layer_abstract"]);
 			$this->objLayer[$layer_cnt]->gui_layer_title = $this->objLayer[$layer_cnt]->layer_title;
 			$e = new mb_notice("class_wms: layer_id: ".$layer_id);
@@ -3545,17 +3558,23 @@
 			$t = array('i');
 			$count_dataUrl = 0;
 			while($row3 = db_fetch_array($res_dataUrl)){
 				$this->objLayer[$layer_cnt]->layer_dataurl[$count_dataUrl]->href = $row3["datalink_url"];
 				//$this->objLayer[$layer_cnt]->layer_dataurl[$count_dataUrl]->type = $row3["linktype"];
 				$count_dataUrl++;
-			//asign first dataurl to gui_layer_dataurl_href to use it in layertree
+				} else {
 			$e = new mb_notice("class_wms.php: # of found dataurls in db: ".$count_dataUrl);
@@ -3567,11 +3586,8 @@
 				$this->objLayer[$layer_cnt]->layer_metadataurl[$count_metadataUrl]->href = $row4["link"];
 				$this->objLayer[$layer_cnt]->layer_metadataurl[$count_metadataUrl]->type = $row4["linktype"];
 				$this->objLayer[$layer_cnt]->layer_metadataurl[$count_metadataUrl]->format = $row4["md_format"];
 				$count_metadataUrl++;
-			//old one:
-			//$this->objLayer[$layer_cnt]->layer_metadataurl[0]->href = $row2["layer_metadataurl"];
 			$this->objLayer[$layer_cnt]->layer_searchable =$row2["layer_searchable"];
 			$this->objLayer[$layer_cnt]->inspire_download =$row2["inspire_download"];
 			$this->objLayer[$layer_cnt]->layer_pos =$row2["layer_pos"];
@@ -3809,9 +3825,9 @@
 	var $layer_queryable;
 	var $layer_minscale;
 	var $layer_maxscale;
-	var $layer_dataurl;
-    	var $layer_dataurl_href;
-    	var $layer_metadataurl;
+	var $layer_dataurl = array();
+    	//var $layer_dataurl_href;
+    	var $layer_metadataurl = array();
 	var $layer_searchable;
 	var $inspire_download;
     	var $layer_keyword = array();
@@ -3829,7 +3845,7 @@
 	var $gui_layer_queryable = 0;
 	var $gui_layer_querylayer = 0;
 	var $gui_layer_style = NULL;
-	var $gui_layer_dataurl_href;
+	//var $gui_layer_dataurl_href;
 	function layer($id,$parent){
 		$this->layer_id = $id;
More information about the Mapbender_commits mailing list
