[Mapbender-commits] r9073 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Sep 12 03:19:29 PDT 2014
Author: armin11
Date: 2014-09-12 03:19:29 -0700 (Fri, 12 Sep 2014)
New Revision: 9073
   trunk/mapbender/http/classes/class_wmc.php
Alter updateUrlsInDb for WMC to add DataURL element after Abstract or Title tag as demanded in WMC 1.1.0 spec - via change from SimpleXML to DOM ;-)
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2014-09-11 11:46:56 UTC (rev 9072)
+++ trunk/mapbender/http/classes/class_wmc.php	2014-09-12 10:19:29 UTC (rev 9073)
@@ -604,7 +604,7 @@
 		while($row = db_fetch_array($res)){
 			$wmsId = $row["fkey_wms_id"];
 			$layerId = $row["layer_id"];
-			$e = new mb_exception("class_wmc.php - updateUrlsInDb - following layer will be processed: ".$layerId);
+			$e = new mb_notice("class_wmc.php - updateUrlsInDb - following layer will be processed: ".$layerId);
 			$layerName = $row["layer_name"];
 			//xpath to pull a special wmc layer object from simple xml object
 			$queryPath = "/wmc:ViewContext/wmc:LayerList/wmc:Layer[wmc:Extension/mapbender:layer_id='".(integer)$layerId."']";
@@ -649,7 +649,7 @@
 					} else {
 						//create dataurl and fill it - maybe with dom?
-						$e = new mb_exception("class_wmc.php - updateUrlsInDb - create new DataURL Element!");
+						$e = new mb_notice("class_wmc.php - updateUrlsInDb - create new DataURL Element!");
 						//$layerXML = $layer->asXML();
 						//$dom_layer = dom_import_string($layerXML);
@@ -679,10 +679,32 @@
 							</xs:sequence>
-						$DataURL = $layer->addChild('DataURL');
-						$OnlineResource = $DataURL->addChild('OnlineResource');
-						$DataURL->OnlineResource->addAttribute('xlink:type', 'simple','http://www.w3.org/1999/xlink');
-						$DataURL->OnlineResource->addAttribute('xlink:href', $downloadOptionsUrl,'http://www.w3.org/1999/xlink');
+						//check if Abstract exists - if it does DataURL came after Abstract, if not DataURL will be after Title Element
+						if (count($layer->Abstract) > 0) {
+							$e = new mb_notice("class_wmc.php - updateUrlsInDb - Abstract found!");
+							//put it after Abstract Element
+							//New element to be inserted
+							$insert = new SimpleXMLElement('<DataURL></DataURL>');
+							//<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="'.$downloadOptionsUrl.'"/>
+							// Get the Abstract element for this layer
+							$target = current($WMCDoc->xpath("/wmc:ViewContext/wmc:LayerList/wmc:Layer[wmc:Extension/mapbender:layer_id='".(integer)$layerId."']/wmc:Abstract"));
+							// Insert the new element after the last nodeA
+							$this->simplexml_insert_after($insert, $target);
+							$layer->DataURL->addChild('OnlineResource');
+							$layer->DataURL->OnlineResource->addAttribute('xlink:type', 'simple','http://www.w3.org/1999/xlink');
+							$layer->DataURL->OnlineResource->addAttribute('xlink:href', $downloadOptionsUrl,'http://www.w3.org/1999/xlink');
+						} else {
+							//put it after Title Element
+							$insert = new SimpleXMLElement("<DataURL></DataURL>");
+							//<OnlineResource xlink:type='simple' xlink:href='".$downloadOptionsUrl."'/>
+							$target = current($WMCDoc->xpath("/wmc:ViewContext/wmc:LayerList/wmc:Layer[wmc:Extension/mapbender:layer_id='".(integer)$layerId."']/wmc:Title"));
 						$e = new mb_notice("class_wmc.php - updateUrlsInDb new DataURL XML : ".$layer->asXML());
@@ -1236,6 +1258,17 @@
+	//http://stackoverflow.com/questions/3361036/php-simplexml-insert-node-at-certain-position
+	private function simplexml_insert_after(SimpleXMLElement $insert, SimpleXMLElement $target) {
+    		$target_dom = dom_import_simplexml($target);
+    		$insert_dom = $target_dom->ownerDocument->importNode(dom_import_simplexml($insert), true);
+    		if ($target_dom->nextSibling) {
+        		return $target_dom->parentNode->insertBefore($insert_dom, $target_dom->nextSibling);
+    		} else {
+        		return $target_dom->parentNode->appendChild($insert_dom);
 	public function extentToJavaScript() {
 		return $this->mainMap->extentToJavaScript();
More information about the Mapbender_commits mailing list
