[Mapbender-commits] r9082 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Sep 22 08:19:12 PDT 2014
Author: armin11
Date: 2014-09-22 08:19:12 -0700 (Mon, 22 Sep 2014)
New Revision: 9082
trunk/mapbender/http/javascripts/mb_downloadFeedClient.php
some optical enhancements
Modified: trunk/mapbender/http/javascripts/mb_downloadFeedClient.php
--- trunk/mapbender/http/javascripts/mb_downloadFeedClient.php 2014-09-22 10:27:59 UTC (rev 9081)
+++ trunk/mapbender/http/javascripts/mb_downloadFeedClient.php 2014-09-22 15:19:12 UTC (rev 9082)
@@ -135,6 +135,7 @@
//don't show elements of dataset feed
$("#representation_select").css("display","none");
$("#representation_info").css("display","none");
+ $("#capabilities_hybrid").css("display","none");
//change size of outer fieldset
$("#client").css("height","450px");
$("#download_link_list").remove();
@@ -171,8 +172,10 @@
identifierAnchor.attr({'id':'capabilities_link'});
identifierAnchor.attr({'href':featureCollection.features[i].properties.capabilitiesLink});
identifierAnchor.text(featureCollection.features[i].properties.capabilitiesLink);
- //$('#capabilities_link').val(featureCollection.features[i].properties.capabilitiesLink);
+ //show hybrid link only if it is there
+ if (typeof featureCollection.features[i].properties.capabilitiesLink !== 'undefined' && featureCollection.features[i].properties.capabilitiesLink !== '' && featureCollection.features[i].properties.capabilitiesLink !== null) {
+ $("#capabilities_hybrid").css("display","block");
//add identifier anchor
identifierAnchor = $(document.createElement('a')).appendTo('#dataset_identifier');
identifierAnchor.attr({'id':'dataset_identifier_link'});
@@ -181,6 +184,7 @@
identifierAnchor.text(featureCollection.features[i].properties.namespace+"#"+featureCollection.features[i].properties.code);
selectOptions = selectOptions+"<option value='"+featureCollection.features[i].properties.datasetFeedLink+"' url='"+featureCollection.features[i].properties.datasetFeedLink+"' optionid='"+i+"'>"+featureCollection.features[i].properties.title+"</option>";
datasetSelect.append(selectOptions);
//preselect option
@@ -207,7 +211,6 @@
alert("No parseable content found");
return false;
- //alert("test");
//remove select element for the different possible representations (formats, crs, ...)
$('#dataset_representation_select').remove();
//generate new select element
More information about the Mapbender_commits
