[Mapbender-commits] r9139 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jan 8 00:40:35 PST 2015
Author: verenadiewald
Date: 2015-01-08 00:40:35 -0800 (Thu, 08 Jan 2015)
New Revision: 9139
   trunk/mapbender/http/plugins/mb_owsproxy_log_csv.php
enable two ways of filling the user select box in the form for owsproxy_csv
Modified: trunk/mapbender/http/plugins/mb_owsproxy_log_csv.php
--- trunk/mapbender/http/plugins/mb_owsproxy_log_csv.php	2015-01-06 15:37:29 UTC (rev 9138)
+++ trunk/mapbender/http/plugins/mb_owsproxy_log_csv.php	2015-01-08 08:40:35 UTC (rev 9139)
@@ -1,6 +1,7 @@
 <?php
 require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+require_once dirname(__FILE__) . "/../../conf/geoportal.conf";
 $LIMIT_INT = OWS_LOG_EXPORT_LIMIT;
@@ -28,20 +29,60 @@
 if($_REQUEST['action'] == "getForm"){
     $mb_user_id = $_SESSION['mb_user_id'];
-    $v = array($mb_user_id);
-    $t = array('i');
-    $users = array();
-    $wmses = array();
-    $sql = "SELECT DISTINCT u.mb_user_id, w.wms_id,w.wms_title,u.mb_user_name"
-            ." FROM mb_proxy_log AS m INNER JOIN wms AS w ON"
-            ." (m.fkey_wms_id = w.wms_id AND w.wms_owner=$1)"
-            ." INNER JOIN mb_user u ON(m.fkey_mb_user_id = u.mb_user_id)"
-	    ." ORDER BY u.mb_user_name ASC, u.mb_user_id ";
-    $result = db_prep_query($sql,$v,$t);
-    while($row = db_fetch_assoc($result)){
-        $users[$row['mb_user_id']] = $row['mb_user_name'];
-        $wmses[$row['wms_id']] = $row['wms_title'];
+    if (defined("SECURED_SERVICES_GUIS") && SECURED_SERVICES_GUIS !== "" ) {
+    	// SQL für WMS Services
+    	$v = array($mb_user_id);
+    	$t = array('i');
+    	$wmses = array();
+    	$sql = "SELECT DISTINCT w.wms_id,w.wms_title"
+    			." FROM mb_proxy_log AS m INNER JOIN wms AS w ON"
+    			." (m.fkey_wms_id = w.wms_id AND w.wms_owner=$1)"
+    			." ORDER BY w.wms_title ";
+    	$result = db_prep_query($sql,$v,$t);
+    	while($row = db_fetch_assoc($result)){
+    		#$users[$row['mb_user_id']] = $row['mb_user_name'];
+    		$wmses[$row['wms_id']] = $row['wms_title'];
+    	// SQL für User mit geschützten Diensten
+    	$securedServiceGuis = explode(",", SECURED_SERVICES_GUIS);
+    	$vUser = array();
+    	$tUser = array();
+    	$users = array();
+    	$sqlUser = "SELECT DISTINCT g.fkey_mb_user_id, u.mb_user_name FROM gui_mb_user g ".
+    			"LEFT JOIN mb_user u ON u.mb_user_id = g.fkey_mb_user_id ".
+    			"WHERE fkey_gui_id ";
+    	$inOffset = 1;
+    	foreach($securedServiceGuis as $gui) {
+    		$vUser[] = trim($gui);
+    		$tUser[] = "s";
+    		$inParams[] = "$".$inOffset;
+    		$inOffset++;
+    	$sqlUser .= "IN (" .implode(",",$inParams) .")";
+    	$sqlUser .= " ORDER BY u.mb_user_name ASC;";
+    	$resultUser = db_prep_query($sqlUser,$vUser,$tUser);
+    	while($rowUser = db_fetch_assoc($resultUser)){
+    		$users[$rowUser['fkey_mb_user_id']] = $rowUser['mb_user_name'];
+    else {
+    	$t = array('i');
+    	$users = array();
+    	$wmses = array();
+    	$sql = "SELECT DISTINCT u.mb_user_id, w.wms_id,w.wms_title,u.mb_user_name"
+    					." INNER JOIN mb_user u ON(m.fkey_mb_user_id = u.mb_user_id)"
+    							." ORDER BY u.mb_user_name ASC, u.mb_user_id ";
+    		$users[$row['mb_user_id']] = $row['mb_user_name'];
     $form = '<div class="form">
     <input name="serviceType" id="serviceType" value="wms" type="hidden" />
More information about the Mapbender_commits mailing list
