[Mapbender-commits] r9142 - trunk/mapbender/owsproxy/http
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jan 8 01:04:03 PST 2015
Author: armin11
Date: 2015-01-08 01:04:03 -0800 (Thu, 08 Jan 2015)
New Revision: 9142
   trunk/mapbender/owsproxy/http/index.php
Possibility to exclude urls from the owsproxy in case of featureinfo requests. Sometimes there are problems with redirects and headers, and not all urls should be replaced.
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php	2015-01-08 09:03:50 UTC (rev 9141)
+++ trunk/mapbender/owsproxy/http/index.php	2015-01-08 09:04:03 UTC (rev 9142)
@@ -24,6 +24,11 @@
 require_once(dirname(__FILE__) . "/../../http/classes/class_connector.php");
 require_once(dirname(__FILE__) . "/../../http/classes/class_mb_exception.php");
 require_once(dirname(__FILE__) . "/./classes/class_QueryHandler.php");
+$urlsToExclude = array();
+if (is_file(dirname(__FILE__) . "/../../conf/excludeproxyurls.conf"))
+    require_once(dirname(__FILE__) . "/../../conf/excludeproxyurls.conf");
 /* * *** conf **** */
 $imageformats = array("image/png", "image/gif", "image/jpeg", "image/jpg");
 $width = 400;
@@ -554,6 +559,7 @@
 function matchUrls($content)
+	global $urlsToExclude;
 	//check if isset owsproxyUrls else create
 	$owsproxyUrls = Mapbender::session()->get('owsproxyUrls');
 	if ($owsproxyUrls == false) {
@@ -568,7 +574,10 @@
     	for ($i = 0; $i < count($matches[1]); $i++) {
         	$req = $matches[1][$i];
         	$notice = new mb_notice("owsproxy found URL " . $i . ": " . $req);
-       	 	#$notice = new mb_exception("owsproxy id:".$req);
+		//only register and exchange urls, that should not be excluded!
+		if (in_array($req,$urlsToExclude)) {
+       	 		continue;
         	$id = registerURL($req);
         	$extReq = setExternalRequest($id);
         	$notice = new mb_notice("MD5 URL " . $id . " - external link: " . $extReq);
More information about the Mapbender_commits mailing list
