[Mapbender-commits] r9147 - in trunk/mapbender: http/classes http_auth/http
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jan 21 07:27:33 PST 2015
Author: verenadiewald
Date: 2015-01-21 07:27:33 -0800 (Wed, 21 Jan 2015)
New Revision: 9147
   trunk/mapbender/http/classes/class_administration.php
   trunk/mapbender/http_auth/http/index.php
some improvements for logging in http auth
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php	2015-01-13 09:13:13 UTC (rev 9146)
+++ trunk/mapbender/http/classes/class_administration.php	2015-01-21 15:27:33 UTC (rev 9147)
@@ -1182,8 +1182,9 @@
    	function logWmsProxyRequest($wms_id,$user_id,$getmap,$price){
-   		$sql = "INSERT INTO mb_proxy_log (fkey_wms_id,fkey_mb_user_id, request, pixel, price) VALUES ($1, $2, $3, $4,$5)";
-   		$t = array("i","i","s","i","r");
+   		$sql = "INSERT INTO mb_proxy_log (fkey_wms_id,fkey_mb_user_id, request, pixel, price, got_result)"
+            ." VALUES ($1, $2, $3, $4, $5, $6)";
+   		$t = array("i","i","s","i","r", "i");
 		#extract height and width
 		#use regexpr
 		$pattern_height = '~HEIGHT=(\d+)&~i';
@@ -1193,8 +1194,8 @@
 		$width=intval($sub_width[1]);
 		$height=intval($sub_height[1]);
 		$pixel=intval($width*$height);
-		$price=$pixel*$price/1000000;
-		$v = array(intval($wms_id),intval($user_id),$getmap,$pixel,$price);
+		$pricePx=$pixel*$price/1000000;
+		$v = array(intval($wms_id),intval($user_id),$getmap,$pixel,$pricePx, 0);
    	        #echo print_r($v,true)."<br>";
 		#var_dump($v);
 		#echo $sql."<br>";
@@ -1216,11 +1217,11 @@
-    function logFullWmsProxyRequest($wms_id,$user_id,$getmap,$price){
+    function logFullWmsProxyRequest($wms_id,$user_id,$getmap,$price,$got_result,$set0Pixels=false){
    		$sql = "INSERT INTO mb_proxy_log "
-            ."(fkey_wms_id,fkey_mb_user_id, request, pixel, price, layer_featuretype_list, request_type) "
-            ."VALUES ($1, $2, $3, $4, $5, $6, 'getMap')";
-   		$t = array("i","i","s","i","r","s");
+            ."(fkey_wms_id,fkey_mb_user_id, request, pixel, price, layer_featuretype_list, request_type, got_result) "
+            ."VALUES ($1, $2, $3, $4, $5, $6, 'getMap', $7)";
+   		$t = array("i","i","s","i","r","s","i");
 		#use regexpr
@@ -1232,9 +1233,9 @@
         $layers = explode("=", $sub_layers[0]);
-		$pixel=intval($width*$height);
-		$v = array(intval($wms_id),intval($user_id),$getmap,$pixel,$price,isset($layers[1]) ? urldecode($layers[1]) : '');
+		$pixel= $got_result === -1 ? 0 : ($set0Pixels ? 0 : intval($width*$height));
+		$v = array(intval($wms_id),intval($user_id),$getmap,$pixel,$pricePx,isset($layers[1]) ? urldecode($layers[1]) : '',$got_result);
 		#var_dump($v);
 		#echo $sql."<br>";
@@ -1260,8 +1261,8 @@
     function updateWmsLog($got_result, $error_message, $error_mime_type, $log_id){
-        $sql = "UPDATE mb_proxy_log SET got_result=$1"
-            .",error_message=$2,error_mime_type=$3  WHERE log_id=$4";
+        $sql = "UPDATE mb_proxy_log SET got_result=$1,error_message=$2,error_mime_type=$3"
+            . ($got_result === -1 ? ',pixel=0' : '') ." WHERE log_id=$4";
         $t = array("i","s","s","i");
         $v = array($got_result, $error_message, $error_mime_type, $log_id);
         $res = db_prep_query($sql,$v,$t) or die(db_error());
Modified: trunk/mapbender/http_auth/http/index.php
--- trunk/mapbender/http_auth/http/index.php	2015-01-13 09:13:13 UTC (rev 9146)
+++ trunk/mapbender/http_auth/http/index.php	2015-01-21 15:27:33 UTC (rev 9147)
@@ -143,10 +143,20 @@
             throwE("GetFeatureInfo permission denied on layer with id" . $layerId);
             die();
+	//Ergaenzungen secured UMN Requests
+        $log_id = false;
+        if ($n->getWmsfiLogTag($arrayOnlineresources['wms_id']) == 1) {
+            #do log to db
+            #get price out of db
+            $price = intval($n->getWmsfiPrice($arrayOnlineresources['wms_id']));
+            $log_id = $n->logWmsGFIProxyRequest($arrayOnlineresources['wms_id'], $_SESSION['mb_user_id'], $request,
+                $price);
         if (isset($auth)) {
-            getFeatureInfo($request, $auth);
+            getFeatureInfo($log_id, $request, $auth);
         } else {
-            getFeatureInfo($request);
+            getFeatureInfo($log_id, $request);
         break;
     case 'getmap':
@@ -159,18 +169,20 @@
         $query->setParam("layers", urldecode($layers));
         $request = $query->getRequest();
+        // Ergaenzungen secured UMN Requests
         #log proxy requests
+        $log_id = false;
         if ($n->getWmsLogTag($wmsId) == 1) {
             #do log to db
             #TODO read out size of bbox and calculate price
             $price = intval($n->getWmsPrice($wmsId));
-            $n->logWmsProxyRequest($wmsId, $userInformation[0], $request, $price);
+            $log_id = $n->logFullWmsProxyRequest($arrayOnlineresources['wms_id'], $userInformation[0], $request, $price, 0);
         if (isset($auth)) {
-            getImage($request, $auth);
+            getImageII($log_id, $request, $auth);
         } else {
-            getImage($request);
+            getImageII($log_id, $request);
         break;
     case 'getlegendgraphic':
@@ -349,21 +361,43 @@
+ * fetch and returns an image to client
+ * @param string the original url of the image to send
+function getImageII($log_id, $or)
+    global $reqParams;
+    $header = "Content-Type: " . $reqParams['format'];
+    #log the image_requests to database
+    #log the following to table mb_proxy_log
+    #timestamp,user_id,getmaprequest,amount pixel,price - but do this only for wms to log - therefor first get log tag out of wms!
+	if (func_num_args() == 3) { //new for HTTP Authentication
+        $auth = func_get_arg(2);
+        getDocumentContentII($log_id, $or, $header, $auth);
+    } else {
+        getDocumentContentII($log_id, $or, $header);
  * fetchs and returns the content of the FeatureInfo Response
  * @param string the url of the FeatureInfoRequest
  * @return string the content of the FeatureInfo document
-function getFeatureInfo($url)
+function getFeatureInfo($log_id, $url)
     global $reqParams;
     $e = new mb_notice("owsproxy: Try to fetch FeatureInfoRequest: " . $url);
     header("Content-Type: " . $reqParams['info_format']);
-    if (func_num_args() == 2) { //new for HTTP Authentication
-        $auth = func_get_arg(1);
-        echo getDocumentContent($url, $auth);
+        getDocumentContent($log_id, $url, false, $auth);
     } else {
-        echo getDocumentContent($url);
+        getDocumentContent($log_id, $url);
@@ -647,15 +681,75 @@
     return $ret;
-function getDocumentContent($url)
+function getDocumentContent($log_id, $url, $header = false)
+    global $reqParams, $n;
+    if (func_num_args() == 4) { //new for HTTP Authentication
+        $auth = func_get_arg(3);
         $d = new connector($url, $auth);
     } else {
         $d = new connector($url);
-    return $d->file;
+    $content = $d->file;
+    if (strtoupper($reqParams["request"]) == "GETMAP") { // getmap
+        $pattern_exc = '~EXCEPTION~i';
+        preg_match($pattern_exc, $content, $exception);
+        if (!$content) {
+            if ($log_id != null && is_integer($log_id)) {
+                $n->updateWmsLog(0, "Mb2OWSPROXY - unable to load: " . $url, "text/plain", $log_id);
+            header("Content-Type: text/plain");
+            echo "Mb2OWSPROXY - unable to load: " . $url;
+        } else if (count($exception) > 0) {
+                $n->updateWmsLog(0, $content, $reqParams["exceptions"], $log_id);
+            header("Content-Type: " . $reqParams["exceptions"]);
+            echo $content;
+        } else {
+            $source = new Imagick();
+            $source->readImageBlob($content);
+            $numColors = $source->getImageColors();
+                $n->updateWmsLog($numColors <= 1 ? -1 : 1, null, null, $log_id);
+            header("Content-Type: " . $reqParams['format']);
+            echo $content;
+        return true;
+    } else if (strtoupper($reqParams["request"]) == "GETFEATUREINFO") { // getmap
+//		header("Content-Type: ".$reqParams['info_format']);
+//		$content = matchUrls($content);
+//		echo $content;
+        if (!$content) {
+            if ($log_id != null) {
+                $n->updateWmsFiLog("Mb2OWSPROXY - unable to load: " . $url, "text/plain", $log_id);
+                $n->updateWmsFiLog($content, "application/xml", $log_id);
+            header("Content-Type: application/xml");
+            echo $content;
+        } else {
+            header("Content-Type: " . $reqParams['info_format']);
+                $n->updateWmsFiLog(null, null, $log_id);
+            $content = matchUrls($content);
+            echo $content;
+        return true;
+    } else {
+	if (header !== false) {
+		header($header);
+        echo $content;
@@ -680,4 +774,75 @@
         return false;
+function getDocumentContentII($log_id, $url, $header = false)
+        $d = new connector($url, $auth);
+    } else {
+        $d = new connector($url);
+        if (!$content) {
+            echo $content;
+        } else {
+            echo $content;
+        return true;
+//		echo $content;
+        if (!$content) {
+            echo $content;
+        } else {
+            echo $content;
+        return true;
+    } else {
+            header($header);
+        echo $content;
More information about the Mapbender_commits mailing list
