[Mapbender-commits] r9237 - trunk/mapbender/http/extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 3 07:11:06 PDT 2015
Author: syed
Date: 2015-07-03 07:11:06 -0700 (Fri, 03 Jul 2015)
New Revision: 9237
   trunk/mapbender/http/extensions/spectrum-min.js
add new version of spectrum.js
Modified: trunk/mapbender/http/extensions/spectrum-min.js
--- trunk/mapbender/http/extensions/spectrum-min.js	2015-07-03 13:43:46 UTC (rev 9236)
+++ trunk/mapbender/http/extensions/spectrum-min.js	2015-07-03 14:11:06 UTC (rev 9237)
@@ -1,953 +1,345 @@
-// Spectrum Colorpicker v1.7.0
-// https://github.com/bgrins/spectrum
-// Author: Brian Grinstead
-// License: MIT
-(function (factory) {
-    "use strict";
-    if (typeof define === 'function' && define.amd) { // AMD
-        define(['jquery'], factory);
-    else if (typeof exports == "object" && typeof module == "object") { // CommonJS
-        module.exports = factory;
-    else { // Browser
-        factory(jQuery);
-})(function($, undefined) {
-    "use strict";
-    var defaultOpts = {
-        // Callbacks
-        beforeShow: noop,
-        move: noop,
-        change: noop,
-        show: noop,
-        hide: noop,
-        // Options
-        color: false,
-        flat: false,
-        showInput: false,
-        allowEmpty: false,
-        showButtons: true,
-        clickoutFiresChange: true,
-        showInitial: false,
-        showPalette: false,
-        showPaletteOnly: false,
-        hideAfterPaletteSelect: false,
-        togglePaletteOnly: false,
-        showSelectionPalette: true,
-        localStorageKey: false,
-        appendTo: "body",
-        maxSelectionSize: 7,
-        cancelText: "cancel",
-        chooseText: "choose",
-        togglePaletteMoreText: "more",
-        togglePaletteLessText: "less",
-        clearText: "Clear Color Selection",
-        noColorSelectedText: "No Color Selected",
-        preferredFormat: false,
-        className: "", // Deprecated - use containerClassName and replacerClassName instead.
-        containerClassName: "",
-        replacerClassName: "",
-        showAlpha: false,
-        theme: "sp-light",
-        palette: [["#ffffff", "#000000", "#ff0000", "#ff8000", "#ffff00", "#008000", "#0000ff", "#4b0082", "#9400d3"]],
-        selectionPalette: [],
-        disabled: false,
-        offset: null
-    spectrums = [],
-    IE = !!/msie/i.exec( window.navigator.userAgent ),
-    rgbaSupport = (function() {
-        function contains( str, substr ) {
-            return !!~('' + str).indexOf(substr);
-        var elem = document.createElement('div');
-        var style = elem.style;
-        style.cssText = 'background-color:rgba(0,0,0,.5)';
-        return contains(style.backgroundColor, 'rgba') || contains(style.backgroundColor, 'hsla');
-    replaceInput = [
-        "<div class='sp-replacer'>",
-            "<div class='sp-preview'><div class='sp-preview-inner'></div></div>",
-            "<div class='sp-dd'>▼</div>",
-        "</div>"
-    ].join(''),
-    markup = (function () {
-        // IE does not support gradients with multiple stops, so we need to simulate
-        //  that for the rainbow slider with 8 divs that each have a single gradient
-        var gradientFix = "";
-        if (IE) {
-            for (var i = 1; i <= 6; i++) {
-                gradientFix += "<div class='sp-" + i + "'></div>";
-        return [
-            "<div class='sp-container sp-hidden'>",
-                "<div class='sp-palette-container'>",
-                    "<div class='sp-palette sp-thumb sp-cf'></div>",
-                    "<div class='sp-palette-button-container sp-cf'>",
-                        "<button type='button' class='sp-palette-toggle'></button>",
-                    "</div>",
-                "</div>",
-                "<div class='sp-picker-container'>",
-                    "<div class='sp-top sp-cf'>",
-                        "<div class='sp-fill'></div>",
-                        "<div class='sp-top-inner'>",
-                            "<div class='sp-color'>",
-                                "<div class='sp-sat'>",
-                                    "<div class='sp-val'>",
-                                        "<div class='sp-dragger'></div>",
-                                    "</div>",
-                                "</div>",
-                            "</div>",
-                            "<div class='sp-clear sp-clear-display'>",
-                            "</div>",
-                            "<div class='sp-hue'>",
-                                "<div class='sp-slider'></div>",
-                                gradientFix,
-                            "</div>",
-                        "</div>",
-                        "<div class='sp-alpha'><div class='sp-alpha-inner'><div class='sp-alpha-handle'></div></div></div>",
-                    "</div>",
-                    "<div class='sp-input-container sp-cf'>",
-                        "<input class='sp-input' type='text' spellcheck='false'  />",
-                    "</div>",
-                    "<div class='sp-initial sp-thumb sp-cf'></div>",
-                    "<div class='sp-button-container sp-cf'>",
-                        "<a class='sp-cancel' href='#'></a>",
-                        "<button type='button' class='sp-choose'></button>",
-                    "</div>",
-                "</div>",
-            "</div>"
-        ].join("");
-    function paletteTemplate (p, color, className, opts) {
-        var html = [];
-        for (var i = 0; i < p.length; i++) {
+! function(window, $, undefined) {
+    function paletteTemplate(p, color, className, tooltipFormat) {
+        for (var html = [], i = 0; i < p.length; i++) {
             var current = p[i];
-            if(current) {
-                var tiny = tinycolor(current);
-                var c = tiny.toHsl().l < 0.5 ? "sp-thumb-el sp-thumb-dark" : "sp-thumb-el sp-thumb-light";
-                c += (tinycolor.equals(color, current)) ? " sp-thumb-active" : "";
-                var formattedString = tiny.toString(opts.preferredFormat || "rgb");
-                var swatchStyle = rgbaSupport ? ("background-color:" + tiny.toRgbString()) : "filter:" + tiny.toFilter();
-                html.push('<span title="' + formattedString + '" data-color="' + tiny.toRgbString() + '" class="' + c + '"><span class="sp-thumb-inner" style="' + swatchStyle + ';" /></span>');
+            if (current) {
+                var tiny = tinycolor(current),
+                    c = tiny.toHsl().l < .5 ? "sp-thumb-el sp-thumb-dark" : "sp-thumb-el sp-thumb-light";
+                c += tinycolor.equals(color, current) ? " sp-thumb-active" : "";
+                var formattedString = tiny.toString(tooltipFormat || "rgb"),
+                    swatchStyle = rgbaSupport ? "background-color:" + tiny.toRgbString() : "filter:" + tiny.toFilter();
+                html.push('<span title="' + formattedString + '" data-color="' + tiny.toRgbString() + '" class="' + c + '"><span class="sp-thumb-inner" style="' + swatchStyle + ';" /></span>')
             } else {
-                var cls = 'sp-clear-display';
-                html.push($('<div />')
-                    .append($('<span data-color="" style="background-color:transparent;" class="' + cls + '"></span>')
-                        .attr('title', opts.noColorSelectedText)
-                    .html()
+                var cls = "sp-clear-display";
+                html.push('<span title="No Color Selected" data-color="" style="background-color:transparent;" class="' + cls + '"></span>')
-        return "<div class='sp-cf " + className + "'>" + html.join('') + "</div>";
+        return "<div class='sp-cf " + className + "'>" + html.join("") + "</div>"
     function hideAll() {
-        for (var i = 0; i < spectrums.length; i++) {
-            if (spectrums[i]) {
-                spectrums[i].hide();
+        for (var i = 0; i < spectrums.length; i++) spectrums[i] && spectrums[i].hide()
     function instanceOptions(o, callbackContext) {
         var opts = $.extend({}, defaultOpts, o);
-        opts.callbacks = {
-            'move': bind(opts.move, callbackContext),
-            'change': bind(opts.change, callbackContext),
-            'show': bind(opts.show, callbackContext),
-            'hide': bind(opts.hide, callbackContext),
-            'beforeShow': bind(opts.beforeShow, callbackContext)
-        return opts;
+        return opts.callbacks = {
+            move: bind(opts.move, callbackContext),
+            change: bind(opts.change, callbackContext),
+            show: bind(opts.show, callbackContext),
+            hide: bind(opts.hide, callbackContext),
+            beforeShow: bind(opts.beforeShow, callbackContext)
+        }, opts
     function spectrum(element, o) {
-        var opts = instanceOptions(o, element),
-            flat = opts.flat,
-            showSelectionPalette = opts.showSelectionPalette,
-            localStorageKey = opts.localStorageKey,
-            theme = opts.theme,
-            callbacks = opts.callbacks,
-            resize = throttle(reflow, 10),
-            visible = false,
-            isDragging = false,
-            dragWidth = 0,
-            dragHeight = 0,
-            dragHelperHeight = 0,
-            slideHeight = 0,
-            slideWidth = 0,
-            alphaWidth = 0,
-            alphaSlideHelperWidth = 0,
-            slideHelperHeight = 0,
-            currentHue = 0,
-            currentSaturation = 0,
-            currentValue = 0,
-            currentAlpha = 1,
-            palette = [],
-            paletteArray = [],
-            paletteLookup = {},
-            selectionPalette = opts.selectionPalette.slice(0),
-            maxSelectionSize = opts.maxSelectionSize,
-            draggingClass = "sp-dragging",
-            shiftMovementDirection = null;
-        var doc = element.ownerDocument,
-            body = doc.body,
-            boundElement = $(element),
-            disabled = false,
-            container = $(markup, doc).addClass(theme),
-            pickerContainer = container.find(".sp-picker-container"),
-            dragger = container.find(".sp-color"),
-            dragHelper = container.find(".sp-dragger"),
-            slider = container.find(".sp-hue"),
-            slideHelper = container.find(".sp-slider"),
-            alphaSliderInner = container.find(".sp-alpha-inner"),
-            alphaSlider = container.find(".sp-alpha"),
-            alphaSlideHelper = container.find(".sp-alpha-handle"),
-            textInput = container.find(".sp-input"),
-            paletteContainer = container.find(".sp-palette"),
-            initialColorContainer = container.find(".sp-initial"),
-            cancelButton = container.find(".sp-cancel"),
-            clearButton = container.find(".sp-clear"),
-            chooseButton = container.find(".sp-choose"),
-            toggleButton = container.find(".sp-palette-toggle"),
-            isInput = boundElement.is("input"),
-            isInputTypeColor = isInput && boundElement.attr("type") === "color" && inputTypeColorSupport(),
-            shouldReplace = isInput && !flat,
-            replacer = (shouldReplace) ? $(replaceInput).addClass(theme).addClass(opts.className).addClass(opts.replacerClassName) : $([]),
-            offsetElement = (shouldReplace) ? replacer : boundElement,
-            previewElement = replacer.find(".sp-preview-inner"),
-            initialColor = opts.color || (isInput && boundElement.val()),
-            colorOnShow = false,
-            preferredFormat = opts.preferredFormat,
-            currentPreferredFormat = preferredFormat,
-            clickoutFiresChange = !opts.showButtons || opts.clickoutFiresChange,
-            isEmpty = !initialColor,
-            allowEmpty = opts.allowEmpty && !isInputTypeColor;
         function applyOptions() {
-            if (opts.showPaletteOnly) {
-                opts.showPalette = true;
-            toggleButton.text(opts.showPaletteOnly ? opts.togglePaletteMoreText : opts.togglePaletteLessText);
-            if (opts.palette) {
-                palette = opts.palette.slice(0);
-                paletteArray = $.isArray(palette[0]) ? palette : [palette];
-                paletteLookup = {};
-                for (var i = 0; i < paletteArray.length; i++) {
+            if (opts.showPaletteOnly && (opts.showPalette = !0), opts.palette) {
+                palette = opts.palette.slice(0), paletteArray = $.isArray(palette[0]) ? palette : [palette], paletteLookup = {};
+                for (var i = 0; i < paletteArray.length; i++)
                     for (var j = 0; j < paletteArray[i].length; j++) {
                         var rgb = tinycolor(paletteArray[i][j]).toRgbString();
-                        paletteLookup[rgb] = true;
+                        paletteLookup[rgb] = !0
-            container.toggleClass("sp-flat", flat);
-            container.toggleClass("sp-input-disabled", !opts.showInput);
-            container.toggleClass("sp-alpha-enabled", opts.showAlpha);
-            container.toggleClass("sp-clear-enabled", allowEmpty);
-            container.toggleClass("sp-buttons-disabled", !opts.showButtons);
-            container.toggleClass("sp-palette-buttons-disabled", !opts.togglePaletteOnly);
-            container.toggleClass("sp-palette-disabled", !opts.showPalette);
-            container.toggleClass("sp-palette-only", opts.showPaletteOnly);
-            container.toggleClass("sp-initial-disabled", !opts.showInitial);
-            container.addClass(opts.className).addClass(opts.containerClassName);
-            reflow();
+            container.toggleClass("sp-flat", flat), container.toggleClass("sp-input-disabled", !opts.showInput), container.toggleClass("sp-alpha-enabled", opts.showAlpha), container.toggleClass("sp-clear-enabled", allowEmpty), container.toggleClass("sp-buttons-disabled", !opts.showButtons), container.toggleClass("sp-palette-disabled", !opts.showPalette), container.toggleClass("sp-palette-only", opts.showPaletteOnly), container.toggleClass("sp-initial-disabled", !opts.showInitial), container.addClass(opts.className).addClass(opts.containerClassName), reflow()
         function initialize() {
-            if (IE) {
-                container.find("*:not(input)").attr("unselectable", "on");
+            function palletElementClick(e) {
+                return e.data && e.data.ignore ? (set($(this).attr("data-color")), move()) : (set($(this).attr("data-color")), move(), updateOriginalInput(!0), hide()), !1
-            applyOptions();
-            if (shouldReplace) {
-                boundElement.after(replacer).hide();
-            if (!allowEmpty) {
-                clearButton.hide();
-            if (flat) {
-                boundElement.after(container).hide();
+            if (IE && container.find("*:not(input)").attr("unselectable", "on"), applyOptions(), shouldReplace && boundElement.after(replacer).hide(), allowEmpty || clearButton.hide(), flat) boundElement.after(container).hide();
             else {
-                var appendTo = opts.appendTo === "parent" ? boundElement.parent() : $(opts.appendTo);
-                if (appendTo.length !== 1) {
-                    appendTo = $("body");
-                appendTo.append(container);
+                var appendTo = "parent" === opts.appendTo ? boundElement.parent() : $(opts.appendTo);
+                1 !== appendTo.length && (appendTo = $("body")), appendTo.append(container)
-            updateSelectionPaletteFromStorage();
-            offsetElement.bind("click.spectrum touchstart.spectrum", function (e) {
-                if (!disabled) {
-                    toggle();
-                e.stopPropagation();
-                if (!$(e.target).is("input")) {
-                    e.preventDefault();
-            if(boundElement.is(":disabled") || (opts.disabled === true)) {
-                disable();
-            // Prevent clicks from bubbling up to document.  This would cause it to be hidden.
-            container.click(stopPropagation);
-            // Handle user typed input
-            textInput.change(setFromTextInput);
-            textInput.bind("paste", function () {
-                setTimeout(setFromTextInput, 1);
-            textInput.keydown(function (e) { if (e.keyCode == 13) { setFromTextInput(); } });
-            cancelButton.text(opts.cancelText);
-            cancelButton.bind("click.spectrum", function (e) {
-                revert();
-                hide();
-            clearButton.attr("title", opts.clearText);
-            clearButton.bind("click.spectrum", function (e) {
-                isEmpty = true;
-                move();
-                if(flat) {
-                    //for the flat style, this is a change event
-                    updateOriginalInput(true);
-            chooseButton.text(opts.chooseText);
-            chooseButton.bind("click.spectrum", function (e) {
-                if (IE && textInput.is(":focus")) {
-                    textInput.trigger('change');
-                if (isValid()) {
-                    hide();
-            toggleButton.bind("click.spectrum", function (e) {
-                opts.showPaletteOnly = !opts.showPaletteOnly;
-                // To make sure the Picker area is drawn on the right, next to the
-                // Palette area (and not below the palette), first move the Palette
-                // to the left to make space for the picker, plus 5px extra.
-                // The 'applyOptions' function puts the whole container back into place
-                // and takes care of the button-text and the sp-palette-only CSS class.
-                if (!opts.showPaletteOnly && !flat) {
-                    container.css('left', '-=' + (pickerContainer.outerWidth(true) + 5));
-                applyOptions();
-            draggable(alphaSlider, function (dragX, dragY, e) {
-                currentAlpha = (dragX / alphaWidth);
-                isEmpty = false;
+            updateSelectionPaletteFromStorage(), offsetElement.bind("click.spectrum touchstart.spectrum", function(e) {
+                disabled || toggle(), e.stopPropagation(), $(e.target).is("input") || e.preventDefault()
+            }), (boundElement.is(":disabled") || opts.disabled === !0) && disable(), container.click(stopPropagation), textInput.change(setFromTextInput), textInput.bind("paste", function() {
+                setTimeout(setFromTextInput, 1)
+            }), textInput.keydown(function(e) {
+                13 == e.keyCode && setFromTextInput()
+            }), cancelButton.text(opts.cancelText), cancelButton.bind("click.spectrum", function(e) {
+                e.stopPropagation(), e.preventDefault(), hide("cancel")
+            }), clearButton.attr("title", opts.clearText), clearButton.bind("click.spectrum", function(e) {
+                e.stopPropagation(), e.preventDefault(), isEmpty = !0, move(), flat && updateOriginalInput(!0)
+            }), chooseButton.text(opts.chooseText), chooseButton.bind("click.spectrum", function(e) {
+                e.stopPropagation(), e.preventDefault(), isValid() && (updateOriginalInput(!0), hide())
+            }), draggable(alphaSlider, function(dragX, dragY, e) {
+                currentAlpha = dragX / alphaWidth, isEmpty = !1, e.shiftKey && (currentAlpha = Math.round(10 * currentAlpha) / 10), move()
+            }, dragStart, dragStop), draggable(slider, function(dragX, dragY) {
+                currentHue = parseFloat(dragY / slideHeight), isEmpty = !1, opts.showAlpha || (currentAlpha = 1), move()
+            }, dragStart, dragStop), draggable(dragger, function(dragX, dragY, e) {
                 if (e.shiftKey) {
-                    currentAlpha = Math.round(currentAlpha * 10) / 10;
-                move();
-            }, dragStart, dragStop);
-            draggable(slider, function (dragX, dragY) {
-                currentHue = parseFloat(dragY / slideHeight);
-                isEmpty = false;
-                if (!opts.showAlpha) {
-                    currentAlpha = 1;
-                move();
-            draggable(dragger, function (dragX, dragY, e) {
-                // shift+drag should snap the movement to either the x or y axis.
-                if (!e.shiftKey) {
-                else if (!shiftMovementDirection) {
-                    var oldDragX = currentSaturation * dragWidth;
-                    var oldDragY = dragHeight - (currentValue * dragHeight);
-                    var furtherFromX = Math.abs(dragX - oldDragX) > Math.abs(dragY - oldDragY);
-                    shiftMovementDirection = furtherFromX ? "x" : "y";
-                var setSaturation = !shiftMovementDirection || shiftMovementDirection === "x";
-                var setValue = !shiftMovementDirection || shiftMovementDirection === "y";
-                if (setSaturation) {
-                    currentSaturation = parseFloat(dragX / dragWidth);
-                if (setValue) {
-                    currentValue = parseFloat((dragHeight - dragY) / dragHeight);
-                isEmpty = false;
-                    currentAlpha = 1;
-                move();
-            if (!!initialColor) {
-                set(initialColor);
-                // In case color was black - update the preview UI and set the format
-                // since the set function will not run (default color is black).
-                updateUI();
-                currentPreferredFormat = preferredFormat || tinycolor(initialColor).format;
-                addColorToSelectionPalette(initialColor);
-            else {
-                updateUI();
-            if (flat) {
-                show();
-            function paletteElementClick(e) {
-                if (e.data && e.data.ignore) {
-                    // version for new jquery-version
-                    // set($(e.target).closest(".sp-thumb-el").data("color"));
-                    // fix for jquery version < 1.4.3
-                    set($(e.target).closest(".sp-thumb-el").attr('data-color'));
-                    move();
-                else {
-                    set($(e.target).closest(".sp-thumb-el").data("color"));
-                    move();
-                    if (opts.hideAfterPaletteSelect) {
-                      hide();
+                    if (!shiftMovementDirection) {
+                        var oldDragX = currentSaturation * dragWidth,
+                            oldDragY = dragHeight - currentValue * dragHeight,
+                            furtherFromX = Math.abs(dragX - oldDragX) > Math.abs(dragY - oldDragY);
+                        shiftMovementDirection = furtherFromX ? "x" : "y"
-                return false;
+                } else shiftMovementDirection = null;
+                var setSaturation = !shiftMovementDirection || "x" === shiftMovementDirection,
+                    setValue = !shiftMovementDirection || "y" === shiftMovementDirection;
+                setSaturation && (currentSaturation = parseFloat(dragX / dragWidth)), setValue && (currentValue = parseFloat((dragHeight - dragY) / dragHeight)), isEmpty = !1, opts.showAlpha || (currentAlpha = 1), move()
+            }, dragStart, dragStop), initialColor ? (set(initialColor), updateUI(), currentPreferredFormat = preferredFormat || tinycolor(initialColor).format, addColorToSelectionPalette(initialColor)) : updateUI(), flat && show();
             var paletteEvent = IE ? "mousedown.spectrum" : "click.spectrum touchstart.spectrum";
-            paletteContainer.delegate(".sp-thumb-el", paletteEvent, paletteElementClick);
-            initialColorContainer.delegate(".sp-thumb-el:nth-child(1)", paletteEvent, { ignore: true }, paletteElementClick);
+            paletteContainer.delegate(".sp-thumb-el", paletteEvent, palletElementClick), initialColorContainer.delegate(".sp-thumb-el:nth-child(1)", paletteEvent, {
+                ignore: !0
+            }, palletElementClick)
         function updateSelectionPaletteFromStorage() {
             if (localStorageKey && window.localStorage) {
-                // Migrate old palettes over to new format.  May want to remove this eventually.
                 try {
                     var oldPalette = window.localStorage[localStorageKey].split(",#");
-                    if (oldPalette.length > 1) {
-                        delete window.localStorage[localStorageKey];
-                        $.each(oldPalette, function(i, c) {
-                             addColorToSelectionPalette(c);
-                catch(e) { }
+                    oldPalette.length > 1 && (delete window.localStorage[localStorageKey], $.each(oldPalette, function(i, c) {
+                        addColorToSelectionPalette(c)
+                } catch (e) {}
                 try {
-                    selectionPalette = window.localStorage[localStorageKey].split(";");
-                catch (e) { }
+                    selectionPalette = window.localStorage[localStorageKey].split(";")
+                } catch (e) {}
         function addColorToSelectionPalette(color) {
             if (showSelectionPalette) {
                 var rgb = tinycolor(color).toRgbString();
-                if (!paletteLookup[rgb] && $.inArray(rgb, selectionPalette) === -1) {
-                    selectionPalette.push(rgb);
-                    while(selectionPalette.length > maxSelectionSize) {
-                        selectionPalette.shift();
-                if (localStorageKey && window.localStorage) {
-                    try {
-                        window.localStorage[localStorageKey] = selectionPalette.join(";");
-                    catch(e) { }
+                if (!paletteLookup[rgb] && -1 === $.inArray(rgb, selectionPalette))
+                    for (selectionPalette.push(rgb); selectionPalette.length > maxSelectionSize;) selectionPalette.shift();
+                if (localStorageKey && window.localStorage) try {
+                    window.localStorage[localStorageKey] = selectionPalette.join(";")
+                } catch (e) {}
         function getUniqueSelectionPalette() {
             var unique = [];
-            if (opts.showPalette) {
-                for (var i = 0; i < selectionPalette.length; i++) {
+            if (opts.showPalette)
+                for (i = 0; i < selectionPalette.length; i++) {
                     var rgb = tinycolor(selectionPalette[i]).toRgbString();
-                    if (!paletteLookup[rgb]) {
-                        unique.push(selectionPalette[i]);
+                    paletteLookup[rgb] || unique.push(selectionPalette[i])
-            return unique.reverse().slice(0, opts.maxSelectionSize);
+            return unique.reverse().slice(0, opts.maxSelectionSize)
         function drawPalette() {
-            var currentColor = get();
-            var html = $.map(paletteArray, function (palette, i) {
-                return paletteTemplate(palette, currentColor, "sp-palette-row sp-palette-row-" + i, opts);
-            if (selectionPalette) {
-                html.push(paletteTemplate(getUniqueSelectionPalette(), currentColor, "sp-palette-row sp-palette-row-selection", opts));
-            paletteContainer.html(html.join(""));
+            var currentColor = get(),
+                html = $.map(paletteArray, function(palette, i) {
+                    return paletteTemplate(palette, currentColor, "sp-palette-row sp-palette-row-" + i, opts.preferredFormat)
+            updateSelectionPaletteFromStorage(), selectionPalette && html.push(paletteTemplate(getUniqueSelectionPalette(), currentColor, "sp-palette-row sp-palette-row-selection", opts.preferredFormat)), paletteContainer.html(html.join(""))
         function drawInitial() {
             if (opts.showInitial) {
-                var initial = colorOnShow;
-                var current = get();
-                initialColorContainer.html(paletteTemplate([initial, current], current, "sp-palette-row-initial", opts));
+                var initial = colorOnShow,
+                    current = get();
+                initialColorContainer.html(paletteTemplate([initial, current], current, "sp-palette-row-initial", opts.preferredFormat))
         function dragStart() {
-            if (dragHeight <= 0 || dragWidth <= 0 || slideHeight <= 0) {
-                reflow();
-            isDragging = true;
-            container.addClass(draggingClass);
-            boundElement.trigger('dragstart.spectrum', [ get() ]);
+            (0 >= dragHeight || 0 >= dragWidth || 0 >= slideHeight) && reflow(), container.addClass(draggingClass), shiftMovementDirection = null, boundElement.trigger("dragstart.spectrum", [get()])
         function dragStop() {
-            isDragging = false;
-            container.removeClass(draggingClass);
-            boundElement.trigger('dragstop.spectrum', [ get() ]);
+            container.removeClass(draggingClass), boundElement.trigger("dragstop.spectrum", [get()])
         function setFromTextInput() {
             var value = textInput.val();
-            if ((value === null || value === "") && allowEmpty) {
-                set(null);
-            else {
+            if (null !== value && "" !== value || !allowEmpty) {
                 var tiny = tinycolor(value);
-                if (tiny.isValid()) {
-                    set(tiny);
-                else {
-                    textInput.addClass("sp-validation-error");
+                tiny.ok ? (set(tiny), updateOriginalInput(!0)) : textInput.addClass("sp-validation-error")
+            } else set(null), updateOriginalInput(!0)
         function toggle() {
-            if (visible) {
-                hide();
-            else {
-                show();
+            visible ? hide() : show()
         function show() {
-            var event = $.Event('beforeShow.spectrum');
-            if (visible) {
-                reflow();
-                return;
-            boundElement.trigger(event, [ get() ]);
-            if (callbacks.beforeShow(get()) === false || event.isDefaultPrevented()) {
-                return;
-            hideAll();
-            visible = true;
-            $(doc).bind("keydown.spectrum", onkeydown);
-            $(doc).bind("click.spectrum", clickout);
-            $(window).bind("resize.spectrum", resize);
-            replacer.addClass("sp-active");
-            container.removeClass("sp-hidden");
-            reflow();
-            updateUI();
-            colorOnShow = get();
-            drawInitial();
-            callbacks.show(colorOnShow);
-            boundElement.trigger('show.spectrum', [ colorOnShow ]);
+            var event = $.Event("beforeShow.spectrum");
+            return visible ? void reflow() : (boundElement.trigger(event, [get()]), void(callbacks.beforeShow(get()) === !1 || event.isDefaultPrevented() || (hideAll(), visible = !0, $(doc).bind("click.spectrum", hide), $(window).bind("resize.spectrum", resize), replacer.addClass("sp-active"), container.removeClass("sp-hidden"), reflow(), updateUI(), colorOnShow = get(), drawInitial(), callbacks.show(colorOnShow), boundElement.trigger("show.spectrum", [colorOnShow]))))
-        function onkeydown(e) {
-            // Close on ESC
-            if (e.keyCode === 27) {
-                hide();
+        function hide(e) {
+            if ((!e || "click" != e.type || 2 != e.button) && visible && !flat) {
+                visible = !1, $(doc).unbind("click.spectrum", hide), $(window).unbind("resize.spectrum", resize), replacer.removeClass("sp-active"), container.addClass("sp-hidden");
+                var colorHasChanged = !tinycolor.equals(get(), colorOnShow);
+                colorHasChanged && (clickoutFiresChange && "cancel" !== e ? updateOriginalInput(!0) : revert()), callbacks.hide(get()), boundElement.trigger("hide.spectrum", [get()])
-        function clickout(e) {
-            // Return on right click.
-            if (e.button == 2) { return; }
-            // If a drag event was happening during the mouseup, don't hide
-            // on click.
-            if (isDragging) { return; }
-            if (clickoutFiresChange) {
-            else {
-                revert();
-            hide();
-        function hide() {
-            // Return if hiding is unnecessary
-            if (!visible || flat) { return; }
-            visible = false;
-            $(doc).unbind("keydown.spectrum", onkeydown);
-            $(doc).unbind("click.spectrum", clickout);
-            $(window).unbind("resize.spectrum", resize);
-            replacer.removeClass("sp-active");
-            container.addClass("sp-hidden");
-            callbacks.hide(get());
-            boundElement.trigger('hide.spectrum', [ get() ]);
         function revert() {
-            set(colorOnShow, true);
+            set(colorOnShow, !0)
         function set(color, ignoreFormatChange) {
-            if (tinycolor.equals(color, get())) {
-                // Update UI just in case a validation error needs
-                // to be cleared.
-                updateUI();
-                return;
+            if (tinycolor.equals(color, get())) return void updateUI();
             var newColor, newHsv;
-            if (!color && allowEmpty) {
-                isEmpty = true;
-            } else {
-                isEmpty = false;
-                newColor = tinycolor(color);
-                newHsv = newColor.toHsv();
-                currentHue = (newHsv.h % 360) / 360;
-                currentSaturation = newHsv.s;
-                currentValue = newHsv.v;
-                currentAlpha = newHsv.a;
-            updateUI();
-            if (newColor && newColor.isValid() && !ignoreFormatChange) {
-                currentPreferredFormat = preferredFormat || newColor.getFormat();
+            !color && allowEmpty ? isEmpty = !0 : (isEmpty = !1, newColor = tinycolor(color), newHsv = newColor.toHsv(), currentHue = newHsv.h % 360 / 360, currentSaturation = newHsv.s, currentValue = newHsv.v, currentAlpha = newHsv.a), updateUI(), newColor && newColor.ok && !ignoreFormatChange && (currentPreferredFormat = preferredFormat || newColor.format)
         function get(opts) {
-            opts = opts || { };
-            if (allowEmpty && isEmpty) {
-                return null;
-            return tinycolor.fromRatio({
+            return opts = opts || {}, allowEmpty && isEmpty ? null : tinycolor.fromRatio({
                 h: currentHue,
                 s: currentSaturation,
                 v: currentValue,
-                a: Math.round(currentAlpha * 100) / 100
-            }, { format: opts.format || currentPreferredFormat });
+                a: Math.round(100 * currentAlpha) / 100
+                format: opts.format || currentPreferredFormat
         function isValid() {
-            return !textInput.hasClass("sp-validation-error");
+            return !textInput.hasClass("sp-validation-error")
         function move() {
-            updateUI();
-            callbacks.move(get());
-            boundElement.trigger('move.spectrum', [ get() ]);
+            updateUI(), callbacks.move(get()), boundElement.trigger("move.spectrum", [get()])
         function updateUI() {
-            textInput.removeClass("sp-validation-error");
-            updateHelperLocations();
-            // Update dragger background color (gradients take care of saturation and value).
-            var flatColor = tinycolor.fromRatio({ h: currentHue, s: 1, v: 1 });
+            textInput.removeClass("sp-validation-error"), updateHelperLocations();
+            var flatColor = tinycolor.fromRatio({
+                h: currentHue,
+                s: 1,
+                v: 1
             dragger.css("background-color", flatColor.toHexString());
-            // Get a format that alpha will be included in (hex and names ignore alpha)
             var format = currentPreferredFormat;
-            if (currentAlpha < 1 && !(currentAlpha === 0 && format === "name")) {
-                if (format === "hex" || format === "hex3" || format === "hex6" || format === "name") {
-                    format = "rgb";
-            var realColor = get({ format: format }),
-                displayColor = '';
-             //reset background info for preview element
-            previewElement.removeClass("sp-clear-display");
-            previewElement.css('background-color', 'transparent');
-            if (!realColor && allowEmpty) {
-                // Update the replaced elements background with icon indicating no color selection
-                previewElement.addClass("sp-clear-display");
+            1 > currentAlpha && (0 !== currentAlpha || "name" !== format) && ("hex" === format || "hex3" === format || "hex6" === format || "name" === format) && (format = "rgb");
+            var realColor = get({
+                format: format
+                displayColor = "";
+            if (previewElement.removeClass("sp-clear-display"), previewElement.css("background-color", "transparent"), !realColor && allowEmpty) previewElement.addClass("sp-clear-display");
             else {
                 var realHex = realColor.toHexString(),
                     realRgb = realColor.toRgbString();
-                // Update the replaced elements background color (with actual selected color)
-                if (rgbaSupport || realColor.alpha === 1) {
-                    previewElement.css("background-color", realRgb);
-                else {
-                    previewElement.css("background-color", "transparent");
-                    previewElement.css("filter", realColor.toFilter());
-                if (opts.showAlpha) {
+                if (rgbaSupport || 1 === realColor.alpha ? previewElement.css("background-color", realRgb) : (previewElement.css("background-color", "transparent"), previewElement.css("filter", realColor.toFilter())), opts.showAlpha) {
                     var rgb = realColor.toRgb();
                     rgb.a = 0;
-                    var realAlpha = tinycolor(rgb).toRgbString();
-                    var gradient = "linear-gradient(left, " + realAlpha + ", " + realHex + ")";
-                    if (IE) {
-                        alphaSliderInner.css("filter", tinycolor(realAlpha).toFilter({ gradientType: 1 }, realHex));
-                    else {
-                        alphaSliderInner.css("background", "-webkit-" + gradient);
-                        alphaSliderInner.css("background", "-moz-" + gradient);
-                        alphaSliderInner.css("background", "-ms-" + gradient);
-                        // Use current syntax gradient on unprefixed property.
-                            "linear-gradient(to right, " + realAlpha + ", " + realHex + ")");
+                    var realAlpha = tinycolor(rgb).toRgbString(),
+                        gradient = "linear-gradient(left, " + realAlpha + ", " + realHex + ")";
+                    IE ? alphaSliderInner.css("filter", tinycolor(realAlpha).toFilter({
+                        gradientType: 1
+                    }, realHex)) : (alphaSliderInner.css("background", "-webkit-" + gradient), alphaSliderInner.css("background", "-moz-" + gradient), alphaSliderInner.css("background", "-ms-" + gradient), alphaSliderInner.css("background", "linear-gradient(to right, " + realAlpha + ", " + realHex + ")"))
-                displayColor = realColor.toString(format);
+                displayColor = realColor.toString(format)
-            // Update the text entry input as it changes happen
-            if (opts.showInput) {
-                textInput.val(displayColor);
-                drawPalette();
-            drawInitial();
+            opts.showInput && textInput.val(displayColor), opts.showPalette && drawPalette(), drawInitial()
         function updateHelperLocations() {
-            var s = currentSaturation;
-            var v = currentValue;
-            if(allowEmpty && isEmpty) {
-                //if selected color is empty, hide the helpers
-                alphaSlideHelper.hide();
-                slideHelper.hide();
-                dragHelper.hide();
+            var s = currentSaturation,
+                v = currentValue;
+            if (allowEmpty && isEmpty) alphaSlideHelper.hide(), slideHelper.hide(), dragHelper.hide();
             else {
-                //make sure helpers are visible
-                alphaSlideHelper.show();
-                slideHelper.show();
-                dragHelper.show();
-                // Where to show the little circle in that displays your current selected color
-                var dragX = s * dragWidth;
-                var dragY = dragHeight - (v * dragHeight);
-                dragX = Math.max(
-                    -dragHelperHeight,
-                    Math.min(dragWidth - dragHelperHeight, dragX - dragHelperHeight)
-                dragY = Math.max(
-                    Math.min(dragHeight - dragHelperHeight, dragY - dragHelperHeight)
-                dragHelper.css({
-                    "top": dragY + "px",
-                    "left": dragX + "px"
+                alphaSlideHelper.show(), slideHelper.show(), dragHelper.show();
+                var dragX = s * dragWidth,
+                    dragY = dragHeight - v * dragHeight;
+                dragX = Math.max(-dragHelperHeight, Math.min(dragWidth - dragHelperHeight, dragX - dragHelperHeight)), dragY = Math.max(-dragHelperHeight, Math.min(dragHeight - dragHelperHeight, dragY - dragHelperHeight)), dragHelper.css({
+                    top: dragY + "px",
+                    left: dragX + "px"
                 var alphaX = currentAlpha * alphaWidth;
                 alphaSlideHelper.css({
-                    "left": (alphaX - (alphaSlideHelperWidth / 2)) + "px"
+                    left: alphaX - alphaSlideHelperWidth / 2 + "px"
-                // Where to show the bar that displays your current selected hue
-                var slideY = (currentHue) * slideHeight;
+                var slideY = currentHue * slideHeight;
                 slideHelper.css({
-                    "top": (slideY - slideHelperHeight) + "px"
+                    top: slideY - slideHelperHeight + "px"
         function updateOriginalInput(fireCallback) {
             var color = get(),
-                displayColor = '',
+                displayColor = "",
                 hasChanged = !tinycolor.equals(color, colorOnShow);
-            if (color) {
-                displayColor = color.toString(currentPreferredFormat);
-                // Update the selection palette with the current color
-                addColorToSelectionPalette(color);
-            if (isInput) {
-                boundElement.val(displayColor);
-            if (fireCallback && hasChanged) {
-                callbacks.change(color);
-                boundElement.trigger('change', [ color ]);
+            color && (displayColor = color.toString(currentPreferredFormat), addColorToSelectionPalette(color)), isInput && boundElement.val(displayColor), colorOnShow = color, fireCallback && hasChanged && (callbacks.change(color), boundElement.trigger("change", [color]))
         function reflow() {
-            dragWidth = dragger.width();
-            dragHeight = dragger.height();
-            dragHelperHeight = dragHelper.height();
-            slideWidth = slider.width();
-            slideHeight = slider.height();
-            slideHelperHeight = slideHelper.height();
-            alphaWidth = alphaSlider.width();
-            alphaSlideHelperWidth = alphaSlideHelper.width();
-            if (!flat) {
-                container.css("position", "absolute");
-                if (opts.offset) {
-                    container.offset(opts.offset);
-                } else {
-                    container.offset(getOffset(container, offsetElement));
-                drawPalette();
-            boundElement.trigger('reflow.spectrum');
+            dragWidth = dragger.width(), dragHeight = dragger.height(), dragHelperHeight = dragHelper.height(), slideWidth = slider.width(), slideHeight = slider.height(), slideHelperHeight = slideHelper.height(), alphaWidth = alphaSlider.width(), alphaSlideHelperWidth = alphaSlideHelper.width(), flat || (container.css("position", "absolute"), container.offset(getOffset(container, offsetElement))), updateHelperLocations(), opts.showPalette && drawPalette(), boundElement.trigger("reflow.spectrum")
         function destroy() {
-            boundElement.show();
-            offsetElement.unbind("click.spectrum touchstart.spectrum");
-            container.remove();
-            replacer.remove();
-            spectrums[spect.id] = null;
+            boundElement.show(), offsetElement.unbind("click.spectrum touchstart.spectrum"), container.remove(), replacer.remove(), spectrums[spect.id] = null
         function option(optionName, optionValue) {
-            if (optionName === undefined) {
-                return $.extend({}, opts);
-            if (optionValue === undefined) {
-                return opts[optionName];
-            opts[optionName] = optionValue;
-            applyOptions();
+            return optionName === undefined ? $.extend({}, opts) : optionValue === undefined ? opts[optionName] : (opts[optionName] = optionValue, void applyOptions())
         function enable() {
-            disabled = false;
-            boundElement.attr("disabled", false);
-            offsetElement.removeClass("sp-disabled");
+            disabled = !1, boundElement.attr("disabled", !1), offsetElement.removeClass("sp-disabled")
         function disable() {
-            hide();
-            disabled = true;
-            boundElement.attr("disabled", true);
-            offsetElement.addClass("sp-disabled");
+            hide(), disabled = !0, boundElement.attr("disabled", !0), offsetElement.addClass("sp-disabled")
-        function setOffset(coord) {
-            opts.offset = coord;
-            reflow();
+        var opts = instanceOptions(o, element),
+            flat = opts.flat,
+            showSelectionPalette = opts.showSelectionPalette,
+            localStorageKey = opts.localStorageKey,
+            theme = opts.theme,
+            callbacks = opts.callbacks,
+            resize = throttle(reflow, 10),
+            visible = !1,
+            dragWidth = 0,
+            dragHeight = 0,
+            dragHelperHeight = 0,
+            slideHeight = 0,
+            slideWidth = 0,
+            alphaWidth = 0,
+            alphaSlideHelperWidth = 0,
+            slideHelperHeight = 0,
+            currentHue = 0,
+            currentSaturation = 0,
+            currentValue = 0,
+            currentAlpha = 1,
+            palette = [],
+            paletteArray = [],
+            paletteLookup = {}, selectionPalette = opts.selectionPalette.slice(0),
+            maxSelectionSize = opts.maxSelectionSize,
+            draggingClass = "sp-dragging",
+            shiftMovementDirection = null,
+            doc = element.ownerDocument,
+            boundElement = (doc.body, $(element)),
+            disabled = !1,
+            container = $(markup, doc).addClass(theme),
+            dragger = container.find(".sp-color"),
+            dragHelper = container.find(".sp-dragger"),
+            slider = container.find(".sp-hue"),
+            slideHelper = container.find(".sp-slider"),
+            alphaSliderInner = container.find(".sp-alpha-inner"),
+            alphaSlider = container.find(".sp-alpha"),
+            alphaSlideHelper = container.find(".sp-alpha-handle"),
+            textInput = container.find(".sp-input"),
+            paletteContainer = container.find(".sp-palette"),
+            initialColorContainer = container.find(".sp-initial"),
+            cancelButton = container.find(".sp-cancel"),
+            clearButton = container.find(".sp-clear"),
+            chooseButton = container.find(".sp-choose"),
+            isInput = boundElement.is("input"),
+            isInputTypeColor = isInput && inputTypeColorSupport && "color" === boundElement.attr("type"),
+            shouldReplace = isInput && !flat,
+            replacer = shouldReplace ? $(replaceInput).addClass(theme).addClass(opts.className).addClass(opts.replacerClassName) : $([]),
+            offsetElement = shouldReplace ? replacer : boundElement,
+            previewElement = replacer.find(".sp-preview-inner"),
+            initialColor = opts.color || isInput && boundElement.val(),
+            colorOnShow = !1,
+            preferredFormat = opts.preferredFormat,
+            currentPreferredFormat = preferredFormat,
+            clickoutFiresChange = !opts.showButtons || opts.clickoutFiresChange,
+            isEmpty = !initialColor,
+            allowEmpty = opts.allowEmpty && !isInputTypeColor;
         initialize();
         var spect = {
             show: show,
             hide: hide,
@@ -956,1365 +348,797 @@
             option: option,
             enable: enable,
             disable: disable,
-            offset: setOffset,
-            set: function (c) {
-                set(c);
-                updateOriginalInput();
+            set: function(c) {
+                set(c), updateOriginalInput()
             get: get,
             destroy: destroy,
             container: container
-        spect.id = spectrums.push(spect) - 1;
-        return spect;
+        return spect.id = spectrums.push(spect) - 1, spect
-    * checkOffset - get the offset below/above and left/right element depending on screen position
-    * Thanks https://github.com/jquery/jquery-ui/blob/master/ui/jquery.ui.datepicker.js
     function getOffset(picker, input) {
-        var extraY = 0;
-        var dpWidth = picker.outerWidth();
-        var dpHeight = picker.outerHeight();
-        var inputHeight = input.outerHeight();
-        var doc = picker[0].ownerDocument;
-        var docElem = doc.documentElement;
-        var viewWidth = docElem.clientWidth + $(doc).scrollLeft();
-        var viewHeight = docElem.clientHeight + $(doc).scrollTop();
-        var offset = input.offset();
-        offset.top += inputHeight;
-        offset.left -=
-            Math.min(offset.left, (offset.left + dpWidth > viewWidth && viewWidth > dpWidth) ?
-            Math.abs(offset.left + dpWidth - viewWidth) : 0);
-        offset.top -=
-            Math.min(offset.top, ((offset.top + dpHeight > viewHeight && viewHeight > dpHeight) ?
-            Math.abs(dpHeight + inputHeight - extraY) : extraY));
-        return offset;
+        var extraY = 0,
+            dpWidth = picker.outerWidth(),
+            dpHeight = picker.outerHeight(),
+            inputHeight = input.outerHeight(),
+            doc = picker[0].ownerDocument,
+            docElem = doc.documentElement,
+            viewWidth = docElem.clientWidth + $(doc).scrollLeft(),
+            viewHeight = docElem.clientHeight + $(doc).scrollTop(),
+            offset = input.offset();
+        return offset.top += inputHeight, offset.left -= Math.min(offset.left, offset.left + dpWidth > viewWidth && viewWidth > dpWidth ? Math.abs(offset.left + dpWidth - viewWidth) : 0), offset.top -= Math.min(offset.top, offset.top + dpHeight > viewHeight && viewHeight > dpHeight ? Math.abs(dpHeight + inputHeight - extraY) : extraY), offset
-    * noop - do nothing
-    function noop() {
+    function noop() {}
-    * stopPropagation - makes the code only doing this a little easier to read in line
     function stopPropagation(e) {
-    * Create a function bound to a given object
-    * Thanks to underscore.js
     function bind(func, obj) {
-        var slice = Array.prototype.slice;
-        var args = slice.call(arguments, 2);
-        return function () {
-            return func.apply(obj, args.concat(slice.call(arguments)));
+        var slice = Array.prototype.slice,
+            args = slice.call(arguments, 2);
+        return function() {
+            return func.apply(obj, args.concat(slice.call(arguments)))
-    * Lightweight drag helper.  Handles containment within the element, so that
-    * when dragging, the x is within [0,element.width] and y is within [0,element.height]
     function draggable(element, onmove, onstart, onstop) {
-        onmove = onmove || function () { };
-        onstart = onstart || function () { };
-        onstop = onstop || function () { };
-        var doc = document;
-        var dragging = false;
-        var offset = {};
-        var maxHeight = 0;
-        var maxWidth = 0;
-        var hasTouch = ('ontouchstart' in window);
-        var duringDragEvents = {};
-        duringDragEvents["selectstart"] = prevent;
-        duringDragEvents["dragstart"] = prevent;
-        duringDragEvents["touchmove mousemove"] = move;
-        duringDragEvents["touchend mouseup"] = stop;
         function prevent(e) {
-            if (e.stopPropagation) {
-            if (e.preventDefault) {
-            e.returnValue = false;
+            e.stopPropagation && e.stopPropagation(), e.preventDefault && e.preventDefault(), e.returnValue = !1
         function move(e) {
             if (dragging) {
-                // Mouseup happened outside of window
-                if (IE && doc.documentMode < 9 && !e.button) {
-                    return stop();
-                var t0 = e.originalEvent && e.originalEvent.touches && e.originalEvent.touches[0];
-                var pageX = t0 && t0.pageX || e.pageX;
-                var pageY = t0 && t0.pageY || e.pageY;
-                var dragX = Math.max(0, Math.min(pageX - offset.left, maxWidth));
-                var dragY = Math.max(0, Math.min(pageY - offset.top, maxHeight));
-                if (hasTouch) {
-                    // Stop scrolling in iOS
-                    prevent(e);
-                onmove.apply(element, [dragX, dragY, e]);
+                if (IE && document.documentMode < 9 && !e.button) return stop();
+                var touches = e.originalEvent.touches,
+                    pageX = touches ? touches[0].pageX : e.pageX,
+                    pageY = touches ? touches[0].pageY : e.pageY,
+                    dragX = Math.max(0, Math.min(pageX - offset.left, maxWidth)),
+                    dragY = Math.max(0, Math.min(pageY - offset.top, maxHeight));
+                hasTouch && prevent(e), onmove.apply(element, [dragX, dragY, e])
         function start(e) {
-            var rightclick = (e.which) ? (e.which == 3) : (e.button == 2);
-            if (!rightclick && !dragging) {
-                if (onstart.apply(element, arguments) !== false) {
-                    dragging = true;
-                    maxHeight = $(element).height();
-                    maxWidth = $(element).width();
-                    offset = $(element).offset();
-                    $(doc).bind(duringDragEvents);
-                    $(doc.body).addClass("sp-dragging");
-                    move(e);
-                    prevent(e);
+                var rightclick = e.which ? 3 == e.which : 2 == e.button;
+                e.originalEvent.touches
+            rightclick || dragging || onstart.apply(element, arguments) !== !1 && (dragging = !0, maxHeight = $(element).height(), maxWidth = $(element).width(), offset = $(element).offset(), $(doc).bind(duringDragEvents), $(doc.body).addClass("sp-dragging"), hasTouch || move(e), prevent(e))
         function stop() {
-            if (dragging) {
-                $(doc).unbind(duringDragEvents);
-                $(doc.body).removeClass("sp-dragging");
-                // Wait a tick before notifying observers to allow the click event
-                // to fire in Chrome.
-                setTimeout(function() {
-                    onstop.apply(element, arguments);
-                }, 0);
-            dragging = false;
+            dragging && ($(doc).unbind(duringDragEvents), $(doc.body).removeClass("sp-dragging"), onstop.apply(element, arguments)), dragging = !1
-        $(element).bind("touchstart mousedown", start);
+        onmove = onmove || function() {}, onstart = onstart || function() {}, onstop = onstop || function() {};
+        var doc = element.ownerDocument || document,
+            dragging = !1,
+            offset = {}, maxHeight = 0,
+            maxWidth = 0,
+            hasTouch = "ontouchstart" in window,
+            duringDragEvents = {};
+        duringDragEvents.selectstart = prevent, duringDragEvents.dragstart = prevent, duringDragEvents["touchmove mousemove"] = move, duringDragEvents["touchend mouseup"] = stop, $(element).bind("touchstart mousedown", start)
     function throttle(func, wait, debounce) {
         var timeout;
-            var context = this, args = arguments;
-            var throttler = function () {
-                timeout = null;
-                func.apply(context, args);
-            if (debounce) clearTimeout(timeout);
-            if (debounce || !timeout) timeout = setTimeout(throttler, wait);
+            var context = this,
+                args = arguments,
+                throttler = function() {
+                    timeout = null, func.apply(context, args)
+            debounce && clearTimeout(timeout), (debounce || !timeout) && (timeout = setTimeout(throttler, wait))
-    function inputTypeColorSupport() {
-        return $.fn.spectrum.inputTypeColorSupport();
-    * Define a jQuery plugin
-    var dataID = "spectrum.id";
-    $.fn.spectrum = function (opts, extra) {
-        if (typeof opts == "string") {
-            var returnValue = this;
-            var args = Array.prototype.slice.call( arguments, 1 );
-            this.each(function () {
+    var defaultOpts = {
+        beforeShow: noop,
+        move: noop,
+        change: noop,
+        show: noop,
+        hide: noop,
+        color: !1,
+        flat: !1,
+        showInput: !1,
+        allowEmpty: !1,
+        showButtons: !0,
+        clickoutFiresChange: !1,
+        showInitial: !1,
+        showPalette: !1,
+        showPaletteOnly: !1,
+        showSelectionPalette: !0,
+        localStorageKey: !1,
+        appendTo: "body",
+        maxSelectionSize: 7,
+        cancelText: "cancel",
+        chooseText: "choose",
+        clearText: "Clear Color Selection",
+        preferredFormat: !1,
+        className: "",
+        containerClassName: "",
+        replacerClassName: "",
+        showAlpha: !1,
+        theme: "sp-light",
+        palette: [
+            ["#ffffff", "#000000", "#ff0000", "#ff8000", "#ffff00", "#008000", "#0000ff", "#4b0082", "#9400d3"]
+        selectionPalette: [],
+        disabled: !1
+    }, spectrums = [],
+        IE = !! /msie/i.exec(window.navigator.userAgent),
+        rgbaSupport = function() {
+            function contains(str, substr) {
+                return !!~("" + str).indexOf(substr)
+            var elem = document.createElement("div"),
+                style = elem.style;
+            return style.cssText = "background-color:rgba(0,0,0,.5)", contains(style.backgroundColor, "rgba") || contains(style.backgroundColor, "hsla")
+        inputTypeColorSupport = function() {
+            var colorInput = $("<input type='color' value='!' />")[0];
+            return "color" === colorInput.type && "!" !== colorInput.value
+        replaceInput = ["<div class='sp-replacer'>", "<div class='sp-preview'><div class='sp-preview-inner'></div></div>", "<div class='sp-dd'>▼</div>", "</div>"].join(""),
+        markup = function() {
+            var gradientFix = "";
+            if (IE)
+                for (var i = 1; 6 >= i; i++) gradientFix += "<div class='sp-" + i + "'></div>";
+            return ["<div class='sp-container sp-hidden'>", "<div class='sp-palette-container'>", "<div class='sp-palette sp-thumb sp-cf'></div>", "</div>", "<div class='sp-picker-container'>", "<div class='sp-top sp-cf'>", "<div class='sp-fill'></div>", "<div class='sp-top-inner'>", "<div class='sp-color'>", "<div class='sp-sat'>", "<div class='sp-val'>", "<div class='sp-dragger'></div>", "</div>", "</div>", "</div>", "<div class='sp-clear sp-clear-display'>", "</div>", "<div class='sp-hue'>", "<div class='sp-slider'></div>", gradientFix, "</div>", "</div>", "<div class='sp-alpha'><div class='sp-alpha-inner'><div class='sp-alpha-handle'></div></div></div>", "</div>", "<div class='sp-input-container sp-cf'>", "<input class='sp-input' type='text' spellcheck='false'  />", "</div>", "<div class='sp-initial sp-thumb sp-cf'></div>", "<div class='sp-button-container sp-cf'>", "<a class='sp-cancel' href='#'></a>", "<button type='button' class='sp-choose'></button>", "</div>", "</div>", "</
 div>"].join("")
+        dataID = "spectrum.id";
+    $.fn.spectrum = function(opts) {
+        if ("string" == typeof opts) {
+            var returnValue = this,
+                args = Array.prototype.slice.call(arguments, 1);
+            return this.each(function() {
                 var spect = spectrums[$(this).data(dataID)];
                 if (spect) {
                     var method = spect[opts];
-                    if (!method) {
-                        throw new Error( "Spectrum: no such method: '" + opts + "'" );
+                    if (!method) throw new Error("Spectrum: no such method: '" + opts + "'");
+                    "get" == opts ? returnValue = spect.get() : "container" == opts ? returnValue = spect.container : "option" == opts ? returnValue = spect.option.apply(spect, args) : "destroy" == opts ? (spect.destroy(), $(this).removeData(dataID)) : method.apply(spect, args)
+            }), returnValue
+        return this.spectrum("destroy").each(function() {
+            var options = $.extend({}, opts, $(this).data()),
+                spect = spectrum(this, options);
+            $(this).data(dataID, spect.id)
+    }, $.fn.spectrum.load = !0, $.fn.spectrum.loadOpts = {}, $.fn.spectrum.draggable = draggable, $.fn.spectrum.defaults = defaultOpts, $.spectrum = {}, $.spectrum.localization = {}, $.spectrum.palettes = {}, $.fn.spectrum.processNativeColorInputs = function() {
+        inputTypeColorSupport || $("input[type=color]").spectrum({
+            preferredFormat: "hex6"
+    function() {
+        function tinycolor(color, opts) {
+            if (color = color ? color : "", opts = opts || {}, "object" == typeof color && color.hasOwnProperty("_tc_id")) return color;
+            var rgb = inputToRGB(color),
+                r = rgb.r,
+                g = rgb.g,
+                b = rgb.b,
+                a = rgb.a,
+                roundA = mathRound(100 * a) / 100,
+                format = opts.format || rgb.format;
+            return 1 > r && (r = mathRound(r)), 1 > g && (g = mathRound(g)), 1 > b && (b = mathRound(b)), {
+                ok: rgb.ok,
+                format: format,
+                _tc_id: tinyCounter++,
+                alpha: a,
+                getAlpha: function() {
+                    return a
+                setAlpha: function(value) {
+                    a = boundAlpha(value), roundA = mathRound(100 * a) / 100
+                toHsv: function() {
+                    var hsv = rgbToHsv(r, g, b);
+                    return {
+                        h: 360 * hsv.h,
+                        s: hsv.s,
+                        v: hsv.v,
+                        a: a
-                    if (opts == "get") {
-                        returnValue = spect.get();
+                toHsvString: function() {
+                    var hsv = rgbToHsv(r, g, b),
+                        h = mathRound(360 * hsv.h),
+                        s = mathRound(100 * hsv.s),
+                        v = mathRound(100 * hsv.v);
+                    return 1 == a ? "hsv(" + h + ", " + s + "%, " + v + "%)" : "hsva(" + h + ", " + s + "%, " + v + "%, " + roundA + ")"
+                toHsl: function() {
+                    var hsl = rgbToHsl(r, g, b);
+                    return {
+                        h: 360 * hsl.h,
+                        s: hsl.s,
+                        l: hsl.l,
+                        a: a
-                    else if (opts == "container") {
-                        returnValue = spect.container;
+                toHslString: function() {
+                    var hsl = rgbToHsl(r, g, b),
+                        h = mathRound(360 * hsl.h),
+                        s = mathRound(100 * hsl.s),
+                        l = mathRound(100 * hsl.l);
+                    return 1 == a ? "hsl(" + h + ", " + s + "%, " + l + "%)" : "hsla(" + h + ", " + s + "%, " + l + "%, " + roundA + ")"
+                toHex: function(allow3Char) {
+                    return rgbToHex(r, g, b, allow3Char)
+                toHexString: function(allow3Char) {
+                    return "#" + this.toHex(allow3Char)
+                toHex8: function() {
+                    return rgbaToHex(r, g, b, a)
+                toHex8String: function() {
+                    return "#" + this.toHex8()
+                toRgb: function() {
+                    return {
+                        r: mathRound(r),
+                        g: mathRound(g),
+                        b: mathRound(b),
+                        a: a
-                    else if (opts == "option") {
-                        returnValue = spect.option.apply(spect, args);
+                toRgbString: function() {
+                    return 1 == a ? "rgb(" + mathRound(r) + ", " + mathRound(g) + ", " + mathRound(b) + ")" : "rgba(" + mathRound(r) + ", " + mathRound(g) + ", " + mathRound(b) + ", " + roundA + ")"
+                toPercentageRgb: function() {
+                    return {
+                        r: mathRound(100 * bound01(r, 255)) + "%",
+                        g: mathRound(100 * bound01(g, 255)) + "%",
+                        b: mathRound(100 * bound01(b, 255)) + "%",
+                        a: a
-                    else if (opts == "destroy") {
-                        spect.destroy();
-                        $(this).removeData(dataID);
+                toPercentageRgbString: function() {
+                    return 1 == a ? "rgb(" + mathRound(100 * bound01(r, 255)) + "%, " + mathRound(100 * bound01(g, 255)) + "%, " + mathRound(100 * bound01(b, 255)) + "%)" : "rgba(" + mathRound(100 * bound01(r, 255)) + "%, " + mathRound(100 * bound01(g, 255)) + "%, " + mathRound(100 * bound01(b, 255)) + "%, " + roundA + ")"
+                toName: function() {
+                    return 0 === a ? "transparent" : hexNames[rgbToHex(r, g, b, !0)] || !1
+                toFilter: function(secondColor) {
+                    var hex8String = "#" + rgbaToHex(r, g, b, a),
+                        secondHex8String = hex8String,
+                        gradientType = opts && opts.gradientType ? "GradientType = 1, " : "";
+                    if (secondColor) {
+                        var s = tinycolor(secondColor);
+                        secondHex8String = s.toHex8String()
-                    else {
-                        method.apply(spect, args);
+                    return "progid:DXImageTransform.Microsoft.gradient(" + gradientType + "startColorstr=" + hex8String + ",endColorstr=" + secondHex8String + ")"
+                toString: function(format) {
+                    var formatSet = !! format;
+                    format = format || this.format;
+                    var formattedString = !1,
+                        hasAlphaAndFormatNotSet = !formatSet && 1 > a && a > 0,
+                        formatWithAlpha = hasAlphaAndFormatNotSet && ("hex" === format || "hex6" === format || "hex3" === format || "name" === format);
+                    return "rgb" === format && (formattedString = this.toRgbString()), "prgb" === format && (formattedString = this.toPercentageRgbString()), ("hex" === format || "hex6" === format) && (formattedString = this.toHexString()), "hex3" === format && (formattedString = this.toHexString(!0)), "hex8" === format && (formattedString = this.toHex8String()), "name" === format && (formattedString = this.toName()), "hsl" === format && (formattedString = this.toHslString()), "hsv" === format && (formattedString = this.toHsvString()), formatWithAlpha ? this.toRgbString() : formattedString || this.toHexString()
-            return returnValue;
-        // Initializing a new instance of spectrum
-        return this.spectrum("destroy").each(function () {
-            var options = $.extend({}, opts, $(this).data());
-            var spect = spectrum(this, options);
-            $(this).data(dataID, spect.id);
-    $.fn.spectrum.load = true;
-    $.fn.spectrum.loadOpts = {};
-    $.fn.spectrum.draggable = draggable;
-    $.fn.spectrum.defaults = defaultOpts;
-    $.fn.spectrum.inputTypeColorSupport = function inputTypeColorSupport() {
-        if (typeof inputTypeColorSupport._cachedResult === "undefined") {
-            var colorInput = $("<input type='color' value='!' />")[0];
-            inputTypeColorSupport._cachedResult = colorInput.type === "color" && colorInput.value !== "!";
+        function inputToRGB(color) {
+            var rgb = {
+                r: 0,
+                g: 0,
+                b: 0
+            }, a = 1,
+                ok = !1,
+                format = !1;
+            return "string" == typeof color && (color = stringInputToObject(color)), "object" == typeof color && (color.hasOwnProperty("r") && color.hasOwnProperty("g") && color.hasOwnProperty("b") ? (rgb = rgbToRgb(color.r, color.g, color.b), ok = !0, format = "%" === String(color.r).substr(-1) ? "prgb" : "rgb") : color.hasOwnProperty("h") && color.hasOwnProperty("s") && color.hasOwnProperty("v") ? (color.s = convertToPercentage(color.s), color.v = convertToPercentage(color.v), rgb = hsvToRgb(color.h, color.s, color.v), ok = !0, format = "hsv") : color.hasOwnProperty("h") && color.hasOwnProperty("s") && color.hasOwnProperty("l") && (color.s = convertToPercentage(color.s), color.l = convertToPercentage(color.l), rgb = hslToRgb(color.h, color.s, color.l), ok = !0, format = "hsl"), color.hasOwnProperty("a") && (a = color.a)), a = boundAlpha(a), {
+                ok: ok,
+                format: color.format || format,
+                r: mathMin(255, mathMax(rgb.r, 0)),
+                g: mathMin(255, mathMax(rgb.g, 0)),
+                b: mathMin(255, mathMax(rgb.b, 0)),
+                a: a
-        return inputTypeColorSupport._cachedResult;
-    $.spectrum = { };
-    $.spectrum.localization = { };
-    $.spectrum.palettes = { };
-    $.fn.spectrum.processNativeColorInputs = function () {
-        var colorInputs = $("input[type=color]");
-        if (colorInputs.length && !inputTypeColorSupport()) {
-            colorInputs.spectrum({
-                preferredFormat: "hex6"
+        function rgbToRgb(r, g, b) {
+            return {
+                r: 255 * bound01(r, 255),
+                g: 255 * bound01(g, 255),
+                b: 255 * bound01(b, 255)
-    // TinyColor v1.1.2
-    // https://github.com/bgrins/TinyColor
-    // Brian Grinstead, MIT License
-    (function() {
-    var trimLeft = /^[\s,#]+/,
-        trimRight = /\s+$/,
-        tinyCounter = 0,
-        math = Math,
-        mathRound = math.round,
-        mathMin = math.min,
-        mathMax = math.max,
-        mathRandom = math.random;
-    var tinycolor = function(color, opts) {
-        color = (color) ? color : '';
-        // If input is already a tinycolor, return itself
-        if (color instanceof tinycolor) {
-           return color;
-        // If we are called as a function, call using new instead
-        if (!(this instanceof tinycolor)) {
-            return new tinycolor(color, opts);
-        var rgb = inputToRGB(color);
-        this._originalInput = color,
-        this._r = rgb.r,
-        this._g = rgb.g,
-        this._b = rgb.b,
-        this._a = rgb.a,
-        this._roundA = mathRound(100*this._a) / 100,
-        this._format = opts.format || rgb.format;
-        this._gradientType = opts.gradientType;
-        // Don't let the range of [0,255] come back in [0,1].
-        // Potentially lose a little bit of precision here, but will fix issues where
-        // .5 gets interpreted as half of the total, instead of half of 1
-        // If it was supposed to be 128, this was already taken care of by `inputToRgb`
-        if (this._r < 1) { this._r = mathRound(this._r); }
-        if (this._g < 1) { this._g = mathRound(this._g); }
-        if (this._b < 1) { this._b = mathRound(this._b); }
-        this._ok = rgb.ok;
-        this._tc_id = tinyCounter++;
-    tinycolor.prototype = {
-        isDark: function() {
-            return this.getBrightness() < 128;
-        isLight: function() {
-            return !this.isDark();
-        isValid: function() {
-            return this._ok;
-        getOriginalInput: function() {
-          return this._originalInput;
-        getFormat: function() {
-            return this._format;
-        getAlpha: function() {
-            return this._a;
-        getBrightness: function() {
-            var rgb = this.toRgb();
-            return (rgb.r * 299 + rgb.g * 587 + rgb.b * 114) / 1000;
-        setAlpha: function(value) {
-            this._a = boundAlpha(value);
-            this._roundA = mathRound(100*this._a) / 100;
-            return this;
-        toHsv: function() {
-            var hsv = rgbToHsv(this._r, this._g, this._b);
-            return { h: hsv.h * 360, s: hsv.s, v: hsv.v, a: this._a };
-        toHsvString: function() {
-            var h = mathRound(hsv.h * 360), s = mathRound(hsv.s * 100), v = mathRound(hsv.v * 100);
-            return (this._a == 1) ?
-              "hsv("  + h + ", " + s + "%, " + v + "%)" :
-              "hsva(" + h + ", " + s + "%, " + v + "%, "+ this._roundA + ")";
-        toHsl: function() {
-            var hsl = rgbToHsl(this._r, this._g, this._b);
-            return { h: hsl.h * 360, s: hsl.s, l: hsl.l, a: this._a };
-        toHslString: function() {
-            var h = mathRound(hsl.h * 360), s = mathRound(hsl.s * 100), l = mathRound(hsl.l * 100);
-              "hsl("  + h + ", " + s + "%, " + l + "%)" :
-              "hsla(" + h + ", " + s + "%, " + l + "%, "+ this._roundA + ")";
-        toHex: function(allow3Char) {
-            return rgbToHex(this._r, this._g, this._b, allow3Char);
-        toHexString: function(allow3Char) {
-            return '#' + this.toHex(allow3Char);
-        toHex8: function() {
-            return rgbaToHex(this._r, this._g, this._b, this._a);
-        toHex8String: function() {
-            return '#' + this.toHex8();
-        toRgb: function() {
-            return { r: mathRound(this._r), g: mathRound(this._g), b: mathRound(this._b), a: this._a };
-        toRgbString: function() {
-              "rgb("  + mathRound(this._r) + ", " + mathRound(this._g) + ", " + mathRound(this._b) + ")" :
-              "rgba(" + mathRound(this._r) + ", " + mathRound(this._g) + ", " + mathRound(this._b) + ", " + this._roundA + ")";
-        toPercentageRgb: function() {
-            return { r: mathRound(bound01(this._r, 255) * 100) + "%", g: mathRound(bound01(this._g, 255) * 100) + "%", b: mathRound(bound01(this._b, 255) * 100) + "%", a: this._a };
-        toPercentageRgbString: function() {
-              "rgb("  + mathRound(bound01(this._r, 255) * 100) + "%, " + mathRound(bound01(this._g, 255) * 100) + "%, " + mathRound(bound01(this._b, 255) * 100) + "%)" :
-              "rgba(" + mathRound(bound01(this._r, 255) * 100) + "%, " + mathRound(bound01(this._g, 255) * 100) + "%, " + mathRound(bound01(this._b, 255) * 100) + "%, " + this._roundA + ")";
-        toName: function() {
-            if (this._a === 0) {
-                return "transparent";
+        function rgbToHsl(r, g, b) {
+            r = bound01(r, 255), g = bound01(g, 255), b = bound01(b, 255);
+            var h, s, max = mathMax(r, g, b),
+                min = mathMin(r, g, b),
+                l = (max + min) / 2;
+            if (max == min) h = s = 0;
+            else {
+                var d = max - min;
+                switch (s = l > .5 ? d / (2 - max - min) : d / (max + min), max) {
+                    case r:
+                        h = (g - b) / d + (b > g ? 6 : 0);
+                        break;
+                    case g:
+                        h = (b - r) / d + 2;
+                        break;
+                    case b:
+                        h = (r - g) / d + 4
+                h /= 6
-            if (this._a < 1) {
-                return false;
+            return {
+                h: h,
+                s: s,
+                l: l
-            return hexNames[rgbToHex(this._r, this._g, this._b, true)] || false;
-        toFilter: function(secondColor) {
-            var hex8String = '#' + rgbaToHex(this._r, this._g, this._b, this._a);
-            var secondHex8String = hex8String;
-            var gradientType = this._gradientType ? "GradientType = 1, " : "";
-            if (secondColor) {
-                var s = tinycolor(secondColor);
-                secondHex8String = s.toHex8String();
+        function hslToRgb(h, s, l) {
+            function hue2rgb(p, q, t) {
+                return 0 > t && (t += 1), t > 1 && (t -= 1), 1 / 6 > t ? p + 6 * (q - p) * t : .5 > t ? q : 2 / 3 > t ? p + (q - p) * (2 / 3 - t) * 6 : p
-            return "progid:DXImageTransform.Microsoft.gradient("+gradientType+"startColorstr="+hex8String+",endColorstr="+secondHex8String+")";
-        toString: function(format) {
-            var formatSet = !!format;
-            format = format || this._format;
-            var formattedString = false;
-            var hasAlpha = this._a < 1 && this._a >= 0;
-            var needsAlphaFormat = !formatSet && hasAlpha && (format === "hex" || format === "hex6" || format === "hex3" || format === "name");
-            if (needsAlphaFormat) {
-                // Special case for "transparent", all other non-alpha formats
-                // will return rgba when there is transparency.
-                if (format === "name" && this._a === 0) {
-                    return this.toName();
-                return this.toRgbString();
+            var r, g, b;
+            if (h = bound01(h, 360), s = bound01(s, 100), l = bound01(l, 100), 0 === s) r = g = b = l;
+            else {
+                var q = .5 > l ? l * (1 + s) : l + s - l * s,
+                    p = 2 * l - q;
+                r = hue2rgb(p, q, h + 1 / 3), g = hue2rgb(p, q, h), b = hue2rgb(p, q, h - 1 / 3)
-            if (format === "rgb") {
-                formattedString = this.toRgbString();
+            return {
+                r: 255 * r,
+                g: 255 * g,
+                b: 255 * b
-            if (format === "prgb") {
-                formattedString = this.toPercentageRgbString();
-            if (format === "hex" || format === "hex6") {
-                formattedString = this.toHexString();
-            if (format === "hex3") {
-                formattedString = this.toHexString(true);
-            if (format === "hex8") {
-                formattedString = this.toHex8String();
-            if (format === "name") {
-                formattedString = this.toName();
-            if (format === "hsl") {
-                formattedString = this.toHslString();
-            if (format === "hsv") {
-                formattedString = this.toHsvString();
-            return formattedString || this.toHexString();
-        _applyModification: function(fn, args) {
-            var color = fn.apply(null, [this].concat([].slice.call(args)));
-            this._r = color._r;
-            this._g = color._g;
-            this._b = color._b;
-            this.setAlpha(color._a);
-            return this;
-        lighten: function() {
-            return this._applyModification(lighten, arguments);
-        brighten: function() {
-            return this._applyModification(brighten, arguments);
-        darken: function() {
-            return this._applyModification(darken, arguments);
-        desaturate: function() {
-            return this._applyModification(desaturate, arguments);
-        saturate: function() {
-            return this._applyModification(saturate, arguments);
-        greyscale: function() {
-            return this._applyModification(greyscale, arguments);
-        spin: function() {
-            return this._applyModification(spin, arguments);
-        _applyCombination: function(fn, args) {
-            return fn.apply(null, [this].concat([].slice.call(args)));
-        analogous: function() {
-            return this._applyCombination(analogous, arguments);
-        complement: function() {
-            return this._applyCombination(complement, arguments);
-        monochromatic: function() {
-            return this._applyCombination(monochromatic, arguments);
-        splitcomplement: function() {
-            return this._applyCombination(splitcomplement, arguments);
-        triad: function() {
-            return this._applyCombination(triad, arguments);
-        tetrad: function() {
-            return this._applyCombination(tetrad, arguments);
-    // If input is an object, force 1 into "1.0" to handle ratios properly
-    // String input requires "1.0" as input, so 1 will be treated as 1
-    tinycolor.fromRatio = function(color, opts) {
-        if (typeof color == "object") {
-            var newColor = {};
-            for (var i in color) {
-                if (color.hasOwnProperty(i)) {
-                    if (i === "a") {
-                        newColor[i] = color[i];
-                    else {
-                        newColor[i] = convertToPercentage(color[i]);
+        function rgbToHsv(r, g, b) {
+                v = max,
+                d = max - min;
+            if (s = 0 === max ? 0 : d / max, max == min) h = 0;
+            else {
+                switch (max) {
+                    case r:
+                        break;
+                    case g:
+                        break;
+                    case b:
+                h /= 6
-            color = newColor;
-        return tinycolor(color, opts);
-    // Given a string or object, convert that input to RGB
-    // Possible string inputs:
-    //     "red"
-    //     "#f00" or "f00"
-    //     "#ff0000" or "ff0000"
-    //     "#ff000000" or "ff000000"
-    //     "rgb 255 0 0" or "rgb (255, 0, 0)"
-    //     "rgb 1.0 0 0" or "rgb (1, 0, 0)"
-    //     "rgba (255, 0, 0, 1)" or "rgba 255, 0, 0, 1"
-    //     "rgba (1.0, 0, 0, 1)" or "rgba 1.0, 0, 0, 1"
-    //     "hsl(0, 100%, 50%)" or "hsl 0 100% 50%"
-    //     "hsla(0, 100%, 50%, 1)" or "hsla 0 100% 50%, 1"
-    //     "hsv(0, 100%, 100%)" or "hsv 0 100% 100%"
-    function inputToRGB(color) {
-        var rgb = { r: 0, g: 0, b: 0 };
-        var a = 1;
-        var ok = false;
-        var format = false;
-        if (typeof color == "string") {
-            color = stringInputToObject(color);
-            if (color.hasOwnProperty("r") && color.hasOwnProperty("g") && color.hasOwnProperty("b")) {
-                rgb = rgbToRgb(color.r, color.g, color.b);
-                ok = true;
-                format = String(color.r).substr(-1) === "%" ? "prgb" : "rgb";
+            return {
+                h: h,
+                s: s,
+                v: v
-            else if (color.hasOwnProperty("h") && color.hasOwnProperty("s") && color.hasOwnProperty("v")) {
-                color.s = convertToPercentage(color.s);
-                color.v = convertToPercentage(color.v);
-                rgb = hsvToRgb(color.h, color.s, color.v);
-                ok = true;
-                format = "hsv";
-            else if (color.hasOwnProperty("h") && color.hasOwnProperty("s") && color.hasOwnProperty("l")) {
-                color.l = convertToPercentage(color.l);
-                rgb = hslToRgb(color.h, color.s, color.l);
-                ok = true;
-                format = "hsl";
-            if (color.hasOwnProperty("a")) {
-                a = color.a;
-        a = boundAlpha(a);
-        return {
-            ok: ok,
-            format: color.format || format,
-            r: mathMin(255, mathMax(rgb.r, 0)),
-            g: mathMin(255, mathMax(rgb.g, 0)),
-            b: mathMin(255, mathMax(rgb.b, 0)),
-            a: a
-    // Conversion Functions
-    // `rgbToHsl`, `rgbToHsv`, `hslToRgb`, `hsvToRgb` modified from:
-    // <http://mjijackson.com/2008/02/rgb-to-hsl-and-rgb-to-hsv-color-model-conversion-algorithms-in-javascript>
-    // `rgbToRgb`
-    // Handle bounds / percentage checking to conform to CSS color spec
-    // <http://www.w3.org/TR/css3-color/>
-    // *Assumes:* r, g, b in [0, 255] or [0, 1]
-    // *Returns:* { r, g, b } in [0, 255]
-    function rgbToRgb(r, g, b){
-        return {
-            r: bound01(r, 255) * 255,
-            g: bound01(g, 255) * 255,
-            b: bound01(b, 255) * 255
-    // `rgbToHsl`
-    // Converts an RGB color value to HSL.
-    // *Assumes:* r, g, and b are contained in [0, 255] or [0, 1]
-    // *Returns:* { h, s, l } in [0,1]
-    function rgbToHsl(r, g, b) {
-        r = bound01(r, 255);
-        g = bound01(g, 255);
-        b = bound01(b, 255);
-        var max = mathMax(r, g, b), min = mathMin(r, g, b);
-        var h, s, l = (max + min) / 2;
-        if(max == min) {
-            h = s = 0; // achromatic
-        else {
-            var d = max - min;
-            s = l > 0.5 ? d / (2 - max - min) : d / (max + min);
-            switch(max) {
-                case r: h = (g - b) / d + (g < b ? 6 : 0); break;
-                case g: h = (b - r) / d + 2; break;
-                case b: h = (r - g) / d + 4; break;
+        function hsvToRgb(h, s, v) {
+            h = 6 * bound01(h, 360), s = bound01(s, 100), v = bound01(v, 100);
+            var i = math.floor(h),
+                f = h - i,
+                p = v * (1 - s),
+                q = v * (1 - f * s),
+                t = v * (1 - (1 - f) * s),
+                mod = i % 6,
+                r = [v, q, p, p, t, v][mod],
+                g = [t, v, v, q, p, p][mod],
+                b = [p, p, t, v, v, q][mod];
+            return {
+                r: 255 * r,
+                g: 255 * g,
+                b: 255 * b
-            h /= 6;
-        return { h: h, s: s, l: l };
-    // `hslToRgb`
-    // Converts an HSL color value to RGB.
-    // *Assumes:* h is contained in [0, 1] or [0, 360] and s and l are contained [0, 1] or [0, 100]
-    // *Returns:* { r, g, b } in the set [0, 255]
-    function hslToRgb(h, s, l) {
-        var r, g, b;
-        h = bound01(h, 360);
-        s = bound01(s, 100);
-        l = bound01(l, 100);
-        function hue2rgb(p, q, t) {
-            if(t < 0) t += 1;
-            if(t > 1) t -= 1;
-            if(t < 1/6) return p + (q - p) * 6 * t;
-            if(t < 1/2) return q;
-            if(t < 2/3) return p + (q - p) * (2/3 - t) * 6;
-            return p;
+        function rgbToHex(r, g, b, allow3Char) {
+            var hex = [pad2(mathRound(r).toString(16)), pad2(mathRound(g).toString(16)), pad2(mathRound(b).toString(16))];
+            return allow3Char && hex[0].charAt(0) == hex[0].charAt(1) && hex[1].charAt(0) == hex[1].charAt(1) && hex[2].charAt(0) == hex[2].charAt(1) ? hex[0].charAt(0) + hex[1].charAt(0) + hex[2].charAt(0) : hex.join("")
-        if(s === 0) {
-            r = g = b = l; // achromatic
-        else {
-            var q = l < 0.5 ? l * (1 + s) : l + s - l * s;
-            var p = 2 * l - q;
-            r = hue2rgb(p, q, h + 1/3);
-            g = hue2rgb(p, q, h);
-            b = hue2rgb(p, q, h - 1/3);
-        return { r: r * 255, g: g * 255, b: b * 255 };
-    // `rgbToHsv`
-    // Converts an RGB color value to HSV
-    // *Assumes:* r, g, and b are contained in the set [0, 255] or [0, 1]
-    // *Returns:* { h, s, v } in [0,1]
-    function rgbToHsv(r, g, b) {
-        var h, s, v = max;
-        s = max === 0 ? 0 : d / max;
-        if(max == min) {
-            h = 0; // achromatic
-        else {
-            switch(max) {
-            h /= 6;
-        return { h: h, s: s, v: v };
-    // `hsvToRgb`
-    // Converts an HSV color value to RGB.
-    // *Assumes:* h is contained in [0, 1] or [0, 360] and s and v are contained in [0, 1] or [0, 100]
-     function hsvToRgb(h, s, v) {
-        h = bound01(h, 360) * 6;
-        v = bound01(v, 100);
-        var i = math.floor(h),
-            f = h - i,
-            p = v * (1 - s),
-            q = v * (1 - f * s),
-            t = v * (1 - (1 - f) * s),
-            mod = i % 6,
-            r = [v, q, p, p, t, v][mod],
-            g = [t, v, v, q, p, p][mod],
-            b = [p, p, t, v, v, q][mod];
-    // `rgbToHex`
-    // Converts an RGB color to hex
-    // Assumes r, g, and b are contained in the set [0, 255]
-    // Returns a 3 or 6 character hex
-    function rgbToHex(r, g, b, allow3Char) {
-        var hex = [
-            pad2(mathRound(r).toString(16)),
-            pad2(mathRound(g).toString(16)),
-            pad2(mathRound(b).toString(16))
-        // Return a 3 character hex if possible
-        if (allow3Char && hex[0].charAt(0) == hex[0].charAt(1) && hex[1].charAt(0) == hex[1].charAt(1) && hex[2].charAt(0) == hex[2].charAt(1)) {
-            return hex[0].charAt(0) + hex[1].charAt(0) + hex[2].charAt(0);
-        return hex.join("");
-        // `rgbaToHex`
-        // Converts an RGBA color plus alpha transparency to hex
-        // Assumes r, g, b and a are contained in the set [0, 255]
-        // Returns an 8 character hex
         function rgbaToHex(r, g, b, a) {
-            var hex = [
-                pad2(convertDecimalToHex(a)),
+            var hex = [pad2(convertDecimalToHex(a)), pad2(mathRound(r).toString(16)), pad2(mathRound(g).toString(16)), pad2(mathRound(b).toString(16))];
+            return hex.join("")
-    // `equals`
-    // Can be called with any tinycolor input
-    tinycolor.equals = function (color1, color2) {
-        if (!color1 || !color2) { return false; }
-        return tinycolor(color1).toRgbString() == tinycolor(color2).toRgbString();
-    tinycolor.random = function() {
-            r: mathRandom(),
-            g: mathRandom(),
-            b: mathRandom()
-    // Modification Functions
-    // Thanks to less.js for some of the basics here
-    // <https://github.com/cloudhead/less.js/blob/master/lib/less/functions.js>
-    function desaturate(color, amount) {
-        amount = (amount === 0) ? 0 : (amount || 10);
-        var hsl = tinycolor(color).toHsl();
-        hsl.s -= amount / 100;
-        hsl.s = clamp01(hsl.s);
-        return tinycolor(hsl);
-    function saturate(color, amount) {
-        hsl.s += amount / 100;
-    function greyscale(color) {
-        return tinycolor(color).desaturate(100);
-    function lighten (color, amount) {
-        hsl.l += amount / 100;
-        hsl.l = clamp01(hsl.l);
-    function brighten(color, amount) {
-        var rgb = tinycolor(color).toRgb();
-        rgb.r = mathMax(0, mathMin(255, rgb.r - mathRound(255 * - (amount / 100))));
-        rgb.g = mathMax(0, mathMin(255, rgb.g - mathRound(255 * - (amount / 100))));
-        rgb.b = mathMax(0, mathMin(255, rgb.b - mathRound(255 * - (amount / 100))));
-        return tinycolor(rgb);
-    function darken (color, amount) {
-        hsl.l -= amount / 100;
-    // Spin takes a positive or negative amount within [-360, 360] indicating the change of hue.
-    // Values outside of this range will be wrapped into this range.
-    function spin(color, amount) {
-        var hue = (mathRound(hsl.h) + amount) % 360;
-        hsl.h = hue < 0 ? 360 + hue : hue;
-    // Combination Functions
-    // Thanks to jQuery xColor for some of the ideas behind these
-    // <https://github.com/infusion/jQuery-xcolor/blob/master/jquery.xcolor.js>
-    function complement(color) {
-        hsl.h = (hsl.h + 180) % 360;
-    function triad(color) {
-        var h = hsl.h;
-        return [
-            tinycolor(color),
-            tinycolor({ h: (h + 120) % 360, s: hsl.s, l: hsl.l }),
-            tinycolor({ h: (h + 240) % 360, s: hsl.s, l: hsl.l })
-    function tetrad(color) {
-        var h = hsl.h;
-        return [
-            tinycolor(color),
-            tinycolor({ h: (h + 90) % 360, s: hsl.s, l: hsl.l }),
-            tinycolor({ h: (h + 180) % 360, s: hsl.s, l: hsl.l }),
-            tinycolor({ h: (h + 270) % 360, s: hsl.s, l: hsl.l })
-    function splitcomplement(color) {
-        var h = hsl.h;
-        return [
-            tinycolor(color),
-            tinycolor({ h: (h + 72) % 360, s: hsl.s, l: hsl.l}),
-            tinycolor({ h: (h + 216) % 360, s: hsl.s, l: hsl.l})
-    function analogous(color, results, slices) {
-        results = results || 6;
-        slices = slices || 30;
-        var part = 360 / slices;
-        var ret = [tinycolor(color)];
-        for (hsl.h = ((hsl.h - (part * results >> 1)) + 720) % 360; --results; ) {
-            hsl.h = (hsl.h + part) % 360;
-            ret.push(tinycolor(hsl));
+        function flip(o) {
+            var flipped = {};
+            for (var i in o) o.hasOwnProperty(i) && (flipped[o[i]] = i);
+            return flipped
-        return ret;
-    function monochromatic(color, results) {
-        var hsv = tinycolor(color).toHsv();
-        var h = hsv.h, s = hsv.s, v = hsv.v;
-        var ret = [];
-        var modification = 1 / results;
-        while (results--) {
-            ret.push(tinycolor({ h: h, s: s, v: v}));
-            v = (v + modification) % 1;
+        function boundAlpha(a) {
+            return a = parseFloat(a), (isNaN(a) || 0 > a || a > 1) && (a = 1), a
-        return ret;
-    // Utility Functions
-    tinycolor.mix = function(color1, color2, amount) {
-        amount = (amount === 0) ? 0 : (amount || 50);
-        var rgb1 = tinycolor(color1).toRgb();
-        var rgb2 = tinycolor(color2).toRgb();
-        var p = amount / 100;
-        var w = p * 2 - 1;
-        var a = rgb2.a - rgb1.a;
-        var w1;
-        if (w * a == -1) {
-            w1 = w;
-        } else {
-            w1 = (w + a) / (1 + w * a);
+        function bound01(n, max) {
+            isOnePointZero(n) && (n = "100%");
+            var processPercent = isPercentage(n);
+            return n = mathMin(max, mathMax(0, parseFloat(n))), processPercent && (n = parseInt(n * max, 10) / 100), math.abs(n - max) < 1e-6 ? 1 : n % max / parseFloat(max)
-        w1 = (w1 + 1) / 2;
-        var w2 = 1 - w1;
-        var rgba = {
-            r: rgb2.r * w1 + rgb1.r * w2,
-            g: rgb2.g * w1 + rgb1.g * w2,
-            b: rgb2.b * w1 + rgb1.b * w2,
-            a: rgb2.a * p  + rgb1.a * (1 - p)
-        return tinycolor(rgba);
-    // Readability Functions
-    // <http://www.w3.org/TR/AERT#color-contrast>
-    // `readability`
-    // Analyze the 2 colors and returns an object with the following properties:
-    //    `brightness`: difference in brightness between the two colors
-    //    `color`: difference in color/hue between the two colors
-    tinycolor.readability = function(color1, color2) {
-        var c1 = tinycolor(color1);
-        var c2 = tinycolor(color2);
-        var rgb1 = c1.toRgb();
-        var rgb2 = c2.toRgb();
-        var brightnessA = c1.getBrightness();
-        var brightnessB = c2.getBrightness();
-        var colorDiff = (
-            Math.max(rgb1.r, rgb2.r) - Math.min(rgb1.r, rgb2.r) +
-            Math.max(rgb1.g, rgb2.g) - Math.min(rgb1.g, rgb2.g) +
-            Math.max(rgb1.b, rgb2.b) - Math.min(rgb1.b, rgb2.b)
-        return {
-            brightness: Math.abs(brightnessA - brightnessB),
-            color: colorDiff
-    // `readable`
-    // http://www.w3.org/TR/AERT#color-contrast
-    // Ensure that foreground and background color combinations provide sufficient contrast.
-    // *Example*
-    //    tinycolor.isReadable("#000", "#111") => false
-    tinycolor.isReadable = function(color1, color2) {
-        var readability = tinycolor.readability(color1, color2);
-        return readability.brightness > 125 && readability.color > 500;
-    // `mostReadable`
-    // Given a base color and a list of possible foreground or background
-    // colors for that base, returns the most readable color.
-    // *Example*
-    //    tinycolor.mostReadable("#123", ["#fff", "#000"]) => "#000"
-    tinycolor.mostReadable = function(baseColor, colorList) {
-        var bestColor = null;
-        var bestScore = 0;
-        var bestIsReadable = false;
-        for (var i=0; i < colorList.length; i++) {
-            // We normalize both around the "acceptable" breaking point,
-            // but rank brightness constrast higher than hue.
-            var readability = tinycolor.readability(baseColor, colorList[i]);
-            var readable = readability.brightness > 125 && readability.color > 500;
-            var score = 3 * (readability.brightness / 125) + (readability.color / 500);
-            if ((readable && ! bestIsReadable) ||
-                (readable && bestIsReadable && score > bestScore) ||
-                ((! readable) && (! bestIsReadable) && score > bestScore)) {
-                bestIsReadable = readable;
-                bestScore = score;
-                bestColor = tinycolor(colorList[i]);
+        function clamp01(val) {
+            return mathMin(1, mathMax(0, val))
-        return bestColor;
-    // Big List of Colors
-    // <http://www.w3.org/TR/css3-color/#svg-color>
-    var names = tinycolor.names = {
-        aliceblue: "f0f8ff",
-        antiquewhite: "faebd7",
-        aqua: "0ff",
-        aquamarine: "7fffd4",
-        azure: "f0ffff",
-        beige: "f5f5dc",
-        bisque: "ffe4c4",
-        black: "000",
-        blanchedalmond: "ffebcd",
-        blue: "00f",
-        blueviolet: "8a2be2",
-        brown: "a52a2a",
-        burlywood: "deb887",
-        burntsienna: "ea7e5d",
-        cadetblue: "5f9ea0",
-        chartreuse: "7fff00",
-        chocolate: "d2691e",
-        coral: "ff7f50",
-        cornflowerblue: "6495ed",
-        cornsilk: "fff8dc",
-        crimson: "dc143c",
-        cyan: "0ff",
-        darkblue: "00008b",
-        darkcyan: "008b8b",
-        darkgoldenrod: "b8860b",
-        darkgray: "a9a9a9",
-        darkgreen: "006400",
-        darkgrey: "a9a9a9",
-        darkkhaki: "bdb76b",
-        darkmagenta: "8b008b",
-        darkolivegreen: "556b2f",
-        darkorange: "ff8c00",
-        darkorchid: "9932cc",
-        darkred: "8b0000",
-        darksalmon: "e9967a",
-        darkseagreen: "8fbc8f",
-        darkslateblue: "483d8b",
-        darkslategray: "2f4f4f",
-        darkslategrey: "2f4f4f",
-        darkturquoise: "00ced1",
-        darkviolet: "9400d3",
-        deeppink: "ff1493",
-        deepskyblue: "00bfff",
-        dimgray: "696969",
-        dimgrey: "696969",
-        dodgerblue: "1e90ff",
-        firebrick: "b22222",
-        floralwhite: "fffaf0",
-        forestgreen: "228b22",
-        fuchsia: "f0f",
-        gainsboro: "dcdcdc",
-        ghostwhite: "f8f8ff",
-        gold: "ffd700",
-        goldenrod: "daa520",
-        gray: "808080",
-        green: "008000",
-        greenyellow: "adff2f",
-        grey: "808080",
-        honeydew: "f0fff0",
-        hotpink: "ff69b4",
-        indianred: "cd5c5c",
-        indigo: "4b0082",
-        ivory: "fffff0",
-        khaki: "f0e68c",
-        lavender: "e6e6fa",
-        lavenderblush: "fff0f5",
-        lawngreen: "7cfc00",
-        lemonchiffon: "fffacd",
-        lightblue: "add8e6",
-        lightcoral: "f08080",
-        lightcyan: "e0ffff",
-        lightgoldenrodyellow: "fafad2",
-        lightgray: "d3d3d3",
-        lightgreen: "90ee90",
-        lightgrey: "d3d3d3",
-        lightpink: "ffb6c1",
-        lightsalmon: "ffa07a",
-        lightseagreen: "20b2aa",
-        lightskyblue: "87cefa",
-        lightslategray: "789",
-        lightslategrey: "789",
-        lightsteelblue: "b0c4de",
-        lightyellow: "ffffe0",
-        lime: "0f0",
-        limegreen: "32cd32",
-        linen: "faf0e6",
-        magenta: "f0f",
-        maroon: "800000",
-        mediumaquamarine: "66cdaa",
-        mediumblue: "0000cd",
-        mediumorchid: "ba55d3",
-        mediumpurple: "9370db",
-        mediumseagreen: "3cb371",
-        mediumslateblue: "7b68ee",
-        mediumspringgreen: "00fa9a",
-        mediumturquoise: "48d1cc",
-        mediumvioletred: "c71585",
-        midnightblue: "191970",
-        mintcream: "f5fffa",
-        mistyrose: "ffe4e1",
-        moccasin: "ffe4b5",
-        navajowhite: "ffdead",
-        navy: "000080",
-        oldlace: "fdf5e6",
-        olive: "808000",
-        olivedrab: "6b8e23",
-        orange: "ffa500",
-        orangered: "ff4500",
-        orchid: "da70d6",
-        palegoldenrod: "eee8aa",
-        palegreen: "98fb98",
-        paleturquoise: "afeeee",
-        palevioletred: "db7093",
-        papayawhip: "ffefd5",
-        peachpuff: "ffdab9",
-        peru: "cd853f",
-        pink: "ffc0cb",
-        plum: "dda0dd",
-        powderblue: "b0e0e6",
-        purple: "800080",
-        rebeccapurple: "663399",
-        red: "f00",
-        rosybrown: "bc8f8f",
-        royalblue: "4169e1",
-        saddlebrown: "8b4513",
-        salmon: "fa8072",
-        sandybrown: "f4a460",
-        seagreen: "2e8b57",
-        seashell: "fff5ee",
-        sienna: "a0522d",
-        silver: "c0c0c0",
-        skyblue: "87ceeb",
-        slateblue: "6a5acd",
-        slategray: "708090",
-        slategrey: "708090",
-        snow: "fffafa",
-        springgreen: "00ff7f",
-        steelblue: "4682b4",
-        tan: "d2b48c",
-        teal: "008080",
-        thistle: "d8bfd8",
-        tomato: "ff6347",
-        turquoise: "40e0d0",
-        violet: "ee82ee",
-        wheat: "f5deb3",
-        white: "fff",
-        whitesmoke: "f5f5f5",
-        yellow: "ff0",
-        yellowgreen: "9acd32"
-    // Make it easy to access colors via `hexNames[hex]`
-    var hexNames = tinycolor.hexNames = flip(names);
-    // Utilities
-    // `{ 'name1': 'val1' }` becomes `{ 'val1': 'name1' }`
-    function flip(o) {
-        var flipped = { };
-        for (var i in o) {
-            if (o.hasOwnProperty(i)) {
-                flipped[o[i]] = i;
+        function parseIntFromHex(val) {
+            return parseInt(val, 16)
-        return flipped;
-    // Return a valid alpha value [0,1] with all invalid values being set to 1
-    function boundAlpha(a) {
-        a = parseFloat(a);
-        if (isNaN(a) || a < 0 || a > 1) {
-            a = 1;
+        function isOnePointZero(n) {
+            return "string" == typeof n && -1 != n.indexOf(".") && 1 === parseFloat(n)
-        return a;
-    // Take input from [0, n] and return it as [0, 1]
-    function bound01(n, max) {
-        if (isOnePointZero(n)) { n = "100%"; }
-        var processPercent = isPercentage(n);
-        n = mathMin(max, mathMax(0, parseFloat(n)));
-        // Automatically convert percentage into number
-        if (processPercent) {
-            n = parseInt(n * max, 10) / 100;
+        function isPercentage(n) {
+            return "string" == typeof n && -1 != n.indexOf("%")
-        // Handle floating point rounding errors
-        if ((math.abs(n - max) < 0.000001)) {
-            return 1;
+        function pad2(c) {
+            return 1 == c.length ? "0" + c : "" + c
-        // Convert into [0, 1] range if it isn't already
-        return (n % max) / parseFloat(max);
-    // Force a number between 0 and 1
-    function clamp01(val) {
-        return mathMin(1, mathMax(0, val));
-    // Parse a base-16 hex value into a base-10 integer
-    function parseIntFromHex(val) {
-        return parseInt(val, 16);
-    // Need to handle 1.0 as 100%, since once it is a number, there is no difference between it and 1
-    // <http://stackoverflow.com/questions/7422072/javascript-how-to-detect-number-as-a-decimal-including-1-0>
-    function isOnePointZero(n) {
-        return typeof n == "string" && n.indexOf('.') != -1 && parseFloat(n) === 1;
-    // Check to see if string passed in is a percentage
-    function isPercentage(n) {
-        return typeof n === "string" && n.indexOf('%') != -1;
-    // Force a hex value to have 2 characters
-    function pad2(c) {
-        return c.length == 1 ? '0' + c : '' + c;
-    // Replace a decimal with it's percentage value
-    function convertToPercentage(n) {
-        if (n <= 1) {
-            n = (n * 100) + "%";
+        function convertToPercentage(n) {
+            return 1 >= n && (n = 100 * n + "%"), n
-        return n;
-    // Converts a decimal to a hex value
-    function convertDecimalToHex(d) {
-        return Math.round(parseFloat(d) * 255).toString(16);
-    // Converts a hex value to a decimal
-    function convertHexToDecimal(h) {
-        return (parseIntFromHex(h) / 255);
-    var matchers = (function() {
-        // <http://www.w3.org/TR/css3-values/#integers>
-        var CSS_INTEGER = "[-\\+]?\\d+%?";
-        // <http://www.w3.org/TR/css3-values/#number-value>
-        var CSS_NUMBER = "[-\\+]?\\d*\\.\\d+%?";
-        // Allow positive/negative integer/number.  Don't capture the either/or, just the entire outcome.
-        var CSS_UNIT = "(?:" + CSS_NUMBER + ")|(?:" + CSS_INTEGER + ")";
-        // Actual matching.
-        // Parentheses and commas are optional, but not required.
-        // Whitespace can take the place of commas or opening paren
-        var PERMISSIVE_MATCH3 = "[\\s|\\(]+(" + CSS_UNIT + ")[,|\\s]+(" + CSS_UNIT + ")[,|\\s]+(" + CSS_UNIT + ")\\s*\\)?";
-        var PERMISSIVE_MATCH4 = "[\\s|\\(]+(" + CSS_UNIT + ")[,|\\s]+(" + CSS_UNIT + ")[,|\\s]+(" + CSS_UNIT + ")[,|\\s]+(" + CSS_UNIT + ")\\s*\\)?";
-        return {
-            rgb: new RegExp("rgb" + PERMISSIVE_MATCH3),
-            rgba: new RegExp("rgba" + PERMISSIVE_MATCH4),
-            hsl: new RegExp("hsl" + PERMISSIVE_MATCH3),
-            hsla: new RegExp("hsla" + PERMISSIVE_MATCH4),
-            hsv: new RegExp("hsv" + PERMISSIVE_MATCH3),
-            hsva: new RegExp("hsva" + PERMISSIVE_MATCH4),
-            hex3: /^([0-9a-fA-F]{1})([0-9a-fA-F]{1})([0-9a-fA-F]{1})$/,
-            hex6: /^([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})$/,
-            hex8: /^([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})$/
-    // `stringInputToObject`
-    // Permissive string parsing.  Take in a number of formats, and output an object
-    // based on detected format.  Returns `{ r, g, b }` or `{ h, s, l }` or `{ h, s, v}`
-    function stringInputToObject(color) {
-        color = color.replace(trimLeft,'').replace(trimRight, '').toLowerCase();
-        var named = false;
-        if (names[color]) {
-            color = names[color];
-            named = true;
+        function convertDecimalToHex(d) {
+            return Math.round(255 * parseFloat(d)).toString(16)
-        else if (color == 'transparent') {
-            return { r: 0, g: 0, b: 0, a: 0, format: "name" };
-        // Try to match string input using regular expressions.
-        // Keep most of the number bounding out of this function - don't worry about [0,1] or [0,100] or [0,360]
-        // Just return an object and let the conversion functions handle that.
-        // This way the result will be the same whether the tinycolor is initialized with string or object.
-        var match;
-        if ((match = matchers.rgb.exec(color))) {
-            return { r: match[1], g: match[2], b: match[3] };
+        function convertHexToDecimal(h) {
+            return parseIntFromHex(h) / 255
-        if ((match = matchers.rgba.exec(color))) {
-            return { r: match[1], g: match[2], b: match[3], a: match[4] };
-        if ((match = matchers.hsl.exec(color))) {
-            return { h: match[1], s: match[2], l: match[3] };
-        if ((match = matchers.hsla.exec(color))) {
-            return { h: match[1], s: match[2], l: match[3], a: match[4] };
-        if ((match = matchers.hsv.exec(color))) {
-            return { h: match[1], s: match[2], v: match[3] };
-        if ((match = matchers.hsva.exec(color))) {
-            return { h: match[1], s: match[2], v: match[3], a: match[4] };
-        if ((match = matchers.hex8.exec(color))) {
-            return {
+        function stringInputToObject(color) {
+            color = color.replace(trimLeft, "").replace(trimRight, "").toLowerCase();
+            var named = !1;
+            if (names[color]) color = names[color], named = !0;
+            else if ("transparent" == color) return {
+                r: 0,
+                g: 0,
+                b: 0,
+                a: 0,
+                format: "name"
+            var match;
+            return (match = matchers.rgb.exec(color)) ? {
+                r: match[1],
+                g: match[2],
+                b: match[3]
+            } : (match = matchers.rgba.exec(color)) ? {
+                r: match[1],
+                g: match[2],
+                b: match[3],
+                a: match[4]
+            } : (match = matchers.hsl.exec(color)) ? {
+                h: match[1],
+                s: match[2],
+                l: match[3]
+            } : (match = matchers.hsla.exec(color)) ? {
+                h: match[1],
+                s: match[2],
+                l: match[3],
+                a: match[4]
+            } : (match = matchers.hsv.exec(color)) ? {
+                h: match[1],
+                s: match[2],
+                v: match[3]
+            } : (match = matchers.hex8.exec(color)) ? {
                 a: convertHexToDecimal(match[1]),
                 r: parseIntFromHex(match[2]),
                 g: parseIntFromHex(match[3]),
                 b: parseIntFromHex(match[4]),
                 format: named ? "name" : "hex8"
-        if ((match = matchers.hex6.exec(color))) {
-            return {
+            } : (match = matchers.hex6.exec(color)) ? {
                 r: parseIntFromHex(match[1]),
                 g: parseIntFromHex(match[2]),
                 b: parseIntFromHex(match[3]),
                 format: named ? "name" : "hex"
-        if ((match = matchers.hex3.exec(color))) {
-            return {
-                r: parseIntFromHex(match[1] + '' + match[1]),
-                g: parseIntFromHex(match[2] + '' + match[2]),
-                b: parseIntFromHex(match[3] + '' + match[3]),
+            } : (match = matchers.hex3.exec(color)) ? {
+                r: parseIntFromHex(match[1] + "" + match[1]),
+                g: parseIntFromHex(match[2] + "" + match[2]),
+                b: parseIntFromHex(match[3] + "" + match[3]),
+            } : !1
-        return false;
-    window.tinycolor = tinycolor;
-    $(function () {
-        if ($.fn.spectrum.load) {
-            $.fn.spectrum.processNativeColorInputs();
+        var trimLeft = /^[\s,#]+/,
+            trimRight = /\s+$/,
+            tinyCounter = 0,
+            math = Math,
+            mathRound = math.round,
+            mathMin = math.min,
+            mathMax = math.max,
+            mathRandom = math.random;
+        tinycolor.fromRatio = function(color, opts) {
+            if ("object" == typeof color) {
+                var newColor = {};
+                for (var i in color) color.hasOwnProperty(i) && (newColor[i] = "a" === i ? color[i] : convertToPercentage(color[i]));
+                color = newColor
+            return tinycolor(color, opts)
+        }, tinycolor.equals = function(color1, color2) {
+            return color1 && color2 ? tinycolor(color1).toRgbString() == tinycolor(color2).toRgbString() : !1
+        }, tinycolor.random = function() {
+            return tinycolor.fromRatio({
+                r: mathRandom(),
+                g: mathRandom(),
+                b: mathRandom()
+        }, tinycolor.desaturate = function(color, amount) {
+            amount = 0 === amount ? 0 : amount || 10;
+            var hsl = tinycolor(color).toHsl();
+            return hsl.s -= amount / 100, hsl.s = clamp01(hsl.s), tinycolor(hsl)
+        }, tinycolor.saturate = function(color, amount) {
+            return hsl.s += amount / 100, hsl.s = clamp01(hsl.s), tinycolor(hsl)
+        }, tinycolor.greyscale = function(color) {
+            return tinycolor.desaturate(color, 100)
+        }, tinycolor.lighten = function(color, amount) {
+            return hsl.l += amount / 100, hsl.l = clamp01(hsl.l), tinycolor(hsl)
+        }, tinycolor.darken = function(color, amount) {
+            return hsl.l -= amount / 100, hsl.l = clamp01(hsl.l), tinycolor(hsl)
+        }, tinycolor.complement = function(color) {
+            return hsl.h = (hsl.h + 180) % 360, tinycolor(hsl)
+        }, tinycolor.triad = function(color) {
+            var hsl = tinycolor(color).toHsl(),
+                h = hsl.h;
+            return [tinycolor(color), tinycolor({
+                h: (h + 120) % 360,
+                s: hsl.s,
+                l: hsl.l
+            }), tinycolor({
+                h: (h + 240) % 360,
+                s: hsl.s,
+                l: hsl.l
+        }, tinycolor.tetrad = function(color) {
+                h = hsl.h;
+                h: (h + 90) % 360,
+                s: hsl.s,
+                l: hsl.l
+            }), tinycolor({
+                h: (h + 180) % 360,
+                s: hsl.s,
+                l: hsl.l
+            }), tinycolor({
+                h: (h + 270) % 360,
+                s: hsl.s,
+                l: hsl.l
+        }, tinycolor.splitcomplement = function(color) {
+                h = hsl.h;
+                h: (h + 72) % 360,
+                s: hsl.s,
+                l: hsl.l
+            }), tinycolor({
+                h: (h + 216) % 360,
+                s: hsl.s,
+                l: hsl.l
+        }, tinycolor.analogous = function(color, results, slices) {
+            results = results || 6, slices = slices || 30;
+                part = 360 / slices,
+                ret = [tinycolor(color)];
+            for (hsl.h = (hsl.h - (part * results >> 1) + 720) % 360; --results;) hsl.h = (hsl.h + part) % 360, ret.push(tinycolor(hsl));
+            return ret
+        }, tinycolor.monochromatic = function(color, results) {
+            results = results || 6;
+            for (var hsv = tinycolor(color).toHsv(), h = hsv.h, s = hsv.s, v = hsv.v, ret = [], modification = 1 / results; results--;) ret.push(tinycolor({
+                h: h,
+                s: s,
+                v: v
+            })), v = (v + modification) % 1;
+            return ret
+        }, tinycolor.readability = function(color1, color2) {
+            var a = tinycolor(color1).toRgb(),
+                b = tinycolor(color2).toRgb(),
+                brightnessA = (299 * a.r + 587 * a.g + 114 * a.b) / 1e3,
+                brightnessB = (299 * b.r + 587 * b.g + 114 * b.b) / 1e3,
+                colorDiff = Math.max(a.r, b.r) - Math.min(a.r, b.r) + Math.max(a.g, b.g) - Math.min(a.g, b.g) + Math.max(a.b, b.b) - Math.min(a.b, b.b);
+            return {
+                brightness: Math.abs(brightnessA - brightnessB),
+                color: colorDiff
+        }, tinycolor.readable = function(color1, color2) {
+            var readability = tinycolor.readability(color1, color2);
+            return readability.brightness > 125 && readability.color > 500
+        }, tinycolor.mostReadable = function(baseColor, colorList) {
+            for (var bestColor = null, bestScore = 0, bestIsReadable = !1, i = 0; i < colorList.length; i++) {
+                var readability = tinycolor.readability(baseColor, colorList[i]),
+                    readable = readability.brightness > 125 && readability.color > 500,
+                    score = 3 * (readability.brightness / 125) + readability.color / 500;
+                (readable && !bestIsReadable || readable && bestIsReadable && score > bestScore || !readable && !bestIsReadable && score > bestScore) && (bestIsReadable = readable, bestScore = score, bestColor = tinycolor(colorList[i]))
+            return bestColor
+        var names = tinycolor.names = {
+            aliceblue: "f0f8ff",
+            antiquewhite: "faebd7",
+            aqua: "0ff",
+            aquamarine: "7fffd4",
+            azure: "f0ffff",
+            beige: "f5f5dc",
+            bisque: "ffe4c4",
+            black: "000",
+            blanchedalmond: "ffebcd",
+            blue: "00f",
+            blueviolet: "8a2be2",
+            brown: "a52a2a",
+            burlywood: "deb887",
+            burntsienna: "ea7e5d",
+            cadetblue: "5f9ea0",
+            chartreuse: "7fff00",
+            chocolate: "d2691e",
+            coral: "ff7f50",
+            cornflowerblue: "6495ed",
+            cornsilk: "fff8dc",
+            crimson: "dc143c",
+            cyan: "0ff",
+            darkblue: "00008b",
+            darkcyan: "008b8b",
+            darkgoldenrod: "b8860b",
+            darkgray: "a9a9a9",
+            darkgreen: "006400",
+            darkgrey: "a9a9a9",
+            darkkhaki: "bdb76b",
+            darkmagenta: "8b008b",
+            darkolivegreen: "556b2f",
+            darkorange: "ff8c00",
+            darkorchid: "9932cc",
+            darkred: "8b0000",
+            darksalmon: "e9967a",
+            darkseagreen: "8fbc8f",
+            darkslateblue: "483d8b",
+            darkslategray: "2f4f4f",
+            darkslategrey: "2f4f4f",
+            darkturquoise: "00ced1",
+            darkviolet: "9400d3",
+            deeppink: "ff1493",
+            deepskyblue: "00bfff",
+            dimgray: "696969",
+            dimgrey: "696969",
+            dodgerblue: "1e90ff",
+            firebrick: "b22222",
+            floralwhite: "fffaf0",
+            forestgreen: "228b22",
+            fuchsia: "f0f",
+            gainsboro: "dcdcdc",
+            ghostwhite: "f8f8ff",
+            gold: "ffd700",
+            goldenrod: "daa520",
+            gray: "808080",
+            green: "008000",
+            greenyellow: "adff2f",
+            grey: "808080",
+            honeydew: "f0fff0",
+            hotpink: "ff69b4",
+            indianred: "cd5c5c",
+            indigo: "4b0082",
+            ivory: "fffff0",
+            khaki: "f0e68c",
+            lavender: "e6e6fa",
+            lavenderblush: "fff0f5",
+            lawngreen: "7cfc00",
+            lemonchiffon: "fffacd",
+            lightblue: "add8e6",
+            lightcoral: "f08080",
+            lightcyan: "e0ffff",
+            lightgoldenrodyellow: "fafad2",
+            lightgray: "d3d3d3",
+            lightgreen: "90ee90",
+            lightgrey: "d3d3d3",
+            lightpink: "ffb6c1",
+            lightsalmon: "ffa07a",
+            lightseagreen: "20b2aa",
+            lightskyblue: "87cefa",
+            lightslategray: "789",
+            lightslategrey: "789",
+            lightsteelblue: "b0c4de",
+            lightyellow: "ffffe0",
+            lime: "0f0",
+            limegreen: "32cd32",
+            linen: "faf0e6",
+            magenta: "f0f",
+            maroon: "800000",
+            mediumaquamarine: "66cdaa",
+            mediumblue: "0000cd",
+            mediumorchid: "ba55d3",
+            mediumpurple: "9370db",
+            mediumseagreen: "3cb371",
+            mediumslateblue: "7b68ee",
+            mediumspringgreen: "00fa9a",
+            mediumturquoise: "48d1cc",
+            mediumvioletred: "c71585",
+            midnightblue: "191970",
+            mintcream: "f5fffa",
+            mistyrose: "ffe4e1",
+            moccasin: "ffe4b5",
+            navajowhite: "ffdead",
+            navy: "000080",
+            oldlace: "fdf5e6",
+            olive: "808000",
+            olivedrab: "6b8e23",
+            orange: "ffa500",
+            orangered: "ff4500",
+            orchid: "da70d6",
+            palegoldenrod: "eee8aa",
+            palegreen: "98fb98",
+            paleturquoise: "afeeee",
+            palevioletred: "db7093",
+            papayawhip: "ffefd5",
+            peachpuff: "ffdab9",
+            peru: "cd853f",
+            pink: "ffc0cb",
+            plum: "dda0dd",
+            powderblue: "b0e0e6",
+            purple: "800080",
+            red: "f00",
+            rosybrown: "bc8f8f",
+            royalblue: "4169e1",
+            saddlebrown: "8b4513",
+            salmon: "fa8072",
+            sandybrown: "f4a460",
+            seagreen: "2e8b57",
+            seashell: "fff5ee",
+            sienna: "a0522d",
+            silver: "c0c0c0",
+            skyblue: "87ceeb",
+            slateblue: "6a5acd",
+            slategray: "708090",
+            slategrey: "708090",
+            snow: "fffafa",
+            springgreen: "00ff7f",
+            steelblue: "4682b4",
+            tan: "d2b48c",
+            teal: "008080",
+            thistle: "d8bfd8",
+            tomato: "ff6347",
+            turquoise: "40e0d0",
+            violet: "ee82ee",
+            wheat: "f5deb3",
+            white: "fff",
+            whitesmoke: "f5f5f5",
+            yellow: "ff0",
+            yellowgreen: "9acd32"
+        }, hexNames = tinycolor.hexNames = flip(names),
+            matchers = function() {
+                var CSS_INTEGER = "[-\\+]?\\d+%?",
+                    CSS_NUMBER = "[-\\+]?\\d*\\.\\d+%?",
+                    CSS_UNIT = "(?:" + CSS_NUMBER + ")|(?:" + CSS_INTEGER + ")",
+                    PERMISSIVE_MATCH3 = "[\\s|\\(]+(" + CSS_UNIT + ")[,|\\s]+(" + CSS_UNIT + ")[,|\\s]+(" + CSS_UNIT + ")\\s*\\)?",
+                    PERMISSIVE_MATCH4 = "[\\s|\\(]+(" + CSS_UNIT + ")[,|\\s]+(" + CSS_UNIT + ")[,|\\s]+(" + CSS_UNIT + ")[,|\\s]+(" + CSS_UNIT + ")\\s*\\)?";
+                return {
+                    rgb: new RegExp("rgb" + PERMISSIVE_MATCH3),
+                    rgba: new RegExp("rgba" + PERMISSIVE_MATCH4),
+                    hsl: new RegExp("hsl" + PERMISSIVE_MATCH3),
+                    hsla: new RegExp("hsla" + PERMISSIVE_MATCH4),
+                    hsv: new RegExp("hsv" + PERMISSIVE_MATCH3),
+                    hex3: /^([0-9a-fA-F]{1})([0-9a-fA-F]{1})([0-9a-fA-F]{1})$/,
+                    hex6: /^([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})$/,
+                    hex8: /^([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})$/
+        window.tinycolor = tinycolor
+    }(), $(function() {
+        $.fn.spectrum.load && $.fn.spectrum.processNativeColorInputs()
+}(window, jQuery);
More information about the Mapbender_commits mailing list
