[Mapbender-commits] r9241 - trunk/mapbender/lib
svn_mapbender at osgeo.org
Tue Jul 7 07:35:11 PDT 2015
Author: syed
Date: 2015-07-07 07:35:11 -0700 (Tue, 07 Jul 2015)
New Revision: 9241
trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
fix select feature
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2015-07-07 12:04:35 UTC (rev 9240)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2015-07-07 14:35:11 UTC (rev 9241)
@@ -181,6 +181,7 @@
$.each(self._kmls, function(_, itm) {
$.each(itm.data.features, function(k, v) {
if (ispoint) {
+ console.log( "isPoint" );
self.matchFeatureToPoint(v, clickPoint, matchedIds, res, itm, wgspt, k);
} else {
self.matchFeatureToBox(v, {
@@ -196,18 +197,63 @@
inBox: function(minx, miny, maxx, maxy, selectBoxMinx, selectBoxMaxx, selectBoxMiny, selectBoxMaxy) {
- // Erster Punk (minx,miny)
- // Zweiter Punk (maxx,maxy)
- if ( ( minx >= selectBoxMinx && minx <= selectBoxMaxx ) || ( miny >= selectBoxMiny && miny <= selectBoxMaxy )) {
- return true;
+ // ############## proof the min-point ##################
+ // proof hit on the x-axis
+ if ( ( minx >= selectBoxMinx && minx <= selectBoxMaxx ) ) {
+ // if x hit, proof y
+ if ( ( miny >= selectBoxMiny && miny <= selectBoxMaxy ) ) {
+ return true;
- if ( ( maxx >= selectBoxMinx && maxx <= selectBoxMaxx ) || ( maxy > selectBoxMiny && maxy < selectBoxMaxy )) {
- return true;
+ // proof hit on the y-axis
+ // if y hit, proof x
+ return true;
+ // ############## proof the max-point ##################
+ if ( ( maxx >= selectBoxMinx && maxx <= selectBoxMaxx ) ) {
+ if ( ( maxy >= selectBoxMiny && maxy <= selectBoxMaxy ) ) {
+ return true;
+ return true;
+ // ############## proof if selectbox contains the feature geometry ##################
+ // proof on x-axis
+ if ( minx >= selectBoxMinx && minx <= selectBoxMaxx && maxx >= selectBoxMinx && maxx <= selectBoxMaxx ) {
+ if ( miny <= selectBoxMiny && maxy >= selectBoxMaxy ) {
+ return true;
+ // proof on y-axis
+ if ( miny >= selectBoxMiny && miny <= selectBoxMaxy && maxy >= selectBoxMiny && maxx <= selectBoxMaxy ) {
+ if ( minx <= selectBoxMinx && maxx >= selectBoxMaxx ) {
+ return true;
return false;
+ pointInBox: function(pointX, pointY, selectBoxMinx, selectBoxMaxx, selectBoxMiny, selectBoxMaxy) {
+ if ( ( pointX >= selectBoxMinx && pointX <= selectBoxMaxx ) && ( pointY >= selectBoxMiny && pointY <= selectBoxMaxy )) {
+ return true;
matchFeatureToPoint: function(feat, clickPoint, matchedIds, res, itm, wgspt, idx) {
+ console.log( "point" );
if (feat.geometry.type.match(/point/i)) {
var pt = Proj4js.transform(this.wgs84, this.targetProj, {
x: feat.geometry.coordinates[0],
@@ -236,7 +282,8 @@
matchFeatureToBox: function(feat, wgsbox, matchedIds, itm, idx) {
- if (this.inBox(wgsbox.min.x, wgsbox.min.y, wgsbox.max.x, wgsbox.max.y, feat.geometry.coordinates[0], feat.geometry.coordinates[1])) {
+ console.log( feat.geometry );
+ if (this.pointInBox(feat.geometry.coordinates[0], feat.geometry.coordinates[1], wgsbox.min.x, wgsbox.max.x, wgsbox.min.y, wgsbox.max.y)) {
matchedIds.push({
url: itm.url,
@@ -244,7 +291,7 @@
} else {
var box = this.getBbox(feat);
- if (this.inBox(box[0], box[1], box[2], box[3], wgsbox.min.x, wgsbox.min.y) || this.inBox(box[0], box[1], box[2], box[3], wgsbox.min.x, wgsbox.max.y) || this.inBox(box[0], box[1], box[2], box[3], wgsbox.max.x, wgsbox.max.y) || this.inBox(box[0], box[1], box[2], box[3], wgsbox.max.x, wgsbox.min.y)) {
+ if (this.inBox(box[0], box[1], box[2], box[3], wgsbox.min.x, wgsbox.max.x, wgsbox.min.y, wgsbox.max.y) ) {
matchedIds.push({
url: itm.url,
More information about the Mapbender_commits
