[Mapbender-commits] r9252 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jul 14 02:16:31 PDT 2015
Author: armin11
Date: 2015-07-14 02:16:31 -0700 (Tue, 14 Jul 2015)
New Revision: 9252
   trunk/mapbender/http/plugins/kmlTree.php
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/http/plugins/mb_loadkmlgeorss.js
Bugfixes for new digitize module
Modified: trunk/mapbender/http/plugins/kmlTree.php
--- trunk/mapbender/http/plugins/kmlTree.php	2015-07-14 06:24:49 UTC (rev 9251)
+++ trunk/mapbender/http/plugins/kmlTree.php	2015-07-14 09:16:31 UTC (rev 9252)
@@ -580,23 +580,25 @@
                 $(dlg).dialog('destroy');
+	    //upload of remote files
             var ifr = $('iframe[name="kml-upload-target"]')[0];
             var onloadfun = function() {
                 ifr.onload = null;
-                var txt = $(this).contents().find('pre').text(); // result von uploadKML.php
+                var txt = $(this).contents().find('pre').text(); // result von php/uploadKML.php
+		//alert(txt.length);
                 var data;
+		//returns geojson from kml (from internal parser) or geojson native - no parsing or exception - then gpx!
                 try {
                     data = JSON.parse(txt);
                 } catch (e) {
                     var xml = new DOMParser().parseFromString(txt, 'application/xml');
                     data = toGeoJSON.gpx(xml);
+		//alert(JSON.stringify(data).length);
                 var kml = $('#mapframe1').data('kml');
                 var name;
-                // check the features for properties
-                data = setFeatureAttr(data);
+                // check the features for properties - old handling!!!!!
+                //data = setFeatureAttr(data);
                 if (data.hasOwnProperty('title')) {
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2015-07-14 06:24:49 UTC (rev 9251)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2015-07-14 09:16:31 UTC (rev 9252)
@@ -720,10 +720,15 @@
                     schemaInstance = instantiate( options.polygonAttributesSchema );
                     geomType = "Polygon"
                     break;
-                    case "Polyline":
+                    case "LineString":
                     schemaInstance = instantiate( options.polylineAttributesSchema );
                     geomType = "Polyline"
                     break;
+		    //TODO: difference between polyline and linestring????
+		    case "Polyline":
+                    schemaInstance = instantiate( options.polylineAttributesSchema );
+                    geomType = "Polyline"
+                    break;
                 attributesDialog.dialog('open');
                 attributesDialog.find('*').unbind();
Modified: trunk/mapbender/http/plugins/mb_loadkmlgeorss.js
--- trunk/mapbender/http/plugins/mb_loadkmlgeorss.js	2015-07-14 06:24:49 UTC (rev 9251)
+++ trunk/mapbender/http/plugins/mb_loadkmlgeorss.js	2015-07-14 09:16:31 UTC (rev 9252)
@@ -56,7 +56,7 @@
 	"sProcessing":   "Processing...",
 	"sLengthMenu":   "Show _MENU_ entries",
 	"sZeroRecords":  "No matching records found",
-	"sInfo":         "SLowing _START_ to _END_ of _TOTAL_ entries",
+	"sInfo":         "Showing _START_ to _END_ of _TOTAL_ entries",
 	"sInfoEmpty":    "Showing 0 to 0 of 0 entries",
 	"sInfoFiltered": "(filtered from _MAX_ total entries)",
 	"sInfoPostFix":  "",
More information about the Mapbender_commits mailing list
