[Mapbender-commits] r9158 - in trunk/mapbender/http: geoportal/preview javascripts php plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Mar 2 02:07:02 PST 2015
Author: syed
Date: 2015-03-02 02:07:02 -0800 (Mon, 02 Mar 2015)
New Revision: 9158
Added:
   trunk/mapbender/http/php/mb_metadata_uploadLayerPreview.php
   trunk/mapbender/http/geoportal/preview/
   trunk/mapbender/http/javascripts/mod_savewmc.php
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/http/plugins/mb_metadata_edit.js
add mb_metadata_uploadLayerPreview.php
Property changes on: trunk/mapbender/http/geoportal/preview
___________________________________________________________________
Added: svn:ignore
Modified: trunk/mapbender/http/javascripts/mod_savewmc.php
--- trunk/mapbender/http/javascripts/mod_savewmc.php	2015-03-02 09:27:24 UTC (rev 9157)
+++ trunk/mapbender/http/javascripts/mod_savewmc.php	2015-03-02 10:07:02 UTC (rev 9158)
@@ -2,8 +2,8 @@
  * License:
  * Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
  * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
 require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
@@ -46,7 +46,7 @@
 	while($row = db_fetch_array($res)) {
 		$i++;
  		$str .= "<label for=\"{$prefix}_wmcIsoTopicCategory_{$row[0]}\">" .
-			"<input class=\"wmcIsoTopicCategory\" id=\"{$prefix}_wmcIsoTopicCategory_{$row[0]}\" " .
+			"<input class=\"wmcIsoTopicCategory\" id=\"{$prefix}_wmcIsoTopicCategory_{$row[0]}\" " .
 			"type=\"checkbox\" />{$row[1]}</label>";
 	return $str;
@@ -84,23 +84,28 @@
 $labelCategories = $translatedI18nObj["labelCategories"];
 echo <<<HTML
+//TODO: add input for uuid,title already there. created and updated need no input.just save it to the database...
-var wmcSaveFormHtml = '<form><fieldset>' +
-	'<label for="{$e_id}_wmctype">{$labelNewOrOverwrite}</label>' +
-	'<select class="ui-corner-all" id="{$e_id}_wmctype">' +
-	'<option value="">{$labelNewWmc}</option></select>' +
-	'<label for="{$e_id}_wmcname">{$labelName}</label>' +
-	'<input id="{$e_id}_wmcname" type="text" class="text ui-widget-content ui-corner-all" />' +
-	'<label for="{$e_id}_wmcabstract">{$labelAbstract}</label>' +
-	'<textarea id="{$e_id}_wmcabstract" class="text ui-widget-content ui-corner-all"></textarea>' +
-	'<label for="{$e_id}_wmckeywords">{$labelKeywords}</label>' +
-	'<input id="{$e_id}_wmckeywords" type="text" class="text ui-widget-content ui-corner-all" />' +
-	'<input id="{$e_id}_wmc_id" type="hidden" />' +
-	'</fieldset><fieldset id="{$e_id}_isoTopic_cat"><legend>{$labelCategories}' +
-	'</legend>' +
-	'{$saveWmcCategoryString}' +
+var wmc_uuid = UUID.genV4().toString();
+var wmcSaveFormHtml = '<form><fieldset>' +
+	'<label for="{$e_id}_wmctype">{$labelNewOrOverwrite}</label>' +
+	'<select class="ui-corner-all" id="{$e_id}_wmctype">' +
+	'<option value="">{$labelNewWmc}</option></select>' +
+	'<label for="{$e_id}_wmcname">{$labelName}</label>' +
+	'<input id="{$e_id}_wmcname" type="text" class="text ui-widget-content ui-corner-all" />' +
+	'<label for="{$e_id}_wmcabstract">{$labelAbstract}</label>' +
+	'<textarea id="{$e_id}_wmcabstract" class="text ui-widget-content ui-corner-all"></textarea>' +
+	'<label for="{$e_id}_wmckeywords">{$labelKeywords}</label>' +
+	'<input id="{$e_id}_wmckeywords" type="text" class="text ui-widget-content ui-corner-all" />' +
+	'<input id="{$e_id}_wmc_id" type="hidden" />' +
+	'<input id="{$e_id}_wmc_uuid" value={wmc_uuid} />' +
+	'</fieldset><fieldset id="{$e_id}_isoTopic_cat"><legend>{$labelCategories}' +
+	'</legend>' +
+	'{$saveWmcCategoryString}' +
 	'</fieldset></form>';
 var originalI18nObj = $originalI18nObjJson;
 var translatedI18nObj = $translatedI18nObjJson;
Added: trunk/mapbender/http/php/mb_metadata_uploadLayerPreview.php
--- trunk/mapbender/http/php/mb_metadata_uploadLayerPreview.php	                        (rev 0)
+++ trunk/mapbender/http/php/mb_metadata_uploadLayerPreview.php	2015-03-02 10:07:02 UTC (rev 9158)
@@ -0,0 +1,141 @@
+<?php
+ * @version   Changed: ### 2015-02-26 13:38:03 UTC ###
+ * @author    Raphael.Syed <raphael.syed at WhereGroup.com> http://WhereGroup.com
+ * Gets an image for layer or wmc preview.
+ * Convert the image to the right format and save it in the @preview_dir
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+$user_id = Mapbender::session()->get("mb_user_id");
+$data = $_POST;
+$source_id = $data['source_id'];
+//set variables
+$width;
+$height;
+$new_name;
+//get the http referer and the service (wms,wmc)
+$referer = explode('=',$_SERVER["HTTP_REFERER"]);
+$service = end($referer);
+// get the file informations
+$info = pathinfo($_FILES['image']['name']);
+// get the extension of the file
+$ext = $info['extension'];
+// set the new fileName
+if ($service == 'admin_wmc_metadata') {
+    $new_name = $source_id."_wmc_preview.png";//.$ext;
+else {
+    $new_name = $source_id."_layer_map_preview.png";//.$ext;
+// get the ímage
+$image = $_FILES['image']['tmp_name'];
+//resize the image to 200px * 200px
+$new_image = dirname(__FILE__)."/../geoportal/preview/".$new_name;
+// get image size
+$size = Getimagesize($image);
+$images_orig;
+//create an gd-image-object from the source file
+switch ($ext) {
+    case 'jpg':
+        $images_orig = ImageCreateFromJPEG($image);
+        break;
+    case 'png':
+        $images_orig = ImageCreateFrompng($image);
+        break;
+    case 'gif':
+        $images_orig = ImageCreateFromgif($image);
+        break;
+    default:
+        return;
+        break;
+//if width and height are to big
+if ($size[0] >= 200 || $size[1] >= 200) {
+    // width of the origin image
+    $photoW = ImagesX($images_orig);
+    // height of the origin image
+    $photoH = ImagesY($images_orig);
+    // create new image with the calculated size
+    $images_target = ImageCreateTrueColor(200, 200);
+    //fill the new image with transparency background
+    $color = imagecolorallocatealpha($images_target, 0, 0, 0, 127); //fill transparent back
+    imagefill($images_target, 0, 0, $color);
+    imagealphablending( $images_target, false );
+    imagesavealpha($images_target, true);
+    //set the new image width and height
+    if ($size[0] > $size[1] || $size[0] == $size[1]) {
+        $width = 200;
+        $height = round($width*$size[1]/$size[0]);
+        // calculate the height of the src_image in the target_image
+        $startHeight = round((200-$height)/2);
+        // resize the image:
+        ImageCopyResampled($images_target, $images_orig, 0, $startHeight, 0, 0, $width, $height, $photoW, $photoH);
+    }else{
+        $height = 200;
+        $width = round($height*$size[0]/$size[1]);
+        $startWidth = round((200-$width)/2);
+        ImageCopyResampled($images_target, $images_orig, $startWidth, 0, 0, 0, $width, $height, $photoW, $photoH);
+    // set new target dir
+    $target = dirname(__FILE__).'/../tmp/'.$new_name;
+    // move File to the new target directory --> always save as png
+    Imagepng($images_target,$new_image);
+    // free space
+    ImageDestroy($images_orig);
+    ImageDestroy($images_target);
+    return;
+} // if image-width and height are to small
+else if($size[0] < 200 && $size[1] < 200){
+    $width = $size[0];
+    // scale the height
+    $height = $size[1];
+    ImageCopyResampled($images_target, $images_orig, $startWidth, $startHeight, 0, 0, $width, $height, $photoW, $photoH);
+    // free space
+    return;
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2015-03-02 09:27:24 UTC (rev 9157)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2015-03-02 10:07:02 UTC (rev 9158)
@@ -71,6 +71,7 @@
         '<div class="digitize-image digitize-point"></div>' +
         '<div class="digitize-image digitize-line"></div>' +
         '<div class="digitize-image digitize-polygon"></div>' +
+        '<div class="digitize-image digitize-attributes editFeatureCollection"></div>' +
         '</div>';
     var editHtml = '<div title="Edit feature">' +
@@ -564,42 +565,80 @@
     var editAttributes = function(feature, kml, url) {
         return function() {
-            attributesDialog.dialog('open');
-            attributesDialog.find('*').unbind();
-            var rows = '';
-            $.each(feature.properties, function(k, v) {
-                if(k.match(/Mapbender:/)) return;
-                rows += '<tr><td>' + k + '</td><td><input type="text" name="' + k + '" value="' + v + '"></input></td></tr>';
-            attributesDialog.find('table').html(rows);
-            attributesDialog.find('.digitize-add').bind('click', function() {
-                var newRow = $('<tr><td><input type="text"></input></td><td><input type="text"></input></td></tr>');
-                attributesDialog.find('table').append(newRow);
-                newRow.find('input').first().bind('change', function() {
-                    newRow.find('input').last().attr('name', $(this).val());
+            if ($(this).hasClass('editFeatureCollection')) {
+                    var featureCollAttrDlg = $('<div id="featureCollAttrDlg"></div>').dialog({
+                        title: "Featurecollection attributes ",// of "+ url,
+                        width: 400,
+                        // height: 212,
+                        position: {
+                            my: "center",
+                            at: "top",
+                            of: window
+                        close: function(){
+                            $('#featureCollAttrDlg').dialog('destroy');
+                            $('#featureCollAttrDlg').remove();
+                    var featureCollectionContent = "<div class='digitize-image digitize-style'></div>"+
+                                                    "<br><br>"+
+                                                    "<div><table>"+
+                                                    "<tr><td>uuid</td><td><input type='text' value='test'/></td></tr>"+
+                                                    "<tr><td>title</td><td><input type='text' value='test'/></td></tr>"+
+                                                    "<tr><td>created</td><td><input type='text' value='test'/></td></tr>"+
+                                                    "<tr><td>updated</td><td><input type='text' value='test'/></td></tr>"+
+                                                    "</table></div>"+
+                                                    "<br><br/>"+
+                                                    "<div class='digitize-image digitize-add'></div>"+
+                                                    "<div class='digitize-image digitize-save'></div>";
+                    $('#featureCollAttrDlg').append(featureCollectionContent);
+            }else{
+                attributesDialog.dialog('open');
+                attributesDialog.find('*').unbind();
+                var rows = '';
+                $.each(feature.properties, function(k, v) {
+                    if(k.match(/Mapbender:/)) return;
+                    rows += '<tr><td>' + k + '</td><td><input type="text" name="' + k + '" value="' + v + '"></input></td></tr>';
+                attributesDialog.find('table').html(rows);
+                attributesDialog.find('.digitize-add').bind('click', function() {
+                    var newRow = $('<tr><td><input type="text"></input></td><td><input type="text"></input></td></tr>');
+                    attributesDialog.find('table').append(newRow);
+                    newRow.find('input').first().bind('change', function() {
+                        newRow.find('input').last().attr('name', $(this).val());
-            var $link = $('li[title="' + url + '"] > ul > li');
+                var $link = $('li[title="' + url + '"] > ul > li');
-            attributesDialog.find('.digitize-style').bind('click', editStyle($link, null));
-            attributesDialog.find('.digitize-save').bind('click', function() {
-                attributesDialog.find('table input').each(function() {
-                    var k = $(this).attr('name');
-                    var v = $(this).val();
-                    if(k) {
-                        feature.properties[k] = v;
+                attributesDialog.find('.digitize-style').bind('click', editStyle($link, null));
+                attributesDialog.find('.digitize-save').bind('click', function() {
+                    attributesDialog.find('table input').each(function() {
+                        var k = $(this).attr('name');
+                        var v = $(this).val();
+                        if(k) {
+                            feature.properties[k] = v;
+                    feature.properties.updated = new Date().toISOString();
+                    attributesDialog.dialog('close');
+                    editDialog.dialog('close');
+                    kml.refresh(url);
-                feature.properties.updated = new Date().toISOString();
+                var preview = attributesDialog.find('.digitize-preview').html('').get(0);
+                kml.renderPreview(feature, preview);
-                attributesDialog.dialog('close');
-                editDialog.dialog('close');
-                kml.refresh(url);
-            var preview = attributesDialog.find('.digitize-preview').html('').get(0);
-            kml.renderPreview(feature, preview);
@@ -731,6 +770,11 @@
                 digitizingFor = $link.parent().attr('title');
                 that.activate();
+            // get the featureCollection data
+            var url = $link.parent().attr('title');
+            var featureCollection = $('#mapframe1').data('kml')._kmls[url].data;
+            digitizeDialog.find('.digitize-attributes').bind('click', editAttributes(featureCollection, kml, url));
             digitizeDialog.find('.digitize-remove').bind('click', function() {
                 var kml = $('#mapframe1').data('kml');
Modified: trunk/mapbender/http/plugins/mb_metadata_edit.js
--- trunk/mapbender/http/plugins/mb_metadata_edit.js	2015-03-02 09:27:24 UTC (rev 9157)
+++ trunk/mapbender/http/plugins/mb_metadata_edit.js	2015-03-02 10:07:02 UTC (rev 9158)
@@ -6,7 +6,7 @@
  * Files:
  * SQL:
  * Help:
  * Maintainer:
@@ -27,7 +27,7 @@
 	var validator;
 	var formReady = false;
 	var wmsId;
 	this.events = {
 		showOriginalMetadata : new Mapbender.Event(),
 		submit: new Mapbender.Event()
@@ -40,7 +40,7 @@
 		return true;
 	this.serialize = function (callback) {
 		$metadataForm.submit();
 		var data = null;
@@ -54,7 +54,7 @@
 		return data !== null ? data.wms : data;
 	// second optional parameter formData
 	var fillForm = function (obj) {
 		if (arguments.length >= 2) {
@@ -63,7 +63,7 @@
 			that.valid();
 			return;
 		// get metadata from server
 		var req = new Mapbender.Ajax.Request({
 			url: "../plugins/mb_metadata_server.php",
@@ -82,7 +82,7 @@
 				that.valid();
-		req.send();
+		req.send();
 	this.fillMdContact = function(obj) {
@@ -106,7 +106,7 @@
 		req.send();
 	//Show more information about the licences
 	this.fillLicence = function(obj) {
@@ -140,12 +140,12 @@
 		req.send();
 	this.fill = function (obj) {
 		$metadataForm.easyform("fill", obj);
 	var showOriginalMetadata = function () {
 		that.events.showOriginalMetadata.trigger({
 			data : {
@@ -154,23 +154,23 @@
 	this.init = function (obj) {
 		wmsId = obj;
 		if (!wmsId) {
 			return;
 		var formData = arguments.length >= 2 ? arguments[1] : undefined;
 		if (!formReady) {
 			$metadataForm.load("../plugins/mb_metadata_edit.php", function () {
 				$metadataForm.find(".help-dialog").helpDialog();
 				$metadataForm.find(".original-metadata-wms").bind("click", 					function() {
 					showOriginalMetadata();
 				validator = $metadataForm.validate({
 					submitHandler: function () {
 						return false;
@@ -188,7 +188,7 @@
 		fillForm(obj);
 	Mapbender.events.localize.register(function () {
 		that.valid();
 		var formData = $metadataForm.easyform("serialize");
More information about the Mapbender_commits mailing list
