[Mapbender-commits] r9165 - in trunk/mapbender: http/php http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Mar 10 05:57:47 PDT 2015
Author: syed
Date: 2015-03-10 05:57:47 -0700 (Tue, 10 Mar 2015)
New Revision: 9165
   trunk/mapbender/http/php/mod_GetPublishedData.php
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
add area and length attributes for specified features
Modified: trunk/mapbender/http/php/mod_GetPublishedData.php
--- trunk/mapbender/http/php/mod_GetPublishedData.php	2015-03-09 13:53:51 UTC (rev 9164)
+++ trunk/mapbender/http/php/mod_GetPublishedData.php	2015-03-10 12:57:47 UTC (rev 9165)
@@ -1,7 +1,6 @@
 <?php
-ini_set('display_errors', 'On');
-error_reporting(E_ALL);
  * @version   Changed: ### 2015-02-23 14:00:42 UTC ###
  * @author    Raphael.Syed <raphael.syed at WhereGroup.com> http://WhereGroup.com
@@ -50,8 +49,15 @@
 $kmls = array_values($myWmc->generalExtensionArray["KMLS"]);
 //create the fileName
 $file = "myDataCollection.".$outputFormat;
+if (isset($kmls[0]["data"]['@context'])) {
+    $file = rawurldecode($kmls[0]["data"]['@context']['title']).'.'.$outputFormat;
 if (sizeof($kmls) > 1) {
     # create a file for each featureCollection and push them in a zip
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2015-03-09 13:53:51 UTC (rev 9164)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2015-03-10 12:57:47 UTC (rev 9165)
@@ -589,18 +589,21 @@
                     var featureCollectionContent = "<div class='digitize-image digitize-style'></div>"+
                                                     "<br><br>"+
                                                     "<div><table id='featureCollTbl'>"+
-                                                    // "<tr><td>uuid</td><td><input type='text' name='uuid' value='"+feature['@context'].uuid+"'/></td></tr>"+
-                                                    // "<tr><td>title</td><td><input type='text' name='title' value='"+feature['@context'].title+"'/></td></tr>"+
-                                                    // "<tr><td>created</td><td><input type='text' name='created' value='"+feature['@context'].created+"'/></td></tr>"+
-                                                    // "<tr><td>updated</td><td><input type='text' name='updated' value='"+feature['@context'].updated+"'/></td></tr>"+
                                                     "</table></div>"+
                                                     "<br><br/>"+
                                                     "<div class='digitize-image digitize-add'></div>"+
                                                     "<div class='digitize-image digitize-save'></div>";
                     $('#featureCollAttrDlg').append(featureCollectionContent);
                     $.each(feature['@context'], function(index, val) {
+                        if (index == 'uuid' || index == 'created' || index == 'updated') {
-                         $('#featureCollTbl').append("<tr><td>"+index+"</td><td><input type='text' name='"+index+"' value='"+val+"'/></td></tr>");
+                            $('#featureCollTbl').append("<tr><td>"+index+"</td><td><input style='width:230px;' type='text' name='"+index+"' value='"+val+"' disabled /></td></tr>");
+                        }else{
+                            $('#featureCollTbl').append("<tr><td>"+index+"</td><td><input  style='width:230px;' type='text' name='"+index+"' value='"+val+"'/></td></tr>");
                     featureCollAttrDlg.find('.digitize-save').bind('click', function() {
                     featureCollAttrDlg.find('table input').each(function() {
@@ -654,7 +657,15 @@
                 var rows = '';
                 $.each(feature.properties, function(k, v) {
                     if(k.match(/Mapbender:/)) return;
-                    rows += '<tr><td>' + k + '</td><td><input type="text" name="' + k + '" value="' + v + '"></input></td></tr>';
+                    if (k == "Fläche [m²]" || k == "Länge [m]") {
+                        rows += '<tr><td>' + k + '</td><td><input disabled type="text" name="' + k + '" value="' + v + '"></input></td></tr>';
+                    }else {
+                        rows += '<tr><td>' + k + '</td><td><input type="text" name="' + k + '" value="' + v + '"></input></td></tr>';
                 attributesDialog.find('table').html(rows);
                 attributesDialog.find('.digitize-add').bind('click', function() {
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2015-03-09 13:53:51 UTC (rev 9164)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2015-03-10 12:57:47 UTC (rev 9165)
@@ -419,6 +419,7 @@
         var geom = new Geometry();
         var multi = new MultiGeometry(tp);
         for (var i = 0; i < pts.length; ++i) {
             var pt = Proj4js.transform(this.targetProj, this.wgs84, pts[i].pos);
             geom.addPoint(pt);
@@ -427,33 +428,107 @@
         multi.add(geom);
         multi.e = new Wfs_element();
         var icon = multi.e.getElementValueByName("Mapbender:icon");
         multi.e.setElement('title', 'title');
         multi.e.setElement('name', 'name');
-        attributesDialog.find('table input').each(function() {
-            var name = $(this).attr('name');
-            if (name) {
-                multi.e.setElement($(this).attr('name'), $(this).val());
+        // cloning the geoms to calculate the area or length
+        var modifiedGeom = $.extend(true, {}, geom);
+        var modifiedData = new MultiGeometry(tp);
+            // add geometry: proof if polygon or linestring and add area or length
+        if (geom.geomType != 'point') {
+            if (geom.geomType == 'polygon') {
+                modifiedGeom.addPoint(geom.list[0]);
+                modifiedData.add(modifiedGeom);
+            } else {
-        if (icon == "false" || icon === false) {
-            multi.e.setElement("Mapbender:iconOffsetX", -10);
-            multi.e.setElement("Mapbender:iconOffsetY", -34);
-            multi.e.setElement("Mapbender:icon", "../img/marker/red.png");
+            // calculate current area (polygon) or length(linestring)
+            $.ajax({
+                url: '../php/mod_CalculateAreaAndLength.php',
+                type: 'POST',
+                data: {
+                    geom_type: modifiedData.geomType,
+                    wkt_geom: modifiedData.toText()
+                success: function(data) {
-        var feat = JSON.parse(multi.toString());
-        itm.data.features.push(feat);
-        this.element.trigger('kml:loaded', {
-            type: "geojson",
-            data: itm.data,
-            url: itm.url,
-            display: itm.display,
-            refreshing: true,
-        $map.setMapRequest();
+                        multi.e.setElement('Fläche [m²]', data);
+                    } else {
+                        multi.e.setElement('Länge [m]', data);
+                complete: function() {
+                    attributesDialog.find('table input').each(function() {
+                        var name = $(this).attr('name');
+                        if (name) {
+                            multi.e.setElement($(this).attr('name'), $(this).val());
+                    if (icon == "false" || icon === false) {
+                        multi.e.setElement("Mapbender:iconOffsetX", -10);
+                        multi.e.setElement("Mapbender:iconOffsetY", -34);
+                        multi.e.setElement("Mapbender:icon", "../img/marker/red.png");
+                    var feat = JSON.parse(multi.toString());
+                    itm.data.features.push(feat);
+                    $('#mapframe1').data('kml').element.trigger('kml:loaded', {
+                        type: "geojson",
+                        data: itm.data,
+                        url: itm.url,
+                        display: itm.display,
+                        refreshing: true,
+                    $map.setMapRequest();
+        } else {
+                if (name) {
+                type: "geojson",
+                data: itm.data,
+                url: itm.url,
+                refreshing: true,
     refresh: function(url) {
@@ -523,7 +598,7 @@
                         name = o.url;
                         if (name.match(/\w*\W(?:kml|gpx|geojson)$/)) {
                             name = name.match(/\w*\W(?:kml|gpx|geojson)$/)[0];
-                        }else {
+                        } else {
                             name = 'ImportFeatures';
More information about the Mapbender_commits mailing list
