[Mapbender-commits] r9169 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Mar 10 08:57:57 PDT 2015
Author: syed
Date: 2015-03-10 08:57:57 -0700 (Tue, 10 Mar 2015)
New Revision: 9169
   trunk/mapbender/http/classes/class_connector.php
fix class_connector
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php	2015-03-10 14:55:16 UTC (rev 9168)
+++ trunk/mapbender/http/classes/class_connector.php	2015-03-10 15:57:57 UTC (rev 9169)
@@ -71,7 +71,7 @@
 		$posPROXY = strpos($url,OWSPROXY);
 		//$e = new mb_exception('class_connector: old url: '.$url);
  		if($posPROXY !== false && OWSPROXY_USE_LOCALHOST == true){
-		var_dump('test1');die;
 			$e = new mb_notice('class_connector: old url: '.$url);
 			$url = str_replace($_SERVER['HTTP_HOST'], "127.0.0.1", $url);
 			$url = str_replace("https", "http", $url);//localhost no https should needed - it will be faster without
@@ -80,13 +80,13 @@
 		$e = new mb_notice('class_connector: load url: '.$url);
 		if (!$url) {
-		var_dump('test2');die;
 			$e = new mb_exception("connector: no URL given");
 			return false;
 		switch ($this->connectionType) {
 			case "curl":
-		var_dump('test3');die;
 			    if (func_num_args() == 2) {
             			$auth = func_get_arg(1);
 						if (isset($auth)) {
@@ -95,25 +95,23 @@
 				else {
-		var_dump('test4');die;
 				$e = new mb_notice("connector: curl without auth");
 					$this->file = $this->getCURL($url);
 				break;
 			case "http":
-		// var_dump('test5');
 			$e = new mb_notice("connector: http");
 				$this->file = $this->getHTTP($url);
-		// var_dump($this->getHTTP($url));
 				break;
 			case "socket":
-		var_dump('test6');die;
 			$e = new mb_notice("connector: socket");
 				$this->file = $this->getSOCKET($url);
 				break;
 		if(!$this->file){
-		// var_dump('test7');die;
 			$e = new mb_exception("connector: unable to load: ".$url);
 			return false;
@@ -361,7 +359,6 @@
 	private function getHTTP($url){
-			// var_dump(file_get_contents($url));die;
 		if ($this->httpType == "get") {
 			return @file_get_contents($url);
More information about the Mapbender_commits mailing list
