[Mapbender-commits] r9557 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 11 03:08:40 PDT 2016
Author: armin11
Date: 2016-08-11 03:08:40 -0700 (Thu, 11 Aug 2016)
New Revision: 9557
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
Fix for long extent strings in layer dimensions
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2016-08-11 07:22:27 UTC (rev 9556)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2016-08-11 10:08:40 UTC (rev 9557)
@@ -1206,7 +1206,8 @@
   multipleValues character varying(512)  DEFAULT ''::character varying,
   nearestValue character varying(512) DEFAULT ''::character varying,
   current character varying(512) DEFAULT ''::character varying,
-  extent character varying(512) NOT NULL DEFAULT ''::character varying,
+  extent text NOT NULL DEFAULT ''::character varying,
+  inherited boolean NOT NULL DEFAULT FALSE,
   CONSTRAINT layer_dimension_ibfk_1 FOREIGN KEY (fkey_layer_id)
       REFERENCES layer (layer_id) MATCH SIMPLE
       ON UPDATE CASCADE ON DELETE CASCADE
More information about the Mapbender_commits mailing list
