[Mapbender-commits] r9561 - trunk/documents/presentations/FOSS4G2016
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 22 02:33:04 PDT 2016
Author: astrid_emde
Date: 2016-08-22 02:33:04 -0700 (Mon, 22 Aug 2016)
New Revision: 9561
Added:
   trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_digitizer.txt
   trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_searchrouter.txt
demos osm_local
Added: trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_digitizer.txt
--- trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_digitizer.txt	                        (rev 0)
+++ trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_digitizer.txt	2016-08-22 09:33:04 UTC (rev 9561)
@@ -0,0 +1,93 @@
+-- DROP VIEW public.view_planet_osm_point;
+CREATE OR REPLACE VIEW public.view_planet_osm_point AS
+ SELECT planet_osm_point.osm_id,
+ planet_osm_point.gid,
+    planet_osm_point."addr:housenumber" AS housenumber,
+    planet_osm_point.amenity,
+    planet_osm_point.barrier,
+    planet_osm_point.bicycle,
+    planet_osm_point.brand,
+    planet_osm_point.building,
+    planet_osm_point.capital,
+    planet_osm_point.disused,
+    planet_osm_point.highway,
+    planet_osm_point.historic,
+    planet_osm_point.man_made,
+    planet_osm_point.name,
+    planet_osm_point.power,
+    planet_osm_point.public_transport,
+    planet_osm_point.railway,
+    planet_osm_point.ref AS location,
+    planet_osm_point.religion,
+    planet_osm_point.shop,
+    planet_osm_point.tourism,
+    planet_osm_point."tower:type" AS towertype,
+    planet_osm_point.z_order,
+    planet_osm_point.way AS geom
+   FROM planet_osm_point
+  WHERE planet_osm_point.amenity = 'post_box'::text
+ALTER TABLE public.view_planet_osm_point
+  OWNER TO "user";
+#-------------UNIQUE ID------------------------------------
+ALTER TABLE public.planet_osm_point ADD COLUMN gid integer;
+ALTER TABLE public.planet_osm_point ALTER COLUMN gid SET NOT NULL;
+ALTER TABLE public.planet_osm_point ALTER COLUMN gid SET DEFAULT nextval('planet_osm_point_gid_seq'::regclass);
+planet_osm_point_gid_seq: start value auf 9570 setzen
+poi:
+    label: point digitizing
+    maxResults: 500
+    featureType:
+        connection: osm_local
+        table: view_planet_osm_point
+        uniqueId: gid
+        geomType: point
+        geomField: geom
+        srid: 4326
+    openFormAfterEdit: true
+    zoomScaleDenominator: 500
+    allowEditData: true
+    allowDelete: true
+    allowDigitize: true
+    toolset:
+        - type: drawPoint
+        - type: moveFeature
+        - type: selectFeature
+        - type: removeSelected
+    popup:
+        title: point test suite
+        width: 500px
+    searchType: currentExtent   # currentExtent|all - default is currentExtent
+    tableFields:
+        gid: {label: Nr. , width: 20%}
+        location: {label: Location , width: 80%}
+    formItems:
+       - type: tabs
+         children:
+           - type: form
+             title: Basic information
+             css: {padding: 10px}
+             children:
+                 - type: label
+                   title: Welcome to the digitize demo. Try the new Mapbender3 feature!
+                 - type: input
+                   title: Name
+                   mandatory: true
+                   name: name
+                   mandatoryText: Please give a name to the poi.
+                   infoText: "Help: Please give a name to the new object."
+                 - type: input
+                   title: Location
+                   mandatory: false
+                   name: location
+                   mandatoryText: Please give a title to the poi.
+                 - type: select
+                   title: Amenity
+                   name: amenity
+                   options: {post_box: post_box}
Added: trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_searchrouter.txt
--- trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_searchrouter.txt	                        (rev 0)
+++ trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_searchrouter.txt	2016-08-22 09:33:04 UTC (rev 9561)
@@ -0,0 +1,80 @@
+-- View: public.view_planet_osm_point
+  OWNER TO "user";
+class: Mapbender\CoreBundle\Component\SQLSearchEngine
+class_options:
+    relation: public.view_planet_osm_point
+    attributes:
+        - osm_id
+        - amenity
+        - brand
+        - highway
+        - name
+        - location
+        - gid
+    geometry_attribute: geom
+form:
+    location:
+        type: text
+        options:
+            required: false
+            label: location
+            attr:
+                data-autocomplete: on
+        compare: ilike
+results:
+    view: table
+    count: true
+    headers:
+        location: Location
+        brand: Brand
+    callback:
+        event: click
+        options:
+            buffer: 50
+            minScale: 500
+            maxScale: 2500
+    styleMap:
+        default:
+            strokeColor: '#00ff00'
+            strokeOpacity: 1
+            fillOpacity: 0
+        select:
+            strokeColor: '#ff0000'
+            fillColor: '#ff0000'
+            fillOpacity: 0.8
More information about the Mapbender_commits mailing list
