[Mapbender-commits] r9568 - trunk/mapbender/http/html
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Aug 31 08:21:05 PDT 2016
Author: armin11
Date: 2016-08-31 08:21:04 -0700 (Wed, 31 Aug 2016)
New Revision: 9568
   trunk/mapbender/http/html/mod_treefolderPlain.php
First draft of new possibility to show clock at in layertree if layer support selection of time dimension
Modified: trunk/mapbender/http/html/mod_treefolderPlain.php
--- trunk/mapbender/http/html/mod_treefolderPlain.php	2016-08-31 15:08:30 UTC (rev 9567)
+++ trunk/mapbender/http/html/mod_treefolderPlain.php	2016-08-31 15:21:04 UTC (rev 9568)
@@ -200,6 +200,7 @@
 if (typeof(datalink) === 'undefined')datalink = 'false';
+if (typeof(activatedimension) === 'undefined')datalink = 'false';
 var defaultMetadataUrl = '../php/mod_showMetadata.php?resource=layer&layout=tabs&';
 if (redirectToMetadataUrl) {
@@ -785,6 +786,57 @@
+function openDimensionSelectHtml(j,k,l,dimensionIndex) {
+	if(!j && !k&& !l){
+		j=selectedMap;
+		k=selectedWMS;
+		l=selectedLayer;
+	var my= mb_mapObj[j].wms[k].objLayer[l];
+	//extract/calculate discrete values for time!
+	//alert(JSON.stringify(mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].extent));
+	//extent - split first for , (discrete) then for / - interval
+	var jsExtent = mb_mapObj[j].wms[k].objLayer[l].layer_dimension[dimensionIndex].extent.split("/");
+	beginDate = jsExtent[0];
+	endDate = jsExtent[1];
+	interval =  jsExtent[2];
+	alert(interval);
+	var dialogHtml = "<select id='dimensionSelect'>";
+	for (var i=0;i < my.layer_style.length;i++) {
+		dialogHtml += "<option value='" + my.layer_style[i].name + "'";
+		if(my.layer_style[i].name == my.gui_layer_style) {
+			dialogHtml += " selected";
+		dialogHtml += ">" + my.layer_style[i].title + "</option>";
+	dialogHtml += "</select>";
+	if(my.layer_style.length > 1) {
+		$("<div id='changeDimensionDialog' title='<?php echo _mb('Change layer dimension');?>'><?php echo _mb('Please select an additional dimension parameter');?>: </div>").dialog(
+				bgiframe: true,
+				autoOpen: true,
+				modal: false,
+				buttons: {
+					"<?php echo _mb('Close');?>": function(){
+						$(this).dialog('close').remove();
+		$(dialogHtml).appendTo("#changeDimensionDialog");
+		$("#dimensionSelect").change(function() {
+			my.gui_layer_style = this.options[this.selectedIndex].value;
+			Mapbender.modules[mod_treeGDE_map].setMapRequest();
+	else {
+		alert("<?php echo _mb('There are no different dimension values available for this layer.');?>");
 function initArray(){
 	var parentObj = "";
 	var controls="";
@@ -889,6 +941,30 @@
 									if(datalink == 'true' && mb_mapObj[i].wms[ii].objLayer[iii].layer_dataurl != ''){
 										controls.push('<a href="'+mb_mapObj[i].wms[ii].objLayer[iii].layer_dataurl+'"'+' target=\'_blank\' onclick="download_window = window.open(this.href,\'Download Data\',\'Width=450, Height=350,scrollbars=yes,menubar=yes,toolbar=yes\'); download_window.focus(); return false;"><img width="18" height="18" alt="'+msgObj.tooltipDownload+'" title="'+msgObj.tooltipDownload+'" src="'+imagedir+'/../gnome/document-save.png" /></a>');
+									//dimension buttons
+									if (activatedimension == 'true') {
+										timeDimensionAvailable = false;
+										timeDimensionIndex = false;
+										elevationDimensionAvailable = false;
+										elevationDimensionIndex = false;
+										//check for existence of time and/or elevation name attribute in dimension
+										for (dimensionIndex = 0; dimensionIndex < mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension.length; ++dimensionIndex) {
+											switch (mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[dimensionIndex].name) {
+												case "time":
+													timeDimensionAvailable = true;
+													timeDimensionIndex = dimensionIndex;
+													break;
+												case "elevation":
+													elevationDimensionAvailable = true;
+													elevationDimensionIndex = dimensionIndex;
+													break;
+										if (timeDimensionAvailable === true) {
+											text = JSON.stringify(mb_mapObj[i].wms[ii].objLayer[iii].layer_dimension[timeDimensionIndex]);
+											controls.push('<img onclick="openDimensionSelectHtml('+i+','+ii+','+iii+','+timeDimensionIndex+');" width="18" height="18" alt="'+msgObj.tooltipTimeDimension+'" title="'+msgObj.tooltipTimeDimension+'" src="'+imagedir+'/../gnome/preferences-system-time.png" />');
 									var groupedImageStyle ='';
 									if (temp.has_childs == true){
 										groupedImageStyle ='closed_folder.png';
More information about the Mapbender_commits mailing list
