[Mapbender-commits] r9540 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jul 13 08:10:59 PDT 2016
Author: armin11
Date: 2016-07-13 08:10:58 -0700 (Wed, 13 Jul 2016)
New Revision: 9540
   trunk/mapbender/http/classes/class_iso19139.php
Bugfixes
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php	2016-07-13 13:20:26 UTC (rev 9539)
+++ trunk/mapbender/http/classes/class_iso19139.php	2016-07-13 15:10:58 UTC (rev 9540)
@@ -17,6 +17,7 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_Uuid.php");
 require_once dirname(__FILE__) . "/../../tools/wms_extent/extent_service.conf";
 class Iso19139 {
 	//values for handling apriori ows metadataurls
@@ -100,7 +101,7 @@
 		$this->hierachyLevel = "dataset";
 		$this->tmpExtentBegin = "1900-01-01";
 		$this->tmpExtentEnd = "1900-01-01";
-		$this->randomId = "";
+		$this->randomId = new Uuid();
 		$this->owner = 0; //dummy entry for metadata owner - in case of metadataURL entries the owner of the corresponding service
 		$this->href = "";
 		$this->format = "";
@@ -489,6 +490,9 @@
 		$metadataConnector = new connector($url);
 		$metadataConnector->set("timeOut", "5");
+		if ($metadataConnector->timedOut == true) {
+			return false;
 		$xml = $metadataConnector->file;
 		$mbMetadata = $this->createMapbenderMetadataFromXML($xml);
 		return $mbMetadata;
@@ -1305,7 +1309,7 @@
 	public function isLinkAlreadyInDB(){
 		$sql = <<<SQL
-SELECT metadata_id FROM mb_metadata WHERE link = $1 AND link <> '' ORDER BY lastchanged DESC
+SELECT metadata_id FROM mb_metadata WHERE link = $1 AND link <> '' AND link IS NOT NULL ORDER BY lastchanged DESC
 SQL;
 		$v = array(
 			$this->href
@@ -1315,8 +1319,8 @@
 		while ($row = db_fetch_array($res)){
 			$metadataId[] = $row['metadata_id'];
-		if (count($metadataId) > 0) {
-			return $metadataId;
+		if (count($metadataId) > 0 && count($metadataId) < 2) {
+			return $metadataId[0];
 		} else {
 			return false;
@@ -1324,7 +1328,7 @@
 	public function isFileIdentifierAlreadyInDB(){
 		$sql = <<<SQL
-SELECT metadata_id, createdate FROM mb_metadata WHERE uuid = $1 AND uuid <> '' ORDER BY lastchanged DESC
+SELECT metadata_id, createdate FROM mb_metadata WHERE uuid = $1 AND uuid <> '' AND uuid IS NOT NULL ORDER BY lastchanged DESC LIMIT 1
 SQL;
 		if (!isset($this->fileIdentifier) || $this->fileIdentifier == '') {
 			$e = new mb_exception("class_Iso19139:"."Empty or no fileIdentifier found in the metadata! No metadataset will be updated");
@@ -1339,8 +1343,8 @@
 		} else {
 			return false;
@@ -1403,6 +1407,9 @@
 		//map category name to id before insert them into db!
 		//read maptable from db
 		//iso - code in xml
+		if ($resourceType == "wms" || $resourceType == "wfs" || $resourceType == "inspire_dls_atom" || $resourceType == "inspire_dls_atom_dataset") {
+			return false;
 		switch ($resourceType) {
 			case "featuretype":
 				$tablePrefix = 'wfs_featuretype';
@@ -1655,6 +1662,9 @@
 	public function deleteCategoriesFromCoupledResource($metadataId,$resourceType,$resourceId) {
+		if ($resourceType == 'inspire_dls_atom' || $resourceType == 'inspire_dls_atom_dataset') {
+			return false;
 		//delete inherited categories from coupled resources: layer/featuretype
 			case "featuretype":
@@ -1772,7 +1782,7 @@
 	public function insertMetadataIntoDB() {
 		//insert an instance for iso19139 into mapbenders database
-		$e = new mb_exception("class_iso19139.php: insert metadata with title: ".$this->title);
+		$e = new mb_notice("class_iso19139.php: insert metadata with title: ".$this->title);
 		$sql = <<<SQL
 INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset, ref_system, the_geom, datalinks, inspire_whole_area, inspire_actual_coverage, inspire_download, bounding_geom, transfer_size, fees, md_license_source_note, constraints, responsible_party_name, responsible_party_email, preview_image)  VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30, $31, $32, $33, $34, $35, $36, $37, $38, $39, $40, $41, $42)
 SQL;
@@ -1875,6 +1885,7 @@
 	public function updateMetadataById($metadataId) {
+		$e = new mb_exception("update metadata id: ".$metadataId);
 		//check if the timestamp of an existing metadata element is not newer than the timestamp of the current metadata object!!!!
 		//TODO
 		//problem: <<<SQL have a limited number of chars!
@@ -1943,7 +1954,7 @@
 		$metadataId = $this->isLinkAlreadyInDB();
 		if ($metadataId != false) {
 			//update the metadataURL entry
-			$e = new mb_notice("class_Iso19139:"."existing metadata link(s) found: ".$metadataId[0]." - update will be performed");
+			$e = new mb_notice("class_Iso19139:"."existing metadata link(s) found: ".$metadataId." - update will be performed");
 			$sql = "UPDATE mb_metadata SET link = $1, origin = $2, md_format = $3, linktype = $4, changedate = now(), export2csw = $5, randomid = $6, harvestresult = $8, harvestexception = $9 WHERE metadata_id = $7";
 			$v = array(
 				$this->href,
@@ -1952,7 +1963,7 @@
 				$this->type,
 				'f',
 				$this->randomId,
-				$metadataId[0],
+				$metadataId,
 				$this->harvestResult,
 				$this->harvestException
@@ -2157,26 +2168,28 @@
 		//check if metadata record already exists, if not create a new one, else insert relation only and update the metadata itself!
 		$metadataId = $this->isFileIdentifierAlreadyInDB();
+		$e = new mb_exception("found metadata_id: ".$metadataId);
 			//update the metadata - new random id set therefor there is no problem when setting the relation afterwards
-			$e = new mb_notice("existing metadata fileIdentifier found at metadata with id: ".$metadataId[0]." - update will be performed");
+			$e = new mb_notice("existing metadata fileIdentifier found at metadata with id: ".$metadataId." - update will be performed");
 			//TODO: Check if the timestamp of an existing metadata element is not newer than the timestamp of the current metadata object!!!!
 			//for uploaded metadata the harvesting was ok otherwise the function returned before
-			$res = $this->updateMetadataById($metadataId[0]);
+			$res = $this->updateMetadataById($metadataId);
-			$this->insertKeywordsAndCategoriesIntoDB($metadataId[0],$resourceType,$resourceId);
+			$this->insertKeywordsAndCategoriesIntoDB($metadataId,$resourceType,$resourceId);
 		} else {
 			//check if href already exists
+			$e = new mb_exception("found metadata_id by link : ".$metadataId);
 			//if so, the metadataset will be the same - (same url same metadataset) - update this as before
 				//the link to an existing metadataset already exists - don't store it again or insert anything
-				$e = new mb_notice("existing metadata linkage found at metadata with id: ".$metadataId[0]." - update will be performed");
+				$e = new mb_notice("existing metadata linkage found at metadata with id: ".$metadataId." - update will be performed");
 			} else {
 				//insert new record
 				$e = new mb_notice("class_Iso19139:"."No existing metadata fileIdentifier found in mapbender metadata table. New record will be inserted with uuid: ".$this->fileIdentifier);
@@ -2192,7 +2205,7 @@
 			return $result;
 		} else {
 			//insert relation into db
-			//get inserted metadata_id by use the
+			//get inserted or updated metadata_id by use the randomid
 			$sql = <<<SQL
 SELECT metadata_id FROM mb_metadata WHERE randomid = $1
 SQL;
More information about the Mapbender_commits mailing list
