[Mapbender-commits] r9523 - trunk/mapbender/http/php
    svn_mapbender at osgeo.org
    Mon Jun 20 06:28:48 PDT 2016
Author: armin11
Date: 2016-06-20 06:28:48 -0700 (Mon, 20 Jun 2016)
New Revision: 9523
Added:
   trunk/mapbender/http/php/mod_catalogueMaintenance.php
   trunk/mapbender/http/php/mod_catalogueMaintenance_server.php
Module to do some maintenance of the catalogue (reindex search tables, start monitor for single wms)
Added: trunk/mapbender/http/php/mod_catalogueMaintenance.php
--- trunk/mapbender/http/php/mod_catalogueMaintenance.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_catalogueMaintenance.php	2016-06-20 13:28:48 UTC (rev 9523)
@@ -0,0 +1,228 @@
+<?php
+# http://www.mapbender.org/index.php/
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+//require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+//$e_id="reindexWMS";
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+//validate parameter values
+if (isset($_REQUEST["resourceType"]) & $_REQUEST["resourceType"] != "") {
+	$testMatch = $_REQUEST["resourceType"];
+ 	if (!($testMatch == 'wms' or $testMatch == 'wfs' or $testMatch == 'dataset')){
+		echo 'Parameter <b>resourceType</b> is not valid (wms, wfs, dataset).<br/>';
+		die();
+	$resourceType = $testMatch;
+	$testMatch = NULL;
+if (isset($_REQUEST["maintenanceFunction"]) & $_REQUEST["maintenanceFunction"] != "") {
+	$testMatch = $_REQUEST["maintenanceFunction"];
+ 	if (!($testMatch == 'reindex' or $testMatch == 'monitor')){
+		echo 'Parameter <b>maintenanceFunction</b> is not valid (reindex, monitor).<br/>';
+		die();
+	$maintenanceFunction = $testMatch;
+if (isset($_REQUEST["resourceIds"]) & $_REQUEST["resourceIds"] != "") {
+	//validate to csv integer list
+	$testMatch = $_REQUEST["resourceIds"];
+	$pattern = '/^[\d,]*$/';
+ 	if (!preg_match($pattern,$testMatch)){
+		//echo 'resourceIds: <b>'.$testMatch.'</b> is not valid.<br/>';
+		echo 'Parameter <b>resourceIds</b> is not valid (integer or cs integer list).<br/>';
+		die();
+	$resourceIds = $testMatch;
+$allowedFunctions = array(
+	'wms' => array('reindex','monitor'),
+	'wfs' => array('reindex'),
+	'dataset' => array('reindex')
+$functionThatNeedIdList = array('monitor');
+//check for allowedFunction
+if (!in_array($maintenanceFunction, $allowedFunctions[$resourceType])) {
+	echo 'Maintenance function not allowed for requested resource type.<br/>';
+	die();
+//check for given id if demanded
+/*if (in_array($maintenanceFunction, $functionThatNeedIdList) && !isset($resourceIds)) {
+	echo 'Maintenance function need parameter resourceIds, but this is not given.<br/>';
+	die();
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title><?php
+switch ($maintenanceFunction) {
+	case "reindex":
+		$title = _mb('Re-Index search database for ');
+	break;
+	case "monitor":
+		$title = _mb('Start monitoring process for ');
+	break;
+switch ($resourceType) {
+	case "wms":
+		$title .= _mb('WebMapService(s)');
+	break;
+	case "wfs":
+		$title .= _mb('WebFeatureService(s)');
+	break;
+	case "dataset":
+		$title .= _mb('Dataset(s)');
+	break;
+echo $title;
+//collect number of objects to reindex
+$count = 0;
+if ($maintenanceFunction == 'reindex') {
+	switch ($resourceType) {
+		case "wms":
+			$sqlCount = "SELECT count(layer_id) from layer WHERE layer_searchable = 1;";
+		break;
+		case "wfs":
+			$sqlCount = "SELECT count(featuretype_id) from wfs_featuretype WHERE featuretype_searchable = 1;";
+		break;
+		case "dataset":
+			$sqlCount = "SELECT count(metadata_id) from mb_metadata;";
+		break;
+	$resCount = db_query($sqlCount);
+	if (!$resCount) {
+		$count = 0;
+	} else {
+		$row = db_fetch_array($resCount);
+		$count = $row['count'];
+	$title .= " (".$count." "._mb("searchable resources").")";
+	case "reindex":
+		$sql = file_get_contents(dirname(__FILE__)."/../../resources/db/materialize_".$resourceType."_view.sql");
+	break;
+</title>
+<script src="../extensions/jquery-1.12.0.min.js"></script>
+<script>
+/*function callServer(resourceType,maintenanceFunction,resourceIds,id) {
+		var req = new Mapbender.Ajax.Request({
+			url: "../php/mod_catalogueMaintenance_server.php",
+			method: maintenanceFunction,
+			parameters: {
+				"resourceIds": resourceIds,
+				"resourceType": resourceType
+			callback: function (obj, result, message) {
+				if (!result) {
+					return;
+				alert(JSON.stringify(obj));
+		req.send();
+function callServer(resourceType,maintenanceFunction,resourceIds,id) {
+	$("#doing_maintenance").css("display","block");
+	$.ajax({
+  		url: '../php/mod_catalogueMaintenance_server.php',
+  		type: "post",
+		async: true,
+		data: {resourceType: resourceType, maintenanceFunction: maintenanceFunction , resourceIds: resourceIds, id: id},
+       		dataType: "json",
+  		success: function(result) {
+			$("#doing_maintenance").css("display","none");
+			//select tab
+			//$('#mytabs a[href="#dataset_info"]').tab('show');
+			//draw georss polygons from service feed
+			//drawMetadataPolygons(result);
+			//show datasets in a dropdown list
+			//showDatasetList(result);
+			alert(JSON.stringify(result));
+	return false;
+</script>
+<style type="text/css">
+.loading_symbol {
+    -webkit-animation:spin 4s linear infinite;
+    -moz-animation:spin 4s linear infinite;
+    animation:spin 4s linear infinite;
+ at -moz-keyframes spin { 100% { -moz-transform: rotate(360deg); } }
+ at -webkit-keyframes spin { 100% { -webkit-transform: rotate(360deg); } }
+ at keyframes spin { 100% { -webkit-transform: rotate(360deg); transform:rotate(360deg); } }
+</style>
+</head>
+<?php include '../include/dyn_css.php'; ?>
+<body>
+<div id="title"><?php echo $title; ?></div>
+<div id="doing_maintenance" style="display: none;"><p><img class="loading_symbol" src="../img/loader_lightblue.gif" style="margin-left: auto; margin-right: auto;"/><?php echo _mb("Doing maintenance ...");?></p></div>
+<form id="start_maintenance_form">
+	<?php
+		$form = "";
+		if (in_array($maintenanceFunction, $functionThatNeedIdList)) {
+        		$form .= "<label for=\"resource_id_list\">"._mb("Resource Ids").":</label><br>";
+       	 		$form .= "<input name=\"resource_id_list\" id=\"resource_id_list\" class=\"required\"";
+			if (isset($resourceIds)) {
+				$form .= " value=\"".htmlspecialchars($resourceIds)."\"";
+			} else {
+				$form .= " value=\"\"/>";
+			$form .= "<img src=\"../img/gnome/process-stop.png\" width=\"20px\" onclick=\"$('#resource_id_list').val('');\"/>";
+		$form .= "<button class=\"btn btn-primary\" type=\"button\" id=\"maintenance_button\" onclick=\"callServer('".$resourceType."','".$maintenanceFunction."',$('#resource_id_list').val(),"."1".");\">";
+		switch ($maintenanceFunction) {
+			case "reindex":
+				$form .= _mb("Build search tables");
+			break;
+			case "monitor":
+				$form .= _mb("Start monitoring");
+			break;
+		$form .= "</button>";
+		echo $form;
+</form>
+<div id="result" style="display: none;">
+</div>
+</body>
+</html>
Added: trunk/mapbender/http/php/mod_catalogueMaintenance_server.php
--- trunk/mapbender/http/php/mod_catalogueMaintenance_server.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_catalogueMaintenance_server.php	2016-06-20 13:28:48 UTC (rev 9523)
@@ -0,0 +1,323 @@
+<?php
+require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
+//classes for monitoring
+require_once dirname(__FILE__) ."/../classes/class_administration.php";
+require_once dirname(__FILE__) ."/../../tools/mod_monitorCapabilities_defineGetMapBbox.php";
+require_once dirname(__FILE__) ."/../classes/class_bbox.php";
+require_once(dirname(__FILE__)."/../../lib/class_Monitor.php");
+//check for catalogue admin id
+$resultObj['result'] = '';
+$resultObj['success'] = false;
+$resultObj['message'] = 'no message';
+if (DEFINED("CATALOGUE_MAINTENANCE_USER") && CATALOGUE_MAINTENANCE_USER !== "") {
+	if (getUserFromSession() == CATALOGUE_MAINTENANCE_USER) {
+		$userId = CATALOGUE_MAINTENANCE_USER;
+	} else {
+		$resultObj['success'] = false;
+		$resultObj['message'] = "User not allowed to do maintenance";
+		echo json_encode($resultObj);
+		die();
+} else {
+	if (getUserFromSession() !== 1) {
+		die();
+	} else {
+		$userId = 1;
+		$resultObj['message'] = "Parameter <b>resourceType</b> is not valid (wms, wfs, dataset).<br/>";
+		die();
+		$resultObj['message'] = "Parameter <b>maintenanceFunction</b> is not valid (reindex, monitor).<br/>";
+		die();
+		$resultObj['message'] = "Parameter <b>resourceIds</b> is not valid (integer or cs integer list).<br/>";
+		die();
+	$resourceIdsArray = explode(",",$testMatch);
+	if (count($resourceIdsArray) > 3) {
+		$resultObj['message'] = "Parameter <b>resourceIds</b> is not allowed to have more than 3 entries (cs integer list).<br/>";
+		die();
+	$resultObj['message'] = "Maintenance function not allowed for requested resource type.<br/>";
+	die();
+if (in_array($maintenanceFunction, $functionThatNeedIdList) && !isset($resourceIds)) {
+	$resultObj['message'] = "Maintenance function need parameter resourceIds, but this is not given.<br/>";
+	die();
+$json = new Mapbender_JSON();
+$resultObj = array();
+	case 'reindex':
+		//$result = $touObject->check($ajaxResponse->getParameter("serviceType"),$ajaxResponse->getParameter("serviceId"));
+		//$e = new mb_exception($ajaxResponse->getParameter("resourceType"));
+		//$e = new mb_exception("resourceType from POST: ".$resourceType);
+		//$ajaxResponse->setResult($sql); //1 or 0
+		//$ajaxResponse->setMessage("cool");
+		//$ajaxResponse->setSuccess(true);
+		$beginTime = time();
+		$res = db_query($sql);
+		$endTime = time();
+		$diffTime = $endTime-$beginTime;
+		if (!$res) {
+			$resultObj['message'] = "Index could not be builded :-( ";
+			echo $json->encode($resultObj);
+			die();
+		} else {
+			$resultObj['success'] = true;
+			$resultObj['message'] = "Time to built index: ".$diffTime;
+			die();
+		break;
+	case 'monitor':
+		//$e = new mb_exception("found resource ids: ".$resourceIds);
+		$admin = new administration();
+		$timeLimit = 5;
+		$time_array = array();
+		$time_array[$userId] = strval(time());
+		//sleep(1);
+		$time = $time_array[$userId];
+		$resultObj = monitorWMSResources(explode(',',$resourceIds), $userId, $admin, $time, $timeLimit);
+		/*$serviceType = $ajaxResponse->getParameter("serviceType");
+		$serviceId = $ajaxResponse->getParameter("serviceId");
+		$result = $touObject->set($ajaxResponse->getParameter("serviceType"),$ajaxResponse->getParameter("serviceId"));
+		$ajaxResponse->setResult($result['setTou']); //1 or 0
+		$ajaxResponse->setMessage(_mb($result['message']));
+		$ajaxResponse->setSuccess(true);*/
+		//$resultObj['success'] = true;
+		//$resultObj['message'] = "found resource ids: ".$resourceIds;
+		break;
+	//Invalid command
+	default:
+		$resultObj['message'] = "No maintenanceFunction given in REQUEST!";
+		die();
+		//$ajaxResponse->setMessage(_mb("No method specified."));
+		//$ajaxResponse->setSuccess(false);
+function getUserFromSession()
+    if (Mapbender::session()->get('mb_user_id')) {
+        if ((integer) Mapbender::session()->get('mb_user_id') >= 0) {
+            $foundUserId = (integer) Mapbender::session()->get('mb_user_id');
+        } else {
+            $foundUserId = false;
+    } else {
+    return $foundUserId;
+function getTagOutOfXML($reportFile,$tagName) {
+	$xml=simplexml_load_file($reportFile);
+	$result=(string)$xml->wms->$tagName;
+	return $result;
+function monitorWMSResources($wmsIdList, $userId, $admin, $time, $timeLimit) {
+	$lb = "\n";
+	$br = "\n";
+	$resultObj['message'] = "Monitoring for wms resources could not be done!";
+	for ($k=0; $k<count($wmsIdList); $k++) {
+		//get relevant data out of registry
+		$sql = "SELECT wms_upload_url, wms_getcapabilities_doc, " .
+			"wms_version, wms_getcapabilities, wms_getmap FROM wms " .
+			"WHERE wms_id = $1";
+		//$e = new mb_exception('wms_id: '.$wmsIdList[0]);
+		$v = array($wmsIdList[$k]);
+		$t = array('i');
+		$res = db_prep_query($sql,$v,$t);
+		$someArray = db_fetch_array($res);
+		$url = $someArray['wms_upload_url'];
+		$capDoc = $someArray['wms_getcapabilities_doc'];
+		$version = $someArray['wms_version'];
+		$capabilities = $someArray['wms_getcapabilities'];
+		$getmap = $someArray['wms_getmap'];
+		$getMapUrl = getMapRequest($wmsIdList[$k], $version, $getmap);
+		// for the case when there is no upload url - however - we need the
+		// url to the capabilities file
+   		if (!$url || $url == "") {
+			$capabilities=$admin->checkURL($capabilities);
+			if ($version == "1.0.0" ) {
+				$url = $capabilities . "REQUEST=capabilities&WMTVER=1.0.0";
+			else {
+				$url = $capabilities . "REQUEST=GetCapabilities&" .
+					"SERVICE=WMS&VERSION=" . $version;
+		//$url is the url to the service which should be monitored in this cycle
+		//initialize monitoriung in db (set status=-2)
+		//echo "initialize monitoring for user: " . $userId .
+		//	" WMS: " . $wmsIdList[$k] . $br;
+		//$e = new mb_notice("mod_monitorCapabilities_main.php: wms: ".$wmsIdList[$k]);
+		$sql = "INSERT INTO mb_monitor (upload_id, fkey_wms_id, " .
+				"status, status_comment, timestamp_begin, timestamp_end, " .
+				"upload_url, updated)";
+		$sql .= "VALUES ($1, $2, $3, $4, $5, $6, $7, $8)";
+		$v = array(
+			$time,
+			$wmsIdList[$k],
+			"-2",
+			"Monitoring is still in progress...",
+			time(),
+			"0",
+			$url,
+			"0"
+		$t = array('s', 'i', 's', 's', 's', 's', 's', 's');
+		// Decode orig capabilities out of db cause they are converted before
+		// saving them while upload
+		//$capDoc=$admin->char_decode($capDoc);
+		// do the next to exchange the update before by another behavior! -
+		// look in class_monitor.php !
+		$currentFilename = "wms_monitor_report_" . $time . "_" .
+			$wmsIdList[$k] . "_" . $userId . ".xml";
+		//$e = new mb_exception("filename: ".TMPDIR."/".$currentFilename);
+ 		$report = fopen(TMPDIR."/".$currentFilename,"a");
+		$lb = chr(13).chr(10);
+		fwrite($report,"<monitorreport>".$lb);
+		fwrite($report,"<wms>".$lb);
+		fwrite($report,"<wms_id>".$wmsIdList[$k]."</wms_id>".$lb);
+		fwrite($report,"<upload_id>".$time."</upload_id>".$lb);
+		fwrite($report,"<getcapbegin></getcapbegin>".$lb);
+		fwrite($report,"<getcapurl>".urlencode($url)."</getcapurl>".$lb);
+		fwrite($report,"<getcapdoclocal>".urlencode($capDoc)."</getcapdoclocal>".$lb);
+		fwrite($report,"<getcapdocremote></getcapdocremote>".$lb);
+		fwrite($report,"<getcapdiff></getcapdiff>".$lb);
+		fwrite($report,"<getcapend></getcapend>".$lb);
+		fwrite($report,"<getcapduration></getcapduration>".$lb);
+		fwrite($report,"<getmapurl>".urlencode($getMapUrl)."</getmapurl>".$lb);
+		fwrite($report,"<status>-2</status>".$lb);
+		fwrite($report,"<image></image>".$lb);
+		fwrite($report,"<comment>Monitoring in progress...</comment>".$lb);
+		fwrite($report,"<timeend></timeend>".$lb);
+		fwrite($report,"</wms>".$lb);
+		fwrite($report,"</monitorreport>".$lb);
+		fclose($report);
+		$monitor = new Monitor($currentFilename, 0, TMPDIR."/");
+		$monitor->updateInXMLReport();
+	set_time_limit($timeLimit);
+	// wait until all monitoring processes are finished
+	//echo "please wait " . $timeLimit . " seconds for the monitoring to finish...$br";
+	sleep($timeLimit);
+	$problemOWS = array();//define array with id's of problematic wms
+	$commentProblemOWS = array();
+	//get the old upload_id from the monitoring to identify it in the database
+	//$time = $time_array[$userId];
+	//read sequencialy all user owned xml files from tmp and update the
+	// records in the database
+	for ($k = 0; $k < count($wmsIdList); $k++) {
+		$monitorFile = TMPDIR."/"."wms_monitor_report_" . $time . "_" .
+			$wmsIdList[$k] . "_".$userId.".xml";
+		$e = new mb_exception("mod_monitorCapabilities_main.php: look for following file: ".$monitorFile);
+		$status = getTagOutOfXML($monitorFile,"status");
+		$status_comment = getTagOutOfXML($monitorFile,"comment");
+		$cap_diff = getTagOutOfXML($monitorFile,"getcapdiff");
+		$image = getTagOutOfXML($monitorFile,"image");
+		$map_url = rawurldecode(getTagOutOfXML($monitorFile,"getmapurl"));
+		$timestamp_begin = getTagOutOfXML($monitorFile,"getcapbegin");
+		$timestamp_end = getTagOutOfXML($monitorFile,"getcapend");
+		$sql = "UPDATE mb_monitor SET updated = $1, status = $2, " .
+			"image = $3, status_comment = $4, timestamp_end = $5, " .
+			"map_url = $6 , timestamp_begin = $7, cap_diff = $8 " .
+			"WHERE upload_id = $9 AND fkey_wms_id=$10 ";
+		// check if status = -2 return new comment and status -1,
+		// push into problematic array
+		if ($status == '-1' or $status == '-2') {
+			$status_comment = "Monitoring process timed out.";
+			$status = '-1';
+			array_push($problemOWS,$wmsIdList[$k]);
+			array_push($commentProblemOWS,$status_comment);
+		$v = array(
+			'0',
+			intval($status),
+			intval($image),
+			$status_comment,
+			(string)intval($timestamp_end),
+			$map_url,
+			(string)intval($timestamp_begin),
+			$cap_diff,
+			(string)$time,
+			$wmsIdList[$k]
+		$t = array('s', 'i', 'i', 's', 's', 's', 's', 's','s','s');
+	$resultObj['message'] = "Monitoring done for WMS: ".implode(',',$wmsIdList);
+	return $resultObj;
More information about the Mapbender_commits
