[Mapbender-commits] r9415 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Mar 1 00:32:00 PST 2016
Author: armin11
Date: 2016-03-01 00:32:00 -0800 (Tue, 01 Mar 2016)
New Revision: 9415
   trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php
Bugfix for generating ATOM Feed ISO metadata on the fly. If more than one option for download of data is defined use the first option that is available ;-)
Modified: trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php
--- trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php	2016-02-29 14:43:02 UTC (rev 9414)
+++ trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php	2016-03-01 08:32:00 UTC (rev 9415)
@@ -105,7 +105,7 @@
 	$testMatch = $_REQUEST["GENERATEFROM"];
  	if ($testMatch != 'wmslayer' && $testMatch != 'dataurl'  && $testMatch != 'wfs' && $testMatch != 'metadata'){
 		//echo 'GENERATEFROM: <b>'.$testMatch.'</b> is not valid.<br/>';
-		echo 'Parameter <b>GENERATEFROM</b> is not valid (dataurl,wfs,wmslayer).<br/>';
+		echo 'Parameter <b>GENERATEFROM</b> is not valid (dataurl, wfs, wmslayer, metadata).<br/>';
 		die();
 	$generateFrom = $testMatch;
@@ -163,16 +163,20 @@
 		wms.fkey_group_id,
 		wms.uuid,
 		dataset identifier*/
+		$foundOption = false;
 		foreach ($downloadOptions->{$recordId}->option as $option) {
 			if ($option->type == "wmslayerdataurl") {
 				$mapbenderMetadata['mdFileIdentifier'] = $recordId;
 				$mapbenderMetadata['serviceId'] = $option->serviceId;
 				$mapbenderMetadata['resourceId'] = $option->resourceId;
-			} else {
-				echo "<error>No option for downloading service via dataurl found in database</error>";
-				die();
+				$foundOption = true;
+				break;
+		if ($foundOption == false) {
+			echo "<error>No option for downloading service via dataurl found in database</error>";
+			die();
 		//check if entries are filled
 		//read information from metadata table
 		$sql = <<<SQL
@@ -225,17 +229,21 @@
 		wms.fkey_group_id,
 		wms.uuid,
 			if ($option->type == "downloadlink") {
 				//$mapbenderMetadata['serviceId'] = $option->serviceId;
 				//$mapbenderMetadata['resourceId'] = $option->resourceId;
 				$mapbenderMetadata['downloadLink'] = $option->link;
-			} else {
-				echo "<error>No option for downloading service from metadata found in database</error>";
-				die();
+				break;
+			echo "<error>No option for downloading service from metadata found in database</error>";
+			die();
 		//TODO!!!!
@@ -301,16 +309,20 @@
 		wms.fkey_group_id,
 		wms.uuid,
 			if ($option->type == "wmslayergetmap") {
-			} else {
-				echo "<error>No option for downloading service via wmslayer found in database</error>";
-				die();
+				break;
+			echo "<error>No option for downloading service via wmslayer found in database</error>";
+			die();
 		$sql = <<<SQL
More information about the Mapbender_commits mailing list
