[Mapbender-commits] r9447 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon May 9 06:11:13 PDT 2016
Author: armin11
Date: 2016-05-09 06:11:13 -0700 (Mon, 09 May 2016)
New Revision: 9447
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
New enhancement for monitoring the usage of metadata by monitoring the usage of their coupled resources
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2016-05-09 13:10:27 UTC (rev 9446)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2016-05-09 13:11:13 UTC (rev 9447)
@@ -941,11 +941,11 @@
 DROP VIEW search_dataset_view;
 CREATE OR REPLACE VIEW search_dataset_view AS
- SELECT dataset_dep.fkey_mb_user_id AS user_id, dataset_dep.dataset_id, dataset_dep.dataset_id AS metadata_id, dataset_dep.srs AS dataset_srs, dataset_dep.title, dataset_dep.abstract AS dataset_abstract, dataset_dep.accessconstraints, dataset_dep.isopen, dataset_dep.termsofuse, f_collect_searchtext_dataset(dataset_dep.dataset_id) AS searchtext, dataset_dep.dataset_timestamp, dataset_dep.department, dataset_dep.mb_group_name, dataset_dep.mb_group_title, dataset_dep.mb_group_country, 0 AS load_count, dataset_dep.mb_group_stateorprovince, f_collect_inspire_cat_dataset(dataset_dep.dataset_id) AS md_inspire_cats, f_collect_custom_cat_dataset(dataset_dep.dataset_id) AS md_custom_cats, f_collect_topic_cat_dataset(dataset_dep.dataset_id) AS md_topic_cats, dataset_dep.bbox AS the_geom, (((((st_xmin(dataset_dep.bbox::box3d)::text || ','::text) || st_ymin(dataset_dep.bbox::box3d)::text) || ','::text) || st_xmax(dataset_dep.bbox::box3d)::text) || ','::text) || st_ymax(dataset_dep.bbox::box3d)::
 text AS bbox, dataset_dep.preview_url, dataset_dep.fileidentifier, f_get_coupled_resources(dataset_dep.dataset_id) AS coupled_resources, dataset_dep.mb_group_logo_path, dataset_dep.timeBegin, dataset_dep.timeEnd
-   FROM ( SELECT mb_metadata.the_geom AS bbox, mb_metadata.ref_system AS srs, mb_metadata.metadata_id AS dataset_id, mb_metadata.title, mb_metadata.abstract, mb_metadata.lastchanged AS dataset_timestamp, mb_metadata.tmp_reference_1 as timeBegin, mb_metadata.tmp_reference_2 as timeEnd, mb_metadata.uuid AS fileidentifier, mb_metadata.preview_image AS preview_url, mb_metadata.fkey_mb_user_id, mb_metadata.constraints as accessconstraints, f_getmd_tou(mb_metadata.metadata_id) AS termsofuse, f_tou_isopen(f_getmd_tou(mb_metadata.metadata_id)) AS isopen, user_dep.mb_group_id AS department, user_dep.mb_group_name, user_dep.mb_group_title, user_dep.mb_group_country, user_dep.mb_group_stateorprovince, user_dep.mb_group_logo_path
+ SELECT dataset_dep.fkey_mb_user_id AS user_id, dataset_dep.dataset_id, dataset_dep.dataset_id AS metadata_id, dataset_dep.srs AS dataset_srs, dataset_dep.title, dataset_dep.abstract AS dataset_abstract, dataset_dep.accessconstraints, dataset_dep.isopen, dataset_dep.termsofuse, f_collect_searchtext_dataset(dataset_dep.dataset_id) AS searchtext, dataset_dep.dataset_timestamp, dataset_dep.department, dataset_dep.mb_group_name, dataset_dep.mb_group_title, dataset_dep.mb_group_country, CASE WHEN load_count IS NULL THEN 0 ELSE load_count END as load_count, dataset_dep.mb_group_stateorprovince, f_collect_inspire_cat_dataset(dataset_dep.dataset_id) AS md_inspire_cats, f_collect_custom_cat_dataset(dataset_dep.dataset_id) AS md_custom_cats, f_collect_topic_cat_dataset(dataset_dep.dataset_id) AS md_topic_cats, dataset_dep.bbox AS the_geom, (((((st_xmin(dataset_dep.bbox::box3d)::text || ','::text) || st_ymin(dataset_dep.bbox::box3d)::text) || ','::text) || st_xmax(dataset_dep.bbox::box3d)::tex
 t) || ','::text) || st_ymax(dataset_dep.bbox::box3d)::text AS bbox, dataset_dep.preview_url, dataset_dep.fileidentifier, f_get_coupled_resources(dataset_dep.dataset_id) AS coupled_resources, dataset_dep.mb_group_logo_path, dataset_dep.timeBegin, dataset_dep.timeEnd
+   FROM ( SELECT mb_metadata.the_geom AS bbox, mb_metadata.ref_system AS srs, mb_metadata.metadata_id AS dataset_id, mb_metadata.title, mb_metadata.abstract, mb_metadata.lastchanged AS dataset_timestamp, mb_metadata.tmp_reference_1 as timeBegin, mb_metadata.tmp_reference_2 as timeEnd, mb_metadata.uuid AS fileidentifier, mb_metadata.preview_image AS preview_url, mb_metadata.load_count as load_count, mb_metadata.fkey_mb_user_id, mb_metadata.constraints as accessconstraints, f_getmd_tou(mb_metadata.metadata_id) AS termsofuse, f_tou_isopen(f_getmd_tou(mb_metadata.metadata_id)) AS isopen, user_dep.mb_group_id AS department, user_dep.mb_group_name, user_dep.mb_group_title, user_dep.mb_group_country, user_dep.mb_group_stateorprovince, user_dep.mb_group_logo_path
            FROM ( SELECT registrating_groups.fkey_mb_user_id AS mb_user_id, mb_group.mb_group_id, mb_group.mb_group_name, mb_group.mb_group_title, mb_group.mb_group_country, mb_group.mb_group_stateorprovince, mb_group.mb_group_logo_path
                    FROM registrating_groups, mb_group
-                  WHERE registrating_groups.fkey_mb_group_id = mb_group.mb_group_id) user_dep, mb_metadata
+                  WHERE registrating_groups.fkey_mb_group_id = mb_group.mb_group_id) user_dep, (SELECT mb_metadata.* ,metadata_load_count.load_count FROM mb_metadata LEFT JOIN metadata_load_count ON mb_metadata.metadata_id = metadata_load_count.fkey_metadata_id) as mb_metadata
           WHERE user_dep.mb_user_id = mb_metadata.fkey_mb_user_id AND mb_metadata.the_geom IS NOT NULL) dataset_dep
   ORDER BY dataset_dep.dataset_id;
@@ -966,3 +966,21 @@
 ALTER TABLE search_wfs_view
   OWNER TO postgres;
+-- Table: metadata_load_count
+-- DROP TABLE metadata_load_count;
+CREATE TABLE metadata_load_count
+  fkey_metadata_id integer,
+  load_count bigint,
+  CONSTRAINT metadata_load_count_fkey_metadata_id_fkey FOREIGN KEY (fkey_metadata_id)
+      REFERENCES mb_metadata (metadata_id) MATCH SIMPLE
+      ON UPDATE CASCADE ON DELETE CASCADE
+WITH (
+  OIDS=FALSE
+ALTER TABLE metadata_load_count
+  OWNER TO postgres;
More information about the Mapbender_commits mailing list
