[Mapbender-commits] r9453 - in trunk/mapbender: . documents http/classes http/css http/frames http/geoportal http/geoportal/news http/img http/javascripts http/php http/plugins http/print http/print/img http/sld http/sld/classes lib owsproxy/http resources test/http/classes tools tools/memcacheadmin tools/memcacheadmin/Config tools/memcacheadmin/Library tools/memcacheadmin/Library/Command tools/memcacheadmin/Library/Configuration tools/memcacheadmin/Library/Data tools/memcacheadmin/Library/HTML tools/memcacheadmin/Public tools/memcacheadmin/Public/Images tools/memcacheadmin/Public/Scripts tools/memcacheadmin/Public/Styles tools/memcacheadmin/Temp tools/memcacheadmin/View tools/memcacheadmin/View/Commands tools/memcacheadmin/View/Configure tools/memcacheadmin/View/LiveStats tools/memcacheadmin/View/Stats tools/wms_extent
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 11 06:52:38 PDT 2016
Author: pschmidt
Date: 2016-05-11 06:52:38 -0700 (Wed, 11 May 2016)
New Revision: 9453
Added:
   trunk/mapbender/documents/Entw?\195?\188rfe.pdf
   trunk/mapbender/documents/Entw?\195?\188rfe01.pdf
   trunk/mapbender/documents/mapbender.svg
   trunk/mapbender/http/classes/class_cache.php~
   trunk/mapbender/http/classes/class_iso19139.php~
   trunk/mapbender/http/classes/class_metadata_new.php~
   trunk/mapbender/http/classes/class_wfs_factory.php~
   trunk/mapbender/http/css/coordsdiv_leftAPP.css
   trunk/mapbender/http/frames/authentication.php_deprecated
   trunk/mapbender/http/frames/index_ext.php
   trunk/mapbender/http/geoportal/breitband_splash.php
   trunk/mapbender/http/geoportal/cr_mobile.php
   trunk/mapbender/http/geoportal/demo_table_jui.css
   trunk/mapbender/http/geoportal/gaz_geom_alt.php
   trunk/mapbender/http/geoportal/gaz_geom_mobile.php.trunk
   trunk/mapbender/http/geoportal/gaz_geom_mobile2.php
   trunk/mapbender/http/geoportal/gaz_geom_mobile_alt.php
   trunk/mapbender/http/geoportal/gaz_geom_mobile_alt_neu.php
   trunk/mapbender/http/geoportal/geoportal_mobile.html
   trunk/mapbender/http/geoportal/logo_breitband.png
   trunk/mapbender/http/geoportal/mobile-base_rlp.js
   trunk/mapbender/http/geoportal/mobile-jq_rlp.js
   trunk/mapbender/http/geoportal/mod_digitize_tab_komserv.php
   trunk/mapbender/http/geoportal/mod_digitize_tab_komserv_orga.php
   trunk/mapbender/http/geoportal/mod_fplanid.php
   trunk/mapbender/http/geoportal/mod_initialStartWmc_new.php
   trunk/mapbender/http/geoportal/mod_statistik.php
   trunk/mapbender/http/geoportal/news/
   trunk/mapbender/http/geoportal/news/georss.xml
   trunk/mapbender/http/geoportal/news/georss.xml.original
   trunk/mapbender/http/img/ui-bg_highlight-soft_75_cccccc_1x100.png
   trunk/mapbender/http/javascripts/geometry.js_old
   trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
   trunk/mapbender/http/javascripts/mb_downloadFeedClient.js~
   trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php
   trunk/mapbender/http/javascripts/mod_copyright_planungsportal.php
   trunk/mapbender/http/javascripts/mod_jsonAutocompleteGazetteer.php
   trunk/mapbender/http/javascripts/mod_legendDiv_old.php
   trunk/mapbender/http/javascripts/mod_mapcheck.php
   trunk/mapbender/http/php/apc.php
   trunk/mapbender/http/php/mb_validateSession2.php
   trunk/mapbender/http/php/mod_callMetadata.php~
   trunk/mapbender/http/php/mod_dataLinkDownloadISOMetadata.php
   trunk/mapbender/http/php/mod_editGuiWmsMeta.php_deprecated
   trunk/mapbender/http/php/mod_edit_element_vars.php_deprecated
   trunk/mapbender/http/php/mod_edit_metadata.php_deprecated
   trunk/mapbender/http/php/mod_export_image.php_deprecated
   trunk/mapbender/http/php/mod_getStyles.php_deprecated
   trunk/mapbender/http/php/mod_inspireDownloadFeed.php~
   trunk/mapbender/http/php/mod_inspireWmsDownloadFeed.php
   trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php
   trunk/mapbender/http/php/mod_printView1.php_deprecated
   trunk/mapbender/http/php/mod_saveWKT.php_deprecated
   trunk/mapbender/http/php/mod_treefolderAdmin.php_deprecated
   trunk/mapbender/http/php/mod_updateDatabaseUuid.php
   trunk/mapbender/http/php/mod_wmc2ol_old.php
   trunk/mapbender/http/php/mod_zoomCoords.php_deprecated
   trunk/mapbender/http/php/mod_zoomCoords_en.php_deprecated
   trunk/mapbender/http/php/nestedSets.php_deprecated
   trunk/mapbender/http/php/test.php
   trunk/mapbender/http/php/test_leuschner.php
   trunk/mapbender/http/php/test_tou.php
   trunk/mapbender/http/plugins/adminpopup.js_deprecated
   trunk/mapbender/http/plugins/kmlTree.js
   trunk/mapbender/http/plugins/mb_div2jqdialog.js_deprecated
   trunk/mapbender/http/plugins/mb_downloadFeedClient.php~
   trunk/mapbender/http/plugins/mb_iframeButtonPopup.js_deprecated
   trunk/mapbender/http/plugins/mb_measure.js_deprecated
   trunk/mapbender/http/plugins/mb_measure_widget.js_deprecated
   trunk/mapbender/http/plugins/mb_print.js_deprecated
   trunk/mapbender/http/plugins/mb_twitter.php_deprecated
   trunk/mapbender/http/plugins/mb_twitter_signin.js_deprecated
   trunk/mapbender/http/plugins/mb_twitter_update.js_deprecated
   trunk/mapbender/http/plugins/mod_jsonAutocompleteGazetteer.php.old
   trunk/mapbender/http/print/A4_landscape_template_geoportal.json
   trunk/mapbender/http/print/A4_landscape_template_geoportal.odg
   trunk/mapbender/http/print/A4_landscape_template_geoportal.pdf
   trunk/mapbender/http/print/Druckbereich_A4_hoch.json
   trunk/mapbender/http/print/Druckbereich_A4_quer.json
   trunk/mapbender/http/print/Dummy_HE_A4.docx
   trunk/mapbender/http/print/Dummy_HE_A4.json
   trunk/mapbender/http/print/Dummy_HE_A4.pdf
   trunk/mapbender/http/print/Dummy_LPP_A4.docx
   trunk/mapbender/http/print/Dummy_LPP_A4.json
   trunk/mapbender/http/print/Dummy_LPP_A4.pdf
   trunk/mapbender/http/print/Dummy_RP_A4.docx
   trunk/mapbender/http/print/Dummy_RP_A4.json
   trunk/mapbender/http/print/Dummy_RP_A4.pdf
   trunk/mapbender/http/print/Hochformat_A4_Legende.odg
   trunk/mapbender/http/print/Hochformat_A4_Legende.pdf
   trunk/mapbender/http/print/Hochformat_HE_A4.docx
   trunk/mapbender/http/print/Hochformat_HE_A4.json
   trunk/mapbender/http/print/Hochformat_HE_A4.pdf
   trunk/mapbender/http/print/Hochformat_LPP_A4.docx
   trunk/mapbender/http/print/Hochformat_LPP_A4.json
   trunk/mapbender/http/print/Hochformat_LPP_A4.pdf
   trunk/mapbender/http/print/Hochformat_RP_A4.docx
   trunk/mapbender/http/print/Hochformat_RP_A4.json
   trunk/mapbender/http/print/Hochformat_RP_A4.pdf
   trunk/mapbender/http/print/Hochformat_RP_A4_NEW.json
   trunk/mapbender/http/print/Hochformat_RP_A4_NEW.pdf
   trunk/mapbender/http/print/Querformat_A4_Legende.odg
   trunk/mapbender/http/print/Querformat_A4_Legende.pdf
   trunk/mapbender/http/print/alt_Querformat_A4_mit_Legende.json
   trunk/mapbender/http/print/alt_Querformat_A4_mit_Legende.odg
   trunk/mapbender/http/print/alt_Querformat_A4_mit_Legende.pdf
   trunk/mapbender/http/print/img/northarrowdummy.png
   trunk/mapbender/line.xml
   trunk/mapbender/mapbender.conf
   trunk/mapbender/owsproxy/http/index.php_old
   trunk/mapbender/resources/install_mapbender.sh
   trunk/mapbender/test/http/classes/GroupTest.php_deprecated
   trunk/mapbender/test/http/classes/MbNoticeTest.php_deprecated
   trunk/mapbender/test/http/classes/MbWarningTest.php_deprecated
   trunk/mapbender/test/http/classes/UserTest.php_deprecated
   trunk/mapbender/tools/memcacheadmin/
   trunk/mapbender/tools/memcacheadmin/Config/
   trunk/mapbender/tools/memcacheadmin/Config/Memcache.php
   trunk/mapbender/tools/memcacheadmin/Library/
   trunk/mapbender/tools/memcacheadmin/Library/Command/
   trunk/mapbender/tools/memcacheadmin/Library/Command/Factory.php
   trunk/mapbender/tools/memcacheadmin/Library/Command/Interface.php
   trunk/mapbender/tools/memcacheadmin/Library/Command/Memcache.php
   trunk/mapbender/tools/memcacheadmin/Library/Command/Memcached.php
   trunk/mapbender/tools/memcacheadmin/Library/Command/Server.php
   trunk/mapbender/tools/memcacheadmin/Library/Configuration/
   trunk/mapbender/tools/memcacheadmin/Library/Configuration/Loader.php
   trunk/mapbender/tools/memcacheadmin/Library/Data/
   trunk/mapbender/tools/memcacheadmin/Library/Data/Analysis.php
   trunk/mapbender/tools/memcacheadmin/Library/Data/Error.php
   trunk/mapbender/tools/memcacheadmin/Library/Data/Version.php
   trunk/mapbender/tools/memcacheadmin/Library/HTML/
   trunk/mapbender/tools/memcacheadmin/Library/HTML/Components.php
   trunk/mapbender/tools/memcacheadmin/Library/Loader.php
   trunk/mapbender/tools/memcacheadmin/Public/
   trunk/mapbender/tools/memcacheadmin/Public/Images/
   trunk/mapbender/tools/memcacheadmin/Public/Images/635855.png
   trunk/mapbender/tools/memcacheadmin/Public/Images/b5463f.png
   trunk/mapbender/tools/memcacheadmin/Public/Scripts/
   trunk/mapbender/tools/memcacheadmin/Public/Scripts/Script.js
   trunk/mapbender/tools/memcacheadmin/Public/Styles/
   trunk/mapbender/tools/memcacheadmin/Public/Styles/Style.css
   trunk/mapbender/tools/memcacheadmin/Temp/
   trunk/mapbender/tools/memcacheadmin/Temp/.version
   trunk/mapbender/tools/memcacheadmin/Temp/latest
   trunk/mapbender/tools/memcacheadmin/View/
   trunk/mapbender/tools/memcacheadmin/View/Commands/
   trunk/mapbender/tools/memcacheadmin/View/Commands/Commands.tpl
   trunk/mapbender/tools/memcacheadmin/View/Configure/
   trunk/mapbender/tools/memcacheadmin/View/Configure/Configure.tpl
   trunk/mapbender/tools/memcacheadmin/View/Footer.tpl
   trunk/mapbender/tools/memcacheadmin/View/Header.tpl
   trunk/mapbender/tools/memcacheadmin/View/LiveStats/
   trunk/mapbender/tools/memcacheadmin/View/LiveStats/Frame.tpl
   trunk/mapbender/tools/memcacheadmin/View/LiveStats/Stats.tpl
   trunk/mapbender/tools/memcacheadmin/View/Stats/
   trunk/mapbender/tools/memcacheadmin/View/Stats/Error.tpl
   trunk/mapbender/tools/memcacheadmin/View/Stats/Items.tpl
   trunk/mapbender/tools/memcacheadmin/View/Stats/Slabs.tpl
   trunk/mapbender/tools/memcacheadmin/View/Stats/Stats.tpl
   trunk/mapbender/tools/memcacheadmin/commands.php
   trunk/mapbender/tools/memcacheadmin/configure.php
   trunk/mapbender/tools/memcacheadmin/index.php
   trunk/mapbender/tools/memcacheadmin/phpMemcachedAdmin-1.2.2-r262.tar.gz
   trunk/mapbender/tools/memcacheadmin/stats.php
   trunk/mapbender/tools/mod_runScheduler.php~
   trunk/mapbender/tools/wms_extent/extent_service_geoportal.conf
   trunk/mapbender/tools/wms_extent/extent_service_geoportal_rlp.conf
   trunk/mapbender/tools/wms_extent/extents.map.original
   trunk/mapbender/tools/wms_extent/extents_geoportal_rlp.map
   trunk/mapbender/http/css/coordsdiv.css
   trunk/mapbender/http/css/digitize_new.css
   trunk/mapbender/http/css/legend.css
   trunk/mapbender/http/sld/classes/AddOperationModule.php
   trunk/mapbender/http/sld/classes/AnchorPoint.php
   trunk/mapbender/http/sld/classes/BinaryComparisonOp.php
   trunk/mapbender/http/sld/classes/BinaryLogicOp.php
   trunk/mapbender/http/sld/classes/ColorMap.php
   trunk/mapbender/http/sld/classes/ColorMapEntry.php
   trunk/mapbender/http/sld/classes/CssParameter.php
   trunk/mapbender/http/sld/classes/DbUtils.php
   trunk/mapbender/http/sld/classes/Displacement.php
   trunk/mapbender/http/sld/classes/DisplayOperationModule.php
   trunk/mapbender/http/sld/classes/ElseFilter.php
   trunk/mapbender/http/sld/classes/ExternalGraphic.php
   trunk/mapbender/http/sld/classes/FeatureTypeStyle.php
   trunk/mapbender/http/sld/classes/Fill.php
   trunk/mapbender/http/sld/classes/Filter.php
   trunk/mapbender/http/sld/classes/Font.php
   trunk/mapbender/http/sld/classes/Graphic.php
   trunk/mapbender/http/sld/classes/GraphicFill.php
   trunk/mapbender/http/sld/classes/GraphicStroke.php
   trunk/mapbender/http/sld/classes/Halo.php
   trunk/mapbender/http/sld/classes/LabelPlacement.php
   trunk/mapbender/http/sld/classes/LegendGraphic.php
   trunk/mapbender/http/sld/classes/LineSymbolizer.php
   trunk/mapbender/http/sld/classes/Mark.php
   trunk/mapbender/http/sld/classes/NamedLayer.php
   trunk/mapbender/http/sld/classes/ParameterValue.php
   trunk/mapbender/http/sld/classes/PointPlacement.php
   trunk/mapbender/http/sld/classes/PointSymbolizer.php
   trunk/mapbender/http/sld/classes/PolygonSymbolizer.php
   trunk/mapbender/http/sld/classes/PropertyIsBetween.php
   trunk/mapbender/http/sld/classes/PropertyIsLike.php
   trunk/mapbender/http/sld/classes/PropertyIsNull.php
   trunk/mapbender/http/sld/classes/RasterSymbolizer.php
   trunk/mapbender/http/sld/classes/Rule.php
   trunk/mapbender/http/sld/classes/Stroke.php
   trunk/mapbender/http/sld/classes/StyledLayerDescriptor.php
   trunk/mapbender/http/sld/classes/TextSymbolizer.php
   trunk/mapbender/http/sld/classes/UnaryLogicOp.php
   trunk/mapbender/http/sld/classes/UserStyle.php
   trunk/mapbender/http/sld/sld_config.php
   trunk/mapbender/http/sld/sld_edit_filter.php
   trunk/mapbender/http/sld/sld_filter_parse.php
   trunk/mapbender/http/sld/sld_function_getusersld.php
   trunk/mapbender/http/sld/sld_function_handler.php
   trunk/mapbender/http/sld/sld_main.php
   trunk/mapbender/http/sld/sld_parse.php
   trunk/mapbender/http/sld/sld_pick_color.php
   trunk/mapbender/lib/editGroup.php
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
   trunk/mapbender/tools/mapbender_setup.php
   trunk/mapbender/tools/send_post.php
   trunk/mapbender/tools/send_post_curl.php
   trunk/mapbender/tools/url_code.php
   trunk/mapbender/tools/wms_extent/extent_service.conf
rebase from svn to git
/var/www/svn/hookscripts/commit-email.pl: `/usr/bin/svnlook diff /var/www/svn/repos/mapbender -r 9453' failed with this output:
Added: trunk/mapbender/documents/Entw?\195?\188rfe.pdf
svnlook: Can't convert string from 'UTF-8' to native encoding:
svnlook: --- trunk/mapbender/documents/Entw?\195?\188rfe.pdf	                        (rev 0)
+++ trunk/mapbender/documents/Entw?\195?\188rfe.pdf	2016-05-11 13:52:38 UTC (rev 9453)
More information about the Mapbender_commits mailing list
