[Mapbender-commits] r9469 - in trunk/mapbender: http/javascripts http/php resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon May 23 01:59:55 PDT 2016
Author: verenadiewald
Date: 2016-05-23 01:59:54 -0700 (Mon, 23 May 2016)
New Revision: 9469
   trunk/mapbender/http/javascripts/mod_coordsLookup.php
   trunk/mapbender/http/php/mod_coordsLookup_server.php
   trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
cleaned up module (clean separate use of coords functionality without mapcode, updated server script postgis function calls st_, new message in Mapbender.po file)
Modified: trunk/mapbender/http/javascripts/mod_coordsLookup.php
--- trunk/mapbender/http/javascripts/mod_coordsLookup.php	2016-05-19 09:18:43 UTC (rev 9468)
+++ trunk/mapbender/http/javascripts/mod_coordsLookup.php	2016-05-23 08:59:54 UTC (rev 9469)
@@ -84,7 +84,7 @@
 		typeof options.perimeters  === 'undefined' || options.perimeters.length  === 0
-	if (typeof options.useMapcode      === 'undefined' || options.useMapcode == false) {
+	if (typeof options.useMapcode      === 'undefined' || options.useMapcode == false || options.useMapcode == 'false') {
 		options.useMapcode = false;
 	} else {
 		options.useMapcode = true;
@@ -106,7 +106,6 @@
 			this.searchRadioButton = this.searchSwitchContainer.append('<label><input type="radio" id="coords" name="searchswitcher" value="coords" /><?php echo _mb("Coordinates");?></label><label><input type="radio" id="mapcode" name="searchswitcher" value="mapcode" /><?php echo _mb("Mapcode");?><a target="_blank" href="http://www.mapcode.com"><img src="../img/help.png"></a></label>');
 		//enable coords by default
 		$('#coords').attr("checked", "checked");
 //		Coordinates input with label
@@ -184,15 +183,27 @@
 	this.zoomToCoordinates = function() {
-		//switch coords / mapcode
-		activatedRadioButton = $("input[name='searchswitcher']:checked").val();
-		if (activatedRadioButton == "coords") {
+		//if radio button selection between coords and mapcode exists, check for selection
+		if($("input[name='searchswitcher']").length > 0) {
+			//switch coords / mapcode
+			activatedSearchMode = $("input[name='searchswitcher']:checked").val();
+		//use default selection coords
+		else {
+			activatedSearchMode = "coords";
+		if (activatedSearchMode == "coords") {
 			this.coords = {};
 			this.coords.x                = this.coordXInput.val().replace(',','.');
 			this.coords.y                = this.coordYInput.val().replace(',','.');
 			//check if deg/minutes/seconds have been inserted
 			//validate
 			this.regexdms = /([0-9.]+)\°([0-9.]+)\'([0-9.]+)\'\'/;
+			if($("#projection-select option:selected").index() == 0) {
+				alert('<?php echo _mb("Invalid spatial reference system! Please select a value from list!");?>');
+				return;
 			this.coords.sourceProjection = (this.projectionSelect.val()) ?
 				this.projectionSelect.val() : null;
 			this.coords.targetProjection = Mapbender.modules[options.target].getSRS();
Modified: trunk/mapbender/http/php/mod_coordsLookup_server.php
--- trunk/mapbender/http/php/mod_coordsLookup_server.php	2016-05-19 09:18:43 UTC (rev 9468)
+++ trunk/mapbender/http/php/mod_coordsLookup_server.php	2016-05-23 08:59:54 UTC (rev 9469)
@@ -32,11 +32,11 @@
 	if(SYS_DBTYPE=='pgsql'){
 		$con = db_connect(DBSERVER, OWNER, PW);
-		$sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".pg_escape_string($x)." ".pg_escape_string($y).")',".pg_escape_string($oldEPSG)."),".pg_escape_string($newEPSG).")) as minx";
+		$sqlMinx = "SELECT X(ST_Transform(ST_GeometryFromText('POINT(".pg_escape_string($x)." ".pg_escape_string($y).")',".pg_escape_string($oldEPSG)."),".pg_escape_string($newEPSG).")) as minx";
 		$resMinx = db_query($sqlMinx);
 		$minx = floatval(db_result($resMinx,0,"minx"));
-		$sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".pg_escape_string($x)." ".pg_escape_string($y).")',".pg_escape_string($oldEPSG)."),".pg_escape_string($newEPSG).")) as miny";
+		$sqlMiny = "SELECT Y(ST_Transform(ST_GeometryFromText('POINT(".pg_escape_string($x)." ".pg_escape_string($y).")',".pg_escape_string($oldEPSG)."),".pg_escape_string($newEPSG).")) as miny";
 		$resMiny = db_query($sqlMiny);
 		$miny = floatval(db_result($resMiny,0,"miny"));
@@ -48,11 +48,11 @@
 		 * @security_patch sqli done
 		$resMinx = pg_query($con,$sqlMinx);
 		$minx = floatval(pg_fetch_result($resMinx,0,"minx"));
 		$resMiny = pg_query($con,$sqlMiny);
 		$miny = floatval(pg_fetch_result($resMiny,0,"miny"));
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po	2016-05-19 09:18:43 UTC (rev 9468)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po	2016-05-23 08:59:54 UTC (rev 9469)
@@ -1908,6 +1908,11 @@
 msgid "coordinates"
 msgstr "Koordinaten"
+#: ../http/javascripts/mod_coordsLookup.php:204
+msgid "Invalid spatial reference system! Please select a value from list!"
+msgstr ""
+"Ungültiges räumliches Bezugssystem! Bitte selektieren Sie einen Wert aus der Liste!"
 #: ../http/javascripts/mod_coordsLookup.php:128
 #: ../http/javascripts/mod_coordsLookup.php:153
 msgid "Invalid X coordinate! Must be a float or a DMS value!"
More information about the Mapbender_commits mailing list
