[Mapbender-commits] r9475 - trunk/mapbender/conf
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 24 04:28:12 PDT 2016
Author: armin11
Date: 2016-05-24 04:28:12 -0700 (Tue, 24 May 2016)
New Revision: 9475
   trunk/mapbender/conf/isoMetadata.conf
fix html representation of temporal extent
Modified: trunk/mapbender/conf/isoMetadata.conf
--- trunk/mapbender/conf/isoMetadata.conf	2016-05-24 11:27:56 UTC (rev 9474)
+++ trunk/mapbender/conf/isoMetadata.conf	2016-05-24 11:28:12 UTC (rev 9475)
@@ -162,7 +162,7 @@
 	category => "location",
 	description => _mb("This is the extent of the resource in the geographic space, given as a bounding box. The bounding box shall be expressed with westbound and eastbound longitudes, and southbound and northbound latitudes in decimal degrees, with a precision of at least two decimals.")
-//B 5. Temporal reference
+//B 5. Temporal reference (13)
 //B 5.1 Temporal extent
 array(	ibus => "t01_object.obj_id",
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/*",
@@ -175,7 +175,7 @@
 	category => "actuality",
 	description => _mb("The temporal extent defines the time period covered by the content of the resource. This time period may be expressed as any of the following: - an individual date, - an interval of dates expressed through the starting date and end date of the interval, - a mix of individual dates and intervals of dates.")
-//B 5.2 Date of publication (13)
+//B 5.2 Date of publication (14)
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation/gmd:date/gmd:CI_Date[gmd:dateType/gmd:CI_DateTypeCode/@codeListValue='publication']/gmd:date/*",
 	iso19139explode => "false" ,
@@ -187,7 +187,7 @@
 	description => _mb("This is the date of publication of the resource when available, or the date of entry into force. There may be more than one date of publication.")
-//B 5.3 Date of last revision (14)
+//B 5.3 Date of last revision (15)
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation/gmd:date/gmd:CI_Date[gmd:dateType/gmd:CI_DateTypeCode/@codeListValue='revision']/gmd:date/*",
@@ -199,7 +199,7 @@
 	description => _mb("This is the date of last revision of the resource, if the resource has been revised. There shall not be more than one date of last revision.")
-//B 5.4 Date of creation (15)
+//B 5.4 Date of creation (16)
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation/gmd:date/gmd:CI_Date[gmd:dateType/gmd:CI_DateTypeCode/@codeListValue='creation']/gmd:date/*",
@@ -212,7 +212,7 @@
 	description => _mb("This is the date of creation of the resource. There shall not be more than one date of creation.")
 //B 6. Quality and validity
-//B 6.1 Lineage (16)
+//B 6.1 Lineage (17)
 	iso19139 => "/gmd:MD_Metadata/gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:lineage/gmd:LI_Lineage/gmd:statement/gco:CharacterString",
@@ -224,9 +224,8 @@
 	category => "quality",
 	description => _mb("This is a statement on process history and/or overall quality of the spatial data set. Where appropriate it may include a statement whether the data set has been validated or quality assured, whether it is the official version (if multiple versions exist), and whether it has legal validity.")
 //B 6.2 Spatial Resolution
-//B 6.2.1 equivalent scale (17)
+//B 6.2.1 equivalent scale (18)
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/gmd:equivalentScale/gmd:MD_RepresentativeFraction/gmd:denominator/gco:Integer",
@@ -239,7 +238,7 @@
 	description => _mb("An equivalent scale is generally expressed as an integer value expressing the scale denominator.")
 //B 6.2.2 ground distance
-//B 6.2.2.1 ground distance value (18)
+//B 6.2.2.1 ground distance value (19)
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/gmd:distance/gco:Distance",
@@ -255,7 +254,7 @@
 //TODO maybe everytime m? or parse the href ...
 //B 7. Conformity
 //B 7.1. Specification
-//B 7.1.1 Title (19)
+//B 7.1.1 Title (20)
 	iso19139 => "/gmd:MD_Metadata/gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult/gmd:specification/gmd:CI_Citation/gmd:title/gco:CharacterString",
@@ -267,7 +266,7 @@
 	description => _mb("This is a citation of the implementing rules adopted under Article 7(1) of Directive 2007/2/EC or other specification to which a particular resource conforms. A resource may conform to more than one implementing rules adopted under Article 7(1) of Directive 2007/2/EC or other specification. This citation shall include at least the title and a reference date (date of publication, date of last revision or of creation) of the implementing rules adopted under Article 7(1) of Directive 2007/2/EC or of the specification.")
-//B 7.1.2 Reference Date (20)
+//B 7.1.2 Reference Date (21)
 	iso19139 => "/gmd:MD_Metadata/gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult/gmd:specification/gmd:CI_Citation/gmd:date/gmd:CI_Date/gmd:date/*",
@@ -279,7 +278,7 @@
-//B 7.2. Degree (21)
+//B 7.2. Degree (22)
 	iso19139 => "/gmd:MD_Metadata/gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult/gmd:pass/gco:Boolean",
@@ -292,7 +291,7 @@
 	description => _mb("This is the degree of conformity of the resource to the implementing rules adopted under Article 7(1) of Directive 2007/2/EC or other specification. The value domain of this metadata element is defined in Part D.")
 //B 8. Constraints related to access and use
-//B 8.1. Conditions applying to access and use (22)
+//B 8.1. Conditions applying to access and use (23)
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:resourceConstraints/gmd:MD_Constraints/gmd:useLimitation/gco:CharacterString",
@@ -305,7 +304,7 @@
 	description => _mb("A set of conditions applying to access and use.")
 //B 8.2. Limitations on public access
-//B 8.2.1 access constraints codelist (23)
+//B 8.2.1 access constraints codelist (24)
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:resourceConstraints/gmd:MD_LegalConstraints/gmd:accessConstraints/gmd:MD_RestrictionCode/@codeListValue",
@@ -318,7 +317,7 @@
 	description => _mb("Code for access constraints")
-//B 8.2.2 other constraints (24)
+//B 8.2.2 other constraints (25)
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:resourceConstraints/gmd:MD_LegalConstraints/gmd:otherConstraints/gco:CharacterString",
@@ -332,7 +331,7 @@
 //B 9. Organisations responsible for the establishment, management, maintance and distribution of spatial data sets and services
 //B 9.1. Responsible party
-//B 9.1.1 Responsible party name (25)
+//B 9.1.1 Responsible party name (26)
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty/gmd:organisationName/gco:CharacterString",
@@ -344,7 +343,7 @@
 	category => "contact",
 	description => _mb("The name of the organisation as free text.")
-//B 9.1.2 Responsible party email (26)
+//B 9.1.2 Responsible party email (27)
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty/gmd:contactInfo/gmd:CI_Contact/gmd:address/gmd:CI_Address/gmd:electronicMailAddress/gco:CharacterString",
@@ -356,7 +355,7 @@
 	description => _mb("A contact e-mail address as a character string.")
-//B 9.2 Responsible party role (27)
+//B 9.2 Responsible party role (28)
 	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty/gmd:role/gmd:CI_RoleCode/@codeListValue",
@@ -371,7 +370,7 @@
 //TODO some more translations
 //B 10 Metadata on metadata
 //B 10.1. Metadata point of contact
-//B 10.1.1 Metadata point of contact name (28)
+//B 10.1.1 Metadata point of contact name (29)
 	iso19139 => "/gmd:MD_Metadata/gmd:contact/gmd:CI_ResponsibleParty/gmd:organisationName/gco:CharacterString",
@@ -383,7 +382,7 @@
-//B 10.1.2 Metadata point of contact email (29)
+//B 10.1.2 Metadata point of contact email (30)
 	iso19139 => "/gmd:MD_Metadata/gmd:contact/gmd:CI_ResponsibleParty/gmd:contactInfo/gmd:CI_Contact/gmd:address/gmd:CI_Address/gmd:electronicMailAddress/gco:CharacterString",
@@ -395,7 +394,7 @@
-//B 10.2. Metadata date (30)
+//B 10.2. Metadata date (31)
 	iso19139 => "/gmd:MD_Metadata/gmd:dateStamp/*",
@@ -407,7 +406,7 @@
 	category => "metadata",
 	description => _mb("The date which specifies when the metadata record was created or updated. This date shall be expressed in conformity with ISO 8601.")
-//B 10.3. Metadata language (31)
+//B 10.3. Metadata language (32)
 	iso19139 => "/gmd:MD_Metadata/gmd:language/gmd:LanguageCode/@codeListValue",
@@ -475,7 +474,7 @@
     </gmd:MD_ReferenceSystem>
 </gmd:referenceSystemInfo>
-//1. Coordinate Reference System (32)
+//1. Coordinate Reference System (33)
 	iso19139 => "/gmd:MD_Metadata/gmd:referenceSystemInfo/gmd:MD_ReferenceSystem/gmd:referenceSystemIdentifier/gmd:RS_Identifier/gmd:code/gco:CharacterString",
@@ -570,6 +569,34 @@
 	value => "",
 	category => "identification",
 	description => _mb("A unique identifier for the ressource (maybe the shapfile)")
+//Temporal reference start (38)
+array(	ibus => "t01_object.obj_id",
+	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/*/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:beginPosition",
+	iso19139explode => "false" ,
+	inspire => "temporal extent begin",
+	inspiremandatory => "true",
+	iso_name => "temporal extent begin",
+	html => _mb("Temportal extent from"),
+	category => "actuality",
+	description => _mb("")
+//Temporal reference end (39)
+	iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/*/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:endPosition",
+	inspire => "temporal extent end",
+	html => _mb("Temportal extent to"),
+	value => "",
+<gmd:extent><gmd:EX_Extent><gmd:temporalElement><gmd:EX_TemporalExtent><gmd:extent><gml:TimePeriod gml:id="temporalextent"><gml:beginPosition>2010-03-10</gml:beginPosition><gml:endPosition>2011-05-25</gml:endPosition></gml:TimePeriod></gmd:extent></gmd:EX_TemporalExtent></gmd:temporalElement></gmd:EX_Extent></gmd:extent>
More information about the Mapbender_commits mailing list
