[Mapbender-commits] r9486 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 27 00:07:37 PDT 2016
Author: armin11
Date: 2016-05-27 00:07:37 -0700 (Fri, 27 May 2016)
New Revision: 9486
Removed:
   trunk/mapbender/http/javascripts/geometry.js_old
   trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
   trunk/mapbender/http/javascripts/mb_downloadFeedClient.js~
   trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php
   trunk/mapbender/http/javascripts/mod_copyright_planungsportal.php
   trunk/mapbender/http/javascripts/mod_jsonAutocompleteGazetteer.php
   trunk/mapbender/http/javascripts/mod_legendDiv_old.php
   trunk/mapbender/http/javascripts/mod_mapcheck.php
Fix wrong commit
Deleted: trunk/mapbender/http/javascripts/geometry.js_old
--- trunk/mapbender/http/javascripts/geometry.js_old	2016-05-27 07:02:37 UTC (rev 9485)
+++ trunk/mapbender/http/javascripts/geometry.js_old	2016-05-27 07:07:37 UTC (rev 9486)
@@ -1,2640 +0,0 @@
-* $Id: geometry.js 8152 2011-09-16 11:18:40Z verenadiewald $
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-// http://www.mapbender.org/index.php/GeometryArray.js
-var nameGeometryArray = "GeometryArray";
-var nameMultiGeometry = "MultiGeometry";
-var nameGeometry = "Geometry";
-Mapbender.geometryType = {
-	polygon: "polygon",
-	line: "line",
-	point: "point"
- * @class A class representing geometry types "polygon", "line" and "point".
- * @constructor
-function GeomType(){
-	 * An identifier for polygons. If you want to check if a {@link MultiGeometry}
-	 * or {@link Geometry} is a polygon, write
-	 * if (someGeometry.geomType == geomType.polygon
-	 * @type String
-	this.polygon = "polygon";
-	 * or {@link Geometry} is a line, write
-	 * if (someGeometry.geomType == geomType.line
-	 * @type String
-	this.line = "line";
-	 * or {@link Geometry} is a point, write
-	 * if (someGeometry.geomType == geomType.point
-	 * @type String
-	this.point = "point";
-var geomType = new GeomType();
- * @class a {@link GeometryArray} is a {@link List} of {@link MultiGeometry} objects
- * @ extends List
- * @ requires MultiGeometry
- * @ requires Geometry
- * @ requires Point
- * @ constructor
-function GeometryArray(){
-	 * creates a new, empty Multigeometry and adds it to this GeometryArray
-	 * @param {String} geomType a {@link GeomType}
-	this.addMember = function(geomType){
-		this.add(new MultiGeometry(geomType));
-	this.addCopy = function (feature) {
-		this.importGeoJSON(feature.toString());
-		this.get(-1).wfs_conf = feature.wfs_conf;
-	 * @ignore
-	this.name = nameGeometryArray;
-	 * A {@link List} of {@link MultiGeometry} objects.
-	 * @type List
-	this.list = [];
-GeometryArray.prototype = new List();
- * gets the j-th {@link Geometry} object of the i-th {@link MultiGeometry} object
- * @param {Integer} i index of the MultiGeometry
- * @param {Integer} j index of the Geometry
- * @type Geometry
-GeometryArray.prototype.getGeometry = function(i,j){
-	var tmp = this.get(i);
-	if (tmp) {
-		return tmp.get(j);
-	return false;
- * gets the k-th Point of the j-th {@link Geometry} object of the i-th {@link MultiGeometry} object
- * @param {Integer} k index of the Point
- * @type Point
- * @returns the Point object at the given indices
-GeometryArray.prototype.getPoint = function(i, j, k, l){
-	var mg = this.get(i);
-	if (mg) {
-		var g = mg.get(j);
-		if (g) {
-			if (l === undefined) {
-				return g.get(k);
-			else {
-				var r = g.innerRings.get(k);
-				if (r) {
-					return r.get(l);
-	return false;
-GeometryArray.prototype.clone = function () {
-	var geomArray = new GeometryArray();
-	return geomArray.union(this, false);
- * appends a geometry array to an existing geometryArray
- * @param {GeometryArray} geom GeometryArray
-GeometryArray.prototype.union = function(geom, uniqueFid){
-	var oldLen = this.count();
-	var i, j;
-	var mygeom = geom;
-	// only add geometries that are not already present
-	if (typeof uniqueFid === "boolean" && uniqueFid) {
-		mygeom = geom.clone();
-		for (i = 0; i < this.count(); i++) {
-			var existingFid = this.get(i).e.getElementValueByName("fid");
-			var len = mygeom.count() - 1;
-			for (j = len; j >= 0; j--) {
-				var fid = mygeom.get(j).e.getElementValueByName("fid");
-				if (fid && fid === existingFid) {
-					mygeom.del(j);
-					continue;
-	this.importGeoJSON(mygeom.toString());
-	j = 0;
-	for (i = oldLen; i < this.count(); i++) {
-		if (typeof mygeom.get(j).wfs_conf !== "undefined") {
-			this.get(i).wfs_conf = mygeom.get(j).wfs_conf;
-		j++;
-	return this;
- * gets an Array of indices; the {@link MultiGeometry} objects at these indices are equal to geom
- * @type Integer[]
- * @param {MultiGeometry} geom
- * @returns an Array of indices
-GeometryArray.prototype.findMultiGeometry = function(geom) {
-	var a = [];
-	for (var i=0; i < this.count(); i++) {
-		if (this.get(i).equals(geom)) {a.push(i);}
-	return a;
- * deletes the j-th {@link Geometry} object of the i-th {@link MultiGeometry} object
-GeometryArray.prototype.delGeometry = function(i,j){
-	if (this.get(i).del(j) === false) {
-		this.del(i);
- * deletes the k-th {@link Point} of the j-th {@link Geometry} object of the i-th {@link MultiGeometry} object
-GeometryArray.prototype.delPoint = function (i, j, k, l) {
-	var res = this.get(i).delPoint(j, k, l);
-	if (res === false) {
-		this.del(i);
- * closes the current {@link MultiGeometry}. Calls method close of the {@link Geometry} class.
-GeometryArray.prototype.close = function(i){
-	var index;
-	if (arguments.length > 0) {
-		index = this.getIndex(i);
-		if (index === false) {
-			return null;
-	else {
-		index = -1;
-	if (!this.get(index).get(-1).close()) {
-		this.delGeometry(index, -1);
-	else {
-		if (this.get(index).get(-1).count() === 0) {
-			this.get(index).del(-1);
-		if (this.get(index).count() === 0) {
-			this.del(index);
- * deletes all {@link Point} objects of this {@link GeometryArray} that equal point
- * @param {Point} point
-GeometryArray.prototype.delAllPointsLike = function(point){
-	var finished = false;
-	var i, j, k, l;
-	while (finished === false){
-		finished = true;
-		for (i = 0 ; finished === true && i < this.count() ; i++){
-			for (j = 0 ; finished === true && j < this.get(i).count() ; j++){
-				var currentGeometry = this.get(i).get(j);
-				if (currentGeometry.geomType == geomType.polygon && currentGeometry.innerRings) {
-					for (k = 0; finished === true && k < currentGeometry.innerRings.count(); k++) {
-						for (l = 0; finished === true && l < currentGeometry.innerRings.get(k).count(); l++) {
-							if (this.getPoint(i, j, k, l).equals(point)) {
-								this.delPoint(i, j, k, l);
-								finished = false;
-				if (!finished) {
-					break;
-				for (k = 0 ; finished === true && k < this.get(i).get(j).count() ; k++){
-					if (this.getPoint(i,j,k).equals(point)){
-						this.delPoint(i,j,k);
-						finished = false;
- * updates all {@link Point} objects of this {@link GeometryArray} that equal oldP to newP
- * @param {Point} oldP
- * @param {Point} newP
-GeometryArray.prototype.updateAllPointsLike = function(oldP, newP){
-	for (var i = 0; i < this.count(); i++){
-		this.get(i).updateAllPointsLike(oldP, newP);
-GeometryArray.prototype.placemarkToString = function (placemarkId) {
-	var i;
-	var str = "{\"type\": \"Feature\", \"geometry\": ";
-	// get geometries with placemarkId
-	var geometriesFromPlacemark = [];
-	for (i = 0, len = this.count(); i < len; i++) {
-		if (this.get(i).isFromKml() && this.get(i).e.getElementValueByName("Mapbender:placemarkId") == placemarkId) {
-			geometriesFromPlacemark.push(i);
-	if (geometriesFromPlacemark.length > 1) {
-		str += "{\"type\": \"GeometryCollection\", \"geometries\": [";
-		for (i = 0; i < geometriesFromPlacemark.length; i++) {
-			if (i > 0) {
-				str += ",";
-			str += this.get(geometriesFromPlacemark[i]).placemarkToString();
-		str += "]}";
-		// metadata is the same for all indices...get from index 0
-		var propString = this.get(geometriesFromPlacemark[0]).e.toString();
-		if (propString) {
-			str += "," + propString;
-	else if (geometriesFromPlacemark.length === 1) {
-		str += this.get(geometriesFromPlacemark[0]).placemarkToString();
-	str += "}";
-	return str;
-GeometryArray.prototype.getBBox = function(){
-	var q = this.get(0).get(0).get(0);
-	var min = Mapbender.cloneObject(q);
-	var max = Mapbender.cloneObject(q);
-	for(var i=0; i < this.count();i++){
-		var pos = this.get(i).getBBox();
-		if (pos[0].x < min.x) {min.x = pos[0].x;}
-		if (pos[1].x > max.x) {max.x = pos[1].x;}
-		if (pos[1].y > max.y) {max.y = pos[1].y;}
-		if (pos[0].y < min.y) {min.y = pos[0].y;}
-	return [min, max];
-GeometryArray.prototype.importGeometryFromText = function (text, srs) {
-	var i, j, m, currentPoint;
-	// remove whitespace after commata
-	text  = text.replace(/,\s*/, ',');
-	var tmpArray = text.split("(");
-	// trim whitespace
-	var geometryType = tmpArray[0].replace(/^\s\s*/, '').replace(/\s\s*$/, '');
-	switch (geometryType) {
-		case "MULTIPOLYGON":
-			var text = text.replace(/\)/g, "");
-			var sepArray = text.split("(((");
-			var polyArray = sepArray[1].split(",((");
-			this.addMember(geomType.polygon);
-			for (i = 0; i < polyArray.length; i++) {
-				var ringArray = polyArray[i].split(",(");
-				for (j = 0; j < ringArray.length; j++) {
-					var coordinatesArray = ringArray[j].split(",");
-					if (j === 0) {
-						// add outer ring
-						this.get(-1).addGeometry();
-						for (m = 0; m < -1 + coordinatesArray.length; m++) {
-							currentPoint = coordinatesArray[m].split(" ");
-							this.getGeometry(-1, -1).addPointByCoordinates(parseFloat(currentPoint[0]), parseFloat(currentPoint[1]));
-							this.getGeometry(-1,-1).setEpsg(srs);
-						this.close();
-					else {
-						// add inner ring
-						var ring = new Geometry(geomType.polygon);
-							ring.addPointByCoordinates(parseFloat(currentPoint[0]), parseFloat(currentPoint[1]));
-						ring.close();
-						this.getGeometry(-1,-1).addInnerRing(ring);
-			break;
-		case "MULTILINESTRING":
-			var sepArray = text.split("((");
-			var lineArray = sepArray[1].split(",(");
-			this.addMember(geomType.line);
-			for (var i = 0; i < lineArray.length; i++) {
-				var coordinatesArray = lineArray[i].split(",");
-				for (var m = 0; m < coordinatesArray.length; m++) {
-					var currentPoint = coordinatesArray[m].split(" ");
-				this.close();
-			break;
-		case "LINESTRING":
-			// generalize the Linestring to a multilinestring, because that's how Mapbender handles this type of thing
-			// Not generalizing Points, because I am not testing it now and something would later break and I'd have to Rage again
-			// It's probably possible though, to do it by just copying this case and converting all "linestring" to "point"
-			var multilinestring = text.replace('(','((');
-			var multilinestring = multilinestring.replace(')','))');
-			var multilinestring = multilinestring.replace("LINESTRING","MULTILINESTRING");
-			this.importGeometryFromText(multilinestring,srs);
-			break;
-		break;
-		default:
-			throw "Can't Import geometries of Type '" + geometryType + "'";
-GeometryArray.prototype.importPoint = function(currentGeometry, featureEpsg){
-	var coordinates = currentGeometry.coordinates;
-	this.addMember(geomType.point);
-	this.getGeometry(-1,-1).addPointByCoordinates(coordinates[0], coordinates[1], coordinates[2]);
-	this.getGeometry(-1,-1).setEpsg(featureEpsg);
-	this.close();
-GeometryArray.prototype.importLine = function(currentGeometry, featureEpsg){
-	for (var m = 0; m < coordinates.length; m++) {
-		var currentPoint = coordinates[m];
-		this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0], currentPoint[1], currentPoint[2]);
-	this.close();
-GeometryArray.prototype.importMultiLine = function(currentGeometry, featureEpsg){
-		var currentLine = coordinates[m];
-		for (var n = 0; n < currentLine.length; n++) {
-			var currentPoint = currentLine[n];
-	this.close();
-GeometryArray.prototype.importMultiPoint = function(currentGeometry, featureEpsg){
-	this.close();
-GeometryArray.prototype.importPolygon = function(currentGeometry, featureEpsg){
-		var currentRing = coordinates[m];
-		if (m === 0) {
-			for (var p = 0; p < currentRing.length; p++) {
-				var currentPoint = currentRing[p];
-				this.getGeometry(-1, -1).addPointByCoordinates(currentPoint[0], currentPoint[1], currentPoint[2]);
-		else {
-				ring.addPointByCoordinates(currentPoint[0], currentPoint[1], currentPoint[2]);
-			ring.close();
-	this.close();
-GeometryArray.prototype.importMultiPolygon = function(currentGeometry, featureEpsg){
-		var currentPolygon = coordinates[m];
-		for (var n = 0; n < currentPolygon.length; n++) {
-			var currentRing = currentPolygon[n];
-			if (n === 0) {
-				this.getGeometry(-1, -1).close();
-			else {
-				ring.close();
-	this.close();
-GeometryArray.prototype.importFeature = function(currentFeature){
-	var isFeature = (currentFeature.type == "Feature") ? true : false;
-	// add geometry ...
-	if (currentFeature.geometry && isFeature) {
-		var featureEpsg = "EPSG:4326";
-		if (!currentFeature.crs || currentFeature.crs.type !== "name" || !currentFeature.crs.properties.name) {
-			var e = new Mb_warning("SRS not set or unknown in GeoJSON. Using 'EPSG:4326'.");
-		else {
-			featureEpsg = currentFeature.crs.properties.name;
-		// GEOMETRY
-		var currentGeometry = currentFeature.geometry;
-		var geometrytype = currentGeometry.type;
-		switch (geometrytype) {
-			case "Point":
-				this.importPoint(currentGeometry, featureEpsg);
-				break;
-			case "MultiPoint":
-				this.importMultiPoint(currentGeometry, featureEpsg);
-				break;
-			case "LineString":
-				this.importLine(currentGeometry, featureEpsg);
-				break;
-			case "MultiLineString":
-				this.importMultiLine(currentGeometry, featureEpsg);
-				break;
-			case "Polygon":
-				this.importPolygon(currentGeometry, featureEpsg);
-				break;
-			case "MultiPolygon":
-				this.importMultiPolygon(currentGeometry, featureEpsg);
-				break;
-			case "GeometryCollection":
-				var exc = new Mb_exception("Geometry: GeometryCollections are not yet supported");
-				break;
-	if (currentFeature.properties && currentFeature.geometry !== "") {
-		var properties = currentFeature.properties;
-		// GeometryCollections are NOT YET IMPLEMENTED
-		if (geometrytype != "GeometryCollection") {
-			for (var l in properties) {
-				if (typeof(properties[l]) != "function") {
-					this.get(-1).e.setElement(l, properties[l]);
-			if (currentFeature.id) {
-				this.get(-1).e.setElement("fid", currentFeature.id);
-GeometryArray.prototype.importGeoJSON = function (geoJSON) {
-	// you can pass either geoJSON or the evaluated geoJSON string
-	// for backwards compatibility
-	if (typeof(geoJSON) == 'string') {
-		var geoJSON = $.parseJSON(geoJSON);
-	// FEATURE COLLECTION
-	var isFeatureCollection = (geoJSON.type == "FeatureCollection") ? true : false;
-	switch (geoJSON.type) {
-		case "FeatureCollection" :
-			var featureArray = geoJSON.features;
-			for (var j = 0; j < featureArray.length; j++) {
-				var currentFeature = featureArray[j];
-				this.importFeature(currentFeature);
-			break;
-		case "Feature" :
-			this.importFeature(geoJSON);
-			break;
-	return true;
-GeometryArray.prototype.featureToString = function (i) {
-	var str = "{\"type\": \"FeatureCollection\", \"features\": [";
-	str += this.get(i).toString();
-	str += "]}";
-	return str;
-GeometryArray.prototype.toString = function () {
-	// separate: geometries that are from a KML and those which are not
-	var multiGeometriesFromKml = [];
-	var multiGeometriesNotFromKml = [];
-	for (var i = 0, len = this.count(); i < len; i++) {
-		if (this.get(i).isFromKml()) {
-			var placemarkId = this.get(i).e.getElementValueByName("Mapbender:placemarkId");
-			// only add placemark ids once!
-			var isFound = false;
-			for (var j = 0; j < multiGeometriesFromKml && isFound === false; j++) {
-				if (multiGeometriesFromKml == placemarkId) {
-					isFound = true;
-			if (!isFound) {
-				multiGeometriesFromKml.push(placemarkId);
-		else {
-			multiGeometriesNotFromKml.push(i);
-	// add geometries not from KML
-	for (var i = 0, len = multiGeometriesNotFromKml.length; i < len; i++) {
-		if (i > 0) {
-			str += ",";
-		str += this.get(multiGeometriesNotFromKml[i]).toString();
-	// add geometries from KML
-	if (multiGeometriesNotFromKml.length > 0 && multiGeometriesFromKml.length > 0) {
-		str += ",";
-	for (var i=0; i < multiGeometriesFromKml.length; i++) {
-		if (i > 0) {
-			str += ",";
-		str += this.placemarkToString();
-	str += "]}";
-	return str;
- * @class a MultiGeometry is a List of Geometry objects
- * @ extends List
- * @ constructor
- * @ param {String} geomType a geomType
-function MultiGeometry(geomType){
-	 * creates a new, empty {@link Geometry} object and adds it to this {@link MultiGeometry}
-	this.addGeometry = function(){
-		this.add(new Geometry(this.geomType));
-	 * deletes the {@link Geometry} object at index i; -1 refers to the last {@link Geometry object in the list
-	 * overwrites the del function of {@link List}.
-	this.del = function(i){
-		i = this.getIndex(i);
-		if (i !== false){
-			var tmpLength = this.count() - 1;
-			for (var z = i; z < tmpLength ; z ++){
-				this.list[z] = this.list[z+1];
-			this.list.length -= 1;
-			if (this.list.length === 0) {return false;}
-		return true;
-	this.list = [];
-	this.e = new Wfs_element();
-	this.geomType = geomType;
-	this.name = nameMultiGeometry;
-MultiGeometry.prototype = new List();
- * updates all {@link Point} objects of this {@link MultiGeometry} that equal oldP to newP
-MultiGeometry.prototype.updateAllPointsLike = function(oldP, newP){
-	for (var i = 0; i < this.count(); i++) {
- * gets the bounding box of this {@link MultiGeometry} as an Array of 2 points
- * @return the bounding box
- * @type Array of two Point objects
-MultiGeometry.prototype.getBBox = function(){
-	var q = this.get(0).get(0);
-	for(var i=0; i<this.count();i++){
- * gets the bounding box of this {@link MultiGeometry} as a polygon of four points
- * @type MultiGeometry
-MultiGeometry.prototype.getBBox4 = function() {
-	var bbox = this.getBBox();
-	var realBox = new MultiGeometry(geomType.polygon);
-	realBox.addGeometry(geomType.polygon);
-	realBox.get(-1).addPointByCoordinates(bbox[0].x, bbox[0].y);
-	realBox.get(-1).addPointByCoordinates(bbox[0].x, bbox[1].y);
-	realBox.get(-1).addPointByCoordinates(bbox[1].x, bbox[1].y);
-	realBox.get(-1).addPointByCoordinates(bbox[1].x, bbox[0].y);
-	realBox.get(-1).close();
-	return realBox;
- * gets the center of the bounding box of this {@link MultiGeometry}.
- * @return the center of the bounding box
- * @type Point
-MultiGeometry.prototype.getCenter = function(){
-	var tmp = this.getBBox();
-	var x = parseFloat(tmp[0].x) + parseFloat((tmp[1].x - tmp[0].x)/2);
-	var y = parseFloat(tmp[0].y) + parseFloat((tmp[1].y - tmp[0].y)/2);
-	return new Point(x,y);
- * gets the total number of {@link Point} objects of this {@link MultiGeometry}.
- * @return number of points
- * @type Integer
-MultiGeometry.prototype.getTotalPointCount = function(){
-	var c = 0;
-	for (var i = 0 ; i < this.count(); i++)	{
-		c += this.get(i).count();
-	return c;
- * @type Integer
-MultiGeometry.prototype.getPoint = function(j,k){
-	return this.get(j).get(k);
- * compares this {@link MultiGeometry} object with the {@link MultiGeometry} object multigeom.
- * @param {MultiGeometry} multigeom another multigeometry
- * @return true if he multigeometries match; else false
- * @type Boolean
-MultiGeometry.prototype.equals = function(multigeom) {
-	if (this.geomType != multigeom.geomType) {return false;}
-	if (this.count() != multigeom.count()) {return false;}
-	if (this.getTotalPointCount() != multigeom.getTotalPointCount()) {return false;}
-	for (var i=0; i<this.count(); i++) {
-		if (!this.get(i).equals(multigeom.get(i))) {return false;}
-	return true;
- * deletes the j-th {@link Point} object of the i-th {@link Geometry} object of this {@link MultiGeometry} object.
- * @param {Integer} i geometry index
- * @param {Integer} j point index
- * @return true if the deletion succeded; else false.
- * @type Boolean
-MultiGeometry.prototype.delPoint = function(i, j, k){
-	var res;
-	if (k === undefined) {
-		res = this.get(i).del(j);
-			return this.del(i);
-	else {
-		res = this.get(i).innerRings.get(j).del(k);
-			this.get(i).innerRings.del(j);
-	return true;
-MultiGeometry.prototype.isFromKml = function () {
-	if (this.e.getElementValueByName("Mapbender:kml")) {
-		return true;
-	return false;
-MultiGeometry.prototype.toText = function () {
-	var text = "";
-	var numOfGeom = this.count();
-	if (numOfGeom >= 1) {
-		if (this.geomType == geomType.polygon) {
-			if (numOfGeom > 1) {
-				text += "MULTIPOLYGON (";
-				for (var i = 0; i < numOfGeom; i++) {
-					if (i > 0) {
-						text += ", ";
-					var currentPolygon = this.get(i);
-					text += "(" + currentPolygon.toText() + ")";
-				text += ")";
-			else {
-				text += "POLYGON (" + this.get(0).toText() + ")";
-		else if (this.geomType == geomType.line) {
-			text += "LINESTRING (";
-			var currentLine = this.get(0);
-			for (var j = 0; j < currentLine.count(); j++) {
-				if (j > 0) {
-					text += ", ";
-				var currentPoint = currentLine.get(j);
-				text += currentPoint.x + " " + currentPoint.y;
-			text += ")";
-		else if(this.geomType == geomType.point){
-			text = this.get(0).toText();
-	return text;
-MultiGeometry.prototype.toString = function () {
-	var str = this.toStringWithoutProperties();
-	// properties
-	var propString = this.e.toString();
-	if (propString) {
-	var fid = this.e.getElementValueByName("fid");
-	if (fid) {
-		str += ", \"id\":\"" + fid + "\"";
-	str += "}";
-	return str;
-MultiGeometry.prototype.placemarkToString = function () {
-	var str = "";
-	// geometries
-		if (i > 0) {
-			str += ",";
-	return str;
-MultiGeometry.prototype.isRectangle = function () {
-	if (this.geomType !== Mapbender.geometryType.polygon || this.count() !== 1 || this.get(0).count() !== 5) {
-		return false;
-	var p1 = this.getPoint(0, 0);
-	var p2 = this.getPoint(0, 1);
-	var p3 = this.getPoint(0, 2);
-	var p4 = this.getPoint(0, 3);
-	if (p1.y === p2.y && p1.x === p4.x && p3.y === p4.y && p3.x === p2.x) {
-		return true;
-	return false;
-MultiGeometry.prototype.toStringWithoutProperties = function () {
-	var str = "{\"type\": \"Feature\", ";
-	var epsg = this.getEpsg();
-	if (epsg) {
-		str += "\"crs\": {\"type\": \"name\", \"properties\": {\"name\": \"" + epsg + "\"}}, ";
-	str += "\"geometry\": {";
-	var len = this.count();
-	switch (this.geomType) {
-		case geomType.polygon:
-			if (len > 1) {
-				str += "\"type\": \"MultiPolygon\", ";
-			else {
-				str += "\"type\": \"Polygon\", ";
-			break;
-		case geomType.line:
-			if (len > 1) {
-				str += "\"type\": \"MultiLineString\", ";
-			else {
-				str += "\"type\": \"LineString\", ";
-			break;
-		case geomType.point:
-			if (len > 1) {
-				str += "\"type\": \"MultiPoint\", ";
-			else {
-				str += "\"type\": \"Point\", ";
-			break;
-	str += "\"coordinates\": ";
-	// geometries
-	if (len > 1) {
-		str += "[";
-		for (var i = 0; i < len; i++) {
-			if (i > 0) {
-				str += ",";
-		str += "]";
-	else if (len === 1) {
-		str += this.get(0).toString();
-	else {
-		str += "[]";
-	str += "}";
-// this closing curly bracket is added in toString()
-//	str += "}";
-	return str;
- * @return the EPSG code of this geometry.
- * @type integer
-MultiGeometry.prototype.getEpsg = function () {
-	if (this.count() > 0) {
-		return this.get(0).getEpsg();
-	return false;
-function InnerRings () {
-	this.list = [];
-InnerRings.prototype = new List();
- * @class a Geometry is a List of Point objects. If it is a polygon, the last point has
- * to equal the first point.
- * @extends List
- * @requires Point
- * @constructor
- * @param {String} a string representing a geometry type, see @see GeomType.
-function Geometry(aGeomtype){
-	 * deletes the {@link Point} object at index i; -1 refers to the last
-	 * {@link Point} object in the list. Overwrites the del function of
-	 * {@link List}.
-	 * @return false if deletion is not yet finished. It is cascaded to
-	 *         {@link MultiGeometry}. True if the deletion is finished.
-		if (i !== false) {
-			var tmpLength = this.count()-1;
-			if (this.geomType == geomType.polygon){
-				if (i == tmpLength && this.complete) {
-					this.list[0] = this.list[tmpLength-1];
-				else if (i === 0) {
-					this.list[tmpLength-1] = this.list[0];
-				if (this.list.length == 1){
-					return false;
-			updateDist();
-			if(this.list.length === 0) {return false;}
-			return true;
-		return false;
-	 * adds a {@link Point} object to this {@link Geometry} object.
-	 * @param {Float} x x value of the point
-	 * @param {Float} y y value of the point
-	this.addPointByCoordinates = function(x,y,z){
-		var newPoint = new Point(x,y,z);
-		this.add(newPoint);
-		updateDist();
-	 * @param {Point} aPoint another point
-	this.addPoint = function(aPoint){
-		this.add(new Point(aPoint.x, aPoint.y, aPoint.z));
-		updateDist();
-	 * inserts a {@link Point} object at index i of this {@link Geometry} object.
-	 * @param {Point} p another point
-	this.addPointAtIndex = function(p,i){
-		if (i !== false){
-			for(var z = this.count(); z > i; z--){
-				this.list[z] = this.list[z-1];
-			this.list[i] = new Point(p.x, p.y, p.z);
-			updateDist();
-	 * Overwrites the {@link Point) object at index i with the {@link Point} object p.
-	 * @private
-	this.updatePointAtIndex = function(p, i){
-		if ((i === 0 || i == this.count()-1) && this.geomType == geomType.polygon){
-			this.list[0] = p;
-			this.list[this.count()-1] = p;
-		else {this.list[i] = p;}
-		updateDist();
-	 * Updates the {@link Geometry#dist} and {@link Geometry#totaldist}
-	 * @private
-	var updateDist = function(){
-		dist[0] = 0;
-		totaldist[0] = 0;
-		for (var i = 1 ; i < that.count(); i++){
-			dist[i] = that.get(i-1).dist(that.get(i));
-			totaldist[i] = totaldist[i-1] + dist[i];
-	 * gets the distance between two points i and i+1
-	 * @param {Integer} numberOfDigits round to numberOfDigits (optional)
-	 * @return the distance
-	 * @type Float
-	this.getDist = function(i, numberOfDigits) {
-		var indexA = this.getIndex(i);
-		var indexB = this.getIndex(i+1);
-		if (indexA === false || indexB === false) {
-			return 0;
-		if (typeof(numberOfDigits) == "number") {
-			return roundToDigits(dist[indexB], numberOfDigits);
-		return dist[indexB];
-	 * gets the distance between the last and last but one point of this {@link Geometry}.
-	 * @param {Integer} numberOfDigitis round to numberOfDigits (optional)
-	 * @type Float
-	this.getCurrentDist = function(numberOfDigits) {
-			return roundToDigits(dist[this.count()-1], numberOfDigits);
-		return dist[this.count()-1];
-	 * gets the total distance between two points i and i+1
-	 * @type Float
-	this.getAggregatedDist = function(i, numberOfDigits) {
-			return 0;
-			return roundToDigits(totaldist[indexB], numberOfDigits);
-		return totaldist[indexB];
-	 * gets the length of the outer rim of this {@link Geometry}.
-	 * @type Float
-	this.getTotalDist = function(numberOfDigits) {
-			return roundToDigits(totaldist[this.count()-1], numberOfDigits);
-		return totaldist[this.count()-1];
-	 * closes this {@link Geometry}.
-	 * @return true if the geometry could be closed; otherwise false
-	 * @type Boolean
-	this.close = function(){
-		complete = true;
-//			if (this.count() > 2){
-				if (this.count() > 0 && !this.get(0).equals(this.get(-1))) {
-					this.addPoint(this.get(0));
-//			else {return false;}
-		if (this.geomType == geomType.line){
-//			if (this.count() < 2){return false;}
-		if (this.geomType == geomType.point){
-			if (this.count() === 0){return false;}
-		return true;
-	this.isValid = function(){
-		if (this.geomType === geomType.polygon){
-			return (this.count() > 3 && this.get(0).equals(this.get(-1))) ? true : false;
-		if (this.geomType === geomType.line){
-			return (this.count() < 2) ? false : true;
-			return (this.count() === 0) ? false : true;
-		return false;
-	this.reopen = function () {
-		if (!complete) {
-			return false;
-		complete = false;
-			this.del(-1);
-		return true;
-	 * checks if this {@link Geometry} has been closed.
-	 * @return true if the geometry is closed; otherwise false
-	 * @type Boolean
-	this.isComplete = function() {
-		return complete;
-	 * Sets the EPSG of this geometry.
-	 * @param {Integer} someEpsg the EPSG of this geometry.
-	 * @return true if the EPSG could be set; else false
-	 * @type boolean
-	this.setEpsg = function (someEpsg) {
-		// TODO: how to check if EPSG code is correct?
-		epsg = someEpsg;
-		return true;
-//		var e = new Mb_exception("EPSG code not valid ("+someEpsg+")");
-//		return false;
-	 * @type integer
-	this.getEpsg = function () {
-		return epsg;
-	this.list = [];
-	var dist = [];
-	var totaldist = [];
-	var complete = false;
-	var epsg;
-	var that = this;
-	this.geomType = aGeomtype;
-	this.name = nameGeometry;
-	// add these members if the geometry is a polygon
-		this.innerRings = new InnerRings();
-		this.addInnerRing = function (somePolygon) {
-			this.innerRings.add(somePolygon);
-		this.delInnerRing = function (index) {
-			this.innerRings.del(index);
-Geometry.prototype = new List();
-Geometry.prototype.toText = function () {
-	var text = "";
-			text += "(";
-			for (var j = 0; j < this.count(); j++) {
-				if (j > 0) {
-					text += ", ";
-				var currentPoint = this.get(j);
-			text += ")";
-			if (this.innerRings && this.innerRings.count() > 0) {
-				for (var k = 0; k < this.innerRings.count(); k++) {
-					text += ", ";
-					text += this.innerRings.get(k).toText();
-			break;
-			var point = this.get(0);
-			if(typeof(!point.z)) {
-				return "POINT(" +point.x + " " + point.y + ")";
-			else {
-				return "POINT Z (" + point.x + " " + point.y + " " + point.z + ")";
-			break;
-	return text;
- * gets the bounding box of this {@link Geometry}
- * @return the bounding box (array of two Point objects)
- * @type Point[]
-Geometry.prototype.getBBox = function(){
-	var q = this.get(0);
-	for (var j=0; j<this.count(); j++){
-		var pos = this.get(j);
-		if (pos.x < min.x) {min.x = pos.x;}
-		else if (pos.x > max.x) {max.x = pos.x;}
-		if (pos.y < min.y) {min.y = pos.y;}
-		else if (pos.y > max.y) {max.y = pos.y;}
-		for (var i = 0; i < this.innerRings.count(); i++) {
-			var currentRing = this.innerRings.get(i);
-			for (var j=0; j<currentRing.count(); j++){
-				var pos = currentRing.get(j);
- * updates all {@link Point} objects of this {@link Geometry} that equal oldP to newP
-Geometry.prototype.updateAllPointsLike = function(oldP, newP){
-	for (var i = 0; i < len ; i++){
-		if (oldP.equals(this.get(i))){
-			if (i>0 && newP.equals(this.get(i-1))){
-				this.del(i);
-				len--;
-				i--;
-			else {this.updatePointAtIndex(newP, i);}
-		for (var j = 0; j < this.innerRings.count(); j++) {
-			var len = this.innerRings.get(j).count();
-				if (oldP.equals(this.innerRings.get(j).get(i))){
-					if (i>0 && newP.equals(this.innerRings.get(j).get(i-1))){
-						this.innerRings.get(j).del(i);
-						len--;
-						i--;
-					else {this.innerRings.get(j).updatePointAtIndex(newP, i);}
- * compares this {@link Geometry} object with the {@link Geometry} object geom point by point.
- * @param {Geometry} geom another geometry
- * @return true if he geometries match; else false
- * @type Boolean
-Geometry.prototype.equals = function(geom) {
-	if (this.geomType != geom.geomType) {return false;}
-	if (this.count() != geom.count()) {return false;}
-		if (!this.get(i).equals(geom.get(i))) {return false;}
-	if (!this.innerRings && !geom.innerRings) {
-		// no inner rings; fine
-	else if (this.innerRings && geom.innerRings) {
-		if (this.innerRings.count() != geom.innerRings.count()) {
-			return false;
-			if (!this.innerRings.get(j).equals(geom.innerRings.get(j))) {
-				return false;
-	else {
-		// inner ring mismatch
-		return false;
-	return true;
- * creates a polygon geometry object which form a buffer around the line geometry
- * @param {float} real world units to buffer around the line
- * @param {float} (optional) units to buffer around the line in Y direction
- * @return linebuffer polygon
- * @type Geometry
-Geometry.prototype.bufferLine = function(bufferX, bufferY){
-	if(typeof(bufferY)=='undefined')
-		bufferY = bufferX;
-	if (this.geomType != geomType.line || this.count() < 2) {
-		return false;
-	var ret = new Geometry(geomType.polygon);
-	//get vector from point 0 to point 1
-	last_vec = this.get(1).minus(this.get(0));
-	//get 90° rotated vector
-	last_vec_o = new Point(-last_vec.y, last_vec.x);
-	//resize vectors with apropriate linebuffer length
-	last_vec_o = last_vec_o.dividedBy(last_vec_o.dist(new Point(0,0)));
-	last_vec_o.x*=bufferX; last_vec_o.y*=bufferY;
-	last_vec = last_vec.dividedBy(last_vec.dist(new Point(0,0)));
-	last_vec.x*=bufferX; last_vec.y*=bufferY;
-	//add first pointsets
-	ret.list.unshift(this.get(0).plus(last_vec_o).minus(last_vec));
-	ret.list.push(this.get(0).minus(last_vec_o).minus(last_vec));
-	for(var i=1;i<this.count()-1;i++){
-		//get vector from point n to point n+1
-		vec = this.get(i+1).minus(this.get(i));
-		//get orthogonal (90° rotated) vector
-		vec_o = new Point(-vec.y, vec.x);
-		//resize vectors to linebuffer length
-		vec_o = vec_o.dividedBy(vec_o.dist(new Point(0,0)));
-		vec_o.x*=bufferX; vec_o.y*=bufferY;
-		vec = vec.dividedBy(vec.dist(new Point(0,0)));
-		vec.x*=bufferX; vec.y*=bufferY;
-		//if direction is the same continue
-		if(vec.equals(last_vec)) {
-			continue;
-		// calculate directed angle between the two vectors by
-		// calculating the argument diffenrences between complex numbers
-		// arg(x + i*y) (because law of cosine can onlycalculate undirected angle)
-		var angle = (Math.atan2(vec.x,vec.y)-Math.atan2(last_vec.x,last_vec.y))
-		//ensure that angle is -180<=angle<=180
-		if(angle<-Math.PI)angle=2*Math.PI+angle;
-		if(angle>+Math.PI)angle=2*Math.PI-angle;
-		//calculate the distance between the next points on boundary
-		//and the line point
-		//the point will be in the direction of angle/2 relative to last_vec_o
-		//since cosine is adjacent side / hypothenuse and we know that
-		//the adjacent side is lineBuffer the hypothenus (our distance) is
-		var ndist = 1/(Math.cos(angle/2))
-		//direction of next points on boundary
-		var int_vec = vec_o.plus(last_vec_o);
-		//resize direction vector to our distance
-		int_vec = int_vec.times(ndist/int_vec.dist(new Point(0,0)));
-		int_vec.x*=bufferX; int_vec.y*=bufferY;
-		//look if we have an outer sharp corner (>90°)
-		if(angle>Math.PI/2){
-			//push cutted edge points
-			ret.list.unshift(this.get(i).plus(last_vec_o).plus(last_vec));
-			ret.list.unshift(this.get(i).plus(vec_o).minus(vec));
-		else{
-			//push inner/light edge
-			ret.list.unshift(this.get(i).plus(int_vec));
-		//look if we have an inner sharp corner (<-90°)
-		if(angle<-Math.PI/2){
-			ret.list.push(this.get(i).minus(last_vec_o).plus(last_vec));
-			ret.list.push(this.get(i).minus(vec_o).minus(vec));
-		else{
-			ret.list.push(this.get(i).minus(int_vec));
-		//copy for next point
-		last_vec = vec;
-		last_vec_o = vec_o;
-	//add last pointsets
-	ret.close();
-	return ret;
-Geometry.prototype.toString = function () {
-	var str = "";
-		str += "[[";
-			if (i > 0) {
-				str += ", ";
-		if (this.count() > 0 && !this.get(0).equals(this.get(i-1))) {
-			str += ", " + this.get(0).toString();
-		if (typeof(this.innerRings) == "object" && this.innerRings.count() > 0) {
-				var currentRing = this.innerRings.get(j);
-				str += "],[";
-				for (var i = 0; i < currentRing.count(); i++) {
-					if (i > 0) {
-						str += ", ";
-					str += currentRing.get(i).toString();
-				if (currentRing.count() > 0 && !currentRing.get(0).equals(currentRing.get(i-1))) {
-					str += ", " + currentRing.get(0).toString();
-		str += "]]";
-		str += "[";
-			if (i > 0) {
-				str += ", ";
-		str += "]";
-	else if (this.geomType == geomType.point) {
-	return str;
- * @class an array of elements, each consisting of a name/value pair
- * @ constructor
-function Wfs_element(){
-	 * returns the number of elements of this {@link Wfs_element} object.
-	 * @return the number of elements
-	 * @type Integer
-	this.count = function(){
-		return this.name.length;
-	 * returns the name of the element at index i.
-	 * @return the name
-	 * @type String
-	this.getName = function(i){
-		if (this.isValidElementIndex(i)) {return this.name[i];}
-		return false;
-	 * returns the value of the element at index i.
-	 * @return the value
-	this.getValue = function(i){
-		if (this.isValidElementIndex(i)) {return this.value[i];}
-		return false;
-	 * appends a new element with a given name. If an element with this name exists, it is overwritten.
-	 * @param {String} aName the name of the new element
-	 * @param {String} aValue the value of the new element
-	this.setElement = function(aName, aValue){
-		var i = this.getElementIndexByName(aName);
-		if (i === false) {i = this.count();}
-		this.name[i] = aName;
-		this.value[i] = aValue;
-	 * removes an element with a given name. If an element with this name exists, it is removed.
-	 * @param {String} aName the name of the element to delete
-	this.delElement = function(aName){
-			this.name.splice(i, 1);
-			this.value.splice(i, 1);
-	 * checks if an index is valid
-	 * @private
-	 * @param {Integer} i an index
-	 * @return true if the index is valid; otherwise false
-	 * @type Boolean
-	this.isValidElementIndex = function(i){
-		if (i>=0 && i<this.name.length) {return true;}
-		var e = new Mb_exception("class Wfs_element: function isValidElementIndex: illegal element index");
-		return false;
-	this.name  = [];
-	this.value = [];
- * gets the index of the element with a given name.
- * @param {String} elementName a name
- * @return the index of the element; if no element with this name exists, false
- * @type Integer, Boolean
-Wfs_element.prototype.getElementIndexByName = function(elementName){
-	for (var j = 0, len = this.count() ; j < len ; j++){
-		if (this.getName(j) == elementName) {return j;}
-	return false;
- * gets the value of the element with a given name.
- * @return the value of the element; if no element with this name exists, false
- * @type String, Boolean
-Wfs_element.prototype.getElementValueByName = function(elementName){
-	var i = this.getElementIndexByName(elementName);
-	if (i === false) {return false;}
-	return this.getValue(i);
-Wfs_element.prototype.toString = function () {
-	var str = "";
-		str += "\"properties\": {";
-			if (i > 0) {
-				str += ",";
-			var key = this.getName(i);
-			var value = this.getValue(i);
-			str += "\"" + key + "\":\"" + (value+'').replace(/([\\"'])/g, "\\$1").replace(/\u0000/g, "\\0").replace(/\n/g, "\\n").replace(/\r/g, "\\r") + "\"";
-		str += "}";
-	return str;
- * @class a {@link Canvas} contains a {@link DivTag} that holds graphics rendered by {@link jsGraphics}
- * @constructor
- * @requires DivTag
- * @requires jsGraphics
- * @requires GeometryArray
- * @requires MultiGeometry
- * @param {String} aMapFrame name of the target mapframe
- * @param {String} aTagName name of the target div tag
- * @param {String} aStyle style of the div tag
- * @param {Integer} aLineWidth the line width of the jsGraphics output
-function Canvas(aMapframe, aTagName, aStyle, aLineWidth) {
-	 * draws the geometry of the canvas
-	 * @param {String} t geometry type (@see GeomType)
-	 * @param {MultiGeometry} g a MultiGeometry object
-	 * @param {String} col a color
-	 * @private
- 	this.drawGeometry = function(t,g,col){
- 		var mapframeWidth = map.width;
-		var mapframeHeight = map.height;
-		var node = null;
-		if(t == geomType.point) {
-			var poiIcon = g.e.getElementValueByName("Mapbender:icon");
-			var poiOffsetX = parseInt(g.e.getElementValueByName("Mapbender:iconOffsetX"), 10);
-			var poiOffsetY = parseInt(g.e.getElementValueByName("Mapbender:iconOffsetY"), 10);
-			var poiWidth = parseInt(g.e.getElementValueByName("Mapbender:iconWidth"), 10);
-			var poiHeight = parseInt(g.e.getElementValueByName("Mapbender:iconHeight"), 10);
-			for(var i=0, ilen = g.count(); i < ilen; i++){
-				var currentGeom = g.get(i);
-				var p = realToMap(mapframe, currentGeom.get(0));
-				var px = p.x;
-				var py = p.y;
-				var radius = diameter/2;
-				if ((px - radius < mapframeWidth && px + radius > 0 &&
-					py - radius < mapframeHeight && py + radius > 0) ||
-					(p.dist(new Point(0,0)) < radius ||
-					 p.dist(new Point(mapframeWidth, mapframeHeight)) < radius ||
-					 p.dist(new Point(0,mapframeHeight)) < radius ||
-					 p.dist(new Point(mapframeWidth, 0)) < radius
-					// if the point contains a link to an icon, display the icon
-					if (poiIcon) {
-						if (isNaN(poiWidth) || isNaN(poiHeight)) {
-							node = displayIcon(poiIcon, px, py, poiOffsetX, poiOffsetY);
-						else {
-							node = displayIcon(poiIcon, px, py, poiOffsetX, poiOffsetY, poiWidth, poiHeight);
-					else {
-						node = drawCircle(px-1, py-1, diameter,col);
-		else if(t == geomType.line || t==geomType.polygon) {
-			if (typeof Raphael !== "undefined") {
-				var path = "";
-				//				if (t == geomType.line) {
-				for (var i = 0, ilen = g.count(); i < ilen; i++) {
-					var previousPoint = realToMap(mapframe, currentGeom.get(0));
-					var segment = "";
-					for (var j = 1, jlen = currentGeom.count(); j < jlen; j++) {
-						(function(){
-							var currentPoint = realToMap(mapframe, currentGeom.get(j));
-							var pq = calculateVisibleDash(previousPoint, currentPoint, mapframeWidth, mapframeHeight);
-							if (pq) {
-								if (segment === "") {
-									segment += "M" + pq[0].x + " " + pq[0].y;
-								else {
-									if (!previousPoint.equals(pq[0])) {
-										if (t == geomType.polygon) {
-											segment += "L" + pq[0].x + " " + pq[0].y;
-										else {
-								segment += " L" + pq[1].x + " " + pq[1].y;
-							previousPoint = currentPoint;
-						segment += " Z";
-					path += segment;
-				var canvasPath = canvas.path(path);
-				node = canvasPath.node;
-					canvasPath.attr({
-						"fill": col,
-						"stroke": col,
-						"stroke-width": lineWidth,
-						"fill-opacity": 0.1
-				else {
-					canvasPath.attr({
-						"stroke": col,
-			else {
-					// paint inner rings
-					if (t==geomType.polygon && currentGeom.innerRings.count() > 0) {
-						for (var k = 0; k < currentGeom.innerRings.count(); k++) {
-							var currentRing = currentGeom.innerRings.get(k);
-							var previousPoint = realToMap(mapframe, currentRing.get(0));
-							for (var j=1, jlen = currentRing.count(); j < jlen; j++) {
-								(function () {
-									var currentPoint = realToMap(mapframe, currentRing.get(j));
-									if (pq) {
-										drawLine([pq[0].x-1, pq[1].x-1], [pq[0].y-1, pq[1].y-1], col);
-					// paint line or outer ring
-					for (var j=1, jlen = currentGeom.count(); j < jlen; j++) {
-						(function () {
-							if (pq) {
-		else {
-			var e = new Mb_exception("class Canvas: function drawGeometry: unknown geomType " + t);
-	return node;
-	 * checks if the MultiGeometry's bounding box width and height is smaller than minWidth
-	 * @private
-	this.isTooSmall = function(g){
-		// TODO switch between dot, original, circle
-//		return false;
-		var tmp = g.getBBox();
-		var min = realToMap(mapframe,tmp[0]);
-		var max = realToMap(mapframe,tmp[1]);
-		if((Math.abs(max.x - min.x) < minWidth) && (Math.abs(max.y - min.y) < minWidth)) {
-			return true;
-		return false;
-	 * gets the jsGraphics.
-	 * @private
-	 * @return the jsGraphics
-	 * @type jsGraphics
-	this.getCanvas = function(){
-		return canvas;
-	this.setDiameter = function (px) {
-		diameter = px;
-	 * draws a circle with {@link jsGraphics}.
-	 * @private
-	 * @param {Float} x x value of the center
-	 * @param {Float} y y value of the center
-	 * @param {Float} diameter diameter of the circle
-	 * @param {String} color the color of the circle in hex format
-	var drawCircle = function(x, y, diameter, color) {
-			var c = canvas.circle(x, y, diameter/2);
-			node = c.node;
-			c.attr({
-				"fill": color,
-				"stroke": color,
-				"fill-opacity": 0.5
-		else {
-			canvas.setColor(color);
-			canvas.drawEllipse(x-diameter/2,y-diameter/2,diameter,diameter);
-		return node;
-	 * draws a polyline with {@link jsGraphics}.
-	 * @private
-	 * @param {Array} x_array array of x values
-	 * @param {Array} y_array array of y values
-	 * @param {String} color the color of the polyline in hex format
-	var drawLine = function(x_array, y_array, color) {
-		else {
-			canvas.drawPolyline(x_array, y_array);
-	 * Displays an icon in the mapframe
-	 * @private
-	 * @param {String} url link to the image
-	 * @param {Float} x x coordinate within the map frame
-	 * @param {Float} y y coordinate within the map frame
-	var displayIcon = function (url, x, y, offsetX, offsetY, width, height) {
-		var node = null;
-		if (typeof offsetX !== "number" || isNaN(offsetX)) {
-			offsetX = -40;
-		if (typeof offsetY !== "number" || isNaN(offsetY)) {
-			offsetY = -40;
-		var newImgTop = y + offsetY;
-		var newImgLeft = x + offsetX;
-			if (width !== undefined && height !== undefined) {
-				var img = canvas.image(url, newImgLeft, newImgTop, width, height);
-				node = img.node;
-			else {
-                                //append tmp img to body to get img width and height for IE
-                                var $tmpImg = $("body").append('<img style="visibility:hidden;" id="tmpImg" src="'+url+'" />');
-                                var $img = $('<img src="'+url+'" />');
-                                var width = $("#tmpImg").attr('width')||19;
-                                var height = $("#tmpImg").attr('height')||34;
-                                //remove tmp img
-                                $("#tmpImg").remove();
-				node = img.node;
-		else {
-			var $img = $("<img title='mapSymbol' class='mapSymbol' src='" +
-			url + "' style='position:absolute;top:" + newImgTop + "px;left:" + newImgLeft +
-			"px;" + (width !== undefined ? "width:" + width + "px;" : "") +
-			(height !== undefined ? "height:" + height + "px;" : "") +
-			";z-index:100;display:none'/>")
-			$(that.canvasDivTag.getTag()).html($img).children("img").show();
-			node = $img.get(0);
-		return node;
-	 * This is the {@link DivTag} that contains the output by {@link jsGraphics}.
-	 * @type DivTag
-	var mapframe = aMapframe;
-	var map = Mapbender.modules[mapframe];
-	if (!map) {
-		new Mb_exception(mapframe + " not found by geometry.js.");
-		return;
-	if (map.getDomElement().frameName) {
-		this.canvasDivTag = new DivTag(aTagName, mapName, aStyle);
-	else {
-		this.canvasDivTag = new DivTag(aTagName, "", aStyle, map.getDomElement());
-	var that = this;
-	var diameter = 8;
-	var minWidth = 8;
-	var lineWidth = aLineWidth || 2;
-	var style = aStyle;
-		var canvas = Raphael(this.canvasDivTag.getTag(), map.getWidth(), map.getHeight());
-		map.events.dimensionsChanged.register(function (obj) {
-			canvas.setSize(obj.width, obj.height);
-//		$(this.canvasDivTag.getTag()).bind("mousedown", function (e) {
-//			e.preventDefault();
-//		}).bind("mouseover", function (e) {
-//		}).bind("mousemove", function (e) {
-	else {
-		var canvas = new jsGraphics(aTagName, map.getDomElement().frameName ? window.frames[mapframe] : window);
-		canvas.setStroke(lineWidth);
-	if (!map.isOverview) {
-		mb_registerPanSubElement(aTagName);
- * cleans the canvas by emptying the canvas {@link DivTag}.
-Canvas.prototype.clean = function () {
-		this.getCanvas().clear();
-	else {
-		this.canvasDivTag.clean();
- * paints all geometries.
- * @param {GeometryArray} gA the geometries that will be drawn
-Canvas.prototype.paint = function(gA) {
-	var nodes = [];
-	var node = null;
-	for (var q = 0; q < gA.count(); q++) {
-		var m = gA.get(q);
-		var t = m.geomType;
-		var col = m.color;
-		if (t == geomType.point) {
-			node =this.drawGeometry(t,m,col);
-			nodes.push(node);
-		else {
-			if (this.isTooSmall(m)){
-				var newMember = new MultiGeometry(geomType.point);
-				newMember.addGeometry();
-				newMember.get(-1).addPoint(m.getCenter());
-				node = this.drawGeometry(geomType.point,newMember,col);
-				nodes.push(node);
-			else{
-				if(t == geomType.line) {
-					node = this.drawGeometry(t,m, col);
-					nodes.push(node);
-				else if(t == geomType.polygon) {
-					node = this.drawGeometry(t,m,col);
-					nodes.push(node);
-				else {
-					var e = new Mb_exception("class Canvas: function paint: unknown geomType" + t);
-	if (typeof Raphael === "undefined") {
-		this.getCanvas().paint();
-	return nodes;
- * @class a {@link Highlight} object is {@link jsGraphics} rendering of a {@link GeometryArray} in various mapframes.
- * @constructor
- * @requires Canvas
- * @param {Array} aTargetArray an array of Strings referring to mapframes
- * @param {String} aTagName the name of the div tags
- * @param {Object} aStyle the style of the div tags
- * @param {Integer} the line width of the jsGraphics lines
-function Highlight(aTargetArray, aTagName, aStyle, aLineWidth) {
-	var nodes = [];
-	 * removes a {@link MultiGeometry} object from the geometry Array
-	 * @param {MultiGeometry} m a MultiGeometry
-	 * @param {String} color a color
-	this.del = function(m, color) {
-		var newMultiGeom;
-		if (m.name == nameMultiGeometry) {
-			newMultiGeom = m;
-		else if (m.name == nameGeometry) {
-			var newMultiGeom = new MultiGeometry(m.geomType);
-			newMultiGeom.add(m);
-		var a = gA.findMultiGeometry(newMultiGeom);
-		var del = false;
-		for (var i=0; i<a.length && del === false; i++) {
-			if (gA.get(a[i]).color == color) {
-				gA.del(a[i]);
-				del = true;
-	 * adds a {@link MultiGeometry} object to the geometry Array
-	 * @param {String} color the color of the highlight
-	this.add = function(m, color) {
-			gA.addCopy(m);
-			gA.addCopy(newMultiGeom);
-		if (typeof(color) != 'undefined') {gA.get(-1).color = color;}
-		else {gA.get(-1).color = lineColor;}
-	this.hide = function () {
-		for (var i=0; i < canvas.length; i++) {
-			if (typeof(canvas[i]) == "object") {canvas[i].clean();}
-	 * removes all MultiGeometries.
-	this.clean = function() {
-		if (gA.count() > 0) {
-			gA = new GeometryArray();
-			this.paint();
-	 * displays the highlight
-	this.paint = function() {
-		this.hide();
-		for (var i=0; i<targets.length; i++){
-			if (typeof(canvas[i]) == 'undefined') {
-				canvas[i] = new Canvas(targets[i], tagname + i, style, lineWidth);
-			nodes = canvas[i].paint(gA);
-	this.setDiameter = function (radius) {
-		for (var i = 0; i < targets.length; i++) {
-			if (typeof(canvas[i]) != "undefined") {
-				canvas[i].setDiameter(radius);
-	this.setMouseOver = function (callback) {
-			if (typeof(canvas[i]) !== 'undefined') {
-				$(canvas[i].canvasDivTag.getTag()).mouseover(function (e) {
-					callback(e);
-	this.setMouseOut = function (callback) {
-				$(canvas[i].canvasDivTag.getTag()).mouseout(function (e) {
-					callback(e);
-	this.setMouseClick = function (callback) {
-				$(canvas[i].canvasDivTag.getTag()).click(function (e) {
-					callback(e);
-	this.getNodes = function(){
-		return nodes;
-	var lineWidth = aLineWidth;
-	var tagname = 'mod_gaz_draw'+aTagName;
-	var targets = aTargetArray;
-	var canvas = [];
-	var gA = new GeometryArray();
-	var lineColor = "#ff0000";
-	this.paint();
-// Snapping
- * @class a {@link Snapping} object stores is {@link jsGraphics} rendering of a {@link GeometryArray} in various mapframes.
- * @constructor
- * @requires Highlight
- * @param {String} aTarget name of the mapframe where snapping occurs
- * @param {String} aTolerance Snapping is activated if the mouse is
- *                 within aTolerance pixel distance to the reference point.
- * @param {String} aColor apparently deprecated?
- * @param {Integer} aZIndex the z-Index of the {@link jsGraphics} generated by {@link Highlight}.
-function Snapping(aTarget, aTolerance, aColor, aZIndex){
-	 * draws a circle to highlight the snapped point.
-	 * @param {Point} center the snapped point.
-	 * @param {Integer} radius radius of the circular highlight.
-	this.draw = function(center,radius){
-		mG = new MultiGeometry(geomType.point);
-		mG.addGeometry();
-		mG.get(-1).addPoint(center);
-		highlight.add(mG,snappingColor);
-		highlight.paint();
-	this.getTolerance = function() {
-		return tolerance;
-	this.getTarget = function() {
-		return target;
-	this.cleanHighlight = function() {
-		return highlight.clean();
-	this.addPoint = function(aPoint) {
-		coord.add(aPoint);
-	this.removePoint = function (aPoint) {
-		var len = coord.count() - 1;
-		for (var i = len; i >= 0; i--) {
-			if (coord.get(i).equals(aPoint)) {
-				coord.del(i);
-	this.getPointCount = function() {
-		return coord.count();
-	this.getPoint = function(i) {
-		return coord.get(i);
-	this.resetPoints = function() {
-		coord.empty();
-	this.getNearestNeighbour = function(){
-		if (min_i != -1) {return this.getPoint(min_i);}
-		return false;
-	this.setIndexOfNearestNeighbour = function(i){
-		min_i = i;
-	this.resetIndexOfNearestNeighbour = function(){
-		min_i = -1;
-	this.toString = function () {
-		return coord.list.join(",");
-	 * @private
-	var tolerance = (typeof(aTolerance) == 'undefined') ? 10 : aTolerance;
-	 * @private
-	var zIndex = (typeof(aZIndex) == 'undefined') ? 50 : aZIndex;
-	 * @private
-	var coord = new List();
-	coord.list = [];
-	 * @private
-	var min_i = -1;
-	 * @private
-	var target = aTarget;
-	 * @private
-	var snappingColor = aColor;
-	 * @private
-	var lineWidth = 2;
-	 * @private
-	var style = {"position":"absolute", "top":"0px", "left":"0px", "z-index":zIndex};
-	 * @private
-	var highlight = new Highlight([target], "snapping"+Math.round(Math.random()*Math.pow(10,10)), style, lineWidth);
-Snapping.prototype.check = function(currPoint){
-	var minDist = false;
-	if (this.getPointCount() === 0) {
-		return;
-	for (var i = 0 ; i < this.getPointCount() ; i++) {
-		var currDist = currPoint.dist(realToMap(this.getTarget(), this.getPoint(i)));
-		if (minDist === false || currDist < minDist) {
-			minDist = currDist;
-			if (minDist < this.getTolerance()) {this.setIndexOfNearestNeighbour(i);}
-	if (this.getPointCount() > 0 && minDist > this.getTolerance()) {
-		this.resetIndexOfNearestNeighbour();
-	this.cleanHighlight();
-	if (this.isSnapped()) {
-		this.draw(this.getNearestNeighbour(), this.getTolerance());
- * Stores the points which will have the snapping property.
- * @param {GeometryArray} geom all points of geom will be stored. May also be a
- *                             {@link MultiGeometry} or {@link Geometry}.
- * @param {Point} point this point is excluded. Useful when moving a point of a
- *                      geometry; you don't want to snap against the point you
- *                      move. Optional.
-Snapping.prototype.store = function(geom, point){
-	this.resetPoints();
-	for (var i = 0 ; i < geom.count(); i++){
-		if (geom.name == nameGeometryArray || geom.name == nameMultiGeometry){
-			for (var j = 0 ; j < geom.get(i).count() ; j++){
-				if (geom.get(i).name == nameMultiGeometry){
-					// inner rings
-					if (geom.get(i).get(j).geomType == geomType.polygon && geom.get(i).get(j).innerRings && geom.get(i).get(j).innerRings.count() > 0) {
-						for (var l = 0; l < geom.get(i).get(j).innerRings.count(); l++) {
-							var currentRing = geom.get(i).get(j).innerRings.get(l);
-							for (var k = 0 ; k < currentRing.count() ; k++){
-								if ((currentRing.isComplete() === true && typeof(point) == 'undefined') || (typeof(point) != 'undefined' && !currentRing.get(k).equals(point))){
-									this.add(currentRing.get(k));
-					// lines, points, outer rings
-					for (var k = 0 ; k < geom.get(i).get(j).count() ; k++) {
-						//if ((geom.get(i).get(j).isComplete() === true && typeof(point) == 'undefined') || (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point))){
-							this.add(geom.getPoint(i, j, k));
-				else {
-					if ((geom.get(i).isComplete() === true && typeof(point) == 'undefined') || (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point))){
-						this.add(geom.getPoint(i, j));
-		else {
-			if (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point)){
-				this.add(geom.get(i));
- * Determines whether a point is within snapping distance to the mouse cursor
- * @return true if a point is within snapping distance; else false
- * @type Boolean
-Snapping.prototype.isSnapped = function(){
-	if (this.getNearestNeighbour() !== false) {return true;}
-	return false;
- * Returns the point that is within snapping distance and closest to the mouse cursor.
- * @return the point (if there is any); else false
- * @type Point
-Snapping.prototype.getSnappedPoint = function(){
-	return this.getNearestNeighbour();
- * Adds the point to the stored points with snapping property.
- * @param {Point} point which receives snapping property.
-Snapping.prototype.add = function(aPoint){
-	this.addPoint(aPoint);
- * Removes the highlight.
-Snapping.prototype.clean = function(){
-// misc. functions
- * @ignore
-function calculateVisibleDash (a, b, width, height) {
-	var p0 = new Mapbender.Point(a);
-	var p1 = new Mapbender.Point(b);
-	if (p0.x > p1.x) {
-		var switched = true;
-		var p_temp = p0;
-		p0 = p1;
-		p1 = p_temp; p_temp = null;
-	var p = p0; var q = p1; var m; var ix; var iy;
-	if (p1.x != p0.x) {
-		m = -(p1.y-p0.y)/(p1.x-p0.x);
-		if (p0.x < width && p1.x > 0 && !(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height) ) {
-			if (p0.x < 0) {
-				iy = p0.y - m*(0-p0.x);
-				if (iy > 0 && iy < height) {p = new Point(0, iy);}
-				else if (iy > height) {
-				    ix = p0.x+((p0.y - height)/m);
-				    if (ix > 0 && ix < width) {p = new Point(ix, height);} else {return false;}
-				else if (iy < 0) {
-				    ix = p0.x+(p0.y/m);
-				    if (ix > 0 && ix < width) {p = new Point(ix, 0);} else {return false;}
-				else {return false;}
-			else if (p0.y >= 0 && p0.y <= height) {p = p0;}
-			else if (p0.y < 0) {
-			else if (p0.y > height && m > 0) {
-			if (p1.x > width) {
-				iy = p1.y - m*(width-p1.x);
-				if (iy > 0 && iy < height) {q = new Point(width, iy);}
-				    if (ix > 0 && ix < width) {q = new Point(ix, 0);} else {return false;}
-				    if (ix > 0 && ix < width) {q = new Point(ix, height);} else {return false;}
-			else if (p1.y >= 0 && p1.y <= height) {q = p1;}
-			else if (p1.y < 0) {
-			    ix = p1.x+(p1.y/m);
-			else if (p1.y > height) {
-			    ix = p1.x+((p1.y- height)/m);
-	else {
-		if (!(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height)) {
-			if (p0.y < 0) {p = new Point(p0.x, 0);}
-			else if (p0.y > height) {p = new Point(p0.x, height);}
-			else {p = p0;}
-			if (p1.y < 0) {q = new Point(p0.x, 0);}
-			else if (p1.y > height) {q = new Point(p0.x, height);}
-			else {q = p1;}
-	if (switched) {
-		return [new Point(Math.round(q.x), Math.round(q.y)), new Point(Math.round(p.x), Math.round(p.y))];
-	return [new Point(Math.round(p.x), Math.round(p.y)), new Point(Math.round(q.x), Math.round(q.y))];
- * @ignore
-function objString (a){
-	var z = "";
-	for (attr in a) {
-		var b = a[attr];
-		if (typeof(b) == "object") {z += objString(b);}
-		else {z += attr + " " + b + "\n";}
-	return z;
Deleted: trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
--- trunk/mapbender/http/javascripts/mb_downloadFeedClient.js	2016-05-27 07:02:37 UTC (rev 9485)
+++ trunk/mapbender/http/javascripts/mb_downloadFeedClient.js	2016-05-27 07:07:37 UTC (rev 9486)
@@ -1,341 +0,0 @@
-var mapframe_dataset_list, mapframe_file_list, datasetSelect, file_list, bboxDataset, bboxFiles, formats, sf;
-function updateFormats() {
-            var in_options = {
-                'internalProjection': mapframe_dataset_list.baseLayer.projection,
-                'externalProjection': new OpenLayers.Projection("EPSG:4326")
-            var out_options = {
-                'externalProjection': new OpenLayers.Projection("EPSG:900913")
-            var gmlOptions = {
-                featureType: "feature",
-                featureNS: "http://example.com/feature"
-            var gmlOptionsIn = OpenLayers.Util.extend(
-                OpenLayers.Util.extend({}, gmlOptions),
-                in_options
-            var gmlOptionsOut = OpenLayers.Util.extend(
-                out_options
-            var kmlOptionsIn = OpenLayers.Util.extend(
-                {extractStyles: true}, in_options);
-            formats = {
-              'in': {
-                wkt: new OpenLayers.Format.WKT(in_options),
-                geojson: new OpenLayers.Format.GeoJSON(in_options),
-                georss: new OpenLayers.Format.GeoRSS(in_options),
-                gml2: new OpenLayers.Format.GML.v2(gmlOptionsIn),
-                gml3: new OpenLayers.Format.GML.v3(gmlOptionsIn),
-                kml: new OpenLayers.Format.KML(kmlOptionsIn),
-                atom: new OpenLayers.Format.Atom(in_options),
-                gpx: new OpenLayers.Format.GPX(in_options)
-              'out': {
-                wkt: new OpenLayers.Format.WKT(out_options),
-                geojson: new OpenLayers.Format.GeoJSON(out_options),
-                georss: new OpenLayers.Format.GeoRSS(out_options),
-                gml2: new OpenLayers.Format.GML.v2(gmlOptionsOut),
-                gml3: new OpenLayers.Format.GML.v3(gmlOptionsOut),
-                kml: new OpenLayers.Format.KML(out_options),
-                atom: new OpenLayers.Format.Atom(out_options),
-                gpx: new OpenLayers.Format.GPX(out_options)
-function init(){
-	//generate 2 Mapframes
-	mapframe_dataset_list = new OpenLayers.Map('mapframe_dataset_list');
-	mapframe_file_list = new OpenLayers.Map('mapframe_file_list');
-	var wms1 = new OpenLayers.Layer.WMS( "Open Layers WMS",
-                "http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv.fcgi?map=/data/umn/geoportal/karte_rp/rheinland-pfalz-gesamt2.map&", {layers: 'ATKIS-Praes',transparent: "true",format: "image/png"}, {singleTile: true, isBaseLayer: false});
-	var wms11 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
-                "http://www2.demis.nl/wms/wms.ashx?wms=WorldMap&", {layers: 'Bathymetry,Countries,Topography,Hillshading,Coastlines,Waterbodies,Rivers,Streams,Railroads,Highways,Roads,Borders,Cities,Settlements,Airports'}, {singleTile: true});
-	//var wms_osm = new OpenLayers.Layer.WMS( "OpenLayers WMS",
-        //        "http://osm.omniscale.net/proxy/service?", {layers: 'osm'}, {singleTile: true});
-	var wms2 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
-	var wms22 = new OpenLayers.Layer.WMS( "DEMIS World",
-	//Vector layer for the georss polygons of the service feed - maybe more than one
-	bboxDataset = new OpenLayers.Layer.Vector("Dataset bounding boxes");
-	//Vector layer for the georss polygons of one single data feed entry - maybe more than one if the dataset is tiled into different sections
-	bboxFiles = new OpenLayers.Layer.Vector("File bounding boxes");
-	mapframe_dataset_list.addLayers([wms11,wms1,bboxDataset]);
-	mapframe_dataset_list.addControl(new OpenLayers.Control.MousePosition());
-	mapframe_file_list.addLayers([wms22,wms2,bboxFiles]);
-	mapframe_file_list.addControl(new OpenLayers.Control.MousePosition());
-	updateFormats();
-	//initialize mapframes
-	mapframe_dataset_list.setCenter(new OpenLayers.LonLat(7, 50), 7);
-	mapframe_file_list.setCenter(new OpenLayers.LonLat(7, 50), 7);
-	resetForm();
-	//start parsing when no empty string was found in input for url
-	if ($('#download_feed_url').val() != "") {
-		method =  "getServiceFeedObjectFromUrl";
-        	data = $("#download_feed_url").val();
-		//call server by ajax function
-		callServer(data,method);
-	//initialize button for load service feed - the first feed will be parsed.
-	$(document).ready(function(e) {
-    		$('#download_feed_button').click(function() {
-			resetForm();
-	//don't show elements of dataset feed
-//central function to call server by ajax, result is a featureCollection which is generated by mapbenders server component
-function callServer(data,method,id) {
-	if (id === undefined) id = 0;
-	//alert("ajax call begin");
-	$.ajax({
-  		url: '../plugins/mb_downloadFeedServer.php',
-  		type: "post",
-		async: false, //cause reading the first feed may take longer than the second
-		data: {url: data, method: method , id: id},
-       		dataType: "json",
-  		success: function(result) {
-			if (method == "getServiceFeedObjectFromUrl") {
-				//draw georss polygons from service feed
-				drawMetadataPolygons(result);
-				//show datasets in a dropdown list
-				showDatasetList(result);
-			if (method == "getDatasetFeedObjectFromUrl") {
-				//function to draw bboxes of single link to data tile and the corresponding list of tiles
-				//alert("ajax datasetfeed read!");
-				showDatasetEntryList(result, id);
-	return false;
-function resetForm() {
-	//reset form
-	$("#representation_select").css("display","none");
-	$("#representation_info").css("display","none");
-	//change size of outer fieldset
-	$("#client").css("height","450px");
-function showDatasetList(featureCollection,id) {
-	resetForm();
-	if (featureCollection == null) {
-		alert("No parseable content found");
-		return false;
-	//remove old dataset select option
-	$('#dataset_select').remove();
-	//delete identifier anchor
-	$('#dataset_identifier_link').remove();
-	//delete capabilities anchor
-	$('#capabilities_link').remove();
-	//delete old entries
-	var datasetSelect =  $(document.createElement('select')).appendTo('#dataset_list');
-	datasetSelect.attr({'id':'dataset_select'});
-	var selectOptions = "";
-	//iterate over all single features which can be identified with the entries of the inspire service feed
-	for(var i=0; i<featureCollection.features.length; ++i) {
-		//fill in first title, rights and abstract in fields
-		if (i == id) {
-			$('#dataset_title').val(featureCollection.features[i].properties.title);
-			$('#dataset_rights').val(featureCollection.features[i].properties.rights);
-			$('#dataset_abstract').val(featureCollection.features[i].properties.summary);
-			//add capabilities anchor
-			identifierAnchor =  $(document.createElement('a')).appendTo('#capabilities_hybrid');
-			identifierAnchor.attr({'id':'capabilities_link'});
-			identifierAnchor.attr({'href':featureCollection.features[i].properties.capabilitiesLink});
-			identifierAnchor.text(featureCollection.features[i].properties.capabilitiesLink);
-			//$('#capabilities_link').val(featureCollection.features[i].properties.capabilitiesLink);
-			//add identifier anchor
-			identifierAnchor =  $(document.createElement('a')).appendTo('#dataset_identifier');
-			identifierAnchor.attr({'id':'dataset_identifier_link'});
-			identifierAnchor.attr({'href':'../php/mod_iso19139ToHtml.php?url='+encodeURIComponent(featureCollection.features[i].properties.metadataLink)});
-			identifierAnchor.text(featureCollection.features[i].properties.namespace+"#"+featureCollection.features[i].properties.code);
-		selectOptions = selectOptions+"<option value='"+featureCollection.features[i].properties.datasetFeedLink+"' url='"+featureCollection.features[i].properties.datasetFeedLink+"' optionid='"+i+"'>"+featureCollection.features[i].properties.title+"</option>";
-	datasetSelect.append(selectOptions);
-	//preselect option
-	$("#dataset_select option[optionid='" + id + "']").attr("selected","selected");
-	$('#dataset_select').bind('change', function() {
-		var $this = $(this);
-		optionSelected = $(this).find('option:selected').attr('optionid');
-		//alert(optionSelected);
-		showDatasetList(featureCollection,optionSelected);
-		method =  "getDatasetFeedObjectFromUrl";
-        	data = $this.val();
-		resetForm();
-	//call second feed with first entry for default
-        data = featureCollection.features[0].properties.datasetFeedLink;
-	datasetFeedObject = callServer(data,method);
-function showDatasetEntryList(featureCollection, id) {
-		return false;
-	//alert("test");
-	//remove select element for the different possible representations (formats, crs, ...)
-	$('#dataset_representation_select').remove();
-	//generate new select element
-	var datasetEntrySelect =  $(document.createElement('select')).appendTo('#dataset_representation_list');
-	datasetEntrySelect.attr({'id':'dataset_representation_select'});
-	//initialize options
-	var selectROptions = "";
-	//iterate over all possible representations, which are modeled as entries in the dataset feed (here features of the featureCollection)
-		selectROptions = selectROptions+"<option value='"+i+"' url='"+featureCollection.features[i].properties.datasetFeedLink+"'>"+featureCollection.features[i].properties.title+"</option>";
-	datasetEntrySelect.append(selectROptions);
-	fillSectionList(featureCollection, id);
-	$('#dataset_representation_select').bind('change', function() {
-		fillSectionList(featureCollection,$this.val());
-function fillSectionList(featureCollection, k) {
-		bboxFiles.removeAllFeatures();
-		$('#section_option').remove();
-		//initialize option string
-		var selectFOptions = "";
-		//count number of links in representation
-		var numberOfLinks = featureCollection.features[k].properties.link.length;
-		if (numberOfLinks >= 1 || numberOfLinks === undefined) {
-			//show list
-			$("#representation_select").css("display","block");
-			//deactivate mapframe2 by default
-			$("#mapframe_file_list").css("display","none");
-			//$("#multi_select").css("display","none");
-			$("#representation_info").css("display","block");
-			//extent size of outer fieldset
-			$("#client").css("height","730px");
-		} else {
-			alert("No links to datasets or parts of them found in feed!");
-                for (var i = 0; i < numberOfLinks; i++) {
-			if (featureCollection.features[k].properties.link[i]['@attributes'].bbox == '' || featureCollection.features[k].properties.link[i]['@attributes'].bbox === undefined) {
-				selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[k].properties.link[i]['@attributes'].href+"' title='"+featureCollection.features[k].properties.link[i]['@attributes'].title+"'  onclick='window.open(\""+featureCollection.features[k].properties.link[i]['@attributes'].href+"\");'>"+featureCollection.features[k].properties.link[i]['@attributes'].title+"</option>";
-			} else {
-                		ext = featureCollection.features[k].properties.link[i]['@attributes'].bbox;
-				extArrayNew = new Array();
-				extArray = ext.split(" ");
-				//sort array to lat lon
-				extArrayNew[0] = extArray[1];
-				extArrayNew[1] = extArray[0];
-				extArrayNew[2] = extArray[3];
-				extArrayNew[3] = extArray[2];
-                		bound = OpenLayers.Bounds.fromArray(extArrayNew);
-				attributes = {id: i, url:featureCollection.features[k].properties.link[i]['@attributes'].href};
-                		box = new OpenLayers.Feature.Vector(bound.toGeometry(),attributes);
-                		bboxFiles.addFeatures(box);
-				selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[k].properties.link[i]['@attributes'].href+"' title='"+featureCollection.features[k].properties.link[i]['@attributes'].title+"' onclick='highlightFeatureIndexById("+i+",true);' onmouseover='highlightFeatureIndexById("+i+",false);'>"+featureCollection.features[k].properties.link[i]['@attributes'].title+"</option>";
-		//count features of bboxFiles
-		//bboxFiles if not available show error message
-		selectFObject = $(document.createElement('select')).appendTo('#section_list');
-		selectFObject.attr({'id':'section_option'});
-		selectFObject.attr({'multiple':'multiple'});
-		//add options
-		selectFOptionsObject = $('#section_option').append(selectFOptions);
-		selectFOptionsObject.attr({'width': 300});
-		//alert(bboxFiles.features.length);
-		if (bboxFiles.features.length >= 1) {//TODO
-			//show mapframe
-			$("#mapframe_file_list").css("display","block");
-			$("#client").css("height","900px");
-			bound = bboxFiles.getDataExtent();
-			mapframe_file_list.zoomToExtent(bound);
-			bboxFiles.events.on({
-   				featureselected: function(event) {
-        				var feature = event.feature;
-        				var id = feature.attributes.id;
-					var url = feature.attributes.url;
-					$('#section_option option').removeAttr('selected')
-					$("#section_option option[value='"+id+"']").attr('selected',true);
-					//window.open(url,'download_window');
-					/*if ($('#multi_select').is(':checked')) {
-						alert("checked");
-					} else {
-						alert("un-checked");
-					alert(url);*/
-                	sf = new OpenLayers.Control.SelectFeature(bboxFiles);
-                	mapframe_file_list.addControl(sf);
-                	sf.activate();
-function drawMetadataPolygons(featureCollection) {
-	 var type = "geojson";
-         var features = formats['in'][type].read(featureCollection);
-         var bounds;
-         if(features) {
-             if(features.constructor != Array) {
-                 features = [features];
-             for(var i=0; i<features.length; ++i) {
-                 if (!bounds) {
-                     bounds = features[i].geometry.getBounds();
-                 } else {
-                     bounds.extend(features[i].geometry.getBounds());
-	     //delete old features:
-	     bboxDataset.removeAllFeatures();
-             bboxDataset.addFeatures(features);
-             mapframe_dataset_list.zoomToExtent(bounds);
-function highlightFeatureIndexById(id, open) {
-	features = bboxFiles.features;
-		if(features[i].attributes.id == id) {
-			index = i;
-			break;
-	//unselect all if one is selected
-	sf.unselectAll();
-	sf.select(bboxFiles.features[index]);
-	if (open) {
-		window.open(bboxFiles.features[index].attributes.url,'download_window');
Deleted: trunk/mapbender/http/javascripts/mb_downloadFeedClient.js~
--- trunk/mapbender/http/javascripts/mb_downloadFeedClient.js~	2016-05-27 07:02:37 UTC (rev 9485)
+++ trunk/mapbender/http/javascripts/mb_downloadFeedClient.js~	2016-05-27 07:07:37 UTC (rev 9486)
@@ -1,339 +0,0 @@
-                in_options
-                out_options
-            formats = {
-              'in': {
-              'out': {
-function init(){
-	updateFormats();
-	resetForm();
-			resetForm();
-	$.ajax({
-  		type: "post",
-       		dataType: "json",
-	return false;
-	//reset form
-	resetForm();
-		return false;
-//alert(featureCollection.features[i].properties.title);//$('#dataset_title').value = "";
-		if (i == id) {
-			identifierAnchor.attr({'href':featureCollection.features[i].properties.metadataLink});
-		resetForm();
-		return false;
-	//alert("test");
-	//alert(featureCollection.features.length);
-	//alert(id);
-		//method =  "getDatasetLinkFromUrl";
-        	//data = $this.val();
-		//alert($this.val());
-		//callServer(data,method);
-		//alert("number of links: "+numberOfLinks+"for representation: "+k);
-		//alert(featureCollection.features[0].properties.entry[0].title);
-		//alert("number of links: "+numberOfLinks);
-			//show list
-		} else {
-			} else {
-				extArray = ext.split(",");
-		//add options
-			//show mapframe
-						alert("checked");
-					} else {
-					alert(url);*/
-                	sf.activate();
-         var bounds;
-         if(features) {
-                 if (!bounds) {
-                 } else {
-			index = i;
-			break;
-	sf.unselectAll();
-	if (open) {
Deleted: trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php
--- trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php	2016-05-27 07:02:37 UTC (rev 9485)
+++ trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php	2016-05-27 07:07:37 UTC (rev 9486)
@@ -1,400 +0,0 @@
-<?php
- * Package: mod_WMSpreferencesDiv
- * Description:
- * This module generates a table with wms of the mapObject. The user
- * can change the mapformat, featureinfoformat and the exceptionformat for each wms.
- * Also the wms priority and the map transparency can be changed interactivly. The module
- * should exchange the old mod_WMSpreferences module which was an iframe before.
- * The module is invoked thru a button click. The button must be a mb_button.js module
- * Files:
- *  - http/javascripts/mod_WMSpreferencesDiv.php
- * SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * >   e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
- * >  e_height, e_z_index, e_more_styles, e_content, e_closetag,
- * >  e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES(
- * > '<app_id>','WMS_preferencesDiv',12,1,'Configure WMS preferences - div tag','WMS preferences',
- * > 'div','','',870,60,400,500,NULL ,'z-index:9999;','','div','mod_WMSpreferencesDiv.php',
- * > '','mapframe1','jq_ui_dialog','http://www.mapbender.org/index.php/mod_WMSpreferencesDiv.php');
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
- * > e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
- * > VALUES('<app_id>','WMS_preferencesButton',2,1,'button for configure the preferences of each loaded wms',
- * > 'Manage WMS preferences','img','../img/button_blink_red/preferences_off.png','',
- * > 670,60,24,24,1,'','','','../plugins/mb_button.js','','WMS_preferencesDiv',
- * > '','http://www.mapbender.org/index.php/mb_button');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
- * > context, var_type) VALUES('gui1', 'WMS_preferencesButton', 'dialogWidth', '400', '' ,'var');
- * Help:
- * http://www.mapbender.org/mod_WMSpreferencesDiv
- * Maintainer:
- * http://www.mapbender.org/User:Armin_Retterath
- * Parameters:
- * none
- * License:
- * Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
- * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-$e_id = 'WMS_preferencesDiv';
-$gui_id = array(Mapbender::session()->get("mb_user_gui"));
-//include all element vars from the given element
-include '../include/dyn_js.php';
-include '../include/dyn_php.php';
-$vis = "";
-$wmsid = "";
-$sql_visible = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1";
-$v = array(Mapbender::session()->get("mb_user_gui"));
-$t = array("s");
-$res_visible = db_prep_query($sql_visible, $v, $t);
-$cnt_visible = 0;
-while($row = db_fetch_array($res_visible)){
-	$gui_wms_visible[$cnt_visible] = $row["gui_wms_visible"];
-	$fkey_wms_id_visible[$cnt_visible] = $row["fkey_wms_id"];
-	if($cnt_visible>0){
-		$vis .= ",";
-		$wmsid .= ",";
-	$vis .= $gui_wms_visible[$cnt_visible];
-	$wmsid .= $fkey_wms_id_visible[$cnt_visible];
-	$cnt_visible++;
-echo "var mod_gui_wms_visible = '".$vis."';";
-echo "var mod_fkey_wms_id_visible = '".$wmsid."';";
-//initialize module
-var WMS_preferencesDiv = function() {
-	var that = this;
-	var targetName = options.target;
-	var ind = getMapObjIndexByName(targetName);
-	var my = mb_mapObj[ind];
-	//functions
-	this.mb_swapWmsByIndex = function(mapObj_ind, indexA, indexB) {
- 		var myMapObj = mb_mapObj[mapObj_ind];
-		if (indexA != indexB && indexA >= 0 && indexA < myMapObj.wms.length && indexB >= 0 && indexB < myMapObj.wms.length) {
-			upper = myMapObj.wms[indexA];
-			myMapObj.wms[indexA] = myMapObj.wms[indexB];
-			myMapObj.wms[indexB] = upper;
-			var upperLayers = myMapObj.layers[indexA];
-			var upperStyles = myMapObj.styles[indexA];
-			var upperQuerylayers = myMapObj.querylayers[indexA];
-			myMapObj.layers[indexA] = myMapObj.layers[indexB];
-			myMapObj.styles[indexA] = myMapObj.styles[indexB];
-			myMapObj.querylayers[indexA] = myMapObj.querylayers[indexB];
-			myMapObj.layers[indexB] = upperLayers;
-			myMapObj.styles[indexB] = upperStyles;
-			myMapObj.querylayers[indexB] = upperQuerylayers;
-			return true;
-		else {
-			return false;
-	this.setMapformat = function(val) {
-		var tmp = val.split(",");
-		my.wms[tmp[0]].gui_wms_mapformat = tmp[1];
-		Mapbender.modules[options.target].setMapRequest();
-		this.formContainer.remove();
-		this.initForm();
-	this.setFeatureformat = function(val) {
-		my.wms[tmp[0]].gui_wms_featureinfoformat = tmp[1];
-		this.initForm();
-	this.setExceptionformat = function(val) {
-		my.wms[tmp[0]].gui_wms_exceptionformat = tmp[1];
-		this.initForm();
-	this.swap = function(index1, index2) {
-		if (this.mb_swapWmsByIndex(ind, index1, index2) == true) {
-			this.initForm();
-			zoom(options.target, true, 1.0);
-			mb_execloadWmsSubFunctions();
-	this.remove_wms = function(num) {
-		var cnt_vis=0;
-		var wms_visible_down = mod_gui_wms_visible.split(",");
-		var wms_vis_down = wms_visible_down.length;
-		//check if there are more than two visible wms's
-		for(var i=0; i < wms_visible_down.length; i++){
-			var my_wms_visible = wms_visible_down[i];
-			if(my_wms_visible == 0){
-  				var cnt_vis = cnt_vis+1;
-		if(my.wms.length - cnt_vis>1){
-	  		var ind = getMapObjIndexByName(options.target);
-  			mb_mapObjremoveWMS(ind,num)
-		else{
-			alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
-		this.initForm();
-	this.deleteForm = function() {
-	this.refreshTransparency = function(visibleWmsIndexArray) {
-		for (var i = 0 ; i < visibleWmsIndexArray.length ; i++) {
-			wmsId = my.wms[visibleWmsIndexArray[i]].wms_id;
-			$( "#transparency_"+wmsId ).val( $( "#slider_" + wmsId ).slider( "value" ) );
-			my.wms[visibleWmsIndexArray[i]].setOpacity(100-($( "#slider_" + wmsId ).slider( "value" )));
-	this.initForm = function() {
-		var str = "";
-		var wms_visible = mod_gui_wms_visible.split(",");
-		var wms_id_visible = mod_fkey_wms_id_visible.split(",");
-		var visibleWmsIndexArray = new Array();
-		this.formContainer = $(document.createElement('form')).attr({'id':'wms-preferences-form'}).appendTo('#' + options.id);
-		for(var i=0; i < my.wms.length; i++){
-			var found = false;
-			for(var j=0; j < wms_id_visible.length; j++){
-				if (wms_visible[j] == 1 && wms_id_visible[j] == my.wms[i].wms_id){
-					visibleWmsIndexArray[visibleWmsIndexArray.length] = i;
-					found = true;
-			if (found == false && my.wms[i].gui_wms_visible == 1) {
-		//loop over all visible wms if reversed layer order is wished, reverse visibleWmsIndexArray
-		options.reversePreferences = true;
-		if (options.reversePreferences) {
-			visibleWmsIndexArray.reverse();
-			z = visibleWmsIndexArray[i];
-			var mapString = "";
-			var featureinfoString = "";
-			var exceptionString = "";
-			for(var j=0; j<my.wms[z].data_type.length; j++){
-				if(my.wms[z].data_type[j] == 'map'){
-					mapString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-					if(my.wms[z].data_format[j] == my.wms[z].gui_wms_mapformat){
-						mapString += "selected";
-					mapString += ">"+my.wms[z].data_format[j]+"</option>";
-				else if(my.wms[z].data_type[j] == 'featureinfo'){
-					featureinfoString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-					if(my.wms[z].data_format[j] == my.wms[z].gui_wms_featureinfoformat){
-						featureinfoString += "selected";
-					featureinfoString += ">"+my.wms[z].data_format[j]+"</option>";
-				else if(my.wms[z].data_type[j] == 'exception'){
-					exceptionString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-					if(my.wms[z].data_format[j] == my.wms[z].gui_wms_exceptionformat){
-						exceptionString += "selected";
-					exceptionString += ">"+my.wms[z].data_format[j]+"</option>";
-			//extract wms title, id and abstract
-			var wmsTitle = my.wms[z].wms_title;
-			var wmsAbstract = my.wms[z].wms_abstract;
-			var wmsId = my.wms[z].wms_id;
-			//generate Form
-			this.tableContainer = $(document.createElement('table')).appendTo(this.formContainer);
-			this.tableContainer.attr({'border':'1'});
-			this.tableContainer.attr({'rules':'rows'});
-			this.tableContainer.attr({'width':'300'});
-			this.rowContainer = $(document.createElement('tr')).appendTo(this.tableContainer);
-			this.columnContainer = $(document.createElement('th')).appendTo(this.rowContainer);
-			if (visibleWmsIndexArray.length > 1) {
-				if (i != 0) {
-					//show up arrow only if it is not the first entry and if the count of entries is greater than 1
-					this.wmsUp = $(document.createElement('img')).appendTo(this.columnContainer);
-					this.wmsUp.attr({'src':'../img/button_gray/up.png'});
-					this.wmsUp.attr({'id':'wmsUp_'+i});
-					//this.wmsUp.attr({'style':'filter:Chroma(color=#C2CBCF);'});
-					this.wmsUp.attr({'value':'up'});
-					this.wmsUp.attr({'title':'move WMS up'});
-					$("#" + "wmsUp" + "_" + i).click((function (i,z) {
-						return function(){
-							Mapbender.modules[options.id].swap(visibleWmsIndexArray[i-1],z);
-                        			//alert("move up");
- 		        		})(i,z));
-				//show down arrow only if the entry is not the last one and if the count of entries is greater than 1
-				if (i != visibleWmsIndexArray.length-1) {
-					this.wmsDown = $(document.createElement('img')).appendTo(this.columnContainer);
-					this.wmsDown.attr({'src':'../img/button_gray/down.png'});
-					this.wmsDown.attr({'id':'wmsDown_'+i});
-					//this.wmsDown.attr({'style':'filter:Chroma(color=#C2CBCF);'});
-					//this.wmsDown.attr({'onclick':'alert("move up");'});
-					this.wmsDown.attr({'value':'down'});
-					this.wmsDown.attr({'title':'move WMS down'});
-					$("#" + "wmsDown" + "_" + i).click((function (i,z) {
-							Mapbender.modules[options.id].swap(z,visibleWmsIndexArray[i+1]);
- 		        		})(i,z));
-				this.wmsRemove = $(document.createElement('img')).appendTo(this.columnContainer);
-				this.wmsRemove.attr({'src':'../img/button_gray/del.png'});
-				this.wmsRemove.attr({'id':'wmsRemove_'+i});
-				//this.wmsRemove.attr({'onclick':'alert("remove");'});
-				this.wmsRemove.attr({'value':'remove'});
-				this.wmsRemove.attr({'title':'remove WMS from GUI'});
-				$("#" + "wmsRemove" + "_" + i).click((function (z) {
-						Mapbender.modules[options.id].remove_wms(z);
- 		       		})(z));
-			this.wmsTitleDiv = $(document.createElement('div')).appendTo(this.columnContainer);
-			this.wmsTitleDiv.attr({'id':'id_'+wmsId});
-			this.wmsTitleDiv.attr({'style':'cursor:pointer'});
-			this.wmsTitleDiv.attr({'onmouseover':'title=\"'+'id:'+wmsId+' '+my.wms[z].wms_abstract+'\"'});
-			//this.wmsTitleDiv.attr({'width':'300'});
-			this.wmsTitle = $(document.createElement('b')).appendTo(this.columnContainer);
-			this.wmsTitle.attr({'title':wmsId+':'+wmsAbstract});
-			this.wmsTitle.append(wmsTitle);
-			//new row mapImageFormat
-			this.columnContainer = $(document.createElement('td')).appendTo(this.rowContainer);
-			this.mapInfoTitle = this.columnContainer.append('<?php echo _mb('MapFormat'); ?>: ');
-			this.mapInfoSelect = $(document.createElement('select')).appendTo(this.columnContainer);
-			this.mapInfoSelect.change(function () {
-					Mapbender.modules[options.id].setMapformat(this.value);
-			this.mapInfoSelect.attr({'onchange':'Mapbender.modules[options.id].setMapformat(this.value);'});
-			this.mapInfoSelect.append(mapString);
-			//new row featureInfoFormat
-			this.featureInfoTitle = this.columnContainer.append('<?php echo _mb('FeatureInfoFormat'); ?>: ');
-			this.featureInfoSelect = $(document.createElement('select')).appendTo(this.columnContainer);
-			this.featureInfoSelect.attr({'onchange':'Mapbender.modules[options.id].setFeatureformat(this.value);'});
-			this.featureInfoSelect.append(featureinfoString);
-			//new row exceptionFormat
-			this.exceptionTitle = this.columnContainer.append('<?php echo _mb('ExceptionFormat'); ?>: ');
-			this.exceptionSelect = $(document.createElement('select')).appendTo(this.columnContainer);
-			this.exceptionSelect.attr({'onchange':'Mapbender.modules[options.id].setExceptionformat(this.value);'});
-			this.exceptionSelect.append(exceptionString);
-			this.transparencyTitle = this.columnContainer.append('<?php echo _mb('Transparency'); ?>: ');
-			this.transparencyValue = $(document.createElement('input')).appendTo(this.columnContainer);
-			this.transparencyValue.attr({'type':'text'});
-			this.transparencyValue.attr({'id':'transparency_'+wmsId});
-			if (isNaN(my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity)) {
-				thisWmsOpacity = 0;
-			} else {
-				thisWmsOpacity =  100-(my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity*100);
-			this.transparencyValue.attr({'value':thisWmsOpacity});
-			this.transparencyValue.attr({'style':'border:0; color:#f6931f; font-weight:bold;'});
-			this.wmsTransparencySliderDiv = $(document.createElement('div')).appendTo(this.columnContainer)
-			this.wmsTransparencySliderDiv.attr({'id':'slider_'+wmsId});
-			$("#slider_" + wmsId).slider({
-				min: 0,
-				max: 100,
-				step: 10,
-				value: thisWmsOpacity,
-				change: function( event, ui) {
-						that.refreshTransparency(visibleWmsIndexArray);
-			/*$("#slider_" + wmsId).slider();
-			$("#slider_" + wmsId).slider( "option", "min", 100 );
-			$("#slider_" + wmsId).slider( "option", "max", 0 );
-			$("#slider_" + wmsId).slider( "option", "step", -10 );*/
-			this.formContainer.append('<br>');
-this.initForm();
-Mapbender.events.init.register(function() {
-	Mapbender.modules[options.id] = $.extend(new WMS_preferencesDiv(),Mapbender.modules[options.id]);
Deleted: trunk/mapbender/http/javascripts/mod_copyright_planungsportal.php
--- trunk/mapbender/http/javascripts/mod_copyright_planungsportal.php	2016-05-27 07:02:37 UTC (rev 9485)
+++ trunk/mapbender/http/javascripts/mod_copyright_planungsportal.php	2016-05-27 07:07:37 UTC (rev 9486)
@@ -1,50 +0,0 @@
-<?php
-# $Id: mod_copyright.php 6660 2010-07-30 09:34:33Z christoph $
-# http://www.mapbender.org/index.php/mod_copyright.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-var mod_copyright_target = options.target;
-options.mod_copyright_text = typeof options.mod_copyright_text === "undefined" ? "mapbender.org" : options.mod_copyright_text;
-var mod_copyright_text = options.mod_copyright_text;
-var mod_copyright_left = 5;
-var mod_copyright_bottom = 20;
-var mod_copyright_color1 = "white";
-var mod_copyright_color2 = "black";
-var mod_copyright_font = "Arial, Helvetica, sans-serif";
-var mod_copyright_fontsize = "9px";
-eventAfterInit.register(function () {
-	mod_copyright();
-function mod_copyright(){
-	var myMapObj = Mapbender.modules[mod_copyright_target];
-	var str_c = "<div style='opacity:0.8;text-align:center;z-index:70;font-family:" + mod_copyright_font + ";font-size:" + mod_copyright_fontsize + ";color:" + mod_copyright_color2 + ";position:absolute;bottom:18px;right:0px;background-color:white;padding:0px 4px 2px 4px'>"+mod_copyright_text+"</div>";
-	var map_el = myMapObj.getDomElement();
-	if(!map_el.ownerDocument.getElementById(myMapObj.elementName+"_copyright")){
-		//create Box Elements
-		var el_top = map_el.ownerDocument.createElement("div");
-		el_top.style.overflow = "hidden";
-		el_top.id = myMapObj.elementName+"_copyright";
-		map_el.appendChild(el_top);
-	writeTag(myMapObj.frameName, myMapObj.elementName+"_copyright", str_c);
Deleted: trunk/mapbender/http/javascripts/mod_jsonAutocompleteGazetteer.php
--- trunk/mapbender/http/javascripts/mod_jsonAutocompleteGazetteer.php	2016-05-27 07:02:37 UTC (rev 9485)
+++ trunk/mapbender/http/javascripts/mod_jsonAutocompleteGazetteer.php	2016-05-27 07:07:37 UTC (rev 9486)
@@ -1,307 +0,0 @@
-<?php
- * Package: mod_jsonAutocompleteGazetteer
- * Description:
- * Files:
- *  - http/javascripts/mod_jsonAutocompleteGazetteer.php
- * SQL:
- * Help:
- * Maintainer:
- * Parameters:
- * none
- * License:
-$e_id = 'jsonAutocompleteGazetteer';
-//include '../include/dyn_js.php';
-//include '../include/dyn_php.php';
-var standingHighlight = null;
-Mapbender.events.afterMapRequest.register( function(){
-	if(standingHighlight){
-		standingHighlight.paint();
-if (options.gazetteerUrl === undefined) {
-	options.gazetteerUrl = 'http://www.geoportal.rlp.de/mapbender/geoportal/gaz_geom_mobile.php';
-	//options.gazetteerUrl = 'http://ws.geonames.org/searchJSON?lang=de&';
-if (options.isGeonames === undefined) {
-	options.isGeonames = false;
-if (options.latLonZoomExtension === undefined) {
-	options.latLonZoomExtension = 0.1;
-if (options.minLength === undefined) {
-	options.minLength = 3;
-if (options.delay === undefined) {
-	options.delay = 400;
-if (options.isDraggable === undefined) {
-	options.isDraggable = true;
-if (options.maxResults === undefined) {
-	options.maxResults = 15;
-if (options.inputWidth === undefined) {
-	options.inputWidth = 250;
-if (options.searchEpsg === undefined) {
-	options.searchEpsg = "4326";
-if (options.drawCentrePoint === undefined) {
-	options.drawCentrePoint = true;
-if (options.gazetteerFrontImageOn === undefined) {
-	options.gazetteerFrontImageOn = "../img/button_blue_red/gazetteer3_on.png";
-if (options.gazetteerFrontImageOff === undefined) {
-	options.gazetteerFrontImageOff = "../img/button_blue_red/gazetteer3_off.png";
-var JsonAutocompleteGazetteer = function() {
-	var that = this;
-	/*this.zoomToExtent = function(minx,miny,maxx,maxy) {
-		var newExtent = new Mapbender.Extent(
-                   	 parseFloat(minx),
-                         parseFloat(miny),
-                         parseFloat(maxx),
-                         parseFloat(maxy)
-		my.calculateExtent(newExtent);
-		alert(my.epsg);
-		my.setMapRequest();
-	this.zoomToExtent = function(fromSrs,minx,miny,maxx,maxy) {
-		var parameters = {
-			fromSrs: fromSrs,
-			toSrs: Mapbender.modules[targetName].epsg
-		parameters.bbox = parseFloat(minx)+ "," +parseFloat(miny)+ "," +parseFloat(maxx)+ "," +parseFloat(maxy);
-		//function to transform from one crs to another
-		var req = new Mapbender.Ajax.Request({
-			url: "../php/mod_coordsLookup_server.php",
-			method: "transform",
-			parameters: parameters,
-			callback: function (obj, success, message) {
-				if (!success) {
-					new Mapbender.Exception(message);
-					return;
-				if (options.drawCentrePoint) {
-					//generate layer for visualization of point
-					if(standingHighlight !== null){
-						standingHighlight.clean();
-					}else{
-						standingHighlight = new Highlight(
-							[options.target],
-							"standingHighlight",
-							{"position":"absolute", "top":"0px", "left":"0px", "z-index":10000},
-							2);
-					var point0 = new Point(obj.points[0].x,obj.points[0].y);
-					var point1 = new Point(obj.points[1].x,obj.points[1].y);
-					var x = point0.x + (point1.x - point0.x)/2;
-					var y = point0.y + (point1.y - point0.y)/2;
-					var point = new Point(x,y);
-					var ga = new GeometryArray();
-					ga.importPoint({
-						coordinates:[x,y,null]
-					},Mapbender.modules[targetName].epsg)
-					var m = ga.get(-1,-1);
-					standingHighlight.add(m, "#ff0000");
-					//alert(m);
-				if (obj.points) {
-					if (obj.points.length === 2) {
-						var newExtent = new Extent(
-							obj.points[0].x,
-							obj.points[0].y,
-							obj.points[1].x,
-							obj.points[1].y
-		req.send();
-	this.toggleInput = function(){
-		/*if (this.inputAddress.attr("disabled")) {
-			$("#geographicName").show();
-		} else {
-			$("#geographicName").hide();
-		if ($("#geographicName").css("display") == 'none') {
-			$("#symboldForInputId").attr({'src':options.gazetteerFrontImageOn});
-		} else {
-			$("#symboldForInputId").attr({'src':options.gazetteerFrontImageOff});
-		//$("#geographicName").toggle();
-		epsg = Mapbender.modules[targetName].epsg.replace('EPSG:', '');
-		this.formContainer = $(document.createElement('form')).attr({'id':'json-autocomplete-gazetteer'}).appendTo('#' + options.id);
-		this.formContainer.submit(function() {
-			return false;
-		if (options.isDraggable){
-			//this.formContainer.draggable();
-		//this.labelForInput = $(document.createElement('label')).appendTo(this.formContainer);
-		//this.labelForInput.attr({'for':'geographicName'});
-		//this.labelForInputTitle = this.labelForInput.append('<?php echo _mb('Address'); ?>: ');
-		this.symbolForInput = $(document.createElement('img')).appendTo(this.formContainer);
-		this.symbolForInput.attr({'id':'symboldForInputId'});
-		this.symbolForInput.attr({'src':options.gazetteerFrontImageOn});
-		this.symbolForInput.attr({'title':'<?php echo _mb('Address'); ?>'});
-		this.symbolForInput.click(function() {
-			that.toggleInput();
-		//.ui-menu .ui-menu-item {
-		this.inputAddress = $(document.createElement('input')).appendTo(this.formContainer);
-		this.inputAddress.attr({'id':'geographicName'});
-		//default value
-		this.inputAddress.val('<?php echo _mb('Search for addresses'); ?>');
-		this.inputAddress.css('width',options.inputWidth);
-		$('.ui-menu').css('width','100px');
-		$('.ui-menu-item').css('width','100px');
-		//set the loading symbol for autoloader class
-		$('.ui-autocomplete-loading').css('background','white url("../img/indicator_wheel.gif") right center no-repeat');
-		//http://stackoverflow.com/questions/622122/how-can-i-change-the-css-class-rules-using-jquery
-		//$("<style type='text/css'> .ui-autocomplete { position: absolute; cursor: default; background:black; color:white} </style>").appendTo("head");
-		//this.inputAddress.attr({'width':options.inputWidth}); is defind thru css ui-widget-autocomplete
-		$(function() {
-			$( "#geographicName" ).autocomplete({
-				source: function( request, response ) {
-					$.ajax({
-						url: options.gazetteerUrl,
-						dataType: "jsonp",
-						data: {
-							outputFormat: 'json',
-							resultTarget: 'web',
-							searchEPSG: options.searchEpsg,
-							maxResults: options.maxResults,
-							maxRows: options.maxResults,
-							searchText: request.term,
-							featureClass: "P",
-							style: "full",
-							name_startsWith: request.term
-						success: function( data ) {
-							if (options.isGeonames) {
-								response( $.map( data.geonames, function( item ) {
-									return {
-										label: item.name+" - "+item.fclName+" - "+item.countryName,
-										minx: item.lng-options.latLonZoomExtension,
-										miny: item.lat-options.latLonZoomExtension,
-										maxx: item.lng+options.latLonZoomExtension,
-										maxy: item.lat+options.latLonZoomExtension
-							} else {
-									return {
-										label: item.title,
-										minx: item.minx,
-										miny: item.miny,
-										maxx: item.maxx,
-										maxy: item.maxy
-				minLength: options.minLength,
-				delay: options.delay,
-				select: function( event, ui ) {
-					that.zoomToExtent("EPSG:"+options.searchEpsg,ui.item.minx,ui.item.miny,ui.item.maxx,ui.item.maxy);
-				open: function() {
-					$( this ).removeClass( "ui-corner-all" ).addClass( "ui-corner-top" );
-				close: function() {
-					$( this ).removeClass( "ui-corner-top" ).addClass( "ui-corner-all" );
-	this.initForm();
-	Mapbender.modules[options.id] = $.extend(new JsonAutocompleteGazetteer(),Mapbender.modules[options.id]);
Deleted: trunk/mapbender/http/javascripts/mod_legendDiv_old.php
--- trunk/mapbender/http/javascripts/mod_legendDiv_old.php	2016-05-27 07:02:37 UTC (rev 9485)
+++ trunk/mapbender/http/javascripts/mod_legendDiv_old.php	2016-05-27 07:07:37 UTC (rev 9486)
@@ -1,133 +0,0 @@
-<?php
-# $Id: mod_legend.php 6887 2010-09-03 14:51:46Z christoph $
-# http://www.mapbender.org/index.php/Legend
-# Copyright (C) 2005 CCGIS / terrestris
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>','legend',2,1,'legend','Legend','div','','',0,0,NULL ,NULL ,600,'','','div','../javascripts/mod_legendDiv.php','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<app_id>', 'legend', 'legendlink', 'false', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<app_id>', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<app_id>', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('<app_id>', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend' ,'var');
-$e_target = "mapframe1";
-$e_top = '10';
-$e_left = '10';
-echo "var mod_legend_target = '".$e_target."';\n";
-echo "var mod_legend_target_left = ".intval($e_left).";\n";
-echo "var mod_legend_target_top = ".intval($e_top).";\n";
-//defaults for element vars
-mod_legend_offsetLeft = 25;
-mod_legend_offsetTop = -10;
-var legendlink = typeof legendlink === "undefined" ? 'false' : legendlink;
-var showwmstitle = typeof showwmstitle === "undefined" ? "false" : showwmstitle;
-var showlayertitle = typeof showlayertitle === "undefined" ? "false" : showlayertitle;
-var showgroupedlayertitle = typeof showgroupedlayertitle === "undefined" ? "false" : showgroupedlayertitle;
-function mod_legend_pos(frameName){
-	if(frameName == mod_legend_target){
-		var ind = getMapObjIndexByName(mod_legend_target);
-		var obj = document.getElementById("legend");
-		var str = "";
-		var str_tmp = "";
-		for(var i=0; i<mb_mapObj[ind].wms.length; i++){
-			 	var layerNames = mb_mapObj[ind].wms[i].getLayers(mb_mapObj[ind]);
-				for(var j=0; j<layerNames.length; j++){
-					var layerParent = mb_mapObj[ind].wms[i].checkLayerParentByLayerName(layerNames[j]);
-					var layerTitle = mb_mapObj[ind].wms[i].getTitleByLayerName(layerNames[j]);
-					var layerStyle = mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layerNames[j]);
-					var legendUrl = false;
-					if(layerStyle == false){
-						legendUrl = mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],"");
-					else{
-						legendUrl = mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],layerStyle);
-					if (legendUrl !== false){
-//	 					if(layerParent == 0){
-		 					if(showlayertitle == 'true'){
-                                                        	str_tmp += "<div><span class='titles'>" + layerTitle+ "</span></div>";
-							str_tmp += "<div>";
-		                    if(legendlink == 'true'){
-		                    	str_tmp += "<a href='../php/result.php?lingo=deutsch&layer="+layerNames[j]+"' class='link_metadata' title='Zeigt Liste zum Thema: "+layerTitle+"' target='result'>";
-		                    str_tmp += "<img border=0 src = '";
-							str_tmp += legendUrl;
-							str_tmp += "'></img>";
-							if (legendlink == 'true'){
-		                    	str_tmp += "</a>";
-		                    str_tmp += "</div>";
-			if(str_tmp !=''){
-				if (showwmstitle == 'true'){
-					str += "<div><span class='header'>" +mb_mapObj[ind].wms[i].wms_title+ "</span></div>";
-				str += str_tmp;
-				str_tmp ='';
-	    if(str != ""){
-			writeTag("", "legend", str);
-		else{
-			writeTag("", "legend", "");
-		return true;
-// Todo: return-value may change in the next version....
-eventAfterMapRequest.register(function (obj) {
-	mod_legend_pos(obj.map.elementName)
-function mod_legend_init(){
-//	obj.style.top = mod_legend_target_top  + mod_legend_offsetTop;
-//	obj.style.left = mod_legend_target_left + mod_legend_target_width + mod_legend_offsetLeft;
-//	var checkobj = document.getElementById("checkboxstyle");
-//	if (checkbox_on_off == 'false'){
-//		checkobj.style.display = "none";
-//		checkobj.style.width = 0;
-//		checkobj.style.height = 0;
-	if (Mapbender.events.init.done) {
-		mod_legend_pos(mod_legend_target);
-	else {
-		Mapbender.events.init.register(function () {
Deleted: trunk/mapbender/http/javascripts/mod_mapcheck.php
--- trunk/mapbender/http/javascripts/mod_mapcheck.php	2016-05-27 07:02:37 UTC (rev 9485)
+++ trunk/mapbender/http/javascripts/mod_mapcheck.php	2016-05-27 07:07:37 UTC (rev 9486)
@@ -1,72 +0,0 @@
-<?php
-# $Id: mod_mapcheck.php 269 2006-05-12 12:22:18Z melchior_moos $
-# http://www.mapbender.org/index.php/mod_mapcheck.php
-# Copyright (C) 2006 Melchior Moos
-$gui_id = $_REQUEST["gui_id"];
-require_once("../../core/globalSettings.php");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
-$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'mapcheck' AND fkey_gui_id = $1";
-$v = array($gui_id);
-$t = array('s');
-$res = db_prep_query($sql, $v, $t);
-$cnt = 0;
-while($row = db_fetch_array($res)){
-	$e_target = $row["e_target"];
-	$cnt++;
-if($cnt > 1){
-	echo "alert('mapcheck: ID not unique!');";
-echo "var mod_mapcheck_target = '".$e_target."';";
-mb_registerSubFunctions("mod_mapcheck()");
-var warned=Array();
-function imgerror()
-	var map=getMapObjIndexByName(mod_mapcheck_target);
-	var wms=Number(this.id.substr(4));
-	if(!warned[wms])
-		warned[wms]=true;
-		if(confirm('<?php echo _mb("Failed to load WMS ");?>'+mb_mapObj[map].wms[wms].objLayer[0].layer_title+'<?php echo _mb(" from server ");?>'+mb_mapObj[map].wms[wms].wms_getmap.substr(0,mb_mapObj[map].wms[wms].wms_getmap.length-1)+'<?php echo _mb("Do you want to try to load it in a new window?");?>'))
-			window.open(this.src,"");
-		this.src="../img/transparent.gif";
-function mod_mapcheck(){
-	var ind = getMapObjIndexByName(mod_mapcheck_target);
-	for(var wms=0;wms<mb_mapObj[ind].wms.length;wms++)
-		var wmsimgid="map_"+wms;
-		if(window.frames[mod_sandclock_target].document.getElementById(wmsimgid))
-			warned[wms]=false;
-			window.frames[mod_sandclock_target].document.getElementById(wmsimgid).onerror=imgerror;
-			window.frames[mod_sandclock_target].document.getElementById(wmsimgid).onabort=imgerror;
More information about the Mapbender_commits mailing list
