[Mapbender-commits] r9609 - trunk/mapbender/lib
svn_mapbender at osgeo.org
Thu Sep 29 08:18:23 PDT 2016
Author: armin11
Date: 2016-09-29 08:18:22 -0700 (Thu, 29 Sep 2016)
New Revision: 9609
trunk/mapbender/lib/class_GetApi.php
New possibility to integrate distributed or local geojson files in the initial wmc for the gui by using some get parameter
Modified: trunk/mapbender/lib/class_GetApi.php
--- trunk/mapbender/lib/class_GetApi.php 2016-09-29 15:18:05 UTC (rev 9608)
+++ trunk/mapbender/lib/class_GetApi.php 2016-09-29 15:18:22 UTC (rev 9609)
@@ -15,8 +15,10 @@
private $featuretypes = array();
private $geoRSSFeeds = array();
private $kml = array();
+ private $geojson = array();
private $wmc = array();
private $zoom = array();
+ private $geojsonzoom;
* @param array $input
@@ -42,6 +44,12 @@
case "KML":
$this->kml = $this->normalizeKmlInput($value);
break;
+ case "GEOJSON":
+ $this->geojson = $this->normalizeGeojsonInput($value);
+ break;
+ case "GEOJSONZOOM":
+ $this->geojsonzoom = $this->normalizeGeojsonZoomInput($value);
+ break;
case "ZOOM":
$this->zoom = $this->normalizeZoomInput($value);
break;
@@ -71,7 +79,6 @@
public function getGeoRSSFeeds(){
return $this->geoRSSFeeds;
@@ -80,9 +87,24 @@
public function getKml(){
return $this->kml;
+ public function getGeojson(){
+ return $this->geojson;
+ public function getGeojsonZoom(){
+ return $this->geojsonzoom;
* Returns an array of zoom parameters
* @return array
@@ -290,9 +312,25 @@
private function normalizeGeoRSSInput($input){
return is_array($input) ? $input : array($input);
private function normalizeKmlInput($input){
+ private function normalizeGeojsonInput($input){
+ return is_array($input) ? $input : array($input);
+ private function normalizeGeojsonZoomInput($input){
+ if ($input == 'true') {
+ //$e = new mb_exception("set geojsonzoom to true");
+ return 'true';
+ } else {
+ //$e = new mb_exception("set geojsonzoom to false");
+ return 'false';
More information about the Mapbender_commits
