[Mapbender-commits] r9774 - in trunk/mapbender/http: classes extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 25 02:01:59 PDT 2017
Author: armin11
Date: 2017-08-25 02:01:58 -0700 (Fri, 25 Aug 2017)
New Revision: 9774
   trunk/mapbender/http/classes/class_ows.php
   trunk/mapbender/http/classes/class_ows_factory.php
   trunk/mapbender/http/classes/class_wfs.php
   trunk/mapbender/http/classes/class_wfs_factory.php
   trunk/mapbender/http/extensions/geom2wfst.php
Fix for digitizing objects via wfs-t and external http_digest authentication
Modified: trunk/mapbender/http/classes/class_ows.php
--- trunk/mapbender/http/classes/class_ows.php	2017-08-23 15:54:02 UTC (rev 9773)
+++ trunk/mapbender/http/classes/class_ows.php	2017-08-25 09:01:58 UTC (rev 9774)
@@ -126,7 +126,6 @@
 		$connection->set("httpType", "post");
 		$connection->set("httpContentType", "text/xml");
 		$connection->set("httpPostData", $postData);
-		//$e = new mb_notice("OWS REQUEST: " . $url . "\n\n" . $postData);
 		if (!$this->auth) {
 			$data = $connection->load($url);
 		} else {
Modified: trunk/mapbender/http/classes/class_ows_factory.php
--- trunk/mapbender/http/classes/class_ows_factory.php	2017-08-23 15:54:02 UTC (rev 9773)
+++ trunk/mapbender/http/classes/class_ows_factory.php	2017-08-25 09:01:58 UTC (rev 9774)
@@ -24,8 +24,13 @@
  * creating OGC Web Services (OWS).
 abstract class OwsFactory {
+	 * Variable controls, if the proxy urls should be used when creating the ows object, otherwise the
+	 * orig
+	public $returnProxyUrls = false;
 	 * Creates an OWS from an XML, presumably a capabilities document.
 	 * @return Ows
Modified: trunk/mapbender/http/classes/class_wfs.php
--- trunk/mapbender/http/classes/class_wfs.php	2017-08-23 15:54:02 UTC (rev 9773)
+++ trunk/mapbender/http/classes/class_wfs.php	2017-08-25 09:01:58 UTC (rev 9774)
@@ -265,7 +265,6 @@
 				$e = new mb_exception("Invalid transaction method: " . $method);
 				return null;
 		$postData = $this->wrapTransaction($featureType, $requestData);
 		return $this->post($this->transaction, $postData); //from class_ows!
Modified: trunk/mapbender/http/classes/class_wfs_factory.php
--- trunk/mapbender/http/classes/class_wfs_factory.php	2017-08-23 15:54:02 UTC (rev 9773)
+++ trunk/mapbender/http/classes/class_wfs_factory.php	2017-08-25 09:01:58 UTC (rev 9774)
@@ -65,7 +65,11 @@
 		else {
 			return null;
-		$withProxyUrls = true;
+		//From class_ows_factory.php :
+		if ($this->returnProxyUrls == true) {
+			$e = new mb_exception("return proxy urls: true");
 		// WFS
 		$sql = "SELECT * FROM wfs WHERE wfs_id = $1;";
 		$v = array($id);
@@ -89,20 +93,21 @@
 			$aWfs->getCapabilitiesDoc = db_result($res, $cnt, "wfs_getcapabilities_doc");
 			$aWfs->uploadUrl = db_result($res, $cnt, "wfs_upload_url");
 			$aWfs->describeFeatureType = db_result($res, $cnt, "wfs_describefeaturetype");
-			if(!$hasOwsproxyUrl || !$withProxyUrls){
+			//TODO check why this switch is used and in which cases this is relevant
+			if($this->returnProxyUrls == false){
 				$aWfs->getFeature = db_result($res, $cnt, "wfs_getfeature");
+				new mb_notice("class_wfs_factory.getFeature.url: don't use proxy");
 			else{
 				$aWfs->getFeature = $owsproxyUrl;
 			new mb_notice("class_wfs_factory.getFeature.url: ".$aWfs->getFeature);
 				$aWfs->transaction = db_result($res, $cnt, "wfs_transaction");
 			else{
 				$aWfs->transaction = $owsproxyUrl;
 			$aWfs->fees = db_result($res, $cnt, "fees");
 			$aWfs->accessconstraints = db_result($res, $cnt, "accessconstraints");
 			$aWfs->owner = db_result($res, $cnt, "wfs_owner");
Modified: trunk/mapbender/http/extensions/geom2wfst.php
--- trunk/mapbender/http/extensions/geom2wfst.php	2017-08-23 15:54:02 UTC (rev 9773)
+++ trunk/mapbender/http/extensions/geom2wfst.php	2017-08-25 09:01:58 UTC (rev 9774)
@@ -47,6 +47,8 @@
 $myWfsFactory = new UniversalWfsFactory();
+//don't return proxy urls cause the request should go directly to the server
+$myWfsFactory->returnProxyUrls = false;
 $myWfs = $myWfsFactory->createFromDb($wfsConf->wfsId);
 if (is_null($myWfs)) {
@@ -64,4 +66,4 @@
 header("Content-Type:application/x-json");
 $json = new Mapbender_JSON();
 echo $json->encode($resObj);
\ No newline at end of file
More information about the Mapbender_commits mailing list
