[Mapbender-commits] r9650 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jan 12 08:33:41 PST 2017
Author: armin11
Date: 2017-01-12 08:33:41 -0800 (Thu, 12 Jan 2017)
New Revision: 9650
Added:
   trunk/mapbender/http/classes/class_qualityReport.php
Forgot s.th. :-(
Added: trunk/mapbender/http/classes/class_qualityReport.php
--- trunk/mapbender/http/classes/class_qualityReport.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_qualityReport.php	2017-01-12 16:33:41 UTC (rev 9650)
@@ -0,0 +1,67 @@
+<?php
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/class_iso19139.php");
+class QualityReport {
+	var $metadataType;
+	var $inspireInteroperability;
+	public function __construct () {
+		$this->metadataType = 'dataset';
+		$this->inspireInteroperability = 'f';
+	public function getIso19139Representation($metadataType, $inspireInteroperability, $legislation_group = false) {
+		$iso19139 = new iso19139();
+		$iso19139->hierachyLevel = $metadataType;
+		$regulations = $iso19139->inspireRegulations;
+		//load xml snippet from filesystem as template
+		$reportDomObject = new DOMDocument();
+		$reportDomObject->load(dirname(__FILE__) . "/../geoportal/metadata_templates/mb_dataqualityreport.xml");
+		$xpathReport = new DOMXpath($reportDomObject);
+		//$reportNodeList = $xpathLicense->query('/mb:dataqualityreport/gmd:report');
+		$xpathReport->registerNamespace("mb", "http://www.mapbender.org/metadata/dataqualityreport");
+		$xpathReport->registerNamespace("gco", "http://www.isotc211.org/2005/gco");
+		$xpathReport->registerNamespace("gmd", "http://www.isotc211.org/2005/gmd");
+		$xpathReport->registerNamespace("xsi", "http://www.w3.org/2001/XMLSchema-instance");
+		//clone report node and get parent
+		$report = $xpathReport->query('/mb:dataqualityreport/gmd:report')->item(0);
+		$parent = $report->parentNode;
+		//check inspire_interoperability
+		switch ($inspireInteroperability) {
+			case "t":
+				//create one part for each regulation with pass to true
+				foreach ($regulations as $regulation) {
+					$xpathReport->query('/mb:dataqualityreport/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult/gmd:specification/gmd:CI_Citation/gmd:title/gco:CharacterString')->item(0)->nodeValue = $regulation['name'];
+					$xpathReport->query('/mb:dataqualityreport/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult/gmd:specification/gmd:CI_Citation/gmd:date/gmd:CI_Date/gmd:date/gco:Date')->item(0)->nodeValue = $regulation['date']->format('Y-m-d');
+					$xpathReport->query('/mb:dataqualityreport/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult/gmd:pass/gco:Boolean')->item(0)->nodeValue = "true";
+					//clone node and add if afterwards
+					$reportNew = $report->cloneNode(true);
+					$parent->appendChild($reportNew);
+				//delete first (template) entry
+				$parent->removeChild($report);
+				break;
+			default:
+					if ($regulation['type'] == 'metadata') {
+					} else {
+						$xpathReport->query('/mb:dataqualityreport/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult/gmd:pass/gco:Boolean')->item(0)->nodeValue = "false";
+				break;
+		$XML = $reportDomObject->saveXML();
+	 	return $XML;
More information about the Mapbender_commits mailing list
