[Mapbender-commits] r9749 - in trunk/mapbender: http/classes http_auth/http owsproxy/http owsproxy/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jun 26 04:39:02 PDT 2017
Author: armin11
Date: 2017-06-26 04:39:02 -0700 (Mon, 26 Jun 2017)
New Revision: 9749
   trunk/mapbender/http/classes/class_owsPostQueryParser.php
   trunk/mapbender/http/classes/class_user.php
   trunk/mapbender/http_auth/http/index.php
   trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php
   trunk/mapbender/owsproxy/http/index.php
Fix for owsproxy with wfs 2.0+ and possibility to get anonymous access to proxied wfs if authorization for public user is given.
Modified: trunk/mapbender/http/classes/class_owsPostQueryParser.php
--- trunk/mapbender/http/classes/class_owsPostQueryParser.php	2017-05-24 12:11:45 UTC (rev 9748)
+++ trunk/mapbender/http/classes/class_owsPostQueryParser.php	2017-06-26 11:39:02 UTC (rev 9749)
@@ -84,6 +84,8 @@
 					$this->serviceType = "WMS";
                                 	break;
+			//$e = new mb_exception("class_owsPostQueryHandler.php: ".$this->serviceRequestType);
+			$this->serviceVersion = $queryDomObject->documentElement->getAttribute("version");
 			if ($this->serviceType == "WFS") {
 				//read out typename from wfs query as attribute
 				//register namespace
@@ -97,11 +99,19 @@
 				//array of requests that need typenames
 				$typenameRequired = array('getfeature','describefeaturetype');
 				if (in_array(strtolower($this->serviceRequestType), $typenameRequired)) {
-					$this->serviceResourceName = $queryNodeList->item(0)->getAttribute('typeName');
+					switch ($this->serviceVersion) {
+						case "2.0.0":
+							$this->serviceResourceName = $queryNodeList->item(0)->getAttribute('typeNames');
+							break;
+						case "2.0.2":
+							break;
+						default:
+							$this->serviceResourceName = $queryNodeList->item(0)->getAttribute('typeName');
+							break;
-			//$e = new mb_exception("class_owsPostQueryHandler.php: ".$this->serviceRequestType);
-			$this->serviceVersion = $queryDomObject->documentElement->getAttribute("version");
 			//check for getfeature request with given storedquery_id
 			if ($this->serviceType == "WFS" && ($this->serviceVersion == "2.0.2" || $this->serviceVersion == "2.0.0") && strtolower($this->serviceRequestType) == 'getfeature') {
 				if ($hasNamespace) {
@@ -115,9 +125,7 @@
 				$this->serviceStoredQueryId = $storedQueryNodeList->item(0)->getAttribute('id');
 			//validate extracted parameters
Modified: trunk/mapbender/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php	2017-05-24 12:11:45 UTC (rev 9748)
+++ trunk/mapbender/http/classes/class_user.php	2017-06-26 11:39:02 UTC (rev 9749)
@@ -613,7 +613,75 @@
 		return $wfsConfIdArray;
+	/** check if feature typenames of a WFS requests are accessible - that means, that
+	 *  a wfs_conf for each featuretype exists and the user has access to a gui in which this wfs_conf
+         *  is integrated
+	 * @params String typenames [csv], Integer wfsId
+	 * @return boolean
+	 * TODO!!!!!!
+	public function areFeaturetypesAccessible ($typenames, $wfsId) {
+		$array_guis = $this->getApplicationsByPermission();
+		if (count($array_guis) == 0) {
+			return false;
+		$v = array();
+		$t = array();
+		//Example sql: select featuretype_id from wfs_featuretype where fkey_wfs_id in (340, 341, 342) and featuretype_name in ('AXE_ROUTE','AX_Flurstueck') and featuretype_id in (select fkey_featuretype_id from wfs_conf where wfs_conf_id in (select fkey_wfs_conf_id from gui_wfs_conf where gui_id in ('testgui')));
+		$sql = "SELECT featuretype_id FROM wfs_featuretype WHERE fkey_wfs_id = $1 ";
+		$v[0] = $wfsId;
+		$t[0] = 'i';
+		$sql .= "AND featuretype_name IN (";
+		$c = 2;
+		$featuretypeArray = explode(",", $typenames);
+		$numberOfFeaturetypes = count($featuretypeArray);
+		//test for string or array?
+		for ($i = 0; $i < $numberOfFeaturetypes; $i++) {
+			if ($i > 0) {
+				$sql .= ",";
+			$sql .= "$".$c;
+			$c++;
+			array_push($v, $featuretypeArray[$i]);
+			array_push($t, 's');
+		$sql .= ") AND featuretype_id IN (SELECT fkey_featuretype_id FROM wfs_conf WHERE wfs_conf_id IN (SELECT fkey_wfs_conf_id FROM gui_wfs_conf WHERE fkey_gui_id IN (";
+		for ($i = 0; $i < count($array_guis); $i++) {
+			if ($i > 0) {
+				$sql .= ",";
+			$sql .= "$".$c;
+			$c++;
+			array_push($v, $array_guis[$i]);
+		$sql .= ")))";
+		//for debug purposes:
+		//$e = new mb_exception($sql);
+		/*foreach ($v as $variable) {
+			$e = new mb_exception($variable);
+		foreach ($t as $type) {
+			$e = new mb_exception($type);
+		$res = db_prep_query($sql,$v,$t);
+		//check if number of results is equal to number of requested typenames
+		$row = db_fetch_all($res);
+		if (count($row) == 1 && $row[0]['featuretype_id'] == null) {
+			new mb_exception("http_auth/index.php: Some featuretype is null - no anonymous access possible!");
+			return false;
+		//$e = new mb_exception("featuretype_id[0]: '".$row[0]['featuretype_id']."' - ".count($row));
+		if (count($row) !== $numberOfFeaturetypes) {
+			new mb_exception("http_auth/index.php: Number of requested featuretypes are not equal to found wfs_confs!");
+			return false;
+		} else {
+			return true;
 	/** identifies the IDs of WFS confs where the user is owner
 	 * @param Array appIdArray [optional] restrict to certain applications
Modified: trunk/mapbender/http_auth/http/index.php
--- trunk/mapbender/http_auth/http/index.php	2017-05-24 12:11:45 UTC (rev 9748)
+++ trunk/mapbender/http_auth/http/index.php	2017-06-26 11:39:02 UTC (rev 9749)
@@ -21,7 +21,9 @@
 require(dirname(__FILE__) . "/../../http/classes/class_administration.php");
 require(dirname(__FILE__) . "/../../http/classes/class_connector.php");
 require_once(dirname(__FILE__) . "/../../http/classes/class_mb_exception.php");
+require_once(dirname(__FILE__) . "/../../http/classes/class_user.php");
 require(dirname(__FILE__) . "/../../owsproxy/http/classes/class_QueryHandler.php");
 $urlsToExclude = array();
 $postData = false;
 if (is_file(dirname(__FILE__) . "/../../conf/excludeproxyurls.conf"))
@@ -37,73 +39,167 @@
 $width = 400;
 $height = 400;
 /* * *** conf **** */
+//check request params for checking anonymous authorization#########################################
+//TODO!!!!!!
+$layerId = false;
+$wfsId = false;
+//$typenames = false;
-//special for type of authentication ******************************
-//control if digest auth is set, if not set, generate the challenge with getNonce()
-if (empty($_SERVER['PHP_AUTH_DIGEST'])) {
-    header('HTTP/1.1 401 Unauthorized');
-    header('WWW-Authenticate: Digest realm="' . REALM .
-        '",qop="auth",nonce="' . getNonce() . '",opaque="' . md5(REALM) . '"');
-    die('Text to send if user hits Cancel button');
+//test for existing post data
+$postData = file_get_contents("php://input");
+if (isset($postData) && $postData !== '') {
+} else {
+	$postData = false;
-//read out the header in an array
-$requestHeaderArray = http_digest_parse($_SERVER['PHP_AUTH_DIGEST']);
-//error if header could not be read
-if (!($requestHeaderArray)) {
-    echo 'Following Header information cannot be validated - check your clientsoftware!<br>';
-    echo $_SERVER['PHP_AUTH_DIGEST'] . '<br>';
-    die();
+if (isset($_REQUEST["layer_id"]) & $_REQUEST["layer_id"] != "") {
+        //validate integer
+        $testMatch = $_REQUEST["layer_id"];
+        //give max 99 entries - more will be to slow
+        $pattern = '/^[0-9]*$/';
+        if (!preg_match($pattern,$testMatch)){
+             	//echo 'userId: <b>'.$testMatch.'</b> is not valid.<br/>';
+                echo 'Parameter <b>layer_id</b> is not valid (integer).<br/>';
+                die();
+        $layerId = $testMatch;
+        $testMatch = NULL;
+if (isset($_REQUEST["wfs_id"]) & $_REQUEST["wfs_id"] != "") {
+        $testMatch = $_REQUEST["wfs_id"];
+                echo 'Parameter <b>wfs_id</b> is not valid (integer).<br/>';
+                die();
+        $wfsId = $testMatch;
-//get mb_username and email out of http_auth username string
-$userIdentification = explode(';', $requestHeaderArray['username']);
-$mbUsername = $userIdentification[0];
-$mbEmail = $userIdentification[1]; //not given in all circumstances
+//parse query
+$query = new QueryHandler($postData);
-$userInformation = getUserInfo($mbUsername, $mbEmail);
+// an array with keys and values toLoserCase -> caseinsensitiv
+$reqParams = $query->getRequestParams();
+//$e = new mb_exception($reqParams['version']);
-if ($userInformation[0] == '-1') {
-    die('User with name: ' . $mbUsername . ' and email: ' . $mbEmail . ' not known to security proxy!');
+if ($wfsId !== false) {
+	//switch for different parameter name - typename for wfs < 2.0 typenames for wfs >= 2.0
+	$typeNameParameter = "typename"; //lowercase
+	switch ($reqParams['version']) {
+		case "2.0.0":
+			$typeNameParameter = "typenames";
+			break;
+		case "2.0.2":
+			break;
+		default:
+			break;
+	//initialize typename parameter with false - not given
+	//check for featuretype name
+	if (isset($reqParams[$typeNameParameter]) & $reqParams[$typeNameParameter] != "") {
+        	$testMatch = $reqParams[$typeNameParameter];
+        	//simple pattern - without blanks!
+       	 	$pattern = '/^[0-9a-zA-Z\.\-_:,]*$/';
+                	echo 'Parameter <b>'.$typeNameParameter.'</b> is not valid.<br/>';
+                	die();
+		$reqParams[$typeNameParameter] = $testMatch;
-if ($userInformation[1] == '') { //check if digest exists in db - if no digest exists it should be a null string!
-    die('User with name: ' . $mbUsername . ' and email: ' . $mbEmail . ' has no digest - please set a new password and try again!');
+//check authorization
+$anonymousAccess = false;
+if ($layerId !== false) {
+	$user = new user(PUBLIC_USER);
+	$anonymousAccess = $user->isLayerAccessible($layerId);
+//$e = new mb_exception("http_auth/index.php: ".$typeNameParameter.": ".(string)$reqParams[$typeNameParameter]);
+	if ($reqParams[$typeNameParameter] !== false) {
+		$anonymousAccess = $user->areFeaturetypesAccessible($reqParams[$typeNameParameter], $wfsId);
-//first check the stale!
-if ($requestHeaderArray['nonce'] == getNonce()) {
-    // Up-to-date nonce received
-    $stale = false;
+//$e = new mb_exception("http_auth/index.php: anonymousAcces possible: ".(string)$anonymousAccess);
+//first check if anonymous user has rights to access ressource - if so - don't use authentication
+if ($anonymousAccess == true) {
+	$userId = PUBLIC_USER;
 } else {
-    // Stale nonce received (probably more than x seconds old)
-    $stale = true;
-    //give another chance to authenticate
-    header('WWW-Authenticate: Digest realm="' . REALM . '",qop="auth",nonce="' . getNonce() . '",opaque="' . md5(REALM) . '" ,stale=true');
-// generate the valid response to check the request of the client
-$A1 = $userInformation[1];
-$A2 = md5($_SERVER['REQUEST_METHOD'] . ':' . $requestHeaderArray['uri']);
-$valid_response = $A1 . ':' . getNonce() . ':' . $requestHeaderArray['nc'];
-$valid_response .= ':' . $requestHeaderArray['cnonce'] . ':' . $requestHeaderArray['qop'] . ':' . $A2;
-$valid_response = md5($valid_response);
+	//special for type of authentication ******************************
+	//control if digest auth is set, if not set, generate the challenge with getNonce()
+	if (empty($_SERVER['PHP_AUTH_DIGEST'])) {
+    	header('HTTP/1.1 401 Unauthorized');
+    	header('WWW-Authenticate: Digest realm="' . REALM .
+        '",qop="auth",nonce="' . getNonce() . '",opaque="' . md5(REALM) . '"');
+    	die('Text to send if user hits Cancel button');
-if ($requestHeaderArray['response'] != $valid_response) {//the user have to authenticate new - cause something in the authentication went wrong
-    die('Authentication failed - sorry, you have to authenticate once more!');
-//if we are here - authentication has been done well!
-//let's do the proxy things (came from owsproxy.php):
+	//read out the header in an array
+	$requestHeaderArray = http_digest_parse($_SERVER['PHP_AUTH_DIGEST']);
-//test for existing post data
-$postData = file_get_contents("php://input");
-if (isset($postData) && $postData !== '') {
-} else {
-	$postData = false;
+	//error if header could not be read
+	if (!($requestHeaderArray)) {
+    		echo 'Following Header information cannot be validated - check your clientsoftware!<br>';
+    		echo $_SERVER['PHP_AUTH_DIGEST'] . '<br>';
+    		die();
+	//get mb_username and email out of http_auth username string
+	$userIdentification = explode(';', $requestHeaderArray['username']);
+	$mbUsername = $userIdentification[0];
+	$mbEmail = $userIdentification[1]; //not given in all circumstances
+	$userInformation = getUserInfo($mbUsername, $mbEmail);
+	if ($userInformation[0] == '-1') {
+    		die('User with name: ' . $mbUsername . ' and email: ' . $mbEmail . ' not known to security proxy!');
+	if ($userInformation[1] == '') { //check if digest exists in db - if no digest exists it should be a null string!
+    		die('User with name: ' . $mbUsername . ' and email: ' . $mbEmail . ' has no digest - please set a new password and try again!');
+	//first check the stale!
+	if ($requestHeaderArray['nonce'] == getNonce()) {
+    		// Up-to-date nonce received
+    		$stale = false;
+	} else {
+    		// Stale nonce received (probably more than x seconds old)
+    		$stale = true;
+    		//give another chance to authenticate
+    		header('WWW-Authenticate: Digest realm="' . REALM . '",qop="auth",nonce="' . getNonce() . '",opaque="' . md5(REALM) . '" ,stale=true');
+	// generate the valid response to check the request of the client
+	$A1 = $userInformation[1];
+	$A2 = md5($_SERVER['REQUEST_METHOD'] . ':' . $requestHeaderArray['uri']);
+	$valid_response = $A1 . ':' . getNonce() . ':' . $requestHeaderArray['nc'];
+	$valid_response .= ':' . $requestHeaderArray['cnonce'] . ':' . $requestHeaderArray['qop'] . ':' . $A2;
+	$valid_response = md5($valid_response);
+	if ($requestHeaderArray['response'] != $valid_response) {//the user have to authenticate new - cause something in the authentication went wrong
+    	die('Authentication failed - sorry, you have to authenticate once more!');
+	//if we are here - authentication has been done well!
+	//let's do the proxy things (came from owsproxy.php):
+	//user information
+	//define $userId from database information
+	$userId = $userInformation[0];
 $layerId = $_REQUEST['layer_id'];
@@ -114,10 +210,10 @@
     $withChilds = true;
-$query = new QueryHandler($postData);
+/*$query = new QueryHandler($postData);
-$reqParams = $query->getRequestParams();
+$reqParams = $query->getRequestParams();*/
 $n = new administration();
 if (!(isset($reqParams['service'])) AND strtolower($reqParams['request'])=='getmap') {
@@ -146,7 +242,7 @@
-$userId = $userInformation[0];
+//$userId = $userInformation[0];
 /* ************ main workflow *********** */
@@ -266,7 +362,8 @@
         	$storedQueryId = $reqParams['storedquery_id'];
         	$arrayOnlineresources = checkWfsStoredQueryPermission($owsproxyString, $storedQueryId, $userId);
 	} else {
-		$arrayFeatures = array($reqParams['typename']);
+		$arrayFeatures = array($reqParams[$typeNameParameter]);
+		$e = new mb_exception("".$typeNameParameter.": ".$reqParams[$typeNameParameter]);
         	$arrayOnlineresources = checkWfsPermission($owsproxyString, $arrayFeatures, $userId);
         $query->setOnlineResource($arrayOnlineresources['wfs_getfeature']);
@@ -281,7 +378,7 @@
                 $price, 0, $reqParams['storedquery_id']);
 	    } else {
             	$log_id = $n->logWfsProxyRequest($arrayOnlineresources['wfs_id'], $userId, $request,
-                $price, 0, $reqParams['typename']);
+                $price, 0, $reqParams[$typeNameParameter]);
         } else {
 		$log_id = false;
@@ -299,7 +396,7 @@
         break;
     case 'describefeaturetype':
         $query->setOnlineResource($arrayOnlineresources['wfs_describefeaturetype']);
         $request = $query->getRequest();
@@ -661,6 +758,7 @@
         if (strtoupper($element['tag']) == "WFS:INSERT" && $element['type'] == "close") {
             $insert = false;
+        //updated features - TODO - fix for wfs 2.0+ - typenames instead of typename!
         //updated features
         if (strtoupper($element['tag']) == "WFS:UPDATE" && $element['type'] == "open") {
             array_push($features, $element['attributes']["typeName"]);
Modified: trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php
--- trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php	2017-05-24 12:11:45 UTC (rev 9748)
+++ trunk/mapbender/owsproxy/http/classes/class_QueryHandler.php	2017-06-26 11:39:02 UTC (rev 9749)
@@ -29,11 +29,13 @@
 	private $owsproxyServiceId;
 	private $onlineResource;
         private $hasPost = false;
+	private $serviceResourceName;
 	 * Constructor of the QueryHandler
 	function __construct($postData){
+		//${$this->typeNameParameter};
 		$this->setRequestParams(array_keys($_REQUEST));
 		if ($postData !== false) {
 			//parse post request for service / request / version parameters
@@ -55,8 +57,23 @@
 				$this->reqParamsToLower['request'] = $postQueryParser->serviceRequestType;
 			if (isset($postQueryParser->serviceResourceName) && $postQueryParser->serviceResourceName !== '') {
-				$this->reqParams['typename'] = $postQueryParser->serviceResourceName;
-				$this->reqParamsToLower['typename'] = $postQueryParser->serviceResourceName;
+				if ($this->reqParams['service'] == 'WFS') {
+					switch ($this->reqParams['version']) {
+						case "2.0.0":
+							$this->reqParams['typenames'] = $postQueryParser->serviceResourceName;
+							$this->reqParamsToLower['typenames'] = $postQueryParser->serviceResourceName;
+							break;
+						case "2.0.2":
+							break;
+						default:
+							$this->reqParams['typename'] = $postQueryParser->serviceResourceName;
+							$this->reqParamsToLower['typename'] = $postQueryParser->serviceResourceName;
+							break;
 			if (isset($postQueryParser->serviceStoredQueryId) && $postQueryParser->serviceStoredQueryId !== '') {
 				$this->reqParams['storedquery_id'] = $postQueryParser->serviceStoredQueryId;
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php	2017-05-24 12:11:45 UTC (rev 9748)
+++ trunk/mapbender/owsproxy/http/index.php	2017-06-26 11:39:02 UTC (rev 9749)
@@ -57,6 +57,37 @@
 // an array with keys and values toLowerCase -> caseinsensitiv
+if ($reqParams['service'] == 'WFS') {
+	//$typeNameParameter = "typename"; //lowercase
+		case "2.0.0":
+			break;
+		case "2.0.2":
+			break;
+		default:
+			break;
+        	//validate featuretype_name
+                	die();
 $e = new mb_notice("incoming request: " . OWSPROXY . "/" . $_REQUEST['sid'] . "/" . $_REQUEST['wms'] . $query->getRequest());
 $e = new mb_notice("owsproxy requested from: " . $_SERVER["REMOTE_ADDR"]);
 $e = new mb_notice("owsproxy requested: " . $query->getRequest());
@@ -354,7 +385,7 @@
 	} else {
@@ -369,7 +400,7 @@
 	    } else {
         } else {
 		$log_id = false;
@@ -385,7 +416,7 @@
         break;
         $arrayOnlineresources = checkWfsPermission($query->getOwsproxyServiceId(), $arrayFeatures, $userId);
@@ -704,12 +735,13 @@
             $insert = false;
-        //updated features
         //deleted features
         if (strtoupper($element['tag']) == "WFS:DELETE" && $element['type'] == "open") {
More information about the Mapbender_commits mailing list
