[Mapbender-commits] r9727 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Mar 30 03:06:30 PDT 2017
Author: armin11
Date: 2017-03-30 03:06:30 -0700 (Thu, 30 Mar 2017)
New Revision: 9727
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
fix - don't create new search view for wfs
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2017-03-30 09:34:08 UTC (rev 9726)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2017-03-30 10:06:30 UTC (rev 9727)
@@ -1837,43 +1837,6 @@
 ALTER TABLE search_wms_view
   OWNER TO postgres;
--- View: search_wfs_view
-DROP VIEW IF EXISTS search_wfs_view;
-CREATE OR REPLACE VIEW search_wfs_view AS
- SELECT wfs_without_geom.wfs_id, wfs_without_geom.wfs_title, wfs_without_geom.wfs_abstract, wfs_without_geom.administrativearea, wfs_without_geom.country, wfs_without_geom.accessconstraints, wfs_without_geom.termsofuse, wfs_without_geom.isopen, wfs_without_geom.wfs_owner, wfs_without_geom.featuretype_id, wfs_without_geom.featuretype_srs, wfs_without_geom.featuretype_title, wfs_without_geom.featuretype_abstract, wfs_without_geom.searchtext, wfs_without_geom.element_type, wfs_without_geom.wfs_conf_id, wfs_without_geom.wfs_conf_abstract, wfs_without_geom.wfs_conf_description, wfs_without_geom.modultype, wfs_without_geom.wfs_timestamp, wfs_without_geom.department, wfs_without_geom.mb_group_name, wfs_without_geom.mb_group_logo_path, wfs_without_geom.wfs_network_access, wfs_without_geom.wfs_pricevolume, wfs_without_geom.wfs_proxylog, wfs_without_geom.featuretype_latlon_bbox, wfs_without_geom.featuretype_latlon_array, geometryfromtext(((((((((((((((((((('POLYGON(('::text || wfs_without_geo
 m.featuretype_latlon_array[1]) || ' '::text) || wfs_without_geom.featuretype_latlon_array[2]) || ','::text) || wfs_without_geom.featuretype_latlon_array[1]) || ' '::text) || wfs_without_geom.featuretype_latlon_array[4]) || ','::text) || wfs_without_geom.featuretype_latlon_array[3]) || ' '::text) || wfs_without_geom.featuretype_latlon_array[4]) || ','::text) || wfs_without_geom.featuretype_latlon_array[3]) || ' '::text) || wfs_without_geom.featuretype_latlon_array[2]) || ','::text) || wfs_without_geom.featuretype_latlon_array[1]) || ' '::text) || wfs_without_geom.featuretype_latlon_array[2]) || '))'::text, 4326) AS the_geom, (((((wfs_without_geom.featuretype_latlon_array[1] || ','::text) || wfs_without_geom.featuretype_latlon_array[2]) || ','::text) || wfs_without_geom.featuretype_latlon_array[3]) || ','::text) || wfs_without_geom.featuretype_latlon_array[4] AS bbox
-   FROM ( SELECT DISTINCT wfs_featuretype.featuretype_id, wfs_dep.wfs_id, wfs_dep.wfs_title, wfs_dep.wfs_abstract, wfs_dep.administrativearea, wfs_dep.country, wfs_dep.accessconstraints, wfs_dep.termsofuse, wfs_dep.isopen, wfs_dep.wfs_owner, wfs_featuretype.featuretype_srs, wfs_featuretype.featuretype_title, wfs_featuretype.featuretype_abstract, f_collect_searchtext_wfs(wfs_dep.wfs_id, wfs_featuretype.featuretype_id) AS searchtext, wfs_element.element_type, wfs_conf.wfs_conf_id, wfs_conf.wfs_conf_abstract, wfs_conf.wfs_conf_description, f_getwfsmodultype(wfs_conf.wfs_conf_id) AS modultype, wfs_dep.wfs_timestamp, wfs_dep.department, wfs_dep.mb_group_name, wfs_dep.mb_group_logo_path, wfs_dep.wfs_network_access, wfs_dep.wfs_pricevolume, wfs_dep.wfs_proxylog, wfs_featuretype.featuretype_latlon_bbox,
-                CASE
-                    WHEN wfs_featuretype.featuretype_latlon_bbox::text = ''::text THEN string_to_array('-180,-90,180,90'::text, ','::text)
-                    WHEN wfs_featuretype.featuretype_latlon_bbox IS NULL THEN string_to_array('-180,-90,180,90'::text, ','::text)
-                    ELSE string_to_array(wfs_featuretype.featuretype_latlon_bbox::text, ','::text)
-                END AS featuretype_latlon_array
-           FROM (
---adoption to pull two different kinds of wms metadata, based on mapbenders role system
-SELECT wfs.wfs_id, wfs.wfs_title, wfs.wfs_abstract, wfs.administrativearea, wfs.country, wfs.accessconstraints, f_getwfs_tou(wfs.wfs_id) AS termsofuse, f_tou_isopen(f_getwfs_tou(wfs.wfs_id)) AS isopen, wfs.wfs_timestamp, wfs.wfs_owner, wfs.wfs_proxylog, wfs.wfs_network_access, wfs.wfs_pricevolume, publishing_registrating_authorities.mb_group_id AS department, publishing_registrating_authorities.mb_group_name, publishing_registrating_authorities.mb_group_logo_path
-                           FROM groups_for_publishing AS publishing_registrating_authorities, wfs
-                          WHERE wfs.fkey_mb_group_id = publishing_registrating_authorities.mb_group_id
-UNION ALL
---now pull the resources for whith the primary group of the registrating user
-SELECT wfs.wfs_id, wfs.wfs_title, wfs.wfs_abstract, wfs.administrativearea, wfs.country, wfs.accessconstraints, f_getwfs_tou(wfs.wfs_id) AS termsofuse, f_tou_isopen(f_getwfs_tou(wfs.wfs_id)) AS isopen, wfs.wfs_timestamp, wfs.wfs_owner, wfs.wfs_proxylog, wfs.wfs_network_access, wfs.wfs_pricevolume, user_dep.fkey_mb_group_id AS department, user_dep.mb_group_name, user_dep.mb_group_logo_path
-                           FROM (
-SELECT publishing_registrating_authorities.*,  users_for_publishing.fkey_mb_user_id FROM groups_for_publishing AS publishing_registrating_authorities, users_for_publishing WHERE users_for_publishing.primary_group_id = publishing_registrating_authorities.fkey_mb_group_id) user_dep,
- wfs
-                          WHERE (wfs.fkey_mb_group_id IS null OR wfs.fkey_mb_group_id = 0) AND wfs.wfs_owner = user_dep.fkey_mb_user_id
-) wfs_dep, wfs_featuretype, wfs_element, wfs_conf
-          WHERE wfs_featuretype.fkey_wfs_id = wfs_dep.wfs_id AND wfs_featuretype.featuretype_searchable = 1 AND wfs_element.element_type::text ~~ '%Type'::text AND wfs_featuretype.featuretype_id = wfs_element.fkey_featuretype_id AND wfs_featuretype.featuretype_id = wfs_conf.fkey_featuretype_id
-          ORDER BY wfs_featuretype.featuretype_id) wfs_without_geom;
-ALTER TABLE search_wfs_view
-  OWNER TO postgres;
 -- View: search_dataset_view
 DROP VIEW IF EXISTS search_dataset_view;
More information about the Mapbender_commits mailing list
