[Mapbender-commits] r9797 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Oct 5 06:29:28 PDT 2017
Author: armin11
Date: 2017-10-05 06:29:28 -0700 (Thu, 05 Oct 2017)
New Revision: 9797
   trunk/mapbender/http/php/mod_inspireDownloadFeed.php
Integration of new class for getting axis order from epsg registry.
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2017-10-05 13:28:26 UTC (rev 9796)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2017-10-05 13:29:28 UTC (rev 9797)
@@ -30,6 +30,7 @@
 require_once(dirname(__FILE__) . "/../../conf/mimetype.conf");
 require_once(dirname(__FILE__) . "/../classes/class_cache.php");
 require_once(dirname(__FILE__) . "/../classes/class_iso19139.php");
+require_once(dirname(__FILE__) . "/../classes/class_crs.php");
 require_once(dirname(__FILE__) . "/../classes/class_metadata_monitor.php");
 //check_epsg_wms_13($tmp_epsg)
@@ -694,10 +695,25 @@
 	//Handle CRS - maybe in 'urn:ogc:def:crs:EPSG:6.9:4326' or 'EPSG:4326' or 'epsg:4326' or 'urn:ogc:def:crs:EPSG::4326' format!
+	//*********************** New use crs class for checking if the order has to be changed in the filter!!!
+	$crsObject = new Crs($crs);
+	if ($crsObject->alterAxisOrder("wms"."_".$mapbenderMetadata[$i]->wms_version) == true) {
+		$alterAxisOrder = true;
+	} else {
+		$alterAxisOrder = false;
+	$epsgId = $crsObject->identifierCode;
 	//TODO test this also in sqls from mapbenders database - see wms 1.3.0 - for layer metadata
 	//explode strings
 	//alter all to uppercase
-	$crsUpper = str_replace("epsg","EPSG",$crs);
+	/*$crsUpper = str_replace("epsg","EPSG",$crs);
 	//explode strings
 	$crsUpperArray = explode(":",$crsUpper);
 	switch (count($crsUpperArray)) {
@@ -717,7 +733,7 @@
 		} else {
 	//infos about the registrating department, check first if a special metadata point of contact is defined in the service table - function from mod_showMetadata - TODO: should be defined in admin class
 	if (!isset($mapbenderMetadata[$m]->fkey_mb_group_id) or is_null($mapbenderMetadata[$m]->fkey_mb_group_id) or $mapbenderMetadata[$m]->fkey_mb_group_id == 0){
 		$e = new mb_exception("mod_inspireDownloadFeed.php: fkey_mb_group_id not found!");
@@ -1178,11 +1194,21 @@
 				$maxFeatureCount = (integer)$mapbenderMetadata[$i]->wfs_max_features;
 				$crs = $mapbenderMetadata[$i]->metadata_ref_system;
-				//use featuretype ref system?
+				//use featuretype ref system - to build the bbox filters!!!
 				$crs = $mapbenderMetadata[$i]->featuretype_srs;
 				//log ref system of metadata - is this a good idea?
 				$e = new mb_notice("Ref system of featuretype ".$mapbenderMetadata[$i]->featuretype_name." : ".$crs);
+				if ($crsObject->alterAxisOrder("wfs"."_".$mapbenderMetadata[$i]->wfs_version) == true) {
+				} else {
 				//handle other definitions of epsg ids
 				//urn:ogc:def:crs:EPSG::31467
 				//Handle CRS
@@ -1204,6 +1230,7 @@
 				$e = new mb_notice("Epsg id of featuretype ".$mapbenderMetadata[$i]->featuretype_name." : ".$epsgId);
 				if (!($mapbenderMetadata[$i]->wfs_version) || $mapbenderMetadata[$i]->wfs_version == '') {
 				return "<error>Version of WFS : ".$mapbenderMetadata[$i]->wfs_version." is not supported to generate inspire download services for predefined datasets!</error>";
@@ -1256,7 +1283,7 @@
 							break;
 					$featureHits[$i] = (integer)$hits[0];
-					$e = new mb_notice($featureHits[$i]." hits for featuretype ".$mapbenderMetadata[$i]->featuretype_name);
+					$e = new mb_exception($featureHits[$i]." hits for featuretype ".$mapbenderMetadata[$i]->featuretype_name);
 					//calculate further bboxes if the # of hits extents some value
 					//minimum number of single tiles:
 					$countTiles = ceil($featureHits[$i]/$maxFeatureCount);
@@ -1264,40 +1291,17 @@
 					$countTiles = 1;
 				//calculate number of rows and columns from x / y ratio
-				if ($epsgId == '4326' && $alterAxisOrder) {
-					//no transformation needed only change order
-					$minx = $mapbenderMetadata[$i]->miny;
-					$miny = $mapbenderMetadata[$i]->minx;
-					$maxx = $mapbenderMetadata[$i]->maxy;
-					$maxy = $mapbenderMetadata[$i]->maxx;
-				} else {
-					//no transformation needed normal order
-					if ($epsgId == '4326') {
-						$minx = $mapbenderMetadata[$i]->minx;
-						$miny = $mapbenderMetadata[$i]->miny;
-						$maxx = $mapbenderMetadata[$i]->maxx;
-						$maxy = $mapbenderMetadata[$i]->maxy;
-					} else {
-						//transformation needed and axis order changed
-						if ($alterAxisOrder) {
-							$e = new mb_exception("axis_order_altered");
-							$minxI = $mapbenderMetadata[$i]->miny;
-							$minyI = $mapbenderMetadata[$i]->minx;
-							$maxxI = $mapbenderMetadata[$i]->maxy;
-							$maxyI = $mapbenderMetadata[$i]->maxx;
-							$mapbenderMetadata[$i]->miny = $minyI;
-							$mapbenderMetadata[$i]->minx = $minxI;
-							$mapbenderMetadata[$i]->maxy = $maxyI;
-							$mapbenderMetadata[$i]->maxx = $maxxI;
-						$sqlExtent = "SELECT X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$epsgId.")) as minx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$epsgId.")) as miny, X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$epsgId.")) as maxx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$epsgId.")) as maxy";
-						$resExtent =  db_query($sqlExtent);
-						$minx = floatval(db_result($resExtent,0,"minx"));
-						$miny = floatval(db_result($resExtent,0,"miny"));
-						$maxx = floatval(db_result($resExtent,0,"maxx"));
-						$maxy = floatval(db_result($resExtent,0,"maxy"));
+				//$e = new mb_exception("http/php/mod_inspireDownloadFeed.php: - Bbox from metadata: minx: ". $mapbenderMetadata[$i]->minx." - miny: ".$mapbenderMetadata[$i]->miny." - maxx: ".$mapbenderMetadata[$i]->maxx." - maxy: ".$mapbenderMetadata[$i]->maxy." - CRS: ".$mapbenderMetadata[$i]->featuretype_srs." - EPSG ID: ".$crsObject->identifierCode);
+				//set epsgId;
+				//read out in variables
+				$sqlExtent = "SELECT X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$crsObject->identifierCode.")) as minx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$crsObject->identifierCode.")) as miny, X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$crsObject->identifierCode.")) as maxx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$crsObject->identifierCode.")) as maxy";
+				$resExtent =  db_query($sqlExtent);
+				$minx = floatval(db_result($resExtent,0,"minx"));
+				$miny = floatval(db_result($resExtent,0,"miny"));
+				$maxx = floatval(db_result($resExtent,0,"maxx"));
+				$maxy = floatval(db_result($resExtent,0,"maxy"));
+				$e = new mb_exception("http/php/mod_inspireDownloadFeed.php: - minx: ".$minx. " - maxx: ".$maxx);
 				//only calculate new boxes if countTiles > 1
 				if ($countTiles > 1) {
 					$diffX = $maxx - $minx; //in m - depends on given epsg code
@@ -1336,10 +1340,14 @@
 					if ($minx == "" || $miny == "" || $maxx == "" || $maxy == "") {
 						//set default values
 						//EPSG:4326
-						$minx = "-90";
-						$miny = "-180";
-						$maxx = "90";
-						$maxy = "180";
+						//use lon/lat - for postgis!!!
+						$minx = "-180";
+						$miny = "-90";
+						$maxx = "180";
+						$maxy = "90";
 						$epsgId = "4326";
 					$bboxWfs[$mapbenderMetadata[$i]->featuretype_name][0] = $minx.",".$miny.",".$maxx.",".$maxy;
@@ -1376,6 +1384,17 @@
 						$geometryFieldName = 'geometry';
 					$currentBbox = explode(',',$bboxWfs[$mapbenderMetadata[$i]->featuretype_name][$l]);
+					//change axis order if crs definition and service needs it
+					if ($alterAxisOrder == true) {
+						$e = new mb_exception("mod_inspireDownloadFeed.php: axis order should be altered!");
+						$currentBboxNew = $currentBbox;
+						$currentBboxGetFeature[0] = $currentBboxNew[1];
+						$currentBboxGetFeature[1] = $currentBboxNew[0];
+						$currentBboxGetFeature[2] = $currentBboxNew[3];
+						$currentBboxGetFeature[3] = $currentBboxNew[2];
+					} else {
+						$currentBboxGetFeature = $currentBbox;
 					if (strpos($mapbenderMetadata[$i]->featuretype_name, ':') !== false) {
 						$ftNamespace = explode(':', $mapbenderMetadata[$i]->featuretype_name);
 						$ftNamespace = $ftNamespace[0];
@@ -1391,8 +1410,8 @@
 							//<gml:Envelope srsName="urn:ogc:def:crs:EPSG::1234">
 							$bboxFilter .= '<gml:Envelope xmlns:gml="http://www.opengis.net/gml/3.2" srsName="'.$crs.'">';
 							//FIX for ESRI? TODO
-							$bboxFilter .= '<gml:lowerCorner>'.$currentBbox[0].' '.$currentBbox[1].'</gml:lowerCorner>';
-							$bboxFilter .= '<gml:upperCorner>'.$currentBbox[2].' '.$currentBbox[3].'</gml:upperCorner>';
+							$bboxFilter .= '<gml:lowerCorner>'.$currentBboxGetFeature[0].' '.$currentBboxGetFeature[1].'</gml:lowerCorner>';
+							$bboxFilter .= '<gml:upperCorner>'.$currentBboxGetFeature[2].' '.$currentBboxGetFeature[3].'</gml:upperCorner>';
               						$bboxFilter .= '</gml:Envelope>';
 		            				$bboxFilter .= '</fes:BBOX>';
 							$bboxFilter .= '</fes:Filter>';
@@ -1404,8 +1423,8 @@
@@ -1421,36 +1440,15 @@
 							//$currentBbox = explode(',',$bboxWfs[$mapbenderMetadata[$i]->featuretype_name][$l]);
 							$e = new mb_notice("Bounding box ".$l." : ".$l.$bboxWfs[$mapbenderMetadata[$i]->featuretype_name][$l]);
 							//fix for esri????? TODO check crs axes order handling
-							if (strtoupper($mapbenderMetadata[$i]->geometry_field_name[0] == "SHAPE")) {
-								$bboxFilter .= $currentBbox[1].','.$currentBbox[0].' '.$currentBbox[3].','.$currentBbox[2];
-							} else {
-								$bboxFilter .= $currentBbox[0].','.$currentBbox[1].' '.$currentBbox[2].','.$currentBbox[3];
+							//if (strtoupper($mapbenderMetadata[$i]->geometry_field_name[0] == "SHAPE")) {
+							//	$bboxFilter .= $currentBboxGetFeature[1].','.$currentBboxGetFeature[0].' '.$currentBboxGetFeature[3].','.$currentBboxGetFeature[2];
+							//} else {
+								$bboxFilter .= $currentBboxGetFeature[0].','.$currentBboxGetFeature[1].' '.$currentBboxGetFeature[2].','.$currentBboxGetFeature[3];
 							$bboxFilter .= '</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter>';
 							$bboxFilter = rawurlencode(utf8_decode($bboxFilter));
 							break;
-					//$bboxFilter = '<ogc:Filter><ogc:BBOX>';
-					$bboxFilter = '<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX>';
-					//$bboxFilter = '<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml"><ogc:BBOX>';
-					//$bboxFilter .= '<gml:Box srsName="EPSG:'.$epsgId[1].'"';
-					$bboxFilter .= '<ogc:PropertyName>'.$mapbenderMetadata[$i]->geometry_field_name[0].'</ogc:PropertyName>';
-					$bboxFilter .= '<gml:Box xmlns:gml="http://www.opengis.net/gml" srsName="'.$crs.'">';
-					$bboxFilter .= '<gml:coordinates decimal="." cs="," ts=" ">';
-					$currentBbox = explode(',',$bboxWfs[$mapbenderMetadata[$i]->featuretype_name][$l]);
-					$e = new mb_notice("Bounding box ".$l." : ".$l.$bboxWfs[$mapbenderMetadata[$i]->featuretype_name][$l]);
-					//fix for esri?????
-					} else {
-					$bboxFilter .= '</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter>';
-					$bboxFilter = rawurlencode(utf8_decode($bboxFilter));
 					//check if owsproxy is activated for wfs - if so, use absolute url of wfs
 					//e.g.: www.geoportal.rlp.de/registry/wfs/{wfs_id}? - important - there has to be one wfsconf defined and assigned!
 					if ($admin->getWFSOWSstring($mapbenderMetadata[$i]->wfs_id) == false) {
@@ -1639,7 +1637,10 @@
 						} else {
 							$getMapUrl = $mapbenderMetadata[$i]->wms_getmap;
+						//TODO - define further link for wms 1.1.1 and wms 1.3.0 - SRS Paramter changed and maybe the axis order!!!!!!
 						$furtherLink[$m] = $getMapUrl."REQUEST=GetMap&VERSION=".$mapbenderMetadata[$i]->wms_version."&SERVICE=WMS&LAYERS=".$mapbenderMetadata[$i]->layer_name;
 						$furtherLink[$m] .= "&STYLES=&SRS=".trim($crs)."&BBOX=".$bboxWms[$m]."&WIDTH=".$maxImageSize."&HEIGHT=".$maxImageSize."&FORMAT=image/tiff&";
 						$furtherLink[$m] .= "BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage";
 						$furtherLinkType[$m] = "image/tiff"; //formats from layer_format - geotiff
@@ -1650,11 +1651,7 @@
 						//exchange lon lat with lat long for georss
 						$newBox = explode(',',$furtherLinkBbox[$m]);
 						//georss needs latitude longitude
-                                                if ($alterAxisOrder == true) {
-							$newBox = $newBox[1].",".$newBox[0].",".$newBox[3].",".$newBox[2];
-						} else {
-							$newBox = $newBox[0].",".$newBox[1].",".$newBox[2].",".$newBox[3];
+						$newBox = $newBox[1].",".$newBox[0].",".$newBox[3].",".$newBox[2];
 						//generate content link
 						$feedEntryLink = $feedDoc->createElement("link");
 						if ($numberOfTiles > 1) {
@@ -1666,7 +1663,9 @@
 						$feedEntryLink->setAttribute("type", $furtherLinkType[$m]);
 						$feedEntryLink->setAttribute("hreflang", "de");
 						$feedEntryLink->setAttribute("title", $furtherLinkTitle[$m]);
+						//if axis order was
 						$feedEntryLink->setAttribute("bbox", str_replace(","," ",$newBox));
 						$feedEntry->appendChild($feedEntryLink);
 				break;
More information about the Mapbender_commits mailing list
