[Mapbender-commits] r9911 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Wed Jun 6 01:49:55 PDT 2018
Author: armin11
Date: 2018-06-06 01:49:54 -0700 (Wed, 06 Jun 2018)
New Revision: 9911
trunk/mapbender/http/javascripts/mod_changeEPSG.php
trunk/mapbender/http/javascripts/mod_pan.js
Bugfixes for problems which occur while when a user pan the map.
Modified: trunk/mapbender/http/javascripts/mod_changeEPSG.php
--- trunk/mapbender/http/javascripts/mod_changeEPSG.php 2018-05-28 12:48:51 UTC (rev 9910)
+++ trunk/mapbender/http/javascripts/mod_changeEPSG.php 2018-06-06 08:49:54 UTC (rev 9911)
@@ -243,14 +243,16 @@
if (newExtent[i].frameName === myTarget){
var map = $("#" + myTarget).mapbender();
+ if (map.mb_MapHistoryObj) {
+ for (var ii = 0; ii < map.mb_MapHistoryObj.length; ii++) {
+ if (map.mb_MapHistoryObj[ii].epsg == newExtent[i].newSrs) {
+ exists = ii;
+ var goback = true;
- for (var ii = 0; ii < map.mb_MapHistoryObj.length; ii++) {
- if (map.mb_MapHistoryObj[ii].epsg == newExtent[i].newSrs) {
- exists = ii;
- var goback = true;
if (goback) {
var extArray = map.mb_MapHistoryObj[exists].extent.toString().split(",");
var newExt = new Extent(
Modified: trunk/mapbender/http/javascripts/mod_pan.js
--- trunk/mapbender/http/javascripts/mod_pan.js 2018-05-28 12:48:51 UTC (rev 9910)
+++ trunk/mapbender/http/javascripts/mod_pan.js 2018-06-06 08:49:54 UTC (rev 9911)
@@ -34,7 +34,7 @@
var map = Mapbender.modules[options.target];
- var mousedown = function (e) {
+ var movestart = function (e) {
mb_panActive = true;
startPos = map.getMousePosition(e);
stopPos = new Point(startPos);
@@ -41,7 +41,7 @@
return false;
- var mousemove = function (e) {
+ var move = function (e) {
if (!mb_panActive) {
return false;
@@ -54,7 +54,7 @@
return false;
- var mouseup = function (e) {
+ var moveend = function (e) {
return false;
@@ -72,7 +72,7 @@
map.moveMap();
map.zoom(false, 1.0, realCenter);
return false;
var button = new Mapbender.Button({
domElement: that,
@@ -88,9 +88,10 @@
$(map.getDomElement())
.css("cursor", "move")
- .mousedown(mousedown)
- .mousemove(mousemove)
- .mouseup(mouseup);
+ .mousedown(movestart)
+ .mousemove(move)
+ .mouseup(moveend)
+ .mouseleave(moveend);
stop: function () {
if (!map) {
@@ -98,10 +99,16 @@
.css("cursor", "default")
- .unbind("mousedown", mousedown)
- .unbind("mouseup", mouseup)
- .unbind("mousemove", mousemove);
+ .unbind("mousedown", movestart)
+ .unbind("mousemove", move)
+ .unbind("mouseup", moveend)
+ .unbind("mouseleave", moveend);
mb_panActive = false;
+ // deactivate if ui-dialog opens
+ $(document).bind('dialogopen', function () {
+ button.stop();
More information about the Mapbender_commits
