[Mapbender-commits] r9968 - in trunk/mapbender/http: classes javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Oct 1 08:37:16 PDT 2018
Author: armin11
Date: 2018-10-01 08:37:16 -0700 (Mon, 01 Oct 2018)
New Revision: 9968
   trunk/mapbender/http/classes/class_elementVar.php
   trunk/mapbender/http/javascripts/initWmcObj.php
Fix error when element var 'removeUnaccessableLayers' is missing in loadwmc module
Modified: trunk/mapbender/http/classes/class_elementVar.php
--- trunk/mapbender/http/classes/class_elementVar.php	2018-09-28 16:27:54 UTC (rev 9967)
+++ trunk/mapbender/http/classes/class_elementVar.php	2018-10-01 15:37:16 UTC (rev 9968)
@@ -34,6 +34,7 @@
 				$this->applicationId = func_get_arg(0);
 				$this->elementId = func_get_arg(1);
 				$this->name = func_get_arg(2);
+				$this->success = false;
 				$this->load();
 			catch (Exception $e) {
@@ -94,14 +95,19 @@
 		$v = array($this->applicationId, $this->elementId, $this->name);
 		$t = array("s", "s", "s");
 		$res = db_prep_query($sql, $v, $t);
-		if ($row = db_fetch_array($res)) {
-			$this->value = $row["var_value"];
-			$this->context = $row["context"];
-			$this->type = $row["var_type"];
+		try {
+			$row = db_fetch_array($res);
+			if ($row !== false) {
+				$this->value = $row["var_value"];
+				$this->context = $row["context"];
+				$this->type = $row["var_type"];
+				$this->success = true;
+			} else {
-		else {
-			 throw new Exception("no such element var");
+		catch (Exception $e) {
+			throw new Exception ("no such element var");
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php	2018-09-28 16:27:54 UTC (rev 9967)
+++ trunk/mapbender/http/javascripts/initWmcObj.php	2018-10-01 15:37:16 UTC (rev 9968)
@@ -153,8 +153,10 @@
 $removeUnaccessableLayers = false;
 $removeUnaccessableLayers = new ElementVar($app, "loadwmc", "removeUnaccessableLayers");
-if ($wmcDocSession && $removeUnaccessableLayers->value === "1") {
-	$removeUnaccessableLayers = true;
+if ($removeUnaccessableLayers->success == true){
+	if ($wmcDocSession && $removeUnaccessableLayers->value === "1") {
+		$removeUnaccessableLayers = true;
 //TODO: if no GET API is given then don't do the following things
More information about the Mapbender_commits mailing list
