[Mapbender-commits] r9974 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Oct 11 06:57:52 PDT 2018
Author: armin11
Date: 2018-10-11 06:57:52 -0700 (Thu, 11 Oct 2018)
New Revision: 9974
Added:
   trunk/mapbender/resources/db/install_geoportal_mb28.sh
First install script to install the mapbender2 based geoportal framework on a fresh debian 8 server
Added: trunk/mapbender/resources/db/install_geoportal_mb28.sh
--- trunk/mapbender/resources/db/install_geoportal_mb28.sh	                        (rev 0)
+++ trunk/mapbender/resources/db/install_geoportal_mb28.sh	2018-10-11 13:57:52 UTC (rev 9974)
@@ -0,0 +1,850 @@
+#!/bin/bash
+# Geoportal-RLP install script for debian 8 server environment
+# 2018-09-16
+# debian netinstall 8 - 11
+# df -h - 954MB
+# install options: webserver, ssh-server, system
+date
+webadmin_email="test at test.de"
+mapbender_database_name="mapbender"
+mapbender_database_port="5432"
+mapbender_database_user="mapbenderdbuser"
+mapbender_database_password="mapbenderdbpassword"
+mapbender_guest_user_id="2"
+mapbender_guest_group_id="22"
+mapbender_subadmin_group_id="21"
+mapbender_subadmin_default_user_id="3"
+mapbender_subadmin_default_group_id="23"
+installation_folder="/data/"
+typo3_database_name="typo3"
+# typo3_database_port="xxxx" # actually the default port
+typo3_database_user="typo3dbuser"
+typo3_database_password="typo3dbpassword"
+use_proxy="false"
+http_proxy_host="proxyip"
+http_proxy_port="proxyport"
+https_proxy_host="proxyip"
+https_proxy_port="proxyport"
+# what should be done
+install_system_packages="true"
+create_folders="true"
+checkout_mapbender_svn="true"
+checkout_typo3_svn="true"
+install_mapbender_source="true"
+install_typo3_source="true"
+install_mapbender_database="true"
+install_typo3_database="true"
+configure_mapbender="true"
+configure_typo3="true"
+configure_apache="true"
+configure_cronjobs="true"
+# set some environment variables
+if [ $use_proxy = 'true' ]; then
+    # set proxy env for wget from shell
+    cp /etc/subversion/servers /etc/subversion/servers_backup_geoportal
+    export http_proxy=http://$http_proxy_host:$http_proxy_port
+    export https_proxy=http://$https_proxy_host:$https_proxy_port
+    # for git access behind proxy
+    # git config --global http.proxy http://$http_proxy_host:$http_proxy_port
+    # git config --global https.proxy http://$https_proxy_host:$https_proxy_port
+    # for apt alter or create /etc/apt/apt.conf
+    if [ -e "/etc/apt/apt.conf" ]; then
+        echo "File exists"
+	cp /etc/apt/apt.conf /etc/apt/apt.conf_backup_geoportal
+	echo "Acquire::http::Proxy \"http://$http_proxy_host:$http_proxy_port\";" > /etc/apt/apt.conf
+    else
+        echo "File does not exist"
+	touch /etc/apt/apt.conf
+    fi
+    # first line should be: Acquire::http::Proxy "http://$http_proxy_host:$http_proxy_port";
+    # for subversion alter /etc/subversion/servers - alter following lines
+    # # http-proxy-host = defaultproxy.whatever.com
+    sed -i "s/# http-proxy-host = defaultproxy.whatever.com/http-proxy-host = $http_proxy_host/g" /etc/subversion/servers
+    sed -i "s/# http-proxy-port = 7000/http-proxy-port = $http_proxy_port/g" /etc/subversion/servers
+    # # http-proxy-port = 7000
+fi
+if [ $install_system_packages = 'true' ]; then
+    # install needed debian packages
+    apt-get install -y php5-mysql libapache2-mod-php5 php5-pgsql php5-gd php5-curl php5-cli php-gettext g++ make bison bzip2 unzip zip gdal-bin cgi-mapserver php5-imagick mysql-server imagemagick locate postgresql postgis postgresql-9.4-postgis-2.1 mc zip unzip links w3m lynx arj xpdf dbview odt2txt ca-certificates oidentd gettext phppgadmin gkdebconf subversion subversion-tools php5-memcached php5-memcache php-apc
+fi
+# +655MB
+# mysql root password: mysqlroot - normally debian-sys-maint
+# after install - 1.9GB!!!
+if [ $create_folders = 'true' ]; then
+    # initial installation of geoportal.rlp on debian 8
+    # create folder structure
+    mkdir $installation_folder
+    mkdir ${installation_folder}svn/
+    mkdir ${installation_folder}access/
+fi
+# check out svn repositories initially
+cd ${installation_folder}svn/
+if [ $checkout_typo3_svn = 'true' ]; then
+    svn co http://www.gdi-rp-dienste.rlp.de/svn/de-rp/data/portal
+fi
+if [ $checkout_mapbender_svn = 'true' ]; then
+    svn co https://svn.osgeo.org/mapbender/trunk/mapbender
+fi
+# compress and create mapbender
+if [ $install_mapbender_source = 'true' ]; then
+    cd ${installation_folder}svn/
+    tar -czf mapbender_trunk.tar.gz mapbender/
+    mv mapbender_trunk.tar.gz /tmp/
+    mv /tmp/mapbender_trunk.tar.gz .
+    tar -xzf mapbender_trunk.tar.gz
+    svn info https://svn.osgeo.org/mapbender/trunk/mapbender | grep Revision | grep -Eo '[0-9]{1,}' > ${installation_folder}mapbender/lastinstalled
+    rm mapbender_trunk.tar.gz
+    echo 'done.'
+fi
+# compress and create typo3
+if [ $install_typo3_source = 'true' ]; then
+    tar -czf typo3trunk.tar.gz portal/
+    mv typo3trunk.tar.gz /tmp/
+    mv /tmp/typo3trunk.tar.gz .
+    tar -xzf typo3trunk.tar.gz
+    svn info http://www.gdi-rp-dienste.rlp.de/svn/de-rp/data/portal | grep Revision | grep -Eo '[0-9]{1,}' > ${installation_folder}portal/lastinstalled
+    rm typo3trunk.tar.gz
+    echo 'done.'
+fi
+# cleanup .svn relicts
+echo -n 'delete .svn files ... '
+    cd ${installation_folder}mapbender/
+    rm -rf $(find . -type d -name .svn)
+fi
+    cd ${installation_folder}portal/
+    # download typo3 sources
+    mkdir ${installation_folder}portal/uploads/
+    mkdir ${installation_folder}portal/typo3temp/
+    mkdir ${installation_folder}portal/fileadmin/user_upload/
+    mkdir ${installation_folder}portal/fileadmin/_temp_/
+    wget http://www.geoportal.rlp.de/metadata/typo3_src-4.5.19.tar.gz
+    tar -xzvf typo3_src-4.5.19.tar.gz
+    chown -R www-data:www-data ${installation_folder}portal/typo3conf/
+    chown -R www-data:www-data ${installation_folder}portal/typo3temp/
+    chown -R www-data:www-data ${installation_folder}portal/fileadmin/user_upload/
+    chown -R www-data:www-data ${installation_folder}portal/fileadmin/_temp_/
+fi
+echo 'done.'
+# configure and install mapbender
+    mkdir ${installation_folder}mapbender/http/tmp/wmc
+fi
+# mapbender db
+if [ $install_mapbender_database = 'true' ]; then
+# su postgres
+# createuser  -S -D -R -P mapbenderdbuser #mapbenderdbpassword
+# CREATE DATABASE yourdbname;
+# CREATE USER youruser WITH ENCRYPTED PASSWORD 'yourpass';
+# GRANT ALL PRIVILEGES ON DATABASE yourdbname TO youruser;
+su - postgres -c "dropdb -p $mapbender_database_port $mapbender_database_name"
+su - postgres -c "createdb -p $mapbender_database_port -E UTF8 $mapbender_database_name -T template0"
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -c "CREATE USER $mapbender_database_user WITH ENCRYPTED PASSWORD '$mapbender_database_password'"
+# su -c - postgres "createlang plpgsql -d $mapbender_database_name" - not needed for debian 8+
+su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -f /usr/share/postgresql/9.4/contrib/postgis-2.1/postgis.sql"
+su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -f /usr/share/postgresql/9.4/contrib/postgis-2.1/spatial_ref_sys.sql"
+su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -f /usr/share/postgresql/9.4/contrib/postgis-2.1/legacy.sql"
+su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -f /usr/share/postgresql/9.4/contrib/postgis-2.1/topology.sql"
+su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'GRANT ALL PRIVILEGES ON DATABASE $mapbender_database_name TO $mapbender_database_user'"
+# su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'grant all on geometry_columns to $mapbender_database_user;'"
+#maybe new to postgis 2.x
+# su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'grant all on geography_columns to $mapbender_database_user;'"
+# su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'grant all on spatial_ref_sys to $mapbender_database_user;'"
+su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'ALTER DATABASE $mapbender_database_name OWNER TO $mapbender_database_user'"
+#overwrite default pg_hba.conf of main - default cluster
+cp /etc/postgresql/9.4/main/pg_hba.conf /etc/postgresql/9.4/main/pg_hba.conf_backup
+cat << EOF > "/etc/postgresql/9.4/main/pg_hba.conf"
+# Database administrative login by Unix domain socket
+local   all             postgres                                peer
+# TYPE  DATABASE        USER            ADDRESS                 METHOD
+# "local" is for Unix domain socket connections only
+local   $mapbender_database_name        $mapbender_database_user                        md5
+# IPv4 local connections:
+host    all             postgres        127.0.0.1/32            trust
+host    $mapbender_database_name             $mapbender_database_user 127.0.0.1/32            md5
+# IPv6 local connections:
+host    all             postgres        ::1/128                 trust
+host    $mapbender_database_name             $mapbender_database_user ::1/128                 md5
+EOF
+service postgresql restart
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -c 'CREATE SCHEMA mapbender'
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -c 'ALTER DATABASE mapbender SET search_path TO mapbender,public,pg_catalog,topology'
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/pgsql_schema_2.5.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.6.2_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.1_to_2.7.2_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
+echo 'adopting mapbenders default database to geoportal default options  ... '
+cat << EOF > ${installation_folder}geoportal_database_adoption_1.sql
+--create new database content
+--geoportal specific extensions
+ALTER TABLE mb_user ADD COLUMN mb_user_glossar character varying(5);
+--ALTER TABLE mb_user ADD COLUMN mb_user_glossar character varying(14);
+--ALTER TABLE mb_user ADD COLUMN mb_user_textsize character varying(14);
+ALTER TABLE mb_user ADD COLUMN mb_user_textsize character varying(14);
+ALTER TABLE mb_user ADD COLUMN mb_user_last_login_date date;
+ALTER TABLE mb_user ADD COLUMN mb_user_spatial_suggest character varying(5);
+UPDATE gui_category SET category_name='Anwendung' WHERE category_id=2;
+UPDATE gui_category SET category_description='Anwendungen (Applications)' WHERE category_id=2;
+--add anonymous user
+INSERT INTO mb_user (mb_user_id, mb_user_name, mb_user_password, mb_user_owner, mb_user_description, mb_user_login_count, mb_user_email, mb_user_phone, mb_user_department, mb_user_resolution, mb_user_organisation_name, mb_user_position_name, mb_user_phone1, mb_user_facsimile, mb_user_delivery_point, mb_user_city, mb_user_postal_code, mb_user_country, mb_user_online_resource, mb_user_textsize, mb_user_glossar, mb_user_last_login_date, mb_user_digest, mb_user_realname, mb_user_street, mb_user_housenumber, mb_user_reference, mb_user_for_attention_of, mb_user_valid_from, mb_user_valid_to, mb_user_password_ticket, mb_user_firstname, mb_user_lastname, mb_user_academictitle, timestamp_create, timestamp, mb_user_spatial_suggest, mb_user_newsletter, mb_user_allow_survey, mb_user_aldigest) VALUES (${mapbender_guest_user_id}, 'guest', '084e0343a0486ff05530df6c705c8bb4', 1, 'test', 0, 'kontakt at geoportal.rlp.de', NULL, '', 72, '', '', NULL, NULL, NULL, '', NULL, NULL, NULL, 'textsize3', 'ja', '2
 012-01-26', '', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, '2013-07-05 08:09:25.560359', '2015-08-20 10:04:04.952796', 'nein', true, true, NULL);
+INSERT INTO mb_user (mb_user_id, mb_user_name, mb_user_password, mb_user_owner, mb_user_description, mb_user_login_count, mb_user_email, mb_user_phone, mb_user_department, mb_user_resolution, mb_user_organisation_name, mb_user_position_name, mb_user_phone1, mb_user_facsimile, mb_user_delivery_point, mb_user_city, mb_user_postal_code, mb_user_country, mb_user_online_resource, mb_user_textsize, mb_user_glossar, mb_user_last_login_date, mb_user_digest, mb_user_realname, mb_user_street, mb_user_housenumber, mb_user_reference, mb_user_for_attention_of, mb_user_valid_from, mb_user_valid_to, mb_user_password_ticket, mb_user_firstname, mb_user_lastname, mb_user_academictitle, timestamp_create, timestamp, mb_user_spatial_suggest, mb_user_newsletter, mb_user_allow_survey, mb_user_aldigest) VALUES (${mapbender_subadmin_default_user_id}, 'bereichsadmin1', '3ad58afdc417b975256af7a6d3eda7a5', 1, '', 0, 'kontakt at geoportal.rlp.de', NULL, NULL, 72, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NUL
 L, NULL, 'nein', '2017-07-28', '3c345c2af80400e1e4c94ed0a967e713', NULL, NULL, NULL, NULL, NULL, NULL, NULL, '', 'bereichsadmin1', 'bereichsadmin1', '', '2013-07-05 08:09:25.560359', '2017-07-28 10:12:13.926954', 'nein', false, false, '2a32c845b23d82bea4653810f146397b');
+INSERT INTO mb_group VALUES (${mapbender_subadmin_group_id}, 'Bereichsadmin', 1, 'Diensteadministratoren der Behörden', '', NULL, '', '', '', '', '', '', '', '', '', NULL, NULL, '2013-07-05 08:09:25.732456', '2018-05-25 08:57:07.988259', NULL, NULL, NULL, NULL, NULL, NULL, true);
+INSERT INTO mb_group VALUES (${mapbender_guest_group_id}, 'guest', 1, 'Gastgruppe', '', NULL, '', '', '', '', '', '', '', '', '', NULL, NULL, '2013-07-05 08:09:25.732456', '2018-05-25 08:57:07.988259', NULL, NULL, NULL, NULL, NULL, NULL, true);
+INSERT INTO mb_group VALUES (${mapbender_subadmin_default_group_id}, 'testgruppe1', 1, 'testgruppe1', 'testgruppe1', NULL, 'Musterstraße 11', '11111 Musterstadt', 'Musterstadt', 'DE-RP', 'DE', '1111', '1111', 'mustermail at musterdomain.com', 'http://www.geoportal.rlp.de/metadata/GDI-RP_mit_Markenschutz_RGB_70.png', NULL, NULL, '2013-07-05 08:09:25.732456', '2018-05-25 08:57:07.988259', NULL, NULL, NULL, NULL, NULL, NULL, true);
+--guest user into guest group
+INSERT INTO mb_user_mb_group VALUES (${mapbender_guest_user_id}, ${mapbender_guest_group_id}, 1);
+--bereichsadmin1 into guest group
+INSERT INTO mb_user_mb_group VALUES (${mapbender_subadmin_default_user_id}, ${mapbender_guest_group_id}, 1);
+--bereichsadmin1 into Bereichsadmin group
+INSERT INTO mb_user_mb_group VALUES (${mapbender_subadmin_default_user_id}, ${mapbender_subadmin_group_id}, 1);
+--bereichsadmin1 into testgruppe1 group - role primary
+INSERT INTO mb_user_mb_group VALUES (${mapbender_subadmin_default_user_id}, ${mapbender_subadmin_default_group_id}, 2);
+--bereichsadmin1 into testgruppe1 group - role standard
+INSERT INTO mb_user_mb_group VALUES (${mapbender_subadmin_default_user_id}, ${mapbender_subadmin_default_group_id}, 1);
+--root into guest group
+INSERT INTO mb_user_mb_group VALUES (1, ${mapbender_guest_group_id}, 1);
+--guis: Geoportal-RLP, Geoportal-RLP_erwSuche2, Administration_DE, Portal_Admin, Owsproxy_csv - admin_metadata fehlt noch!!!!
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('service_container1', 'service_container1', 'service_container1', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('service_container1_free', 'service_container1_free', 'service_container1_free', 1);
+--guis: Geoportal-RLP, Administration_DE, Owsproxy_csv, admin_metadata, .....
+DELETE FROM gui WHERE gui_id IN ('Geoportal-RLP', 'Owsproxy_csv', 'admin_wms_metadata', 'admin_wfs_metadata', 'admin_wmc_metadata', 'admin_metadata', 'admin_ows_scheduler', 'PortalAdmin_DE', 'Administration_DE', 'Geoportal-RLP_erwSuche2');
+EOF
+# sql for beeing executed after recreating of the guis
+cat << EOF > ${installation_folder}geoportal_database_adoption_2.sql
+INSERT INTO gui_gui_category (fkey_gui_id, fkey_gui_category_id) VALUES ('Geoportal-RLP', 2);
+INSERT INTO gui_gui_category (fkey_gui_id, fkey_gui_category_id) VALUES ('Administration_DE', 2);
+INSERT INTO gui_gui_category (fkey_gui_id, fkey_gui_category_id) VALUES ('PortalAdmin_DE', 2);
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('PortalAdmin_DE', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('Geoportal-RLP', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('Administration_DE', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('Owsproxy_csv', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('Geoportal-RLP_erwSuche2', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_wms_metadata', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_wfs_metadata', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_wmc_metadata', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_metadata', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_ows_scheduler', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('service_container1', ${mapbender_subadmin_default_user_id}, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('service_container1_free', ${mapbender_subadmin_default_user_id}, 'owner');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('Administration_DE', ${mapbender_subadmin_group_id});
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('Owsproxy_csv', ${mapbender_subadmin_group_id});
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_wmc_metadata', ${mapbender_subadmin_group_id});
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_wms_metadata', ${mapbender_subadmin_group_id});
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_wfs_metadata', ${mapbender_subadmin_group_id});
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_ows_scheduler', ${mapbender_subadmin_group_id});
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_metadata', ${mapbender_subadmin_group_id});
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('Geoportal-RLP', ${mapbender_guest_group_id});
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('Geoportal-RLP_erwSuche2', ${mapbender_guest_group_id});
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('service_container1_free', ${mapbender_guest_group_id});
+--alter views to integrate real subadmin and guest user ids
+-- View: groups_for_publishing
+-- DROP VIEW groups_for_publishing;
+CREATE OR REPLACE VIEW groups_for_publishing AS
+ SELECT mb_group.mb_group_id AS fkey_mb_group_id,
+    mb_group.mb_group_id,
+    mb_group.mb_group_name,
+    mb_group.mb_group_owner,
+    mb_group.mb_group_description,
+    mb_group.mb_group_title,
+    mb_group.mb_group_ext_id,
+    mb_group.mb_group_address,
+    mb_group.mb_group_postcode,
+    mb_group.mb_group_city,
+    mb_group.mb_group_stateorprovince,
+    mb_group.mb_group_country,
+    mb_group.mb_group_voicetelephone,
+    mb_group.mb_group_facsimiletelephone,
+    mb_group.mb_group_email,
+    mb_group.mb_group_logo_path,
+    mb_group.mb_group_homepage,
+    mb_group.mb_group_admin_code,
+    mb_group.timestamp_create,
+    mb_group."timestamp",
+    mb_group.mb_group_address_location,
+    mb_group.uuid,
+    mb_group.mb_group_ckan_uuid,
+    mb_group.mb_group_ckan_api_key
+   FROM mb_group
+  WHERE (mb_group.mb_group_id IN ( SELECT DISTINCT f.fkey_mb_group_id
+           FROM mb_user_mb_group f,
+            mb_user_mb_group s
+          WHERE (f.mb_user_mb_group_type = ANY (ARRAY[2, 3])) AND s.fkey_mb_group_id = ${mapbender_subadmin_group_id} AND f.fkey_mb_user_id = s.fkey_mb_user_id));
+ALTER TABLE groups_for_publishing
+  OWNER TO postgres;
+GRANT ALL ON TABLE groups_for_publishing TO postgres;
+GRANT ALL ON TABLE groups_for_publishing TO mapbenderdbuser;
+-- View: registrating_groups
+-- DROP VIEW registrating_groups;
+CREATE OR REPLACE VIEW registrating_groups AS
+ SELECT f.fkey_mb_group_id,
+    f.fkey_mb_user_id
+  WHERE f.mb_user_mb_group_type = 2 AND s.fkey_mb_group_id = ${mapbender_subadmin_group_id} AND f.fkey_mb_user_id = s.fkey_mb_user_id
+  ORDER BY f.fkey_mb_group_id, f.fkey_mb_user_id;
+ALTER TABLE registrating_groups
+GRANT ALL ON TABLE registrating_groups TO postgres;
+GRANT ALL ON TABLE registrating_groups TO mapbenderdbuser;
+-- View: users_for_publishing
+-- DROP VIEW users_for_publishing;
+CREATE OR REPLACE VIEW users_for_publishing AS
+ SELECT DISTINCT f.fkey_mb_user_id,
+    f.fkey_mb_group_id AS primary_group_id
+  ORDER BY f.fkey_mb_user_id;
+ALTER TABLE users_for_publishing
+GRANT ALL ON TABLE users_for_publishing TO postgres;
+GRANT ALL ON TABLE users_for_publishing TO mapbenderdbuser;
+EOF
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}geoportal_database_adoption_1.sql
+# recreate the guis via psql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Geoportal-RLP.sql # -- maybe a problem: too long entry ...
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Owsproxy_csv.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_wms_metadata.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_wfs_metadata.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_wmc_metadata.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_metadata.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_ows_scheduler.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_PortalAdmin_DE.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Administration_DE.sql
+sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Geoportal-RLP_erwSuche2.sql
+sudo -u postgres psql -d mapbender -f ${installation_folder}geoportal_database_adoption_2.sql
+# add privilegs for mapbenderdbuser
+su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'GRANT USAGE ON SCHEMA mapbender TO $mapbender_database_user'"
+su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'GRANT USAGE ON SCHEMA public TO $mapbender_database_user'"
+su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'GRANT SELECT, INSERT, UPDATE, DELETE ON ALL TABLES IN SCHEMA mapbender TO $mapbender_database_user'"
+su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'GRANT SELECT, INSERT, UPDATE, DELETE ON ALL TABLES IN SCHEMA public TO $mapbender_database_user'"
+su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'GRANT SELECT, INSERT, UPDATE, DELETE ON DATABASE $mapbender_database_name TO $mapbender_database_user'"
+fi # end of installation of the mapbender database
+if [ $configure_mapbender = 'true' ]; then
+    echo 'language compiling ... '
+    cd ${installation_folder}mapbender/tools
+    sh ./i18n_update_mo.sh
+    cp conf/mapbender.conf-dist conf/mapbender.conf
+    # create folder to store generated metadata xml documents
+    mkdir ${installation_folder}mapbender/metadata
+    echo -n 'change more permissones ... '
+    # alter owner of folders where webserver should be able to alter data
+    chown -R www-data:www-data ${installation_folder}mapbender/http/tmp/
+    chown -R www-data:www-data ${installation_folder}mapbender/log/
+    chown -R www-data:www-data ${installation_folder}mapbender/http/geoportal/preview/
+    chown -R www-data:www-data ${installation_folder}mapbender/http/geoportal/news/
+    chown -R www-data:www-data ${installation_folder}mapbender/metadata/
+    echo -n 'adopt mapbender.conf ... '
+    # alter connection type to use curl
+    sed -i "s/define(\"CONNECTION\", \"http\");/#define(\"CONNECTION\", \"http\");/g" ${installation_folder}mapbender/conf/mapbender.conf
+    sed -i "s/#define(\"CONNECTION\", \"curl\");/define(\"CONNECTION\", \"curl\");/g" ${installation_folder}mapbender/conf/mapbender.conf
+    # sed -i "s///g" ${installation_folder}mapbender/conf/mapbender.conf
+    if [ $use_proxy = 'true' ]; then
+	    sed -i "s/define(\"CONNECTION_PROXY\", \"\");/define(\"CONNECTION_PROXY\", \"$http_proxy_host\");/g" ${installation_folder}mapbender/conf/mapbender.conf
+	    sed -i "s/define(\"CONNECTION_PROXY\", \"\");/define(\"CONNECTION_PORT\", \"$http_proxy_port\");/g" ${installation_folder}mapbender/conf/mapbender.conf
+    fi
+    sed -i "s/%%DBSERVER%%/localhost/g" ${installation_folder}mapbender/conf/mapbender.conf
+    sed -i "s/%%DBPORT%%/$mapbender_database_port/g" ${installation_folder}mapbender/conf/mapbender.conf
+    sed -i "s/%%DBNAME%%/$mapbender_database_name/g" ${installation_folder}mapbender/conf/mapbender.conf
+    sed -i "s/%%DBOWNER%%/$mapbender_database_user/g" ${installation_folder}mapbender/conf/mapbender.conf
+    sed -i "s/%%DBPASSWORD%%/$mapbender_database_password/g" ${installation_folder}mapbender/conf/mapbender.conf
+    # maybe problematic!:
+    sed -i "s#/data/#$installation_folder#g" ${installation_folder}mapbender/conf/mapbender.conf
+    #special users & groups
+    sed -i "s/#define(\"PUBLIC_USER\", \"\");/#define(\"PUBLIC_USER\", \"${mapbender_guest_user_id}\");/g" ${installation_folder}mapbender/conf/mapbender.conf
+    sed -i "s/#define(\"REGISTRATING_GROUP\",36);/define(\"REGISTRATING_GROUP\",${mapbender_subadmin_group_id});/g" ${installation_folder}mapbender/conf/mapbender.conf
+    sed -i "s/#define(\"PORTAL_ADMIN_USER_ID\",\"1\");/define(\"PORTAL_ADMIN_USER_ID\",\"1\");/g" ${installation_folder}mapbender/conf/mapbender.conf
+    sed -i "s/#define(\"CATALOGUE_MAINTENANCE_USER\",\"1\");/define(\"CATALOGUE_MAINTENANCE_USER\",\"1\");/g" ${installation_folder}mapbender/conf/mapbender.conf
+    # alter group id for subadministrators in monitoring tool - use group_id 21 - this is the subadmin mb_group_id
+cat << EOF > ${installation_folder}mapbender/tools/monitorCapabilities.sh
+. /etc/profile
+cd ${installation_folder}mapbender/tools/
+[ -f /tmp/wmsmonitorlock ] && : || php5 ${installation_folder}mapbender/tools/mod_monitorCapabilities_main.php group:${mapbender_subadmin_group_id} > /dev/null
+EOF
+fi
+# configure and install typo3
+#grep debian mysql maintainer password from /etc/
+if [ $install_typo3_database = 'true' ]; then
+    while IFS='=' read -r col1 col2
+    do
+        if [ "$col1" = "password " ] ; then
+            mysql_debian_password=$(echo "$col2" | awk '{print $1}')
+            break
+        fi
+    done </etc/mysql/debian.cnf
+# echo $mysql_debian_password
+cat << EOF > ${installation_folder}initialize_typo3_database.sql
+CREATE DATABASE typo3;
+DROP USER '${typo3_database_user}'@'localhost';
+CREATE USER '${typo3_database_user}'@'localhost' IDENTIFIED BY '${typo3_database_password}';
+GRANT ALL PRIVILEGES ON typo3.* TO '{typo3_database_user}'@'localhost';
+--GRANT SELECT,INSERT,UPDATE,DELETE,CREATE,DROP,FILE,INDEX,ALTER,CREATE TEMPORARY TABLES,CREATE VIEW,EVENT,TRIGGER,SHOW VIEW,CREATE ROUTINE,ALTER ROUTINE,EXECUTE ON * . * TO '${typo3_database_user}'@'%' IDENTIFIED BY '${typo3_database_password}' WITH MAX_QUERIES_PER_HOUR 0 MAX_CONNECTIONS_PER_HOUR 0 MAX_UPDATES_PER_HOUR 0 MAX_USER_CONNECTIONS 0 ;
+--GRANT ALL PRIVILEGES ON `typo3` . * TO '${typo3_database_user}'@'%';
+FLUSH PRIVILEGES;
+EOF
+# download typo3 default database
+cd /data/
+wget http://www.geoportal.rlp.de/metadata/geoportal_typo3_db.tar.gz
+tar -xzvf geoportal_typo3_db.tar.gz
+# prepare typo3 database
+mysql --user=debian-sys-maint --password=$mysql_debian_password -e "DROP DATABASE typo3;"
+# mysql --user=debian-sys-maint --password=$mysql_debian_password -e "CREATE DATABASE typo3;"
+mysql --user=debian-sys-maint --password=$mysql_debian_password < ${installation_folder}initialize_typo3_database.sql
+# import typo3 database
+mysql --user=debian-sys-maint --password=$mysql_debian_password typo3 < typo3_db.sql
+fi
+#configure files for db connect:
+#/data/portal/fileadmin/function/util.php
+#/data/portal/typo3conf/localconf.php
+if [ $configure_apache = 'true' ]; then
+# create apache configuration for mapbender
+echo -n 'create apache configuration ...'
+cat << EOF > ${installation_folder}geoportal-apache.conf
+<VirtualHost *:80>
+        ServerAdmin $webadmin_email
+        ReWriteEngine On
+        RewriteRule ^/registry/wfs/([\d]+)\/?$ http://127.0.0.1/http_auth/http/index.php?wfs_id=$1 [P,L,QSA,NE]
+        RewriteRule ^/layer/(.*) http://%{SERVER_NAME}/mapbender/php/mod_showMetadata.php?resource=layer&languageCode=de&id=$1
+        RewriteRule ^/wms/(.*) http://%{SERVER_NAME}/mapbender/php/mod_showMetadata.php?resource=wms&languageCode=de&id=$1
+        RewriteRule ^/wmc/(.*) http://%{SERVER_NAME}/mapbender/php/mod_showMetadata.php?resource=wmc&languageCode=de&id=$1
+#       RewriteRule ^/metadata/(.*) http://%{SERVER_NAME}/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=$1
+#       For typo3 installation
+        DocumentRoot ${installation_folder}portal
+        <Directory />
+                Options FollowSymLinks
+                AllowOverride None
+        </Directory>
+        Alias /portal ${installation_folder}portal
+        <Directory  ${installation_folder}portal/>
+                Allow from all
+                Options -Indexes +FollowSymLinks +Includes
+                AllowOverride FileInfo
+        </Directory>
+        ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
+        <Directory "/usr/lib/cgi-bin">
+                Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
+                #SetEnv http_proxy http://[IP}:{PORT}
+                Order allow,deny
+                Allow from all
+        </Directory>
+        ErrorLog /var/log/apache2/error.log
+        # Possible values include: debug, info, notice, warn, error, crit,
+        # alert, emerg.
+        LogLevel error
+        CustomLog /var/log/apache2/access.log combined
+        Alias /mapbender ${installation_folder}mapbender/http
+        <Directory ${installation_folder}mapbender/http/>
+           Options MultiViews
+           Order deny,allow
+           Allow from all
+           #Allow from 127.0.0.0/255.0.0.0 ::1/128
+           # Insert filter
+           SetOutputFilter DEFLATE
+           # Netscape 4.x has some problems...
+           BrowserMatch ^Mozilla/4 gzip-only-text/html
+           # Netscape 4.06-4.08 have some more problems
+           BrowserMatch ^Mozilla/4\.0[678] no-gzip
+           # MSIE masquerades as Netscape, but it is fine
+           # BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
+           # NOTE: Due to a bug in mod_setenvif up to Apache 2.0.48
+           # the above regex won't work. You can use the following
+           # workaround to get the desired effect:
+           BrowserMatch \bMSI[E] !no-gzip !gzip-only-text/html
+           # Don't compress images
+           SetEnvIfNoCase Request_URI \
+           \.(?:gif|jpe?g|png)$ no-gzip dont-vary
+           # Make sure proxies don't deliver the wrong content
+           Header append Vary User-Agent env=!dont-vary
+        </Directory>
+        #Part for proxy function
+        ProxyPreserveHost On
+        #ReWriteEngine On
+        SetEnv force-proxy-request-1.0 1
+        SetEnv proxy-nokeepalive 1
+        ProxyTimeout 50
+        #NoProxy localhost
+        #ProxyBadHeader Ignore
+        ProxyMaxForwards 3
+        #RewriteLog "/tmp/rewrite.log"
+        #RewriteLogLevel 3
+        Alias /owsproxy ${installation_folder}mapbender/owsproxy
+        <Directory ${installation_folder}mapbender/owsproxy/>
+                Options +FollowSymLinks
+                ReWriteEngine On
+                RewriteBase /owsproxy
+                RewriteRule  ^([\w\d]+)\/([\w\d]+)\/?$ http://127.0.0.1/owsproxy/http/index.php?sid=$1\&wms=$2\& [P,L,QSA,NE]
+                Options +Indexes
+                Allow from all
+        </Directory>
+        Alias /tools ${installation_folder}mapbender/tools
+        <Directory ${installation_folder}mapbender/tools/>
+                AuthType Digest
+                AuthName "mb_tools"
+                AuthDigestProvider file
+                AuthUserFile ${installation_folder}access/.mb_tools
+                Require valid-user
+                order deny,allow
+                deny from all
+                Options +Indexes
+                Allow from all
+        </Directory>
+        Alias /http_auth ${installation_folder}mapbender/http_auth
+        <Directory ${installation_folder}mapbender/http_auth/>
+                Options +FollowSymLinks +Indexes
+                ReWriteEngine On
+                RewriteBase /http_auth
+                RewriteRule  ^([\w\d]+)\/?$ http://127.0.0.1/http_auth/http/index.php?layer_id=$1 [P,L,QSA,NE]
+                Order allow,deny
+                Allow from all
+        </Directory>
+</VirtualHost>
+EOF
+# copy conf to apache directory and configure apache24+
+cp ${installation_folder}geoportal-apache.conf /etc/apache2/sites-available/
+# activate modules
+a2enmod rewrite
+a2enmod cgi
+# a2enmod serv-cgi-bin
+a2enmod proxy_http
+a2enmod headers
+a2enmod auth_digest
+# to be compatible to older apache2.2 directives:
+a2enmod access_compat
+# alter central apache2 conf to allow access to /
+cp /etc/apache2/apache2.conf /etc/apache2/apache2.conf_backup_geoportal
+# replace only the first occurence of Require all denied - this is the entry for /
+sed -i "0,/Require all denied/{s/Require all denied/Require all granted/}" /etc/apache2/apache2.conf
+a2ensite geoportal-apache
+a2dissite 000-default
+service apache2 restart
+fi #end of apache configuration
+if [ $configure_cronjobs = 'true' ]; then
+mkdir ${installation_folder}cronjobs/
+# create script to call metadata via localhost
+cat << EOF > ${installation_folder}cronjobs/generateMetadata.sh
+#!/bin/bash
+curl http://localhost/mapbender/php/mod_exportISOMetadata.php?Type=ALL > /tmp/metadataGeneration.log
+EOF
+# install cronjobs for root account
+# https://stackoverflow.com/questions/878600/how-to-create-a-cron-job-using-bash-automatically-without-the-interactive-editor
+# 1. delete old monitoring xmls
+croncmd1="find ${installation_folder}mapbender/tools/tmp -type f -print | xargs rm -f"
+cronjob1="25 1,3,5,7,9,11,13,15,17,19,21,23 * * * $croncmd1"
+( crontab -l | grep -v -F "$croncmd1" ; echo "$cronjob1" ) | crontab -
+# 2. delete mapbender tmp files
+croncmd2="find ${installation_folder}mapbender/http/tmp  -name '*.*' -mmin +40 -type f | xargs rm -f"
+cronjob2="55 * * * * $croncmd2"
+( crontab -l | grep -v -F "$croncmd2" ; echo "$cronjob2" ) | crontab -
+# 3. delete mapbender tmp wmc files
+croncmd3="find ${installation_folder}mapbender/http/tmp/wmc  -name '*' -mmin +40 -type f | xargs rm -f"
+cronjob3="55 * * * * $croncmd3"
+( crontab -l | grep -v -F "$croncmd3" ; echo "$cronjob3" ) | crontab -
+# 4. delete mapbender log files
+croncmd4="find ${installation_folder}mapbender/log  -name '*.log' -mmin +40 -type f | xargs rm -f"
+cronjob4="5 * * * * $croncmd4"
+( crontab -l | grep -v -F "$croncmd4" ; echo "$cronjob4" ) | crontab -
+# 5. generate metadata xml files
+croncmd5="sh ${installation_folder}cronjobs/generateMetadata.sh"
+cronjob5="45 23 * * * $croncmd5"
+( crontab -l | grep -v -F "$croncmd5" ; echo "$cronjob5" ) | crontab -
+# 6. run ows scheduler - to update ows capabilities
+croncmd6="php5 ${installation_folder}mapbender/tools/mod_runScheduler.php"
+cronjob6="57 23 * * * $croncmd6"
+( crontab -l | grep -v -F "$croncmd6" ; echo "$cronjob6" ) | crontab -
+# 7. delete typo3 tmp files
+croncmd7="find ${installation_folder}portal/typo3conf/ext/q4u_search/pi1/temp -name "*.typo3.xml"  -cmin +60 | xargs rm -f"
+cronjob7="55 * * * * $croncmd7"
+( crontab -l | grep -v -F "$croncmd7" ; echo "$cronjob7" ) | crontab -
+# 8. materialize wms search view
+croncmd8="su - postgres -c \"psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/materialize_wms_view.sql\""
+cronjob8="0,30 * * * * $croncmd8"
+( crontab -l | grep -v -F "$croncmd8" ; echo "$cronjob8" ) | crontab -
+# 9. materialize dataset search view
+croncmd9="su - postgres -c \"psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/materialize_dataset_view.sql\""
+cronjob9="1,31 * * * * $croncmd9"
+( crontab -l | grep -v -F "$croncmd9" ; echo "$cronjob9" ) | crontab -
+# 10. materialize wfs search view
+croncmd10="su - postgres -c \"psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/materialize_wfs_view.sql\""
+cronjob10="2,32 * * * * $croncmd10"
+( crontab -l | grep -v -F "$croncmd10" ; echo "$cronjob10" ) | crontab -
+# 11. monitor capabilities (wms/wfs)
+croncmd11="sh ${installation_folder}mapbender/tools/monitorCapabilities.sh"
+cronjob11="7 2,4,6,8,10,12,14,16,18,20,22 * * * $croncmd11"
+( crontab -l | grep -v -F "$croncmd11" ; echo "$cronjob11" ) | crontab -
+##TODO: send mails
+fi
+# create script to uninstall all files and clear databases
+echo -n 'create shell script to clean folders and databases'
+cat << EOF > ${installation_folder}cleanup_geoportal_installation.sh
+#!/bin/bash
+rm -R ${installation_folder}mapbender
+rm -R ${installation_folder}portal
+rm -R ${installation_folder}svn
+rm ${installation_folder}geoportal_database_adoption_1.sql
+rm ${installation_folder}geoportal_database_adoption_2.sql
+rm ${installation_folder}geoportal-apache.conf
+rm ${installation_folder}install.log
+rm ${installation_folder}initialize_typo3_database.sql
+    if [ -e "/etc/apt/apt.conf_backup_geoportal" ]; then
+        echo "Backup version of file exists - overwrite it with the original one"
+        cp /etc/apt/apt.conf_backup_geoportal /etc/apt/apt.conf
+        #echo "File does not exist"
+        #touch /etc/apt/apt.conf
+        #echo "Acquire::http::Proxy \"http://$http_proxy_host:$http_proxy_port\";" > /etc/apt/apt.conf
+    fi
+fi
+if [ -e "/etc/apache2/apache2.conf_backup_geoportal" ]; then
+        cp /etc/apache2/apache2.conf_backup_geoportal /etc/apache2/apache2.conf
+fi
+rm *.tar.gz*
+rm *.sql
+rm -R ${installation_folder}cronjobs
+rm ${installation_folder}cleanup_geoportal_installation.sh
+#restore old pg_hba.conf of main - default cluster
+cp /etc/postgresql/9.4/main/pg_hba.conf_backup /etc/postgresql/9.4/main/pg_hba.conf
+cp /etc/subversion/servers_backup_geoportal /etc/subversion/servers
+EOF
+chmod +x ${installation_folder}cleanup_geoportal_installation.sh
+# TODO 's:
+# Integrate default wms in default gui - register and authorize them
+# Initially monitor ows
+# Initially create materialized search views - see cronjobs
+# Alter other configuration files
+# checkout install specific files and database content
+date
More information about the Mapbender_commits mailing list
