[Mapbender-commits] r9976 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Oct 11 09:04:00 PDT 2018
Author: armin11
Date: 2018-10-11 09:04:00 -0700 (Thu, 11 Oct 2018)
New Revision: 9976
   trunk/mapbender/resources/db/install_geoportal_mb28.sh
Fix for typo3 mysql db installation
Modified: trunk/mapbender/resources/db/install_geoportal_mb28.sh
--- trunk/mapbender/resources/db/install_geoportal_mb28.sh	2018-10-11 15:35:01 UTC (rev 9975)
+++ trunk/mapbender/resources/db/install_geoportal_mb28.sh	2018-10-11 16:04:00 UTC (rev 9976)
@@ -33,8 +33,8 @@
 typo3_database_name="typo3"
 # typo3_database_port="xxxx" # actually the default port
-typo3_database_user="typo3dbuser"
-typo3_database_password="typo3dbpassword"
+typo3_database_user="typo3"
+typo3_database_password="typo3password"
@@ -246,21 +246,21 @@
 sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/pgsql_schema_2.5.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.6.2_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.1_to_2.7.2_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/pgsql_data_2.5.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/pgsql_serial_set_sequences_2.5.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.6.2_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.1_to_2.7.2_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
 echo 'adopting mapbenders default database to geoportal default options  ... '
@@ -430,25 +430,25 @@
 GRANT ALL ON TABLE users_for_publishing TO mapbenderdbuser;
 EOF
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}geoportal_database_adoption_1.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}geoportal_database_adoption_1.sql
 # recreate the guis via psql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Geoportal-RLP.sql # -- maybe a problem: too long entry ...
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Geoportal-RLP.sql # -- maybe a problem: too long entry ...
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Owsproxy_csv.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_wms_metadata.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_wfs_metadata.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_wmc_metadata.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_metadata.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_ows_scheduler.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_PortalAdmin_DE.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Administration_DE.sql
-sudo -u postgres psql -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Geoportal-RLP_erwSuche2.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Owsproxy_csv.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_wms_metadata.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_wfs_metadata.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_wmc_metadata.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_metadata.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_admin_ows_scheduler.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_PortalAdmin_DE.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Administration_DE.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/gui_Geoportal-RLP_erwSuche2.sql
-sudo -u postgres psql -d mapbender -f ${installation_folder}geoportal_database_adoption_2.sql
+sudo -u postgres psql -q -d mapbender -f ${installation_folder}geoportal_database_adoption_2.sql
 # add privilegs for mapbenderdbuser
 su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'GRANT USAGE ON SCHEMA mapbender TO $mapbender_database_user'"
@@ -530,11 +530,11 @@
 # echo $mysql_debian_password
 cat << EOF > ${installation_folder}initialize_typo3_database.sql
 CREATE DATABASE typo3;
-DROP USER '${typo3_database_user}'@'localhost';
+-- DROP USER '${typo3_database_user}'@'localhost';
 CREATE USER '${typo3_database_user}'@'localhost' IDENTIFIED BY '${typo3_database_password}';
 GRANT ALL PRIVILEGES ON typo3.* TO '${typo3_database_user}'@'localhost';
---GRANT SELECT,INSERT,UPDATE,DELETE,CREATE,DROP,FILE,INDEX,ALTER,CREATE TEMPORARY TABLES,CREATE VIEW,EVENT,TRIGGER,SHOW VIEW,CREATE ROUTINE,ALTER ROUTINE,EXECUTE ON * . * TO '${typo3_database_user}'@'%' IDENTIFIED BY '${typo3_database_password}' WITH MAX_QUERIES_PER_HOUR 0 MAX_CONNECTIONS_PER_HOUR 0 MAX_UPDATES_PER_HOUR 0 MAX_USER_CONNECTIONS 0 ;
---GRANT ALL PRIVILEGES ON `typo3` . * TO '${typo3_database_user}'@'%';
+GRANT SELECT,INSERT,UPDATE,DELETE,CREATE,DROP,FILE,INDEX,ALTER,CREATE TEMPORARY TABLES,CREATE VIEW,EVENT,TRIGGER,SHOW VIEW,CREATE ROUTINE,ALTER ROUTINE,EXECUTE ON * . * TO '${typo3_database_user}'@'%' IDENTIFIED BY '${typo3_database_password}' WITH MAX_QUERIES_PER_HOUR 0 MAX_CONNECTIONS_PER_HOUR 0 MAX_UPDATES_PER_HOUR 0 MAX_USER_CONNECTIONS 0 ;
+-- GRANT ALL PRIVILEGES ON `typo3` . * TO '${typo3_database_user}'@'%';
 FLUSH PRIVILEGES;
 EOF
More information about the Mapbender_commits mailing list
