[Mapbender-commits] r9983 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Oct 22 08:26:53 PDT 2018
Author: armin11
Date: 2018-10-22 08:26:53 -0700 (Mon, 22 Oct 2018)
New Revision: 9983
   trunk/mapbender/resources/db/install_geoportal_mb28.sh
Fix for wrong proxy port definition
Modified: trunk/mapbender/resources/db/install_geoportal_mb28.sh
--- trunk/mapbender/resources/db/install_geoportal_mb28.sh	2018-10-22 15:08:42 UTC (rev 9982)
+++ trunk/mapbender/resources/db/install_geoportal_mb28.sh	2018-10-22 15:26:53 UTC (rev 9983)
@@ -540,7 +540,7 @@
     # sed -i "s///g" ${installation_folder}mapbender/conf/mapbender.conf
     if [ $use_proxy = 'true' ]; then
 	    sed -i "s/define(\"CONNECTION_PROXY\", \"\");/define(\"CONNECTION_PROXY\", \"$http_proxy_host\");/g" ${installation_folder}mapbender/conf/mapbender.conf
-	    sed -i "s/define(\"CONNECTION_PROXY\", \"\");/define(\"CONNECTION_PORT\", \"$http_proxy_port\");/g" ${installation_folder}mapbender/conf/mapbender.conf
+	    sed -i "s/define(\"CONNECTION_PORT\", \"\");/define(\"CONNECTION_PORT\", \"$http_proxy_port\");/g" ${installation_folder}mapbender/conf/mapbender.conf
 	    sed -i "s/define(\"NOT_PROXY_HOSTS\", \"<ip>,<ip>,<ip>\");/define(\"NOT_PROXY_HOSTS\", \"localhost,127.0.0.1\");/g" ${installation_folder}mapbender/conf/mapbender.conf
     fi
More information about the Mapbender_commits mailing list
