[Mapbender-commits] r9986 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Oct 29 08:36:38 PDT 2018
Author: armin11
Date: 2018-10-29 08:36:38 -0700 (Mon, 29 Oct 2018)
New Revision: 9986
   trunk/mapbender/resources/db/install_geoportal_mb28.sh
Add backend authentication and some other things
Modified: trunk/mapbender/resources/db/install_geoportal_mb28.sh
--- trunk/mapbender/resources/db/install_geoportal_mb28.sh	2018-10-29 11:02:21 UTC (rev 9985)
+++ trunk/mapbender/resources/db/install_geoportal_mb28.sh	2018-10-29 15:36:38 UTC (rev 9986)
@@ -20,7 +20,7 @@
 use_ssl="false"
-domain_name="www.geoportal.test.de"
+domain_name="localhost:8083"
 not_proxy_hosts="localhost,127.0.0.1"
@@ -31,6 +31,14 @@
 mapbender_subadmin_default_user_id="3"
 mapbender_subadmin_default_group_id="23"
+# backend authentication
+typo3backend_user="typo3"
+typo3backend_password="typo3_password"
+phppgadmin_user="postgresadmin"
+phppgadmin_password="postgresadmin_password"
 installation_folder="/data/"
@@ -37,11 +45,15 @@
+bbox_wgs84="6.05,48.9,8.6,50.96"
 # default services
 wms_1_url="'http://geo4.service24.rlp.de/wms/dop_basis.fcgi?REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS'"
 wms_2_url="'http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv?map=/data/umn/geoportal/relief_rp/rlp_relief.map&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS'"
 wms_3_url="'http://geo5.service24.rlp.de/wms/karte_rp.fcgi?REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS'"
+# demo wms
+wms_4_url="'https://gis.mffjiv.rlp.de/cgi-bin/mapserv?map=/data/mapserver/mapfiles/institutions_0601.map&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS'"
 ##################### Geoportal-RLP
 wms_1_register_cmd="/usr/bin/php -f ${installation_folder}mapbender/tools/registerOwsCli.php userId=1 guiId='Geoportal-RLP' serviceType='wms' serviceAccessUrl=$wms_1_url"
@@ -51,6 +63,8 @@
 wms_4_register_cmd="/usr/bin/php -f ${installation_folder}mapbender/tools/registerOwsCli.php userId=1 guiId='Geoportal-RLP_erwSuche2' serviceType='wms' serviceAccessUrl=$wms_1_url"
 wms_5_register_cmd="/usr/bin/php -f ${installation_folder}mapbender/tools/registerOwsCli.php userId=1 guiId='Geoportal-RLP_erwSuche2' serviceType='wms' serviceAccessUrl=$wms_2_url"
+##################### demo service -
+wms_6_register_cmd="/usr/bin/php -f ${installation_folder}mapbender/tools/registerOwsCli.php userId=3 guiId='service_container1_free' serviceType='wms' serviceAccessUrl=$wms_4_url"
 typo3_database_name="typo3"
 # typo3_database_port="xxxx" # actually the default port
@@ -59,13 +73,13 @@
-use_proxy="false"
+use_proxy="true"
-http_proxy_host="proxyip"
-http_proxy_port="proxyport"
+http_proxy_host="proxyip" # TODO: adopt!!!
+http_proxy_port="proxyport" # TODO: adopt!!!
-https_proxy_host="proxyip"
-https_proxy_port="proxyport"
+https_proxy_host="proxyip" # TODO: adopt!!!
+https_proxy_port="proxyport" # TODO: adopt!!!
 # what should be done
@@ -87,8 +101,11 @@
 configure_cronjobs="true"
+# other svn to checkout - installation specific
+checkout_custom_svn="true"
+custom_svn_url="http://www.gdi-rp-dienste.rlp.de/svn/de-rp-landau/data"
 # set some environment variables
 if [ $use_proxy = 'true' ]; then
@@ -110,6 +127,11 @@
 	echo "Acquire::http::Proxy \"http://$http_proxy_host:$http_proxy_port\";" > /etc/apt/apt.conf
     fi
     # first line should be: Acquire::http::Proxy "http://$http_proxy_host:$http_proxy_port";
+    # for subversion alter /etc/subversion/servers - alter following lines
+    # # http-proxy-host = defaultproxy.whatever.com
+    # sed -i "s/# http-proxy-host = defaultproxy.whatever.com/http-proxy-host = $http_proxy_host/g" /etc/subversion/servers
+    # sed -i "s/# http-proxy-port = 7000/http-proxy-port = $http_proxy_port/g" /etc/subversion/servers
+    # # http-proxy-port = 7000
 fi
 if [ $install_system_packages = 'true' ]; then
@@ -123,7 +145,6 @@
 # after install - 1.9GB!!!
@@ -155,7 +176,26 @@
 if [ $checkout_mapbender_svn = 'true' ]; then
     svn co https://svn.osgeo.org/mapbender/trunk/mapbender
 fi
+if  [ $checkout_custom_svn = 'true' ]; then
+	svn co $custom_svn_url
+fi
+# adopt configuration files and copy them to right folder - if exists
+# mapbender
+#cp /data/mapbender.conf /data/mapbender/conf/
+#cp /data/geoportal.conf /data/mapbender/conf/
+#cp /data/extents_geoportal_rlp.map /data/mapbender/tools/wms_extent/extents.map
+#cp /data/extent_service_geoportal_rlp.conf /data/mapbender/tools/wms_extent/extent_service.conf
+# typo3
 # compress and create mapbender
 if [ $install_mapbender_source = 'true' ]; then
@@ -184,6 +224,33 @@
     echo 'done.'
 fi
+# compress and create custom conf files
+    cd ${installation_folder}svn/
+    tar -czf custom.tar.gz data/
+    mv custom.tar.gz /tmp/
+    mv /tmp/custom.tar.gz .
+    tar -xzf custom.tar.gz
+    cd ${installation_folder}data/conf/
+    rm -rf $(find . -type d -name .svn)
+    cd ${installation_folder}data/portal
+    cd ${installation_folder}data/mapbender/
+    cp -r -a ${installation_folder}data/conf ${installation_folder}
+    cp -r -a ${installation_folder}data/portal ${installation_folder}
+    cp -r -a ${installation_folder}data/mapbender ${installation_folder}
+    rm -R ${installation_folder}data/
+    #svn info $custom_svn_url"/conf" | grep Revision | grep -Eo '[0-9]{1,}' > ${installation_folder}conf/lastinstalled
+    rm custom.tar.gz
+    echo 'done.'
+fi
 # cleanup .svn relicts
 echo -n 'delete .svn files ... '
@@ -378,7 +445,9 @@
 INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_wfs_metadata', ${mapbender_subadmin_group_id});
 INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_ows_scheduler', ${mapbender_subadmin_group_id});
 INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_metadata', ${mapbender_subadmin_group_id});
+#INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin1', ${mapbender_subadmin_group_id});
 INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('Geoportal-RLP', ${mapbender_guest_group_id});
 INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('Geoportal-RLP_erwSuche2', ${mapbender_guest_group_id});
@@ -488,7 +557,6 @@
 su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'GRANT ALL PRIVILEGES ON DATABASE $mapbender_database_name TO $mapbender_database_user'"
 su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'GRANT SELECT, INSERT, UPDATE, DELETE ON DATABASE $mapbender_database_name TO $mapbender_database_user'"
 su - postgres -c "psql -q -p $mapbender_database_port -d $mapbender_database_name -c 'GRANT USAGE, SELECT ON ALL SEQUENCES IN SCHEMA mapbender TO $mapbender_database_user'"
 # add precise coordinate transformation to proj and postgis extension
@@ -585,9 +653,69 @@
     ##################### Geoportal-RLP_erwSuche2
 eval $wms_4_register_cmd
 eval $wms_5_register_cmd
+    ##################### demo service
+eval $wms_6_register_cmd
 fi
+    # override information in custom conf files
+    # mapbender.conf
+    echo -n 'adopt mapbender.conf ... '
+    # alter connection type to use curl
+    sed -i "s/define(\"CONNECTION\", \"http\");/#define(\"CONNECTION\", \"http\");/g" ${installation_folder}conf/mapbender.conf
+    sed -i "s/#define(\"CONNECTION\", \"curl\");/define(\"CONNECTION\", \"curl\");/g" ${installation_folder}conf/mapbender.conf
+    # define proxy settings
+    # sed -i "s///g" ${installation_folder}mapbender/conf/mapbender.conf
+    if [ $use_proxy = 'true' ]; then
+	    sed -i "s/define(\"CONNECTION_PROXY\", \"\");/define(\"CONNECTION_PROXY\", \"$http_proxy_host\");/g" ${installation_folder}conf/mapbender.conf
+	    sed -i "s/define(\"CONNECTION_PORT\", \"\");/define(\"CONNECTION_PORT\", \"$http_proxy_port\");/g" ${installation_folder}conf/mapbender.conf
+	    sed -i "s/define(\"NOT_PROXY_HOSTS\", \"<ip>,<ip>,<ip>\");/define(\"NOT_PROXY_HOSTS\", \"localhost,127.0.0.1\");/g" ${installation_folder}conf/mapbender.conf
+    fi
+    # set database connection
+    sed -i "s/%%DBSERVER%%/localhost/g" ${installation_folder}conf/mapbender.conf
+    sed -i "s/%%DBPORT%%/$mapbender_database_port/g" ${installation_folder}conf/mapbender.conf
+    sed -i "s/%%DBNAME%%/$mapbender_database_name/g" ${installation_folder}conf/mapbender.conf
+    sed -i "s/%%DBOWNER%%/$mapbender_database_user/g" ${installation_folder}conf/mapbender.conf
+    sed -i "s/%%DBPASSWORD%%/$mapbender_database_password/g" ${installation_folder}conf/mapbender.conf
+    sed -i "s#%%INSTALLATIONFOLDER%%#${installation_folder}#g" ${installation_folder}conf/mapbender.conf
+    sed -i "s/%%DOMAINNAME%%/$domain_name/g" ${installation_folder}conf/mapbender.conf
+    sed -i "s/%%WEBADMINMAIL%%/$webadmin_email/g" ${installation_folder}conf/mapbender.conf
+    # special users & groups%%INSTALLATIONFOLDER%%
+    sed -i "s/%%PUBLICUSERID%%/$mapbender_guest_user_id/g" ${installation_folder}conf/mapbender.conf
+    sed -i "s/%%PORTALADMINUSERID%%/1/g" ${installation_folder}conf/mapbender.conf
+    sed -i "s/%%ANONYMOUSUSER%%/$mapbender_guest_user_id/g" ${installation_folder}conf/mapbender.conf
+    sed -i "s/%%ANONYMOUSGROUP%%/$mapbender_guest_group_id/g" ${installation_folder}conf/mapbender.conf
+    sed -i "s/%%REGISTRATINGGROUP%%/$mapbender_subadmin_group_id/g" ${installation_folder}conf/mapbender.conf
+    #sed -i "s/%%INSTALLATIONFOLDER%%/$installation_folder/g" ${installation_folder}conf/mapbender.conf
+    # copy conf files to right places
+    cp ${installation_folder}conf/mapbender.conf ${installation_folder}mapbender/conf/
+    # alter other conf files
+    sed -i "s#%%INSTALLATIONFOLDER%%#${installation_folder}#g" ${installation_folder}conf/geoportal.conf
+    # copy conf file to right places
+    cp ${installation_folder}conf/geoportal.conf ${installation_folder}mapbender/conf/
+    # mapfile for metadata wms
+    sed -i "s#%%INSTALLATIONFOLDER%%#${installation_folder}#g" ${installation_folder}conf/extents_geoportal_rlp.map
+    sed -i "s/dbname=geoportal /dbname=$mapbender_database_name /g" ${installation_folder}conf/extents_geoportal_rlp.map
+    sed -i "s/user=postgres /user=$mapbender_database_user password=$mapbender_database_password /g" ${installation_folder}conf/extents_geoportal_rlp.map
+    sed -i "s/port=5436 /port=$mapbender_database_port /g" ${installation_folder}conf/extents_geoportal_rlp.map
+    #sed -i "s/%%BBOXWGS84%%/$bbox_wgs84/g" ${installation_folder}conf/extents_geoportal_rlp.map
+    cp ${installation_folder}conf/extents_geoportal_rlp.map ${installation_folder}mapbender/tools/wms_extent/extents.map
+    # conf file for invocation of metadata wms
+    sed -i "s#%%INSTALLATIONFOLDER%%#${installation_folder}#g" ${installation_folder}conf/extent_service_geoportal_rlp.conf
+    sed -i "s/%%BBOXWGS84%%/$bbox_wgs84/g" ${installation_folder}conf/extent_service_geoportal_rlp.conf
+    cp ${installation_folder}conf/extent_service_geoportal_rlp.conf ${installation_folder}mapbender/tools/wms_extent/extent_service.conf
+    #typo3 configuration files
+fi
 # configure and install typo3
@@ -778,11 +906,79 @@
+# configure phppgadmin
+echo -n 'adopt phppgadmin default apache24 configuration'
+cp /etc/apache2/conf-available/phppgadmin.conf /etc/apache2/conf-available/phppgadmin.conf_backup_geoportal
+cat << EOF > /etc/apache2/conf-available/phppgadmin.conf
+Alias /phppgadmin /usr/share/phppgadmin
+<Directory /usr/share/phppgadmin>
+DirectoryIndex index.php
+AllowOverride None
+# Only allow connections from localhost:
+AuthType Digest
+AuthName "phppgadmin"
+AuthDigestProvider file
+AuthUserFile ${installation_folder}access/.phppgadmin
+Require valid-user
+<IfModule mod_php5.c>
+  php_flag magic_quotes_gpc Off
+  php_flag track_vars On
+  #php_value include_path .
+</IfModule>
+<IfModule !mod_php5.c>
+  <IfModule mod_actions.c>
+    <IfModule mod_cgi.c>
+      AddType application/x-httpd-php .php
+      Action application/x-httpd-php /cgi-bin/php
+    </IfModule>
+    <IfModule mod_cgid.c>
+    </IfModule>
+  </IfModule>
+</IfModule>
+</Directory>
+EOF
+# configure typo3backend
+echo -n 'adopt typo3backend configuration'
+cat << EOF > /etc/apache2/conf-available/typo3backend.conf
+<Directory ${installation_folder}portal/typo3>
+<Files index.php>
+  Order allow,deny
+  Allow from all
+  AuthType Digest
+  AuthName "typo3backend"
+  AuthDigestProvider file
+  AuthUserFile ${installation_folder}access/.typo3backend
+  Require valid-user
+</Files>
+</Directory>
+EOF
+# activate apache conf and reload
 a2ensite geoportal-apache
 a2dissite 000-default
+a2enconf typo3backend
 service apache2 restart
 fi #end of apache configuration
+# add privileges on search tables to mapbender database user from installation
+echo "GRANT ALL ON TABLE wms_search_table TO mapbenderdbuser;" >> ${installation_folder}mapbender/resources/db/materialize_wms_view.sql
+echo "GRANT ALL ON TABLE wfs_search_table TO mapbenderdbuser;" >> ${installation_folder}mapbender/resources/db/materialize_wfs_view.sql
+echo "GRANT ALL ON TABLE dataset_search_table TO mapbenderdbuser;" >> ${installation_folder}mapbender/resources/db/materialize_dataset_view.sql
 if [ $configure_cronjobs = 'true' ]; then
@@ -859,6 +1055,18 @@
 fi
+# initially monitor registrated services and add them to catalogue (materialize search tables)
+eval $croncmd11
+eval $croncmd8
+eval $croncmd9
+eval $croncmd10
+# things after cli
+chown -R www-data:www-data ${installation_folder}mapbender/log/
 # create script to uninstall all files and clear databases
 echo -n 'create shell script to clean folders and databases'
@@ -868,6 +1076,7 @@
 rm -R ${installation_folder}mapbender
 rm -R ${installation_folder}portal
 rm -R ${installation_folder}svn
+rm -R ${installation_folder}conf
 rm ${installation_folder}geoportal_database_adoption_1.sql
 rm ${installation_folder}geoportal_database_adoption_2.sql
@@ -888,6 +1097,10 @@
         echo "Backup version of file exists - overwrite it with the original one"
         cp /etc/apache2/apache2.conf_backup_geoportal /etc/apache2/apache2.conf
 fi
+if [ -e "/etc/apache2/phppgadmin.conf_backup_geoportal" ]; then
+        echo "Backup version of file exists - overwrite it with the original one"
+        cp /etc/apache2/conf-available/phppgadmin.conf_backup_geoportal /etc/apache2/conf-available/phppgadmin.conf
+fi
 rm *.tar.gz*
 rm *.sql
 rm -R ${installation_folder}cronjobs
@@ -905,21 +1118,24 @@
 # TODO 's:
-# Integrate default wms in default gui - register and authorize them
+# Alter other configuration files
-# Initially monitor ows
+# checkout install specific files and database content
-# Initially create materialized search views - see cronjobs
+# after installation create authentication files for backends
+phppgadmin_realm="phppgadmin"
+digest_phppgadmin="$( printf "%s:%s:%s" "$phppgadmin_user" "$phppgadmin_realm" "$phppgadmin_password" |
+           md5sum | awk '{print $1}' )"
+printf "%s:%s:%s\n" "$phppgadmin_user" "$phppgadmin_realm" "$digest_phppgadmin" >> ${installation_folder}"access/.phppgadmin"
+typo3backend_realm="typo3backend"
+digest_typo3backend="$( printf "%s:%s:%s" "$typo3backend_user" "$typo3backend_realm" "$typo3backend_password" |
+printf "%s:%s:%s\n" "$typo3backend_user" "$typo3backend_realm" "$digest_typo3backend" >> ${installation_folder}"access/.typo3backend"
-# Alter other configuration files
-# checkout install specific files and database content
 date
More information about the Mapbender_commits mailing list
