[Mapbender-commits] r10111 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Apr 18 07:44:40 PDT 2019
Author: armin11
Date: 2019-04-18 07:44:40 -0700 (Thu, 18 Apr 2019)
New Revision: 10111
   trunk/mapbender/http/classes/class_kml_ows.php
   trunk/mapbender/http/classes/class_kml_parser_ows.php
   trunk/mapbender/http/classes/class_kml_point.php
   trunk/mapbender/http/php/mod_GetPublishedData.php
Some enhancement for digitized kml export from current session
Modified: trunk/mapbender/http/classes/class_kml_ows.php
--- trunk/mapbender/http/classes/class_kml_ows.php	2019-04-18 11:21:01 UTC (rev 10110)
+++ trunk/mapbender/http/classes/class_kml_ows.php	2019-04-18 14:44:40 UTC (rev 10111)
@@ -586,11 +586,9 @@
 	public function parseGeoJSON ($geoJSON) {
 		$this->kml = "";
 		if (!$this->storeInDb()) {
 			return false;
 		$parser = new KmlOwsParser();
 		$parser->parseGeoJSON($geoJSON, $this->id);
 		$e = new mb_notice("parsing finished...#placemarks: " . count($this->placemarkArray) . " (" . count($parser->placemarkArray) . ")");
Modified: trunk/mapbender/http/classes/class_kml_parser_ows.php
--- trunk/mapbender/http/classes/class_kml_parser_ows.php	2019-04-18 11:21:01 UTC (rev 10110)
+++ trunk/mapbender/http/classes/class_kml_parser_ows.php	2019-04-18 14:44:40 UTC (rev 10111)
@@ -45,7 +45,7 @@
 			if ($geometryFromGeoJSON->crs->type == "EPSG" && $geometryFromGeoJSON->crs->properties->code) {
 				$epsg = $geometryFromGeoJSON->crs->properties->code;
-			// create Placemarks
+			// create Placemarks for each feature object
 			for ($i = 0; $i < count($geometryFromGeoJSON->features); $i++) {
 				$e = new mb_notice("parsing plm #" . $i . "...length of placemarkArray: " . count($this->placemarkArray));
 				$feature = $geometryFromGeoJSON->features[$i];
@@ -54,7 +54,7 @@
 						$epsg = $feature->geometry->crs->properties->code;
 					if (!$epsg) {
-						$e = new mb_exception("EPSG is not set defaults to 4326!");
+						$e = new mb_notice("EPSG is not set - defaults to 4326!");
 						//$currentGeometry = false;
 						$epsg = "4326";
@@ -151,6 +151,7 @@
+				unset($epsg); //used for each feature!
 		return true;
Modified: trunk/mapbender/http/classes/class_kml_point.php
--- trunk/mapbender/http/classes/class_kml_point.php	2019-04-18 11:21:01 UTC (rev 10110)
+++ trunk/mapbender/http/classes/class_kml_point.php	2019-04-18 14:44:40 UTC (rev 10111)
@@ -36,7 +36,6 @@
 	public function __construct ($geometryString, $epsg) {
 		//TODO: parameter validation and exception handling
 		// KML 2.2
 		if (preg_match("/,/", $geometryString)) {
 			$aPoint = explode(",", $geometryString);
Modified: trunk/mapbender/http/php/mod_GetPublishedData.php
--- trunk/mapbender/http/php/mod_GetPublishedData.php	2019-04-18 11:21:01 UTC (rev 10110)
+++ trunk/mapbender/http/php/mod_GetPublishedData.php	2019-04-18 14:44:40 UTC (rev 10111)
@@ -419,14 +419,17 @@
 		return $mergedKml->mergeKMLDocuments($kmlArray);
 	} else {
+		//$kmlArray = array();
 		$kmlObj = new Kml();
 		$kmlObj->parseGeoJSON(json_encode($geoJson));
         	// create the json-file
         	$kmlFile = TMPDIR.'/myDataCollection-'.$fileUuid.'.kml';
+		$kmlString = $kmlObj->__toString();
         	// put the contents to the created file
-        	file_put_contents($kmlFile, $kmlObj->__toString());
+        	file_put_contents($kmlFile, $kmlString);
         	// return the string
-		return $kmlObj->__toString();
+		$fileString = file_get_contents(TMPDIR.'/myDataCollection-'.$fileUuid.'.kml');
+		return $fileString;
 		die;
 	die();
More information about the Mapbender_commits mailing list
