[Mapbender-commits] r10216 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Fri Aug 23 21:41:55 PDT 2019
Author: armin11
Date: 2019-08-23 21:41:55 -0700 (Fri, 23 Aug 2019)
New Revision: 10216
trunk/mapbender/http/classes/class_cswClient.php
trunk/mapbender/http/php/mod_callCswMetadata.php
Code cleaning and option to do different combined text searches via csw
Modified: trunk/mapbender/http/classes/class_cswClient.php
--- trunk/mapbender/http/classes/class_cswClient.php 2019-08-23 14:05:32 UTC (rev 10215)
+++ trunk/mapbender/http/classes/class_cswClient.php 2019-08-24 04:41:55 UTC (rev 10216)
@@ -494,20 +494,17 @@
private function getResult($url, $postData, $auth=false) {
- //$e = new mb_exception("postdata: ".$postData);
$cswInterfaceObject = new connector();
$cswInterfaceObject->set('httpType','POST');
$postData = stripslashes($postData);
- //$e = new mb_exception("classes/class_cswClient.php: post xml: ".$postData);
+//$e = new mb_exception("classes/class_cswClient.php: post xml: ".$postData);
$dataXMLObject = new SimpleXMLElement($postData);
$postData = $dataXMLObject->asXML();
- //$e = new mb_exception($postData);
$cswInterfaceObject->set('curlSendCustomHeaders',true);
$cswInterfaceObject->set('httpPostData', $postData);
$cswInterfaceObject->set('httpContentType','text/xml');
$cswInterfaceObject->load($url);
- //$file = $cswInterfaceObject->file;
- //$e = new mb_exception($cswInterfaceObject->file);
+//$e = new mb_exception("classes/class_cswClient.php: result xml: ".$cswInterfaceObject->file);
return $cswInterfaceObject->file;
//insert or update - depends if record with same fileidentifier already exists in catalog and if timestamp is not newer than the timestamp of the new record
Modified: trunk/mapbender/http/php/mod_callCswMetadata.php
--- trunk/mapbender/http/php/mod_callCswMetadata.php 2019-08-23 14:05:32 UTC (rev 10215)
+++ trunk/mapbender/http/php/mod_callCswMetadata.php 2019-08-24 04:41:55 UTC (rev 10216)
@@ -474,54 +474,56 @@
$searchResourcesArray = explode(",",$searchResources);
$searchPages = explode(",",$searchPages);
-//begin main program
+//build query - one solution is combining all textfilter with single <And> tags, other solution maybe like filter as "*searchText1*searchText2*searchText3*"
+//single leads to a lower amount of results ! - mmh - how does the filter will be evaluated?
+//example: "*wald*baum*" on anytext -> 3 results in 1 sec || <And> combined "*wald*" and "*baum*" -> 102 results in 2.1 sec (geonetwork 3.6.0)
//$queryString = $searchText;
$searchTextArray = explode(",",$searchText);
-//$queryText = $queryStringArray[0];
-//if ($queryText == '*') {
-// $queryText = '';
-//} else {
-if (count($searchTextArray) > 1) {
- $fullTextFilter = "<ogc:And>";
-} else {
- $fullTextFilter = "";
-//$fullTextFilter = "";
-//$e = new mb_exception($searchTextArray[0]."".gettype($searchTextArray));
-foreach($searchTextArray as $queryString) {
-//$e = new mb_exception("querystring: ".$queryString);
- $fullTextFilter .= '<ogc:PropertyIsLike wildCard="*" singleChar="_" escapeChar="">';
+$combineTextOption = "multiple"; //"multiple","single"
+switch ($combineTextOption) {
+ case "single":
+ $fullTextFilter .= '<ogc:PropertyIsLike wildCard="*" singleChar="_" escapeChar="">';
$fullTextFilter .= '<ogc:PropertyName>AnyText</ogc:PropertyName>';
- /*if($queryString != '*'){
- $queryString = '*' . explode($queryString) . '*';
- //$queryString = '*' . implode("*", $searchTextArray) . '*';
- if ($queryString == "*") {
- $fullTextFilter .= '<ogc:Literal>*</ogc:Literal>';
+ if (count($searchTextArray) > 1) {
+ $fullTextFilter .= '<ogc:Literal>*'.implode('*', $searchTextArray).'*</ogc:Literal>';
} else {
- $fullTextFilter .= '<ogc:Literal>'.$queryString.'*</ogc:Literal>';
+ $fullTextFilter .= '<ogc:Literal>*'.$searchTextArray[0].'*</ogc:Literal>';
+ //$fullTextFilter .= '<ogc:Literal>%'.implode('%', $searchTextArray).'%</ogc:Literal>';
$fullTextFilter .= '</ogc:PropertyIsLike>';
+ break;
+ case "multiple":
+ $fullTextFilter = "<ogc:And>";
+ } else {
+ $fullTextFilter = "";
+ //$e = new mb_exception($searchTextArray[0]."".gettype($searchTextArray));
+ foreach($searchTextArray as $queryString) {
+ //$e = new mb_exception("querystring: ".$queryString);
+ $fullTextFilter .= '<ogc:PropertyName>AnyText</ogc:PropertyName>';
+ /*if($queryString != '*'){
+ $queryString = '*' . explode($queryString) . '*';
+ //$queryString = '*' . implode("*", $searchTextArray) . '*';
+ if ($queryString == "*") {
+ $fullTextFilter .= '<ogc:Literal>*</ogc:Literal>';
+ } else {
+ $fullTextFilter .= '<ogc:Literal>*'.$queryString.'*</ogc:Literal>';
+ $fullTextFilter .= '</ogc:PropertyIsLike>';
+ $fullTextFilter .= "</ogc:And>";
+ break;
- $fullTextFilter .= "</ogc:And>";
//$e = new mb_exception("fulltextfilter: ".$fullTextFilter);
- $fullTextFilter .= '<ogc:PropertyIsLike wildCard="%" singleChar="_" escapeChar="">';
- $fullTextFilter .= '<ogc:PropertyName>AnyText</ogc:PropertyName>';
- $fullTextFilter .= '<ogc:Literal>%'.implode('%', $searchTextArray).'%</ogc:Literal>';
- $fullTextFilter .= '</ogc:PropertyIsLike>';*/
-//$e = new mb_exception("fulltextfilter: ".$fullTextFilter);
$existsSpatialFilter = false;
+//$e = new mb_exception("searchBbox: ".$searchBbox);
+//$e = new mb_exception("searchTypeBbox: ".$searchTypeBbox);
$searchBboxArray = explode(",", $searchBbox);
//TODO: test the right filter! - inspire has other ones and no logical option!
if ($searchBbox !== NULL) {
@@ -567,20 +569,27 @@
//combine filter
-//$e = new mb_exception("fullTextFilter: ".$fullTextFilter);
-if ($existsSpatialFilter == true && $searchText !== '' && $searchText !== '*'){
- $additionalFilter = "<ogc:And>".$fullTextFilter.$spatialFilter."</ogc:And>";
+//$e = new mb_exception("spatialFilter: ".$spatialFilter);
+//TODO: inspire spatial filter only supported, if no other filter is set!!!! see https://ies-svn.jrc.ec.europa.eu/issues/3658
+//if spatial filter and some text filter is set, combine them with and
+if ($existsSpatialFilter == true) {
+ //some textfilter is given
+ if ($searchText !== '' && $searchText !== '*') {
+ $additionalFilter = "<ogc:And>".$fullTextFilter.$spatialFilter."</ogc:And>";
+ } else {
+ //no textfilter is given
+ $additionalFilter = $spatialFilter;
} else {
- if ($searchText == '') {
- $additionalFilter = $spatialFilter;
+ //no spatial filter is given
+ $additionalFilter = $fullTextFilter;
} else {
- $additionalFilter = $fullTextFilter;
+ $additionalFilter = false;
//$e = new mb_exception("additionalFilter: ".$additionalFilter);
-//csw Id = catalogueId
$csw = new csw();
$csw->createCatObjFromDB($catalogueId);
More information about the Mapbender_commits
