[Mapbender-commits] r10068 - in trunk/mapbender/http: classes plugins
svn_mapbender at osgeo.org
Wed Mar 6 11:54:56 PST 2019
Author: armin11
Date: 2019-03-06 11:54:56 -0800 (Wed, 06 Mar 2019)
New Revision: 10068
trunk/mapbender/http/classes/class_stripRequest.php
trunk/mapbender/http/classes/class_weldMaps2JPEG.php
trunk/mapbender/http/plugins/mb_metadata_layerPreview.php
Fix problem with generating getlegendgraphic preview image if width and height parameter are not given in getlegendgraphic request. TODO: get size of legend elements when capabilities are parsed.
Modified: trunk/mapbender/http/classes/class_stripRequest.php
--- trunk/mapbender/http/classes/class_stripRequest.php 2019-03-06 17:33:08 UTC (rev 10067)
+++ trunk/mapbender/http/classes/class_stripRequest.php 2019-03-06 19:54:56 UTC (rev 10068)
@@ -74,7 +74,7 @@
if($exists == false){
- $e = new mb_exception("stripRequest: key '".$key."' lacks");
+ $e = new mb_notice("stripRequest: key '".$key."' lacks");
return false;
@@ -188,4 +188,4 @@
return $this->url;
\ No newline at end of file
Modified: trunk/mapbender/http/classes/class_weldMaps2JPEG.php
--- trunk/mapbender/http/classes/class_weldMaps2JPEG.php 2019-03-06 17:33:08 UTC (rev 10067)
+++ trunk/mapbender/http/classes/class_weldMaps2JPEG.php 2019-03-06 19:54:56 UTC (rev 10068)
@@ -28,7 +28,6 @@
require_once(dirname(__FILE__)."/class_connector.php");
class weldMaps2JPEG{
function __construct($urls,$filename, $encode = true){
if(!$urls || $urls == ""){
$e = new mb_exception("weldMaps2JPEG: no maprequests delivered");
@@ -41,11 +40,10 @@
//following is only possible, if parameters with and height are given :-( - when getlegendgraphic is used - otherwise we have to get the original width and height from capabilities - or mapbender database itself!
- //$e = new mb_exception("width: ".$width);
//check if url is of type getlegendgraphic or getmap - these are considered here
$request = strtoupper($obj1->get("REQUEST"));
- //$e = new mb_exception(strtoupper($obj1->get("REQUEST")));
- //$e = new mb_exception("count url: ".count($url));
+//$e = new mb_exception(strtoupper($obj1->get("REQUEST")));
+//$e = new mb_exception("count url: ".count($url));
if ($request !== "GETMAP" && $request !== "GETLEGENDGRAPHIC") {
//no width or height exists - e.g. legend graphics
//$e = new mb_exception("No GetMap or GetLegendGraphic");
@@ -72,23 +70,30 @@
return true;
} else {
- $e = new mb_exception("Normal GetMap or GetLegendGraphic");
$width = $obj1->get("width");
$height = $obj1->get("height");
+ if (!$width || $width == '' || !$height || $height == '') {
+ $e = new mb_exception("classes/class_weldMaps2JPEG.php: Paremeters width and/or height are not given in $request request! Try to get it from image size.");
+ if ($url[0] != false){
+ $url[0] = urldecode($url[0]);
+ //$e = new mb_exception("class_weldMaps2JPEG.php: ".$url[0]);
+ //list($width, $height, $type, $attr) = getimagesizefromstring($this->loadpng($url[0]));
+ $img = $this->loadpng($url[0]);
+ $width = imagesx($img);
+ $height = imagesy($img);
$image = imagecreatetruecolor($width, $height);
$white = ImageColorAllocate($image,255,255,255);
ImageFilledRectangle($image,0,0,$width,$height,$white);
for($i=0; $i<count($url); $i++){
if ($url[$i] != false) { //sometimes some false urls will be send? - don't use them
//before encode the url it should be decoded to be secure that a decoded url is used!
$url[$i] = urldecode($url[$i]);
- //$e = new mb_exception("oldurl: ".$url[$i]);
$obj = new stripRequest($url[$i]);
$url[$i] = $obj->setPNG();
$url[$i] = $obj->encodeGET($encode);
- //$e = new mb_exception("newurl: ".$url[$i]);
$img = $this->loadpng($url[$i]);
if($img != false){
imagecopy($image, $img, 0, 0, 0, 0, $width, $height);
@@ -101,9 +106,7 @@
imagejpeg($image,$filename);
imagedestroy($image);
* Old constructor to keep PHP downward compatibility
@@ -126,20 +129,20 @@
//Connection keep-alive
//Host geodaten-luwg.rlp.de
//User-Agent Mozilla/5.0 (X11; Ubuntu; Linux i686; rv:25.0) Gecko/20100101 Firefox/25.0
- $headers = array(
- "GET: ".$path." HTTP/1.1",
- "User-Agent: Mozilla/5.0 (X11; Ubuntu; Linux i686; rv:25.0) Gecko/20100101 Firefox/25.0",
- "Accept-Encoding: gzip, deflate",
- "Accept-Language: de-de,de;q=0.8,en-us;q=0.5,en;q=0.3",
- "Host: geodaten-luwg.rlp.de",
- "Cache-Control: max-age=0",
- "Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8",
- "Connection: Keep-Alive"
+ //$headers = array(
+ // "GET: ".$path." HTTP/1.1",
+ // "User-Agent: Mozilla/5.0 (X11; Ubuntu; Linux i686; rv:25.0) Gecko/20100101 Firefox/25.0",
+ // "Accept-Encoding: gzip, deflate",
+ // "Accept-Language: de-de,de;q=0.8,en-us;q=0.5,en;q=0.3",
+ // "Host: geodaten-luwg.rlp.de",
+ // "Cache-Control: max-age=0",
+ // "Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8",
+ // "Connection: Keep-Alive"
//$x->set("curlSendCustomHeaders",true);
//$x->set("externalHeaders", $headers);
//$f = $obj->get("format");
-$e = new mb_exception($imgurl);
+//$e = new mb_exception($imgurl);
$im = imagecreatefromstring($x->load($imgurl));
if(!$im){
$im = false;
Modified: trunk/mapbender/http/plugins/mb_metadata_layerPreview.php
--- trunk/mapbender/http/plugins/mb_metadata_layerPreview.php 2019-03-06 17:33:08 UTC (rev 10067)
+++ trunk/mapbender/http/plugins/mb_metadata_layerPreview.php 2019-03-06 19:54:56 UTC (rev 10068)
@@ -6,8 +6,6 @@
//define("LAYER_PREVIEW_BASE","../tmp/layerpreviews/");
//define("LAYER_PREVIEW_BASE","../tmp/");
$ajaxResponse = new AjaxResponse($_REQUEST);
$mapurl = $ajaxResponse->getParameter("mapurl");
$layerName = $ajaxResponse->getParameter("layerName");
@@ -17,14 +15,11 @@
$layerPreviewMapFileName = PREVIEW_DIR ."/".$layerId."_layer_map_preview.jpg";
$layerPreviewLegendFileName = PREVIEW_DIR ."/".$layerId."_layer_legend_preview.jpg";
if(!$mapurl){
$ajaxResponse->setSuccess(false);
$ajaxResponse->setMessage('mapURL not set');
$ajaxResponse->send();
if(!$legendurl){
@@ -42,10 +37,9 @@
$ajaxResponse->setMessage('layerName not set');
switch ($ajaxResponse->getMethod()) {
case "saveLayerPreview":
- $e = new mb_notice("plugins/mb_metadatalayerPreview.php: weld map");
+ $e = new mb_notice("plugins/mb_metadatalayerPreview.php: weld map: ".$mapurl);
$mapImg = new weldMaps2JPEG($mapurl, $layerPreviewMapFileName);
if(!$mapImg) {
@@ -53,7 +47,7 @@
if ($legendUrl) {
- $e = new mb_notice("plugins/mb_metadatalayerPreview.php: weld legend");
+ $e = new mb_notice("plugins/mb_metadatalayerPreview.php: weld legend: ".$legendUrl);
$legendImg = new weldMaps2JPEG($legendUrl, $layerPreviewLegendFileName);
if(!$legendImg) {
More information about the Mapbender_commits
