[Mapbender-commits] r10121 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon May 13 06:06:50 PDT 2019
Author: armin11
Date: 2019-05-13 06:06:50 -0700 (Mon, 13 May 2019)
New Revision: 10121
Added:
   trunk/mapbender/http/php/mod_showOrganizationList.php
List of registrating organizations with number of datasets, layers, featuretypes, wmcs
Added: trunk/mapbender/http/php/mod_showOrganizationList.php
--- trunk/mapbender/http/php/mod_showOrganizationList.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_showOrganizationList.php	2019-05-13 13:06:50 UTC (rev 10121)
@@ -0,0 +1,79 @@
+<?php
+//server component to pull statistics FROM geoportal catalogue
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+$sql = <<<SQL
+SELECT published_resources.*, mb_group_name, mb_group_description, mb_group_logo_path, mb_group_title, uuid FROM (
+SELECT SUM(dataset_count) AS datasets, SUM(featuretype_count) AS featuretypes, SUM(layer_count) AS layers, SUM(wmc_count) AS wmcs, mb_group_id FROM (
+SELECT 0 AS dataset_count, 0 AS featuretype_count, resource_count AS layer_count, 0 AS wmc_count, mb_group_id FROM (
+	SELECT COUNT(layer_id) AS resource_count, fkey_mb_group_id FROM (
+		SELECT wms_id, fkey_mb_group_id FROM wms WHERE fkey_mb_group_id <> 0 AND fkey_mb_group_id IS NOT NULL GROUP BY fkey_mb_group_id, wms_id
+		UNION SELECT wms_id, fkey_mb_group_id FROM (
+			SELECT wms_owner, wms_id FROM wms WHERE fkey_mb_group_id = 0 OR fkey_mb_group_id is null GROUP BY  wms_owner, wms_id
+		) AS owner_wms INNER JOIN mb_user_mb_group on owner_wms.wms_owner = mb_user_mb_group.fkey_mb_user_id WHERE mb_user_mb_group_type = 2
+	) AS published_wms INNER JOIN (
+		SELECT layer_id, fkey_wms_id FROM layer WHERE layer_searchable = 1
+) AS layer on published_wms.wms_id = layer.fkey_wms_id GROUP BY fkey_mb_group_id) AS layer_count INNER JOIN mb_group on mb_group.mb_group_id = layer_count.fkey_mb_group_id
+UNION
+SELECT  0 AS dataset_count, resource_count AS featuretype_count, 0 AS layer_count, 0 AS wmc_count, mb_group_id FROM (
+	SELECT COUNT(featuretype_id) AS resource_count, fkey_mb_group_id FROM (
+		SELECT wfs_id, fkey_mb_group_id FROM wfs WHERE fkey_mb_group_id <> 0 AND fkey_mb_group_id IS NOT NULL GROUP BY fkey_mb_group_id, wfs_id
+		UNION SELECT wfs_id, fkey_mb_group_id FROM (
+			SELECT wfs_owner, wfs_id FROM wfs WHERE fkey_mb_group_id = 0 OR fkey_mb_group_id is null GROUP BY  wfs_owner, wfs_id
+		) AS owner_wfs INNER JOIN mb_user_mb_group on owner_wfs.wfs_owner = mb_user_mb_group.fkey_mb_user_id WHERE mb_user_mb_group_type = 2
+	) AS published_wfs INNER JOIN (
+		SELECT featuretype_id, fkey_wfs_id FROM wfs_featuretype WHERE featuretype_searchable = 1
+) AS featuretype on published_wfs.wfs_id = featuretype.fkey_wfs_id GROUP BY fkey_mb_group_id) AS featuretype_count INNER JOIN mb_group on mb_group.mb_group_id = featuretype_count.fkey_mb_group_id
+UNION
+SELECT COUNT(metadata_id) AS dataset_count, 0 AS featuretype_count, 0 AS layer_count, 0 AS wmc_count, mb_group_id FROM (
+SELECT metadata_id, fkey_mb_group_id, searchable FROM mb_metadata WHERE fkey_mb_group_id <> 0 AND fkey_mb_group_id IS NOT NULL GROUP BY fkey_mb_group_id, fkey_mb_group_id, metadata_id
+UNION SELECT metadata_id, fkey_mb_group_id, searchable FROM (
+		SELECT fkey_mb_user_id, metadata_id, searchable FROM mb_metadata WHERE fkey_mb_group_id = 0 OR fkey_mb_group_id is null GROUP BY  fkey_mb_user_id, metadata_id
+) AS owner_metadata INNER JOIN mb_user_mb_group on owner_metadata.fkey_mb_user_id = mb_user_mb_group.fkey_mb_user_id WHERE mb_user_mb_group_type = 2
+) AS published_metadata INNER JOIN mb_group on mb_group.mb_group_id = published_metadata.fkey_mb_group_id WHERE searchable = true GROUP BY mb_group_id, fkey_mb_group_id
+UNION
+SELECT 0 AS dataset_count, 0 AS featuretype_count, 0 AS layer_count, COUNT(wmc_serial_id) AS wmc_count, fkey_mb_group_id AS mb_group_id FROM ( SELECT * FROM (
+		SELECT fkey_user_id, wmc_serial_id FROM  mb_user_wmc WHERE wmc_public = 1 GROUP BY fkey_user_id, wmc_serial_id
+) AS owner_wmc INNER JOIN mb_user_mb_group on owner_wmc.fkey_user_id = mb_user_mb_group.fkey_mb_user_id WHERE mb_user_mb_group_type = 2 ) AS published_wmc GROUP BY fkey_mb_group_id
+) AS resources GROUP BY mb_group_id ) AS published_resources INNER JOIN mb_group on published_resources.mb_group_id = mb_group.mb_group_id
+ORDER BY mb_group_name DESC
+SQL;
+//order by - group_id, group_name, group_title
+$v = array();
+$t = array();
+$res = db_prep_query($sql, $v, $t);
+$jsonOutput = new stdClass();
+$jsonOutput->organizations = array();
+$numberOfOrgas = 0;
+while($row = db_fetch_array($res)){
+	$jsonOutput->organizations[$numberOfOrgas]->{'id'} = $row['mb_group_id'];
+	$jsonOutput->organizations[$numberOfOrgas]->{'uuid'} = $row['uuid'];
+	$jsonOutput->organizations[$numberOfOrgas]->{'name'} = $row['mb_group_name'];
+	$jsonOutput->organizations[$numberOfOrgas]->{'description'} = $row['mb_group_description'];
+	$jsonOutput->organizations[$numberOfOrgas]->{'title_long'} = $row['mb_group_title'];
+	$jsonOutput->organizations[$numberOfOrgas]->{'image_display_url'} = $row['mb_group_logo_path'];
+	$jsonOutput->organizations[$numberOfOrgas]->{'detail_url'} = '../mod_showOrganizationInfo.php?id='.$row['mb_group_id'].'&outputFormat=ckan';
+	$jsonOutput->organizations[$numberOfOrgas]->{'datasets'} = $row['datasets'];
+	$jsonOutput->organizations[$numberOfOrgas]->{'layers'} = $row['layers'];
+	$jsonOutput->organizations[$numberOfOrgas]->{'featuretypes'} = $row['featuretypes'];
+	$jsonOutput->organizations[$numberOfOrgas]->{'wmcs'} = $row['wmcs'];
+	$numberOfOrgas++;
+$json = json_encode($jsonOutput);
+header('Content-Type: application/json');
+echo $json;
More information about the Mapbender_commits mailing list
